enilria
OAG Changes 4/26/2020: Saturday Night Massacre
Sun Apr 26, 2020 12:06 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M BIM-FLL MAY 0.5>0.3[1.5]
3M CHS-FLL MAY 0.2>0[0] JUN 0.6>0[0]
3M CHS-MCO MAY 0.4>0[0] JUN 1.0>0[0]
3M CHS-TPA JUN 0.4>0[0]
3M ELH-FLL MAY 1.1>0.3[4]
3M EYW-FLL MAY 1.2>0.4[3]
3M EYW-MCO MAY 0.7>0[2]
3M EYW-TPA MAY 1.1>0[3]
3M FLL-FPO MAY 0.5>0.3[3]
3M FLL-GGT MAY 0.8>0.3[1.7]
3M FLL-GHB MAY 0.3>0[0.7]
3M FLL-MCO MAY 1.0>0.4[2]
3M FLL-MHH MAY 0.5>0.3[4]
3M FLL-PNS MAY 0.4>0[1.0]
3M FLL-TLH MAY 0.5>0[1.5]
3M FLL-TPA MAY 1.0>0.4[2]
3M MCO-PNS MAY 0.8>0.4[1.7]
3M NAS-TPA MAY 0.4>0[1.0]
3M PNS-TPA MAY 0.6>0[1.7]
3M TLH-TPA MAY 0.8>0.4[1.6]
3U HGH-LAX SEP 0.4>0[0.4] OCT 0.4>0.1[0.4]
3U LAX-TNA SEP 0.4>0[0.4] OCT 0.4>0.1[0.5]
4M EZE-MIA MAY 1.0>0[1.3]
9K ACK-BOS MAY 10>7[10]
9K ACK-HYA MAY 6>5[4]
9K BOS-MVY MAY 6>4[6]
9K BOS-PVC MAY 4>3[4]
AA ASE-DFW JAN 4>3[3]
AA AUA-MIA MAY 0.7>0[2]
AA BAQ-MIA MAY 0.7>0[0.7]
AA BDA-JFK MAY 0.8>0[1.0] AUG 0.5>1.0[1.0] OCT 0.8>1.0[1.0]
AA BHM-DFW MAY 3>2.0[7]
AA BOG-MIA MAY 1.4>0[3]
AA BZE-MIA SEP 0>1.0[1.1] OCT 0.8>1.0[1.0]
AA CAK-ORD AUG 2>1.5[1.9] SEP 2>1.0[2.0] OCT 2>1.0[2.0] NOV 2>1.0[1.9] DEC 2>1.0[2] JAN 2>1.0[2]
AA CHO-ORD NOV 3>2[3] DEC 3>2[3] JAN 3>2[3]
AA CLO-MIA MAY 0.7>0[1.0]
*AA COS-PHX AUG 2>1.1[0] SEP 2>0[0] OCT 1.5>0[0]
AA CTG-MIA MAY 0.7>0[1.0]
**AA CYS-DFW AUG 1.0>0.5[2.0] SEP 1.0>0[2.0] OCT 1.0>0[1.1] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
AA DFW-HSV MAY 2>1.5[5]
AA DFW-MBJ SEP 0.3>0[0.3] OCT 0.8>0.2[0.8]
**AA DFW-MEI AUG 1.0>0.5[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
AA DFW-OGG SEP 0.6>1.0[1.0]
**AA DFW-PIB AUG 1.8>1.0[1.0] SEP 1.9>0[1.8] OCT 1.8>0[1.9] NOV 1.9>0[1.8] DEC 1.9>0[1.8] JAN 1.8>0[1.9]
**AA DFW-SGU AUG 1.0>0.5[0] SEP 1.0>0[0.2] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
AA DFW-TYS MAY 2>1.3[5]
AA FDF-MIA JUN 0.9>0[0.9]
AA GCM-MIA MAY 0.7>0[2] AUG 0.5>1.0[1.6] SEP 0>1.0[1.5] NOV 2>1.4[2] DEC 3>1.5[3] JAN 2>1.2[2]
*AA JFK-SJO JUN 0.9>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0.3] DEC 1.0>0.5[1.0]
AA KIN-MIA MAY 0.7>0[2]
AA LIR-MIA MAY 0.7>0[1.9]
*AA MAO-MIA JUN 0.9>0[0.9] JUL 1.0>0[1.0] AUG 0.9>0[1.0] SEP 0.7>0[0.8] OCT 0.7>0.2[0.7]
AA MBJ-MIA MAY 0.7>0[3]
AA MDE-MIA MAY 0.7>0[2]
**AA MEI-ORD AUG 1.0>0.5[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
AA MHH-MIA AUG 1.0>0.6[1.0] SEP 1.0>0.1[0.1]
AA MIA-PAP MAY 0.7>0[2]
AA MIA-PTY MAY 0.7>0[2]
AA MIA-SJO MAY 0.7>0[3] AUG 1.1>2[3] OCT 1.6>2[2]
**AA PHX-RAP AUG 1.0>0.5[0] SEP 1.0>0[0.9] OCT 1.0>0[1.0] NOV 1.0>0[0.9] DEC 1.0>0[0.9] JAN 1.0>0[1.0]
AA PHX-SGU SEP 3>2[0.5] OCT 3>2[3] NOV 3>2[3] DEC 3>2[2] JAN 3>2[3]
AC BOS-YUL MAY 1.0>0.3[5]
AC BOS-YYZ MAY 2>0.6[7]
AC DEN-YYZ MAY 0.7>0.3[3]
AC FLL-YUL MAY 0.5>0.2[2]
AC FLL-YYZ MAY 0.5>0.2[2]
AC IAD-YYZ MAY 1.0>0.3[3]
AC IAH-YYZ MAY 1.0>0.3[3]
AC LAX-YVR MAY 1.6>0.5[4]
AC LAX-YYZ MAY 1.0>0.3[5]
AC LGA-YUL MAY 0.9>0.3[8]
AC LGA-YYZ MAY 0.9>0.3[12]
AC MCO-YUL MAY 0.3>0.1[2]
AC MCO-YYZ MAY 0.5>0.2[3]
AC ORD-YUL MAY 1.0>0.3[5]
AC ORD-YYZ MAY 2>0.6[8]
AC SEA-YVR MAY 1.0>0.3[6]
AC SFO-YVR MAY 1.6>0.5[4]
AC SFO-YYZ MAY 1.0>0.3[4]
