pdp
De-Icing in the dry
Sun Nov 03, 2019 10:25 am
Last night I was at LUZ/EPLB with the girlfriend and a friend and we were watching a Ryanair 738 to Dublin preparing to depart (it's not an area with a lot of things to do of a Satuirday evening).
Now, first of all, the METAR was something along the lines of 21010KT 06/06 Q1002. Whilst the static air temperature was reasonable for the time of night (2200 local) the wind was absolutely bitter and made it feel a good 5-10c colder than it was. There was no precipitation of any sorts and the taxi from stand to runway is about 50 metres (albeit a 1.3knm backtrack is required).
What surprised me was that despite the rather mild (for Poland in November at least) conditions, they then pushed the aircraft onto the de-icing pad and proceded to spray it. Being far away we couldn't see what fluid type it was.
My Q is, why would you de-ice when there wasn't any snow or rain in the area? I would have expected the aircraft's anti-ice system to be sufficient.
jumpship
Re: De-Icing in the dry
Sun Nov 03, 2019 11:38 am
The fuel in the wings gets cold soaked while flying and when the plane is on the ground moisture can freeze to the upper surface of the wings.
Have a nice day.
Sun Nov 03, 2019 12:43 pm
As jumpship says, the wings are cold. I've been dripped on from melting ice during walkarounds in 30 degree weather.
pdp
Sun Nov 03, 2019 1:28 pm
Thanks both!
Tristarsteve
Mon Nov 04, 2019 3:48 pm
And the aircraft antice system does not usually work on the ground. On most jet airliners it is inhibited by weight on wheels, to stop the wing getting too hot.
26point2
Wed Nov 06, 2019 2:13 pm
Not true. Anti ice systems can work on the ground, it is required to, for take off in icing conditions. Also, aircraft anti ice systems don’t heat the top or bottom of wings, only the leading edge of wings. Any ice on top or bottom is unaffected by aircraft anti ice.....thus de-ice fluid is used.
Tristarsteve
Wed Nov 06, 2019 4:08 pm
Well the wing antice system on the A320 does not work on the ground. There is a test switch which opens the wing antice valves, they stay open for a few seconds, and then the overheat sensors close them again. If you select wing antice on, these valves will open at lift off.
The A330 is similar, but the valves open for 30secs on the ground, and then close, to open again in the air.
GalaxyFlyer
Wed Nov 06, 2019 4:28 pm
Depends on the plane—all BBD products allow use of anti-ice systems on the ground.
Francoflier
Wed Nov 06, 2019 5:37 pm
Did they only do one pass or two?
In clear weather, only the hot de-icing spraying might be done to clear the wings of any contamination accumulated on the ground.
If there are precipitations or icing conditions, or if some might be expected before takeoff, then the second coat of cold anti-ici fluid would be applied as well.
In your case, if the temperature and dewpoint were the same, then icing conditions might have been threatening, even if they were not present when they dispatched.
Wed Nov 06, 2019 9:16 pm
To expand, on the A330, wing anti-ice does not work on the ground. However, engine anti-ice does.
GalaxyFlyer
Wed Nov 06, 2019 10:19 pm
To clarify.all the bizjets and the CRJs allow and require the use of wing and cowl anti-ice on the ground in icing conditions. The exception being when Type IV is applied, then wing anti-ice is ON at the start of the take-off run.
DiamondFlyer
Wed Nov 06, 2019 11:04 pm
For what it's worth, so did the DC-9-10 series...
From my cold, dead hands
Users browsing this forum: A340TLS, zeeth and 40 guests
