icejuice25
Why do we have to PACKS OFF during Engine Start?
Wed Nov 13, 2019 3:02 pm
Hello.
Simple Question.
Why do we have to PACKS OFF during the
Engine Start?
n901wa
Re: Why do we have to PACKS OFF during Engine Start?
Wed Nov 13, 2019 4:16 pm
The Eng uses Bleed Air to turn the starter. If you run the packs ( They run on Bleed Air too) You don't have enough air pressure to get the starter to turn fast enough to get the eng turning fast enough to add fuel to the engine, so it can start. Not sure on the 787 since that uses Electric. Hope that helps
unimproved
Wed Nov 13, 2019 4:22 pm
The 787 runs both on electric so you won't have enough current from just the APU.
Max Q
Thu Nov 14, 2019 4:23 am
I believe some aircraft, perhaps the 747 can leave one pack on during engine start and we never tried it but
theoretically we could do the same on the 727 by re configuring the #2 engine bleeds
GGg
RetiredWeasel
Thu Nov 14, 2019 4:57 am
Yes you could, but not for the first engine started at least according to our ops. I posted before, after getting one started, you could isolate the pneumatic duct on that side so the APU supplied air only to the opposite side to start it's engines . The one engine running would then provide bleed air to run the one pack on its side of the ducting. The one engine and one pack provided a little relief while starting in a very hot environment. It got some air moving at least. That technique was used infrequently.
Thu Nov 14, 2019 5:04 am
You don’t touch the packs when starting an Airbus normally.
fr8mech
Thu Nov 14, 2019 7:03 am
Yes, but on the Airbus I'm familiar with, A300, the Packs automatically shut down when you're starting engines. I'm pretty sure our new Jumbos do the same.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Max Q
Thu Nov 14, 2019 7:59 am
Thanks for that RW,
Interesting, I though I’d heard that before. Theoretically you could do the same on the 727 after starting one
It wasn’t approved so I never tried it
GGg
unimproved
Thu Nov 14, 2019 10:21 am
Thanks for that RW,
You can do the same on any aircraft with more than 1 engine if the bleed valves can be controlled manually. Crossbleed start with packs on APU.
GalaxyFlyer
Thu Nov 14, 2019 11:23 am
I hope the OP isn’t a pilot of airliners. Appalling lack of mechanical sense, if so.
Tristarsteve
Thu Nov 14, 2019 4:27 pm
The Tristar had a PT6 engine for its APU. It produced bleed air all the time, but if there was no demand, or the APU bleed valve was closed, there was a surge valve on the APU that opened and blew all the excess air very noisily overboard. So we tried to not open the surge valve by selecting the relevant pack on as the the start valve closed on the engine. With two cross bleed valves and everything manually controlled on the FE panel it was possible.
unimproved
Thu Nov 14, 2019 6:23 pm
The ones that have just a basic understanding of how things work are more dangerous IMO.
ual777
Thu Nov 14, 2019 6:57 pm
On the 737, the PACK #2 is usually on when you start engine #1. You crank engine #2 first, then "isolate and ventilate". Close the isolation valve and run PACK #2 off of the engine bleed and use the APU to start engine #1.
It is always darkest before the sun comes up.
speedbird52
Fri Nov 15, 2019 4:28 am
I clicked on this thread just to post this. The reason why is literally in the FCOM. If you can't be assed to read that (and somehow pass all your tests...) this is something that can be answered with 5 seconds of Googling. The only airliners I have ever flown are virtual airliners, and even I managed to learn why just by reading the manual.
Loran
Fri Nov 15, 2019 9:09 am
I've experienced this live in 2013 when flying on a Tristar 500 ex-NBO. Significant issues in starting the engines off the APU plus the GPU combined with the altitude. Eventually #3 started and provided sufficient cross-feed pneumatics to start #1 and #2. I've documented it on video:
https://youtu.be/IP05DjM0vFk
Loran
703 717 727 732-9 747 757 767 777 787 AB2/6 310 318-321 330 340 359 380 D8M D91/3/5 D1C M11 M81-90 L10 IL1/8/6/7/W/9/4 TU3/5/2 YK4/2
Nicoeddf
Fri Nov 15, 2019 1:05 pm
It shouldn't be necessary to read any manual to understand the connection, if you are a pilot.
If you are not, perfectly reasonable question.
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
strfyr51
Sat Nov 16, 2019 12:44 am
the B787 started is also electric and it's just a precaution just like no airline ever started all 4 engines on the 747-400 at once even though it could do it,, But? At What Cost?
BravoOne
Sat Nov 16, 2019 1:54 am
Some stations had such strong air that you could in fact start all 4 at the same time. (707)
GlobalMoose
Sun Nov 17, 2019 2:21 pm
It all comes down to how the aircraft was designed!
In my jet, we have two packs (left and right); during engine start, the on side pack automatically shuts down when an engine is started on that side of the aircraft (i.e. when we are starting number 1, the left pack automatically shuts down) and the other pack is left running to provide environmental air to the avionics and cabin. The silent shutdown occurs regardless of the type of start we are doing (APU air, engine cross bleed, or external huffer cart) and is designed to give the maximum amount of air to the engine while still providing acceptable airflow to the cabin. If we know we are working with a weak bleed source or a low-margin engine, we will normally manually shut down the opposing side pack to give the best possible chance for he engine to start on the first go.
When it absolutely positively has to be there ... at some point.
thepinkmachine
Sun Nov 17, 2019 6:12 pm
I once forgot to switch off the bleeds/packs before engine start on EMB145. The result was a hung start (or 2, I don’t remember).
We only could start it when we figured out the reason... :banghead:
"Tell my wife I am trawling Atlantis - and I still have my hands on the wheel…"
Sun Nov 17, 2019 11:45 pm
I think these things happen to all of us. In the sim, I once forgot to turn the APU bleed on before trying to start the engines. Realisation dawned when I heard badly muffled chuckling from the instructor after I'd stared blankly at the engine instruments for a bit.
Users browsing this forum: GSOtoIND, KLAM, medexman and 23 guests