AD CNF-FLL JUL 0.4>0[0] AUG 0.3>0[0] SEP 0.3>0[0] OCT 0.3>0.1[0]
AD CNF-MCO JUL 0.5>0[0.4] AUG 0.3>0[0.4] SEP 0.3>0[0.1] OCT 0.3>0.1[0.4]
AM JFK-MEX MAY 0.4>0.2[4]
AM MEX-ORD MAY 0.5>0[2]
AN HHR-PHX MAY 0.4>0[0.5]
AR EZE-MIA MAY 0.7>0[2]
AS beginning tag flying
**AS ABQ-SAT MAY 0>0.2[0]
**AS ALW-PUW MAY 0>0.2[0]
AS ANC-LAX MAY 0.9>0.7[1.0]
AS ANC-SCC MAY 1.8>2[1.4]
AS AUS-SJC MAY 0.9>0.7[1.8]
AS BOI-SAN MAY 0.9>0.7[1.0]
AS BWI-PIT MAY 0.1>0.3[0]
AS BWI-SEA MAY 0.9>0.7[1.0]
AS CHS-RDU MAY 0.1>0.3[0]
AS CHS-SEA MAY 0.9>0.7[0.7]
AS CMH-MSP MAY 0.1>0.3[0]
AS CMH-SEA MAY 0.9>0.7[1.0]
AS DFW-IAH MAY 0.1>0.3[0]
AS DFW-PDX MAY 0.9>0.7[1.0]
**AS EAT-YKM MAY 0>0.2[0]
AS EWR-PDX MAY 0.9>0.7[1.0]
AS GEG-SAN MAY 1.0>0.7[1.0]
AS GEG-SFO MAY 1.0>0.7[0]
AS HNL-LAX MAY 1.0>0.8[1.0]
AS IAH-SEA MAY 1.9>1.4[1.8]
**AS ICT-OKC MAY 0>0.2[0]
AS IND-SEA MAY 1.0>0.8[1.0]
**AS IND-STL MAY 0>0.2[0]
AS JFK-PDX MAY 0.9>0.7[1.0]
AS KOA-SEA MAY 1.9>1.4[2]
AS LAX-RDM MAY 1.0>0.7[0]
AS LAX-SEA MAY 10>8[13]
AS LIH-SEA MAY 1.9>1.4[2]
AS MCI-PDX MAY 0.9>0.7[0.5]
AS OGG-SEA MAY 1.9>1.4[2]
AS OKC-SEA MAY 1.0>0.8[1.0]
AS ORD-SFO MAY 0.9>0.7[2]
AS PAE-SFO MAY 0.9>0.7[2]
AS PAE-SNA MAY 0.9>0.7[1.0]
AS PDX-SEA MAY 11>10[16]
AS PUW-SEA MAY 1.0>0.8[4]
AS RDM-SFO MAY 0.9>0.7[0]
AS SAT-SEA MAY 1.0>0.8[1.0]
AS SEA-SFO MAY 10>8[11]
AS SEA-SJC MAY 6>5[8]
AS SEA-SNA MAY 6>5[8]
AS SEA-YKM MAY 1.9>1.4[3]
AT BOS-CMN MAY 0.4>0[0]
AT CMN-IAD MAY 0.5>0[0.5]
AT CMN-JFK MAY 0.9>0[0.9]
AT CMN-MIA MAY 0.5>0[0.5]
AV BAQ-MIA JUN 1.0>0[1.0]
AV BOG-FLL JUN 1.6>0[1.0]
AV BOG-IAD MAY 0.5>0[1.0] JUN 2>0.6[1.0]
AV BOG-JFK MAY 0.5>0[3] JUN 3>1.0[3]
AV BOG-LAX JUN 1.0>0[1.0]
AV BOG-MCO MAY 0.3>0[1.0] JUN 1.6>0[1.0]
AV BOG-MIA MAY 0.5>0[3] JUN 4>1.0[3]
AV CLO-MIA JUN 1.0>0[1.0]
AV DFW-SAL MAY 0.4>0[1.0] JUN 1.0>0[1.0]
AV EWR-SAL JUN 1.0>0[1.0]
AV GUA-LAX JUN 1.0>0[1.0]
AV IAD-SAL JUN 3>1.0[3]
AV IAH-SAL MAY 0.5>0[1.0] JUN 1.0>0[1.0]
AV JFK-MDE JUN 0.6>0[1.0]
AV JFK-SAL JUN 2.0>1.0[2]
AV LAX-SAL MAY 0.8>1.6[3] JUN 4>2[3]
AV MDE-MIA JUN 1.0>0[1.0]
AV MIA-SAL MAY 0.8>0.4[1.0] JUN 1.0>0.4[1.0]
AV SAL-SFO JUN 2.0>0.6[2]
Tag-o-rama + May is reduced to near statutory minimum under CARES
**B6 ABQ-DEN MAY 0>0.4[0] JUN 0>0.4[0]
B6 ABQ-JFK MAY 0.4>0.1[0.8] JUN 0.8>0[1.0]
B6 ACK-HPN JUN 0.5>0[0.5]
B6 ACK-LGA JUN 0.5>0[0.9]
B6 ATL-BOS MAY 2>0.7[5]
B6 ATL-FLL MAY 1.0>0.1[2]
B6 ATL-JFK MAY 1.0>0.3[2]
B6 AUA-BOS MAY 1.9>0.2[1.4]
B6 AUA-JFK MAY 1.0>0.1[1.3]
B6 AUS-BOS MAY 1.5>0.5[1.0]
B6 AUS-FLL MAY 0.6>0.1[1.0]
B6 AUS-JFK MAY 0.8>0.3[2]
B6 AUS-LGB MAY 0.5>0.1[1.0]
B6 AUS-MCO MAY 0.5>0.1[1.0]
B6 BDL-FLL MAY 1.0>0.5[1.9]
B6 BDL-MCO MAY 1.0>0.4[2]
B6 BDL-PBI MAY 0.6>0.1[1.0]
B6 BDL-SJU MAY 1.1>0.1[2.0]
B6 BDL-TPA MAY 0.4>0.0[1.0]
B6 BNA-BOS MAY 0.9>0.5[3]
B6 BNA-FLL MAY 0.6>0.1[1.6]
B6 BNA-JFK MAY 1.4>0.1[0]
B6 BOG-FLL MAY 0.3>0.0[1.0]
B6 BOS-BUF MAY 1.9>0.7[4]
B6 BOS-BUR JUN 0.7>0[0.7]
B6 BOS-BWI JUN 3>0[6]
B6 BOS-CHS MAY 1.3>0.6[3]
B6 BOS-CLE MAY 1.9>0.7[3]
B6 BOS-CLT MAY 3>0.8[2]
B6 BOS-CUN MAY 0.3>0.1[0.5]
B6 BOS-DCA MAY 6>1.5[10]
B6 BOS-DEN MAY 0.8>0.5[1.9]
B6 BOS-DTW MAY 2>0.8[3]
B6 BOS-EWR MAY 1.8>0.2[4]
B6 BOS-FLL MAY 4>1.5[6]
*B6 BOS-IAH MAY 0.3>0.0[0] JUN 0.7>0[0]
B6 BOS-JAX MAY 1.0>0.5[3]
