PHXWRLD wrote:I was wondering what aircraft maintenance entails, how long it takes, how frequent it is, etc. I've heard there are A checks, B checks, etc. but I would like to know what those are and how frequent they are. Maybe if it varies by aircraft use the A320 as an example. Thanks!
PHXWRLD wrote:Are hangers needed for A checks?
bennett123 wrote:Why do they only do D Checks on WB?.
Dalmd88 wrote:fr8mech has the biggest point, all operators have different programs with different names for all of the different level of checks. What is included in one carriers 'A'/Service Check may not be in another operators. Plus they are always evolving. I've been out of hangar /line mtc for about 5 years now. I'm sure what is on the different checks is someone changed.
We never lubed much during A checks. Major lube tasks were done on a stand alone visit. Usually one for flight controls and another for gear. Narrow body gear usually just got added to a overnight "daily check" and were done where ever the plane was parked. Most of our flight control lubes were done in a hangar mostly due to that's where we had the most access to man lifts quickly. For a 757 lube we would use 1 basket lift (not me!) for the vertical, 1 electric man lift for the horizontal, 2 electrics for the flaps(2 AMT's each), and 1 more for the slats since they got lube on alternate visits per side. One other AMT would do the daily stuff. That was one 10 hour shift overnight.
Our A checks were single overnights also. Most of the time they were done where ever the plane was parked. Oil and fuel filters, hydraulic filters. A list of flight control ops checks and other system checks. The tasks varied by fleet types and where in the rotating cycle of checks that plane was. Usually 2-5 AMTs for one shift.
Our C checks typically ran 2-3 weeks. There is a lot of optional work that gets loaded into these checks. I would guess half of the work is optional. Performance or reliability driven upgrades. Or marketing driven like interior minor changes. The big killer is the focused structural inspections. Inspectors had tasks to look at know bad areas for corrosion or fatigue cracking. Sometimes nothing was found. Other times it was remove the galley and do floor beam repairs or other very time consuming work. These checks were every 2 years. A series of 4 checks that alternated heavy and light with the last being the full crown inspection that required cabin strip. That one at DL has been an out source check for a while now. It required a lot of man hours.
A380MSN004 wrote:Candid question : what are the differences in terms of process between a jet like E190 for instance and a Turboprop Dash 8 - Q400 ?
Dalmd88 wrote:A380MSN004 wrote:Candid question : what are the differences in terms of process between a jet like E190 for instance and a Turboprop Dash 8 - Q400 ?
Not much difference I would imagine. It might depend on the regulatory status the plane is operated under, say 121 vs 135. From my standpoint they don't have much difference. Both a small jet aircraft. Yes, one has a prop and the other has a big fan. Really they are very similar. Small vs large just more airplane. The E190 might have better avionics, but it wouldn't change the required inspections and servicing tasks.
JayinKitsap wrote:Quite interesting info - thanks
So a 757 lube is about 60 manhours? Is the 737 easier? Is the lube at 1 month intervals?
On the structural checks how is it tracked what portions inspected if not the whole plane? Are there defined areas that are always done in full or is it logged by diagram in the reports? I've had to track weld inspections on construction sites and it can get complicated really fast to ensure all are checked, if in doubt it was done, it gets done again.
Does the day shift work the larger jobs with a plane having 2 mechanic shifts a day or is the night shift only working the overnight jobs.
