AirwayBill wrote:Some late-build NGs have Split Scimitar winglets, which are similar to the MAX's winglets, but sporting a curvier profile, and with the tips of both upper and lower sections pointing backwards. Lower winglet section is also smaller, and looks like its been hastily added to the regular NG winglet assembly.
The MAX have AT winglets, which sport a more angular shape than the Split Scimitar found on the NG. They also have the strobe (more like a long flash LED now actually) directly built into the lower winglet. Look better integrated than the late implemented Split Scimitars.
A good comparison from the same perspective:
737 NG SS winglet
737MAX AT winglet
Also, from the front only, you can see that the MAX's AT winglets are more pointing more "outwards" than the almost-vertical NG winglets (can't integrate that picture):
http://www.b737.org.uk/images/atwinglets_diagram.jpg
JannEejit wrote:The split scimitar design (or scimitar as it doesn't include the lower portion) is also available as a 757 upgrade, although I think only Icelandair and United have taken them so far ?
FlyingJhawk wrote:Very interesting information but the real question is how does one pronounce "scimitar"?
At first I thought it was "skim-a-tar" but then heard it as "sim-e-ter" with the "c" silent an no accent on any of the syllables.
hOMSaR wrote:JannEejit wrote:The split scimitar design (or scimitar as it doesn't include the lower portion) is also available as a 757 upgrade, although I think only Icelandair and United have taken them so far ?
Technically, it’s not a split scimitar, because it doesn’t have the lower strake. It’s just a scimitar.
JannEejit wrote:hOMSaR wrote:JannEejit wrote:The split scimitar design (or scimitar as it doesn't include the lower portion) is also available as a 757 upgrade, although I think only Icelandair and United have taken them so far ?
Lol, apologies if I didn't qualify that enough in my original post.
Actually, I just misread the part in parentheses.
Polot wrote:FlyingJhawk wrote:Very interesting information but the real question is how does one pronounce "scimitar"?
The “c” is silent. Not sure if it is suppose to end on “tar” or “ter”, I’ve heard both. I think it varies by region/accent.
leghorn wrote:If you had a 737-800 going transcontinental day-in day-out would the upgrade of tip pay for itself.
how much more efficient are they?
edit: got my answer
http://www.b737.org.uk/winglets.htm#splitscimitar
FatCat wrote:I've seen those winglets on a Transavia 737-700 (or -800, do not remember very well) in PSA sone 5 months ago.
SXDFC wrote:Just out of curiosity, could the MAX winglets fit on an NG wing?
WN732 wrote:SXDFC wrote:Just out of curiosity, could the MAX winglets fit on an NG wing?
Technically yes since the only difference between the two wings is FBW spoilers on the MAX. Although, the mating point between the AT winglet on the MAX has more symmetry since the NG's winglets were after market. So the only way to make it work would be to change the wing tip entirely to allow the AT winglet to be installed. I believe there is also more structural reinforcement at the wing root since the AT winglet is larger than the scimitar.
Could it be done? Probably. Is it worth it? Probably not.
planecane wrote:WN732 wrote:SXDFC wrote:Just out of curiosity, could the MAX winglets fit on an NG wing?
Didn't aviation partners say that the split scimitar performs better than the AT?
barney captain wrote:scim·i·tar
/ˈsimədər,ˈsiməˌtär/
noun
a short sword with a curved blade that broadens toward the point, used originally in Eastern countries.
N664US wrote:FatCat wrote:I've seen those winglets on a Transavia 737-700 (or -800, do not remember very well) in PSA sone 5 months ago.
HV installed their first split scimitars on PH-HSK in February, and plans to have 5 737-800's equipped with the splits by the end of the year. Europe as a whole has been steadily increasing in split scimitar operators — LG, QS, NO, BY, X3, TB, OR, 6B, and PQ are (I think) all European split scimitar operators.
Your best chance of seeing the scimitars is still in North and South America, as AM, AS, CP, DL, G3, UA, WG, WN, and WS all have some scimitar-equipped NGs.
justplanesmart wrote:N664US wrote:FatCat wrote:I've seen those winglets on a Transavia 737-700 (or -800, do not remember very well) in PSA sone 5 months ago.
Here are the operators of scimitar-equipped 737 aircraft that I am aware of:
Asia:
Hainan, Jeju Air, NewGen Airways
In addition, I am aware of 13 BBJ/VIP aircraft so equipped, but one of those has yet to find a customer.
OA940 wrote:Honestly I think the scimitars look better than the MAX winglets. I think they're more elegant and I love the little curve at the top