B6 BOS-JFK MAY 4>2[6]
B6 BOS-LAS MAY 2>0.7[4]
B6 BOS-LAX MAY 3>1.1[4]
**B6 BOS-LGA JUN 6>0[5]
B6 BOS-MCO MAY 4>1.2[6]
*B6 BOS-MSP MAY 0.4>0.1[3] JUN 2>0[3]
B6 BOS-MSY MAY 1.5>0.5[2]
B6 BOS-NAS MAY 0.4>0.1[0.5]
B6 BOS-ORD MAY 3>0.8[4]
B6 BOS-PBI MAY 2.0>0.7[4]
*B6 BOS-PDX JUN 0.7>0[1.1]
B6 BOS-PHL MAY 3>0.8[6]
B6 BOS-PHX MAY 1.0>0.5[1.0]
B6 BOS-PIT MAY 3>0.8[6]
B6 BOS-PUJ MAY 0.6>0.2[1.1]
B6 BOS-RDU MAY 4>0.8[6]
B6 BOS-RIC MAY 2.0>0.6[4]
B6 BOS-RSW MAY 3>1.2[4]
*B6 BOS-SAN MAY 1.8>0.2[2] JUN 3>0[2]
B6 BOS-SAV MAY 1.0>0.5[1.7]
B6 BOS-SDQ MAY 1.0>0.1[1.9]
B6 BOS-SEA MAY 1.0>0.4[1.9]
B6 BOS-SFO MAY 4>0.8[5]
*B6 BOS-SJC JUN 0.7>0[0.9]
B6 BOS-SJU MAY 1.0>0.5[3.0]
B6 BOS-SLC MAY 0.6>0.1[0.7]
B6 BOS-SYR MAY 1.0>0.5[1.0]
B6 BOS-TPA MAY 3>0.7[4]
*B6 BQN-FLL JUN 0.7>0[1.0]
*B6 BQN-JFK JUN 1.3>0[1.3]
*B6 BQN-MCO MAY 0.4>0.0[1.5] JUN 1.3>0[2.0]
B6 BTV-JFK MAY 1.0>0.6[3]
B6 BUF-JFK MAY 3>2[5]
B6 BUF-MCO MAY 0.5>0[1.0]
*B6 BUR-JFK JUN 1.2>0[1.8]
*B6 BZN-LGB JUN 0.2>0[0.2]
B6 CHS-FLL MAY 0.6>0.1[1.0]
B6 CHS-JFK MAY 1.0>0.4[3]
B6 CUN-FLL MAY 0.4>0[1.0]
B6 CUN-JFK MAY 1.0>0.4[1.7]
B6 CUN-MCO MAY 0.6>0.4[1.0]
B6 DCA-FLL MAY 2>0.6[5]
B6 DCA-MCO MAY 2.0>0.5[3]
B6 DCA-PBI MAY 0.6>0.1[1.0]
B6 DCA-RSW MAY 0.6>0.1[1.6]
B6 DCA-SJU MAY 0.4>0[1.0]
B6 DEN-JFK MAY 0.8>0[1.6]
B6 EWR-FLL MAY 3>1.0[3]
B6 EWR-MCO MAY 3>1.1[5]
B6 EWR-PBI MAY 1.0>0.1[2]
B6 EWR-RSW MAY 0.6>0.1[1.9]
B6 EWR-SDQ MAY 0.7>0.1[1.0]
B6 EWR-SJU MAY 1.5>0.4[2.0]
B6 EWR-STI MAY 0.6>0.1[1.0]
B6 EWR-TPA MAY 1.0>0.1[2]
B6 FLL-GYE MAY 0.7>0.4[1.0]
B6 FLL-HAV MAY 1.0>0.1[3]
*B6 FLL-HPN JUN 1.3>0[1.9]
B6 FLL-JAX MAY 1.6>0.2[3]
B6 FLL-JFK MAY 3>1.3[7]
B6 FLL-KIN MAY 0.4>0.0[2]
B6 FLL-LAS MAY 1.1>0.2[1.0]
B6 FLL-LAX MAY 3>0.7[3]
*B6 FLL-LGA JUN 1.3>0[4]
B6 FLL-LIM MAY 0.6>0.1[1.0]
B6 FLL-MBJ MAY 0.5>0.0[1.0]
B6 FLL-MSY MAY 0.6>0.1[1.0]
B6 FLL-NAS MAY 1.0>0.4[5]
B6 FLL-PAP MAY 0.6>0.1[2]
B6 FLL-PHL MAY 0.6>0.0[1.0]
B6 FLL-PLS MAY 0.4>0.1[1.0]
*B6 FLL-PVD JUN 0.7>0[1.0]
B6 FLL-RDU MAY 0.6>0.1[2]
B6 FLL-RIC MAY 0.6>0.1[1.7]
B6 FLL-SDQ MAY 0.6>0.1[1.3]
B6 FLL-SFO MAY 1.0>0.3[2]
B6 FLL-SJO MAY 0.3>0[1.0]
B6 FLL-SJU MAY 2.7>0.8[5]
*B6 FLL-SWF JUN 0.7>0[1.0]
B6 FLL-UIO MAY 0.6>0.1[1.0]
B6 GND-JFK MAY 0.4>0.2[0.8]
*B6 HPN-MCO JUN 2>0[3]
*B6 HPN-PBI JUN 2>0[3]
*B6 HPN-RSW JUN 1.3>0[1.0]
*B6 HPN-TPA JUN 0.7>0[1.0]
*B6 IAH-JFK MAY 0.3>0.0[0] JUN 0.7>0[0]
**B6 IAH-MSY MAY 0>0.4[0] JUN 0>0.5[0]
B6 JAX-JFK MAY 1.0>0.4[3]
B6 JFK-KIN MAY 1.0>0.1[3]
B6 JFK-LAS MAY 2>0.6[4]
B6 JFK-LAX MAY 6>1.5[11]
B6 JFK-LGB MAY 0.8>0[1.9]
B6 JFK-MBJ MAY 1.0>0.1[1.0]
B6 JFK-MCO MAY 4>1.4[8]
B6 JFK-MSY MAY 1.0>0.3[4]
B6 JFK-NAS MAY 0.6>0.1[1.8]
*B6 JFK-ONT JUN 1.0>0[1.0]
B6 JFK-PAP MAY 0.4>0.0[2]
B6 JFK-PBI MAY 2>0.6[3]
B6 JFK-PLS MAY 0.6>0.2[1.0]
B6 JFK-POP MAY 0.3>0.0[1.0]
*B6 JFK-PSE JUN 0.7>0[0.8]
**B6 JFK-PSP MAY 0>0.3[0.5] JUN 0>0.5[0]
B6 JFK-PUJ MAY 1.0>0.4[3]
B6 JFK-RDU MAY 1.0>0.1[2]
B6 JFK-RSW MAY 1.0>0.5[2]
B6 JFK-SAN MAY 1.0>0.1[1.9]
B6 JFK-SAV MAY 1.0>0.1[2]
B6 JFK-SDQ MAY 2>1.1[5]
B6 JFK-SEA MAY 1.0>0.5[1.9]
B6 JFK-SFO MAY 3>0.8[6]
*B6 JFK-SJC JUN 0.7>0[1.0]
B6 JFK-SJU MAY 2.9>1.2[5]
B6 JFK-SLC MAY 1.0>0.4[2]
*B6 JFK-SMF MAY 0.4>0.1[1.0] JUN 0.8>0[1.0]
*B6 JFK-SRQ MAY 0.6>0.1[1.0] JUN 0.8>0[1.0]
