jakewo4
best camera to buy
Wed Jul 03, 2019 8:55 am
hello again
i'm using a canon 7d and i love it but there are 2 problems with it. The noice and the AF points
as i'm going to a lot off airshows there are a lot of performances that include multiple aircraft and i need as many af points as possible to get all the aircraft in focus
for noice i'm finding after 1600 iso it gets very noicey and was wondering what apsc camera for canon has good af points and good iso capability's
i was thinking the 77d cause it has 6 fps which means ill only be losing one frame a second and has 45 af points. But any suggestions would be greatly appreciated
thanks in advance
Bostrom
Re: best camera to buy
Wed Jul 03, 2019 12:25 pm
If those are your only issues with your current camera, howabout a 7D mkII?
spompert
Wed Jul 03, 2019 12:50 pm
I use the 80D. Noise is pretty good and focuspoints as well. But I personally don`t really care about focuspoints in aviation photography. Burstrate would be important I would say with airshows, so the 7DII sounds like a good option.
jakewo4
Wed Jul 03, 2019 1:19 pm
yes i was thinking that thanks for the advice
jakewo4
Wed Jul 03, 2019 1:22 pm
yes the 7dII is a good option im thinking the 77d the 80d or the 7dII
im going to look into it more thanks for the advice
airkas1
Wed Jul 03, 2019 2:07 pm
Depends heavily on your budget as well I'd say. I've found the ISO capabilities very good on the 5D's I've owned so far (had a II, now a IV).
vikkyvik
Wed Jul 03, 2019 2:29 pm
airkas1 wrote:
5D's
jakewo4 wrote:
apsc camera
:biggrin:
jakewo4
Wed Jul 03, 2019 2:33 pm
ive owned the 5d mark 2 but i just didn't use it enough i dont like the fps and the 1.6 crop is really helpful for me
in 6 months i used it 3 times just wasn't enough
thanks for the suggestion though
airkas1
Wed Jul 03, 2019 3:42 pm
Woops. In that case, I guess I’ll support the 7D2 suggestion.
jakewo4
Wed Jul 03, 2019 4:25 pm
thansk for all the suggestions but the canon 7d mark 2 dxomark is saying i would be losing 1 megapixel off sharpness if i changed can you tell the diffrence ?
JakTrax
Wed Jul 03, 2019 5:44 pm
Don't take DXOMark too literally as it's all theoretical. Basically the more megapixels your camera has, the greater the pixel density, meaning the lens has to work harder to get the best out of the sensor. In theory, when using the same lens, you will lose sharpness with the 7DII compared to the 7DI; but in reality the extra detail generated by the II's sensor sort of cancels out the ill-effects. On a per-pixel level the lower megapixel camera will typically out-perform the higher megapixel example.
jakewo4
Wed Jul 03, 2019 6:35 pm
oh ok thank you
