bhill
Tanker refueling question
Tue Sep 03, 2019 7:25 pm
This may sound silly, but how are the tankers themselves refueled? Through the wing access ports as a usual airliner? Or are there ports with larger GPH throughput? I would think the AF would want the turn around tile to be as short as possible.
Carpe Pices
GalaxyFlyer
Re: Tanker refueling question
Tue Sep 03, 2019 10:25 pm
Thru the standard SPR port, most bases are on hydrant lines, so fairly quick—45 minutes.
GalaxyFlyer
Thru the standard SPR port, most bases are on hydrant lines, so fairly quick—45 minutes. They might have two, as we did on the C-5
superbizzy73
Wed Sep 04, 2019 8:40 pm
If I remember correctly (definitely take this with a grain of salt), when we fueled KC-10’s, the could take fuel at right around 1000 gallons per minute. The KC-135’s were around 500-600 gpm. I’m thinking the KC-46 would be able to take around 1000 gpm, just like the 767.
kc135topboom
Sun Sep 08, 2019 11:44 pm
The SPR for the KC-135R, and all other Mission C-135s is in the right main gear wheel well. The KC-135Ts have two SPRs, one in each main gear wheel well.
Users browsing this forum: No registered users and 48 guests