B6 JFK-STI MAY 2>1.1[6]
B6 JFK-SXM MAY 0.6>0.1[1.1]
B6 JFK-TPA MAY 2>0.5[3]
B6 JFK-UVF MAY 0.6>0.2[1.1]
B6 LAS-LGB MAY 0.7>0.1[3]
**B6 LAS-SAN MAY 0>0.5[0] JUN 0>0.5[0]
B6 LGA-MCO JUN 1.3>0[4]
B6 LGA-PBI JUN 1.3>0[3]
*B6 LGB-PDX MAY 0.4>0.0[1.0] JUN 0.8>0[1.0]
**B6 LGB-PSP MAY 0>0.3[0] JUN 0>0.5[0]
B6 LGB-SEA MAY 0.6>0.1[2]
B6 LGB-SLC MAY 1.6>0.4[3]
B6 MBJ-MCO MAY 0.4>0.0[1.0]
*B6 MCO-PSE MAY 0.4>0.0[2.0] JUN 1.3>0[1.8]
*B6 MCO-PVD JUN 0.7>0[1.0]
B6 MCO-RIC MAY 0.7>0.1[1.7]
B6 MCO-SJO MAY 0.4>0.0[1.0]
B6 MCO-SJU MAY 3.7>1.2[7]
B6 MCO-SLC MAY 0.6>0.1[1.0]
**B6 MCO-SRQ MAY 0>0.4[0] JUN 0>0.4[0]
*B6 MCO-SWF JUN 0.7>0[1.0]
B6 MCO-SYR MAY 0.6>0.1[1.0]
**B6 MSP-ORD MAY 0>0.5[0] JUN 0>0.6[0]
*B6 PBI-PVD JUN 0.7>0[1.0]
**B6 PDX-SEA MAY 0>0.4[0] JUN 0>0.6[0]
**B6 SFO-SMF MAY 0>0.4[0] JUN 0>0.5[0]
B6 SJU-TPA MAY 0.6>0.1[2.0]
BA AUS-LHR MAY 0.5>0[1.0]
BA BNA-LHR MAY 0.3>0[1.0]
BA BWI-LHR MAY 1.0>0[1.0]
BA CHS-LHR MAY 0.3>0[0.3]
BA EWR-LHR MAY 0.9>0[2]
BA IAH-LHR MAY 1.1>0[2]
What's left? LAX and JFK?
*BA JFK-LHR MAY 2>1.0[8]
BA LHR-MIA MAY 0.9>0[3]
BA LHR-MSY MAY 0.8>0[0.7]
BA LHR-PHL MAY 0.6>0[1.4]
BA LHR-PHX MAY 1.0>0[1.0]
BA LHR-PIT MAY 0.6>0[0.6]
BA LHR-SAN MAY 1.0>0[1.0]
BA LHR-SEA MAY 0.9>0[2]
BA LHR-SFO MAY 0.5>0[2]
BA LHR-SJC MAY 0.9>0[1.0]
BR IAH-TPE MAY 0.7>0.2[1.0]
BR JFK-TPE MAY 0.5>0.1[1.0]
BR LAX-TPE MAY 1.0>0.2[3]
BR ORD-TPE MAY 0.6>0.2[0.7]
BR SEA-TPE MAY 0.7>0.1[1.1]
BR SFO-TPE MAY 1.0>0.2[3]
CZ CAN-JFK MAY 0.9>0.0[1.4] JUN 1.6>1.1[1.5]
CZ CAN-LAX MAY 0.9>0.2[1.4]
CZ CAN-SFO MAY 0.5>0.0[0.5]
I think they can cancel this beyond June
*CZ JFK-WUH MAY 0.4>0[0] JUN 0.4>0.0[0]
CZ LAX-SHE MAY 0.4>0[0.4]
CZ SFO-WUH JUN 0.4>0.0[0.4]
DE FRA-LAS MAY 0.5>0.3[0.6]
DE FRA-PHX MAY 0.4>0.2[0.4]
DE FRA-SEA MAY 0.7>0.4[0.7]
DL ABE-DTW DEC 3>2[1.9] JAN 3>2[3]
DL ABQ-SLC MAY 2.0>1.0[3]
DL ABY-ATL MAY 1.4>0.9[3]
DL AEX-ATL MAY 1.3>0.8[4]
DL AGS-ATL MAY 2>1.8[8]
DL ALB-ATL MAY 0.5>0[3]
DL ALB-MSP DEC 0.6>0[0.3]
**DL AMS-MCO JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0[0.9] NOV 0.5>0[0.5] DEC 0.6>0[0.6] JAN 0.6>0[0.6]
**DL AMS-TPA JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.9>0[0.7] OCT 0.5>0[0.5]
DL ANC-MSP MAY 0.3>0[1.0]
DL ATH-JFK JUN 1.9>1.0[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2.0>1.0[2.0]
DL ATL-AUA MAY 0.5>0[1.1]
DL ATL-AVL MAY 1.9>1.0[7]
**DL ATL-BCN JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
DL ATL-BDA MAY 1.0>0[1.0]
DL ATL-BHM MAY 3>2[9]
DL ATL-BOG MAY 0.4>0[1.0]
**DL ATL-BOI JUL 0.6>0[0] AUG 1.0>0[0] SEP 0.6>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.6>0[0] JAN 0.7>0[0]
DL ATL-BOS MAY 3>2[12]
DL ATL-BTR MAY 1.5>1.0[7]
DL ATL-BWI MAY 2>1.9[11]
DL ATL-BZE MAY 0.4>0[1.0]
**DL ATL-BZN JUN 0.3>0[0.5] JUL 0.7>0[0.7] AUG 0.8>0[0.5] SEP 0.6>0[0] OCT 0.6>0[0] NOV 0.6>0[0] DEC 1.1>0.8[0.7]
DL ATL-CAE MAY 3>2[8]
DL ATL-CHA MAY 3>2[10]
DL ATL-CHO MAY 1.3>0.9[5]
DL ATL-CLT MAY 3>2.0[9]
DL ATL-CRW MAY 1.4>0.9[5]
DL ATL-CSG MAY 1.5>1.0[4]
DL ATL-CUN MAY 2.0>0.3[6]
DL ATL-CVG MAY 3>2[8]
DL ATL-DAB MAY 1.9>1.0[5]
DL ATL-DAL MAY 2>1.0[5]
DL ATL-DAY MAY 0.5>0.0[4]
DL ATL-DEN NOV 8>7[6] DEC 8>7[8] JAN 8>7[7]
DL ATL-DHN MAY 1.5>1.0[4]
