Fri Jun 21, 2019 5:32 pm
I am struggling to understand what you wrote. I think you are saying you have a small RC turbine mounted on a test rig underneath a helo rotor, sticking out of the open door, and pointed up (turbine inlet faces up). (I guess a university project?)
On one side, the turbine starts easily, on the other it tends to get a hung start but after several tries it does start?
I would suggest looking at the direction of rotation of the helo rotor and the turbine blades. I suspect you are getting an interaction between the rotor wash and the turbine, which causes a hung start, unless the turbine is already been warmed up by the prior hung starts.
It seems to me that whichever side you are on, the rotor wash swirl would increase or decrease incidence at the front of the turbine's 1 compressor stage (1 shaft I assume). But that should be the same on both sides of the helo. However, the fuselage shape, and helo engine inlet and exhaust are in a different spot relative to the rc turbine inlet.
How far outside of the helo does your rig extend ? You may also want to try flying the helo forward or backward while trying to start, that would alter the rotor wash pattern.
Any gas turbine aero guys here?
