Max Q
Do nuclear aircraft carriers transit the Panama Canal ?
Thu Sep 12, 2019 6:56 am
I was just looking at the maximum dimensions for the new Panama Canal
They can accept a ship up to 1200’ in length, with a beam of 168’ and a maximum draft of 47’
These limits would allow passage of a Nimitz class carrier unless I’m missing something. I haven’t looked at the
Ford class.
However i don’t think I’ve ever seen pictures of a CVN transiting the canal
Is this / has this been done ?
Guns are a malignant cancer that are destroying our society
JayinKitsap
Re: Do nuclear aircraft carriers transit the Panama Canal ?
Thu Sep 12, 2019 7:23 am
The deck is super wide, 252 feet, DD6 at PSNS is massive and you can barely see the DD, it hangs over the side roads completely.
A major addition to PSNS was Dry-dock No. 6, large enough to hold the new giant Forrestal-class aircraft carriers. Dry-dock No. 6, dedicated on April 23, 1962, is 1,180 feet long, 180 feet wide, and 60 feet deep.
historylink.org
CVN68 also will not fit under one of the bridges at the canal. The Ford hullform is basically the same as the Nimitz, so it fits in DD6, needs huge utility upgrades.
Max Q
Thu Sep 12, 2019 7:37 am
Beautiful picture you have there
Hadn’t thought about the overhanging structure but that explains why they go around Cape Horn occasionally
I imagine the smaller amphibious carriers can transit the canal
ThePointblank
Thu Sep 12, 2019 7:40 am
No, until 2016, the locks were too small for any post WWII era carrier, including the post-war Essex class carriers with the angle deck refit.
The Panama Canal is also still too narrow for a carrier as well; one of the rules is that a ship transiting the canal cannot overhang the lock walls (or they’d strike the lock walls as the water level was lowered), and with a flight deck width of 256 ft, the carriers are dramatically over the maximum width.
And there has never been a need for a USN carrier to transit the canal; the big issue is that it can easily take 12 hours to transit the canal, and it can only be done in broad daylight for any ship that's even close to the maximum dimensions. That's a lot of time spent being tied up waiting for a modern warship.
VSMUT
Thu Sep 12, 2019 7:42 am
The Wasps can, but need to fold the elevators up before. The America class also lives up to Panamax, but would also need to fold the elevators.
Max Q
Fri Sep 13, 2019 6:40 am
Interesting replies, thanks
WIederling
Fri Sep 13, 2019 7:20 am
If that is technically not an issue ...
And anyway: Wasn't the Panama Canal infrastructure expanded in recent years
to accomodate ships built to a larger limit?
https://en.wikipedia.org/wiki/Panamax#New_Panamax
Shipping passage to the new limits started in June 2016 ( a Chineese box carrier made the first passage : "The United States dispatched a navy ship to Panama to demonstrate U.S. naval power to the Chinese ship." :-))
<quote>.. to handle vessels with overall length of 366 m (1201 feet), 49 meters beam (increased by the Canal Authority effective 1 June 2018 to 51.25 meters, to accommodate ships with 20 rows of containers) and 15.2 meters draft.. </quote>
Murphy is an optimist
ThePointblank
Fri Sep 13, 2019 10:29 am
Yes, the Panama Canal was expanded, but the biggest issue is that there is a bottleneck at the Culevra Cut. The Cut is only wide enough for ships that are close to or at the Panamax dimensions to go by itself, i.e. ships going the other way must wait for the ship to pass (or the ship has to sit while any ship in the Cut clears the Cut). Hence, the Canal often operates in a one-way mode when there are a number of ships that are close to or are at the Panamax maximum dimensions.
WIederling
Fri Sep 13, 2019 12:14 pm
That should be no hold back for US Navy ships passing.
( They could re-invade Panama if the Canal Authority balks :-)
GalaxyFlyer
Sat Sep 14, 2019 12:27 am
Carriers are well past post-Panamax size in beam of the flight deck. We could take it back, but it wouldn’t change anything.
GF
canyonblue17
Sun Sep 15, 2019 8:09 pm
Do military submarines use the Panama Canal? I would imagine most are small enough to fit?
negative ghostrider the pattern is full
dfwjim1
Sun Sep 15, 2019 9:28 pm
A side question...how often do carriers go around Cape Horn? Couldn't be that common.
Ozair
Sun Sep 15, 2019 10:31 pm
According to this history of the Nimitz it passed Cape Horn twice, first in 87 and then again in 2001.
https://www.history.navy.mil/content/hi ... imitz.html
Looks like most carriers do the Horn trip at least a couple times and sometimes more. The Enterprise was even towed from Newport News to Puget Sound via the Horn after decommissioning.
A youtube video of a 688 passing through the canal.
https://www.youtube.com/watch?v=9Hgrxl5Ng1Q
zanl188
Mon Sep 16, 2019 12:43 am
Enterprise is still in Newport News
Ozair
Mon Sep 16, 2019 1:21 am
Interesting. The article I found the info from, http://nation.time.com/2013/01/07/obit-for-a-carrier/ was written in 2013. I didn't realise the Enterprise was still there. Assume the plan hasn't changed though?
zanl188
Mon Sep 16, 2019 2:59 am
Original plan to decommission & scrap Enterprise was cost prohibitive. I believe USN has several new proposals under evaluation. Regardless, they are way behind schedule and over budget.
JayinKitsap
Mon Sep 16, 2019 3:15 am
A very tricky ship to recycle. Subs and cruisers have a single reactor. Enterprise has 4 paired reactors located in an ackward manner. The shield bell for the pair is too heavy to lift. The work to split the primary loop is dangerous. Best plan is to let it float until one of 2 drydocks has a 2 year window, maybe longer.
Woodreau
Mon Sep 16, 2019 1:27 pm
The Navy has to rotate carriers between the coasts for the mid life refueling. Newport News in Virginia is the only shipyard that is capable of refueling a carrier. So in general, “new” or “freshly refueled” carrier gets rotated out to the West coast via deployment to the Arabian gulf, finish the deployment on the west coast. The west coast carrier coming up for refueling, deploys to the Arabian gulf, finishes the deployment in Norfolk.
Carriers can go through the Suez Canal, so whether they go through the Suez or go around Cape Horn depends on operational needs. They don’t have to go around Cape Horn.
Ford class.
It’s not just the dimensions of the lock itself, but the height of the lock walls also limits the kind of ships. The few times I’ve transited the Panama Canal, you’re staring at the lock walls standing on the bridge (on a frigate) as you enter the bottom lock to be raised. The width of the flight deck overhang wouldn’t allow the carrier to get into the bottom lock to be raised.
Users browsing this forum: No registered users and 33 guests