**DL ATL-DUB JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
DL ATL-ECP MAY 2>1.9[6]
**DL ATL-FCO JUN 1.9>0[2] JUL 2>0[2] AUG 2>0[2] SEP 2.0>1.0[2]
DL ATL-FLL MAY 3>2.0[13]
DL ATL-FWA MAY 0.9>0[4]
**DL ATL-GEG JUL 0.6>0[0] AUG 1.0>0[0] SEP 0.7>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.4>0[0] JAN 0.6>0[0]
DL ATL-GSO MAY 3>1.8[8]
DL ATL-GSP MAY 3>1.8[7]
DL ATL-GTR MAY 1.5>1.0[3]
*DL ATL-HND JUN 1.0>0[0]
**DL ATL-HNL JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[0.9]
DL ATL-HSV MAY 3>2[7]
DL ATL-ICT MAY 1.3>0.8[3]
DL ATL-JAN MAY 2.0>1.0[6]
DL ATL-JAX MAY 3>2[12]
DL ATL-JFK MAY 3>2[8]
DL ATL-KIN MAY 0.4>0[1.0]
DL ATL-LEX MAY 3>2[7]
DL ATL-LFT MAY 1.4>1.0[5]
DL ATL-LIR MAY 0.4>0.2[1.0]
**DL ATL-MAD JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0[0.9] NOV 0.7>0[0.8] DEC 0.7>0[0.7] JAN 0.6>0[0.5]
DL ATL-MBJ MAY 1.0>0[3]
DL ATL-MCO MAY 4>3[16]
DL ATL-MDT MAY 0.5>0.0[3]
DL ATL-MEX MAY 2>1.6[5]
DL ATL-MGM MAY 2>1.1[6]
DL ATL-MIA MAY 3>2[12]
DL ATL-MKE MAY 2>1.9[7]
DL ATL-MLB MAY 1.5>1.0[4]
DL ATL-MLU MAY 1.4>0.9[4]
DL ATL-MOB MAY 1.9>1.0[7]
**DL ATL-MXP JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.2>0[0.1]
DL ATL-MYR MAY 1.5>1.0[4]
DL ATL-NAS MAY 0.5>0.3[4]
DL ATL-OKC MAY 2.0>1.1[5]
DL ATL-OMA MAY 1.9>1.0[5]
DL ATL-ONT SEP 3>1.9[1.7] OCT 3>1.8[1.7]
DL ATL-PBI MAY 3>1.8[10]
DL ATL-PHX MAY 1.5>1.0[6]
DL ATL-PIT MAY 2>1.8[8]
DL ATL-PLS MAY 1.0>0.1[1.1]
DL ATL-PTY MAY 0.3>0[1.0]
DL ATL-PUJ MAY 1.0>0[3]
**DL ATL-RNO JUN 0.9>0[0] JUL 0.9>0[0] AUG 0.8>0[0] SEP 0.6>0[0] OCT 0.6>0[0] NOV 0.6>0[0] DEC 0.7>0.4[0.4]
DL ATL-ROA MAY 1.5>1.0[5]
DL ATL-ROC MAY 0.5>0[3]
DL ATL-RSW MAY 3>2[9]
DL ATL-SAN MAY 1.5>1.0[5]
DL ATL-SAV MAY 3>2[10]
DL ATL-SFO SEP 8>7[6] OCT 8>7[6]
DL ATL-SJC MAY 0.5>0[3]
DL ATL-SJO MAY 0.5>0.3[2]
DL ATL-SJU MAY 1.4>0.7[3.1]
DL ATL-SNA MAY 0.5>0[3]
DL ATL-SRQ MAY 3>2[7]
DL ATL-STT MAY 1.0>0.5[1.0]
DL ATL-SXM MAY 0.5>0[1.0]
DL ATL-SYR MAY 0.5>0[3]
DL ATL-TGU MAY 0.5>0[1.0]
DL ATL-TPA MAY 3>2[13]
DL ATL-TUL MAY 1.5>1.0[5]
DL ATL-TUS MAY 0.5>0[2.0]
DL ATL-TYS MAY 3>2[8]
**DL ATL-VCE JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
DL ATL-VLD MAY 1.4>1.0[3]
DL ATL-XNA MAY 1.5>1.0[5]
DL ATL-YUL JAN 5>4[4]
DL ATL-YYZ MAY 0.5>0[6]
**DL ATL-ZRH JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.2>0[0.4]
DL ATW-MSP MAY 1.5>1.0[4]
DL AUS-LAX MAY 0.5>0[3]
DL AUS-SLC MAY 1.5>1.0[3]
DL AVP-DTW MAY 1.4>1.0[3] DEC 3>1.9[1.9] JAN 3>1.8[2]
DL AZO-DTW MAY 1.5>1.0[5]
DL BNA-DTW MAY 1.5>1.0[5]
DL BNA-MSP MAY 1.5>1.0[4]
DL BNA-SLC JUN 1.8>0.8[1.2]
DL BOI-LAX SEP 3>2[1.7] OCT 3>2[1.7] NOV 3>2[1.5] DEC 3>2[1.8] JAN 3>2[1.7]
**DL BOS-EDI JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.1]
**DL BOS-FCO JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 0.2>0[0]
DL BOS-LAX MAY 0.5>0[2]
Wow
**DL BOS-LGA MAY 1.0>0[14]
**DL BOS-LGW JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0]
**DL BOS-LIS JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.1]
**DL BOS-MAN JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 0.2>0[0]
DL BOS-SLC MAY 0.5>0[3]
DL BTV-DTW MAY 1.5>1.0[3]
DL BUF-JFK MAY 0.5>0[5]
DL BWI-DTW MAY 1.5>1.0[5]
DL BZN-SEA MAY 1.0>0.0[0]
