Byrdluvs747
LAX: What is this?
Tue Mar 03, 2020 12:17 am
Simple LAX question.
What is this hole that's been dug next to TBIT? I assumed it was related to the people mover between TBIT and the MFC but it seems too far north.
https://www.google.com/maps/@33.9464387 ... a=!3m1!1e3
The 747: The hands who designed it were guided by god.
LAXintl
Re: LAX: What is this?
Tue Mar 03, 2020 12:34 am
Projects as part of the MSC - tunnels one for passengers, one for utility use. Also bag make up areas and bus port.
SEAflyer97
Tue Mar 03, 2020 12:38 am
Baggage sorting facility
Byrdluvs747
Tue Mar 03, 2020 12:54 am
Oh ok. That makes sense. Thanks for clearing that up LAXintl and SEAflyer.
Adipocere
Tue Mar 03, 2020 12:57 am
Good to know. Would be radical if they were putting up carrier-like lifts to have an underground terminal and double up gate space.
questions
Tue Mar 03, 2020 1:07 am
It’s been a couple of years since I departed from TBIT. It’s a nice terminal. However the north end was quite drab.
In the google image, what is the aircraft on the taxiway to the left of Lamill Coffee? It’s length looks distorted, however the markings on the taxiway look undistorted.
FromCDGtoSYD
Tue Mar 03, 2020 1:37 am
A322
questions
Tue Mar 03, 2020 5:39 am
FromCDGtoSYD wrote:
A322
On second look...
Delta... 2L forward of the wing... 12 windows between 1L and 2L... winglets... I’m going with 752.
Also, zooming in, I can now see where the image skips and part of the aircraft is duplicated, therefore creating an elongated aircraft.
gregn21
Tue Mar 03, 2020 6:19 am
questions wrote:
FromCDGtoSYD wrote:
A322
On second look...
Nope it’s an Airbus
AAlaxfan
Tue Mar 03, 2020 6:45 am
777 or 767
Grumpy. Not a dwarf, not an attitude. It's a lifestyle.
questions
Tue Mar 03, 2020 6:47 am
gregn21 wrote:
questions wrote:
FromCDGtoSYD wrote:
A322
On second look...
Nope it’s an Airbus
Upon further analysis, the cockpit windows suggest it is A321.
Interestingly, there are 12 windows between 1L and 2L on the 752 and 321, however on DL’s “Our Aircraft” page the 321 has 13 windows between 1L and 2L.
Ebmek
Tue Mar 03, 2020 7:08 am
FlyThiz wrote:
bravotango75 wrote:
ICBM Missle complex.
I am totally onboard with an ICBM complex of some sort.
In actuality, it’s a makeshift terminal that is attached to TBIT. I’ve been in there once or twice. There is I believe one gate attached. It’s been there for a number of years.
I have actually been wondering for years why that old portion of terminal was attached to the new TBIT. What is it for?
AAlaxfan
Tue Mar 03, 2020 7:35 am
questions wrote:
gregn21 wrote:
questions wrote:
On second look...
Nope it’s an Airbus
Now that I have the right aircraft, it’s an A321 distorted by it’s motion while the satellite was taking the picture. You can see the tail of the aircraft just to the left of the gate 134 apron marking.
gregn21
Tue Mar 03, 2020 7:59 am
All of the concourses on the north side were supposed to be shortened at one point to allow room for the north runways to be spread apart. That never happened and likely never will. For now, the bus gates and exterior baggage handling facility adjacent to the old portion of the terminal are necessary to support the remote gates. The remote gates will (fingers crossed) become obsolete once MSC, T0, and T9 are complete, finally allowing for the full build out of TBIT north. For now, the small old portion of the terminal is actually quite functional, being the only segment of the facility optimized for smaller aircraft.
FSDan
Tue Mar 03, 2020 4:23 pm
These tunnels have been in the works for at least two years, no? I assume the two gates (131 and 132?) that have been out of commission will finally be back in action sometime this summer?
This is my signature until I think of a better one.
NiMar
Tue Mar 03, 2020 6:56 pm
Is there a tunnel being built from the Delta Terminals to the TBIT and on to the MSC?
FSDan
Tue Mar 03, 2020 7:56 pm
An above-ground connector will be built in a few years as part of DL's Sky Way project, similar to what AA has between T4 and TBIT.
blacksoviet
Tue Mar 03, 2020 8:22 pm
After the connector is built, will Gate 131 still be able to handle widebodies? That gate is already close to the headhouse.
FSDan
Tue Mar 03, 2020 8:27 pm
Good question. I'm not sure if any actual architectural plans have been released for the connector yet. I suppose depending on where it enters the terminal building, it could affect gate 131.
