DALMD80
X-Plane 11 Controllers... Stick VS Yoke?
Sat Sep 07, 2019 6:23 pm
Hi guys. At some point in the future, I'm going to get XP11, and I was wondering what type of controller I should get. I'm thinking either the Saitek yoke and throttle set, or the CH Fighterstick with one or two Saitek throttle quadrants. The reason I'm asking is that I foresee myself flying both airliners and fighters. It would feel wrong to fly a 737 or an MD-80 with a stick, but it would feel wrong to fly a Phantom or a Hawg with a yoke. Thanks.
You can take the boy away from aviation, but you can't take aviation out of the boy.
litzj
Re: X-Plane 11 Controllers... Stick VS Yoke?
Sun Sep 08, 2019 11:07 am
stick for modern Airbus or yoke for Boeing
DALMD80
Sun Sep 08, 2019 12:39 pm
Right, but I'm gonna be flying Boeings, MD-80s, and FIGHTERS!
DALMD80
Sun Sep 08, 2019 8:00 pm
To clarify, I need to pick one that will serve ALL purposes.
Crosswind787
Wed Sep 11, 2019 12:31 pm
Yoke. Ch pro yoke works well with all commercial and fighter jets and is inexpensive. There are much better, more expensive yokes out there though so depends if you want force feedback or not. In my home cockpit I have 2 CH Pro yokes and they work just fine, but at some point id like to get the forcefeeback yoke for $1000
DALMD80
Wed Sep 11, 2019 6:38 pm
Right. Does it feel wrong to fly fighters with a yoke?
Crosswind787
Wed Sep 11, 2019 10:05 pm
Not really. If you primarily fly fighters then get a joystick but if you'll fly more commercial jets then id deal with the yoke in a fighter.
DALMD80
Thu Sep 12, 2019 1:50 am
Hmm... I see doing both equally.
Noshow
Thu Sep 12, 2019 12:21 pm
A stick is more versatile. Better get some twisting one that can emulate rudders moving or tail rotors. Technically hall effect joysticks are best because they measure a magnetic field for steering commands instead of mechanical switches.
This is one that is not so expensive: Logitech Extreme 3D Pro Joystick -just as one example for both Windows and Apple.
DALMD80
Thu Sep 12, 2019 12:50 pm
I like the price. Do you feel like flying a Boeing with a stick is right? I'm just wondering. I love that it has rudder built in, so I don't have to buy a pedal setup.
DALMD80
Thu Sep 12, 2019 12:54 pm
By the way... what about throttles? https://www.logitechg.com/en-us/product ... drant.html
That one has 3 levers, but I would want to fly the King Air and the 747 as well. Could just get 2 but if you know of more...
Noshow
Thu Sep 12, 2019 1:13 pm
No need for separate throttles. Finally you are sitting next to a PC sim whatever yoke you install. Better max out your GPU and RAM.
DALMD80
Thu Sep 12, 2019 2:22 pm
What?
Noshow
Thu Sep 12, 2019 2:58 pm
No need for too much hardware. It will always be just a flight sim and not a real aircraft cockpit. However with more RAM or a good graphics card your computer will run better and the simulation will be more realistic.
DALMD80
Thu Sep 12, 2019 6:08 pm
Ok. Makes sense.
Users browsing this forum: No registered users and 17 guests