DL BZN-SLC MAY 1.5>1.0[4]
**DL CDG-IND JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.7>0[0.7] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.4>0[0.4]
**DL CDG-SLC JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0[0.9] NOV 0.7>0[0.7] DEC 0.7>0[0.7] JAN 0.6>0[0.6]
DL CID-MSP MAY 2>1.1[3]
DL CLE-DTW MAY 3>1.9[5]
DL CLE-RDU DEC 0.9>0.5[0.6]
**DL CMH-SEA JUN 0.8>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 0.6>0[0] JAN 0.9>0[0]
**DL CPH-JFK JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.1]
DL CUN-SLC MAY 1.0>0[1.0]
DL CVG-DTW MAY 3>2[5]
DL CVG-RDU JUN 2>1.6[1.8] JUL 2>1.6[1.5] AUG 3>1.7[1.8] SEP 2>1.7[1.7] OCT 3>1.7[1.6] NOV 3>1.7[1.5] DEC 2.0>1.5[1.5] JAN 3>1.9[1.5]
DL CVG-YYZ JAN 1.5>0[0]
DL CWA-MSP MAY 1.5>1.0[3]
Wow
**DL DCA-LGA MAY 0.5>0[10]
DL DCA-MSP MAY 1.8>1.0[6]
DL DCA-SLC MAY 0.5>0[1.0]
DL DEN-DTW MAY 1.5>1.0[4]
DL DEN-MSP MAY 1.5>1.0[5]
DL DFW-DTW MAY 1.5>1.0[5]
DL DFW-MSP MAY 1.5>1.0[6]
**DL DFW-SEA JUN 2>0[0] JUL 3>0[0] AUG 3>0[0] SEP 3>0[0] OCT 3>0[0] NOV 3>0[0] DEC 3>0[0] JAN 3>0[0]
DL DFW-SLC MAY 1.5>1.0[5]
DL DLH-MSP MAY 1.9>1.0[5]
DL DSM-DTW MAY 1.0>0[4]
DL DTW-EWR MAY 1.5>1.0[6]
**DL DTW-FCO JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
DL DTW-GRB MAY 1.5>1.0[4]
DL DTW-GRR MAY 3>2[6]
DL DTW-GSO MAY 0.5>0.0[3]
DL DTW-GSP MAY 0.5>0.0[3]
DL DTW-IAH MAY 1.4>1.0[5]
DL DTW-IND MAY 3>1.9[6]
DL DTW-ITH MAY 1.4>0.9[3]
DL DTW-JAX MAY 0.5>0[1.8]
DL DTW-JFK MAY 2>1.9[4]
DL DTW-LAN MAY 1.5>1.2[4]
DL DTW-LGA MAY 3>2[7]
DL DTW-LHR JUN 1.8>1.0[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2] OCT 1.7>1.0[2]
DL DTW-MBS MAY 1.9>1.0[5]
DL DTW-MCI MAY 1.4>1.0[4]
DL DTW-MDT MAY 1.5>1.0[4] JAN 4>3[3]
DL DTW-MEM MAY 0.5>0.0[3]
DL DTW-MIA JUN 3>2.0[2] JUL 3>2[1.8] AUG 3>2[1.9] SEP 3>2[1.9] OCT 3>2[1.8] NOV 3>2[1.7] DEC 3>2[2] JAN 3>2[2]
DL DTW-MKE MAY 1.4>0.1[6]
DL DTW-MLI MAY 0.5>0.0[1.9]
DL DTW-MSN MAY 1.4>0.1[5]
DL DTW-MSY MAY 0.5>0[3]
**DL DTW-MUC JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
*DL DTW-NGO JUN 0.9>0[0.9]
DL DTW-PHL MAY 2>1.1[5]
DL DTW-PHX MAY 1.5>1.0[4]
DL DTW-PVD DEC 4>3[3] JAN 4>3[3]
DL DTW-PWM DEC 3>2[2] JAN 3>2[2.0]
DL DTW-ROC MAY 2>1.9[4]
DL DTW-SAN MAY 0.5>0[2]
DL DTW-SBN MAY 2>1.0[4]
DL DTW-SCE MAY 1.3>0.9[3]
DL DTW-SDF MAY 1.4>1.0[5]
DL DTW-STL MAY 1.5>1.0[5]
DL DTW-SYR MAY 2>1.8[4]
DL DTW-TYS MAY 1.4>1.0[4]
DL DTW-YOW SEP 3>1.9[1.8] OCT 3>1.8[1.7] NOV 3>1.9[1.7] DEC 2>1.9[1.9] JAN 3>1.8[1.8]
DL EWR-MSP MAY 1.5>1.0[5]
DL FAR-MSP MAY 3>2[7]
DL FCA-SLC MAY 1.5>1.0[3]
DL FLL-JFK MAY 0.5>0[4]
DL FSD-MSP MAY 3>2[5]
DL GEG-LAX SEP 1.6>1.0[1.0] OCT 2>1.0[1.0] NOV 2>1.0[1.0] DEC 2>1.0[1.0] JAN 2>1.0[1.0]
DL GEG-SEA MAY 3>2[8]
DL GEG-SLC MAY 2>1.9[4]
DL GFK-MSP MAY 2.0>1.1[5]
**DL GLA-JFK JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
DL GRB-MSP MAY 1.0>0.0[4]
DL GRR-MSP MAY 0.9>0.0[5]
DL GTF-MSP MAY 0.5>0.0[1.0]
DL GUA-LAX MAY 0.4>0[1.0]
DL HLN-SLC MAY 1.4>1.0[3]
DL HND-HNL JUN 1.0>0[0]
DL HND-MSP JUN 1.0>0[1.0]
DL HND-PDX JUN 1.0>0[0]
DL HNL-KIX JUN 1.0>0[1.0]
DL HNL-LAX MAY 1.5>1.0[4]
**DL HNL-MSP JUN 0.8>0[0.8] JUL 0.9>0[0.8] AUG 0.8>0[0.7]
DL HNL-NGO JUN 1.0>0[1.0]
DL IAH-MSP MAY 2>1.0[5]