NiMar
Tue Mar 03, 2020 9:13 pm
Ah, ok. Because in the satellite view provided above it looks like a tunnel is being built just north of the TBIT headhouse that goes straight into T3 and all the way out to the MSC. That could give Delta some nice gate access.
blacksoviet
Tue Mar 03, 2020 9:52 pm
Does the MSC have its own FIS or is there a seperate tunnel for arrivals?
NiMar
Tue Mar 03, 2020 10:52 pm
My understanding is that there will be a separated tunnel for international arrivals to access the facility in TBIT.
gmcc
Tue Mar 03, 2020 11:13 pm
In related MSC news latest BOAC agenda has Air France looking to sign a lease for a 11500 sq ft lounge in the MSC and to operate flights out of the MSC
ldvaviation
Tue Mar 03, 2020 11:28 pm
What you see there is the "Far East Tunnel." It is a tunnel for bags, not passengers. It ends just west of the taxiway between TBIT and T3.
See page 11 of the most recent project update, https://lawa.granicus.com/MetaViewer.ph ... a_id=40034
DTWLAX
Wed Mar 04, 2020 4:07 am
With KLM retiring the 747 and AF not planning to fly the A380 for too long, we may see additional flights to AMS and CDG year long by AF/KLM. So probably makes sense to build a lounge considering the KE lounge at TBIT is too small.
cooley21
Sat Mar 07, 2020 2:52 am
Not sure if this is the correct spot, but found some additional information regarding the operation of the MSC
https://6ed98d40-571e-436b-afa1-60be3ad ... 574d23.pdf
https://6ed98d40-571e-436b-afa1-60be3ad ... 734546.pdf
FSDan
Sat Mar 07, 2020 4:46 am
Thanks for the info! Super interesting! It's cool to see the various circulation patterns mapped out.
It looks like the previous publication that mentioned 15 gates wasn't wrong, with 1 of the 2 ADG-VI and 2 of the 10 ADG-V gates each being able to be split into two ADG-III gates.
MrPeanut
Sat Mar 07, 2020 7:42 pm
Have they announced which airlines will operate out of the MSC yet?
rjbesikof
Sat Mar 07, 2020 11:10 pm
What is the purpose of the baggage building in front of the bus gates in TBIT?
blacksoviet
Sat Mar 07, 2020 11:23 pm
Do 757s ever operate out of the International Terminal?
rbavfan
Sun Mar 08, 2020 12:14 am
To make Delta happy
ldvaviation
Sun Mar 08, 2020 12:41 am
Baggage storage.
questions
Sun Mar 08, 2020 1:22 am
To make Delta happy
Why would DL be happy about that? I would think they would prefer to have use of more modern terminal facilities than that area of TBIT.
rjbesikof
Sun Mar 08, 2020 1:37 am
Per this website, 134 will be unavailable soon. Does anyone know why?
https://www.lawa.org/en/news-releases/2 ... elease-017
blacksoviet
Sun Mar 08, 2020 1:42 am
questions wrote:
rbavfan wrote:
To make Delta happy
They left the old section of the original TBIT because they plan on demolishing it later on when they separate the northern runways. There is no point in extending the new concourse all the way north if there is a chance that a large section of it will have to be demolished in 25 years. The old concourse seems to work fine for three gates.
alasizon
Sun Mar 08, 2020 1:44 am
Likely in order to rip up the concrete and do the work for the early bag storage system. The tunnels run underneath 132 and 134.
gregn21
Sun Mar 08, 2020 1:51 am
I’m not entirely sure but I think it’s primarily used to process baggage for ops at the remote gates. That should make it relatively unnecessary and hopefully obsolete once the MSC and T0/T9 projects are complete. Again, I’m not 100% sure about this, the building might have some functionality beyond this. I’ve also heard rumblings from LAWA brass that the bus facility at TBIT north and the adjacent building you are talking about could be moved to a site just west of MSC to allow for the full completion/expansion of the TBIT concourse.
blacksoviet
Sun Mar 08, 2020 2:58 am
When was the AA hangar south of the MSC built?
reltney
Sun Mar 08, 2020 4:20 am
Been flying to LAX for 30+ years as a pilot......never heard of tbit or mwc..... is this an armchair pilot thing???
Knives don't kill people. People with knives kill people.
OUTLAW KNIVES.
I am a pilot, therefore I envy no one...
alasizon
Sun Mar 08, 2020 4:33 am
TBIT - Tom Bradley International Terminal
MSC - Midfield Satellite Concourse
Not sure how you haven't heard of TBIT; particularly since that is how the airport refers to it as well.