DL IAH-SLC MAY 1.5>1.0[3]
*DL ICN-MSP JUN 1.0>0[1.0]
DL ICT-MSP MAY 0.5>0.0[3]
DL JAC-SLC MAY 1.5>1.0[3] SEP 4>3[3] OCT 4>3[3] NOV 4>3[3] DEC 4>3[3] JAN 4>3[3]
**DL JFK-KEF JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.5>0[0.6]
DL JFK-LHR JUN 3>2.0[2] JUL 3>2[2] AUG 3>2[2] SEP 3>2[2] OCT 3>2[2]
**DL JFK-LOS JUN 0.4>0[0.4] JUL 0.5>0[0.5] AUG 0.9>0[0.4] SEP 0.5>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.5]
DL JFK-MCO MAY 0.5>0[5]
DL JFK-MIA MAY 0.5>0[4]
DL JFK-MSP MAY 1.5>1.0[4]
**DL JFK-NCE JUN 1.1>0[1.1] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
DL JFK-PBI JUN 0.2>0[1.8]
**DL JFK-PRG JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
DL JFK-ROC MAY 0.5>0[3]
DL JFK-SDQ MAY 1.0>0.5[3]
DL JFK-SFO MAY 0.5>0[7]
DL JFK-SJU MAY 1.0>0[3.0]
**DL JFK-SNN JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
DL JFK-STI MAY 1.0>0.3[3]
DL JFK-SYR MAY 0.5>0[3]
DL JFK-TLV JUN 1.5>1.0[1.5] JUL 1.6>1.0[2] AUG 1.6>1.0[2] SEP 1.6>1.0[1.7] OCT 1.7>1.3[1.5]
DL JFK-TPA MAY 0.5>0[4]
**DL JFK-TXL JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL JFK-VCE JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL JFK-YVR JUN 0.9>0[0.6] JUL 0.9>0[0.9] AUG 1.0>0[0.9] SEP 0.7>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.7>0[0] JAN 0.7>0[0]
DL JNU-SEA JUN 0.8>1.0[1.0]
**DL KEF-MSP JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.2>0[0.1]
DL KOA-LAX MAY 1.0>0.6[1.0]
DL KTN-SEA JUN 0.8>1.0[0.8]
DL LAX-LIH MAY 1.0>0.5[0.7]
DL LAX-OGG MAY 1.0>0.6[2]
DL LAX-PVR MAY 0.5>0[1.0]
DL LAX-SJD MAY 0.6>0[2]
DL LAX-SJO MAY 0.6>0[1.0]
DL LAX-SMF JUL 6>5[5]
DL LEX-MSP JUN 0.8>1.0[1.0]
DL LGA-MSP MAY 2.0>1.0[6]
DL LGA-MYR AUG 0.3>0[0.3]
**DL LGA-TVC JUL 0.4>0[0.5] AUG 0.5>0[0.6]
**DL LHR-PDX JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.5>0[0.5]
**DL LHR-SLC JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0.3[0.6]
DL LNK-MSP MAY 1.4>1.0[3]
DL MCI-SEA JUL 1.8>1.0[0.9] AUG 1.9>1.0[1.0] SEP 1.7>1.0[0.8] OCT 1.8>1.0[0.9] NOV 1.9>1.0[0.8] DEC 1.8>1.0[0.9] JAN 1.8>1.0[0.9]
DL MCI-SLC MAY 2>1.0[3]
DL MCO-SEA JUL 1.6>1.1[1.0] AUG 1.3>1.0[0.8]
DL MCO-SLC MAY 0.5>0[3]
DL MEX-SLC MAY 1.0>0.2[1.0]
DL MFR-SEA MAY 1.4>1.0[3]
DL MIA-MSP MAY 0.5>0[1.9] JUN 3>1.9[2.0] JUL 3>1.9[1.8] AUG 3>2[1.8] SEP 3>2[1.6] OCT 3>2[1.7] NOV 3>2[1.6] DEC 3>2[1.8] JAN 3>2[3]
DL MKE-MSP MAY 1.8>1.0[5]
DL MSN-MSP MAY 2>1.0[5]
DL MSP-PHL MAY 1.5>1.0[5]
DL MSP-PHX MAY 1.5>1.0[5] OCT 6>5[5] NOV 6>5[5]
DL MSP-PIT MAY 1.4>1.0[4]
DL MSP-RST MAY 1.9>1.0[4]
DL MSP-STL MAY 1.0>0[5]
DL MSP-TUS DEC 1.0>0.4[0.4]
DL MSP-YXE MAY 0.3>0.0[1.9]
DL MSP-YYZ DEC 4>3[3] JAN 4>3[3]
DL MSY-SLC MAY 0.4>0[1.0]
DL OGG-SEA MAY 0.5>0[1.0]
DL ONT-SLC OCT 5>4[3] NOV 5>4[3]
DL PDX-SEA NOV 8>7[7] DEC 8>7[7] JAN 8>7[7]
DL PHL-SLC JUN 1.7>1.0[1.2] JUL 1.8>1.0[1.4] AUG 1.8>1.0[1.5]
DL PHX-SEA SEP 4>3[3] OCT 4>3[3]
DL PSC-SEA NOV 4>3[3]
DL PSP-SLC MAY 1.5>1.0[2]
DL RDM-SEA MAY 1.5>1.0[3] DEC 3>2[2]
DL SEA-SIT JUN 0.8>1.0[1.0]
DL SEA-SJC NOV 6>5[4]
DL SEA-SLC MAY 4>3[8]
DL SEA-YVR MAY 2>3[6]
EI BDL-DUB MAY 1.0>0.6[1.0]
EI BOS-DUB MAY 2>1.6[2]
EI BOS-SNN MAY 1.0>0.6[1.0]
EI DUB-EWR MAY 1.0>0.6[1.0]
EI DUB-IAD MAY 1.0>0.6[1.0]
EI DUB-LAX MAY 1.0>0.6[1.0]
EI DUB-MCO MAY 0.8>0.5[0.5]
EI DUB-MSP MAY 0.7>0.5[0]
EI DUB-ORD JAN 2>1.5[1.4]
EI DUB-PHL MAY 1.0>0.6[1.0]
EI DUB-SEA MAY 1.0>0.6[0.6]
EI DUB-SFO MAY 1.0>0.6[1.0]
EI JFK-SNN MAY 1.0>0.6[0.9]
EK ATH-EWR JUN 1.0>0[1.0]
EK BOS-DXB JUN 1.0>0.6[1.0]
EK DFW-DXB JUN 1.0>0.6[1.0]
EK DXB-IAD JUN 1.0>0.6[1.0]
EK DXB-JFK JUN 2>0.7[2] JUL 2>1.5[2]
EK DXB-LAX JUL 1.0>0.6[1.0]
EK DXB-MCO JUL 1.0>0.7[0.7] AUG 1.0>0.7[0.7]
EK DXB-ORD JUN 1.0>0.6[1.0]
EK DXB-SEA JUL 1.0>0.6[1.0]
EK DXB-SFO JUN 1.0>0.4[1.0]
EK JFK-MXP JUN 1.0>0.3[1.0]
ET IAH-LFW MAY 0.4>0.2[0]
EW DUS-EWR MAY 0.9>0[0.9] JUN 1.0>0[0.9]
EW DUS-JFK MAY 0.4>0[0.9] JUN 0.8>0[0.9]
EW DUS-MIA MAY 0.4>0[0.7] JUN 0.5>0[0.7]
EW DUS-RSW MAY 0.4>0[0.4] JUN 0.4>0[0.4]
EW FRA-PHX JUN 0.7>0[0] JUL 0.7>0[0]
EY AUH-IAD MAY 0.5>0.3[1.0]
EY AUH-JFK MAY 0.6>0.3[1.0]
EY AUH-ORD MAY 0.6>0.3[1.0]
FJ LAX-NAN JUN 1.0>0.7[1.0]
FJ NAN-SFO JUN 0.5>0.3[0.5]
G3 BSB-MCO JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0]
G3 BSB-MIA JUL 1.0>0[0.6] AUG 1.0>0[0.7] SEP 0.6>0[0.7] OCT 0.7>0[0.6] NOV 1.0>0[0.6]
G3 FOR-MCO JUL 1.0>0[1.0] AUG 1.0>0[0.1] SEP 0.4>0[0.2] OCT 0.6>0[0] NOV 1.0>0[0]
G4 ABE-BNA MAY 0>0.3[0.2]
G4 ABE-MDW MAY 0>0.2[0]
G4 ABE-MYR MAY 0>0.3[0.4]
G4 ABE-PIE MAY 0>0.7[0.4]
G4 ABE-SAV MAY 0>0.3[0]
G4 ABE-SFB MAY 0>0.7[1.5]
G4 ABE-SRQ MAY 0>0.3[0]
G4 ALB-PIE MAY 0>0.3[0.4]
G4 ALB-SFB MAY 0>0.3[0.4]
G4 ATW-BNA MAY 0>0.3[0]
G4 ATW-PGD MAY 0>0.3[0]
G4 AUS-LAS MAY 0>0.3[0.6]
G4 AVL-EWR MAY 0>0.3[0.7]
G4 AVL-FLL MAY 0>0.7[2]
G4 AVL-PBI MAY 0>0.3[0]
G4 AVL-PGD MAY 0>0.3[0.5]
G4 AVL-PIE MAY 0>0.6[1.3]
G4 AVL-SFB MAY 0>0.7[1.0]
G4 AZA-BIS MAY 0>0.3[0.5]
G4 AZA-CID MAY 0>0.5[0.4]
G4 AZA-DSM MAY 0>0.4[0.5]
G4 AZA-FSD MAY 0>0.5[0.6]
G4 AZA-GRI MAY 0>0.3[0.4]
G4 AZA-ICT MAY 0>0.2[0.3]
G4 AZA-IDA MAY 0>0.3[0.4]
G4 AZA-LAS MAY 0>0.3[0.5]
G4 AZA-OAK MAY 0>0.3[0.5]
G4 AZA-PVU MAY 0>0.6[1.5]
G4 AZA-RAP MAY 0>0.3[0.5]
G4 AZA-RFD MAY 0>0.3[0.4]
G4 AZA-SGF MAY 0>0.4[0.5]
G4 BGR-SFB MAY 0>0.5[0.6]
G4 BLV-JAX MAY 0>0.2[0.3]
G4 BLV-PIE MAY 0>0.6[0.5]
G4 BLV-SFB MAY 0>0.4[0.5]
G4 BLV-SRQ MAY 0>0.3[0]
G4 BLV-VPS MAY 0>0.7[0.9]
G4 BNA-CID MAY 0>0.3[0.2]
G4 BNA-CLE MAY 0>0.3[0.2]
G4 BNA-DSM MAY 0>0.3[0]
G4 BNA-GRR MAY 0>0.3[0]
G4 BNA-MDT MAY 0>0.3[0]
G4 BNA-PGD MAY 0>0.3[0.4]
G4 BNA-SFB MAY 0>0.3[0.2]
G4 BNA-XNA MAY 0>0.3[0]
G4 BWI-VPS MAY 0>0.2[0.3]
G4 CHS-CLE MAY 0>0.3[0]
G4 CHS-LCK MAY 0>0.3[0]
G4 CHS-PGD MAY 0>0.2[0]
G4 CID-PGD MAY 0>0.2[0.3]
G4 CLE-PGD MAY 0>0.3[0.4]
G4 CLE-PIE MAY 0>0.2[0.3]
G4 CVG-EWR MAY 0>0.3[0.5]
G4 CVG-FLL MAY 0>0.6[1.0]
G4 CVG-LAX MAY 0>0.3[0.6]
G4 CVG-MSY MAY 0>0.4[0.3]
G4 CVG-MYR MAY 0>0.3[0.4]
G4 CVG-PBI MAY 0>0.3[0]
G4 CVG-PGD MAY 0>0.8[1.1]
G4 CVG-PIE MAY 0>0.9[1.1]
G4 CVG-SFB MAY 0>0.9[1.1]
G4 CVG-SRQ MAY 0>0.6[0.5]
G4 CVG-VPS MAY 0>0.8[1.0]
G4 DAY-PGD MAY 0>0.3[0]
G4 DAY-VPS MAY 0>0.2[0]
G4 DSM-PGD MAY 0>0.4[0.3]
G4 DSM-PIE MAY 0>0.6[0.4]
G4 DSM-SFB MAY 0>0.5[0.4]
G4 ELM-PIE MAY 0>0.2[0.3]
G4 ELM-SFB MAY 0>0.3[0.5]
G4 ELP-LAS MAY 0>0.2[0.4]
G4 EUG-LAS MAY 0>0.3[0.4]
G4 EWR-TYS MAY 0>0.3[0.5]
G4 FAT-LAS MAY 0>0.6[1.6]
G4 FLL-GSP MAY 0>0.3[0.4]
G4 FLL-MEM MAY 0>0.4[0.5]
G4 FLL-SDF MAY 0>0.3[0.5]
G4 FLL-TYS MAY 0>0.6[0.8]
G4 FLL-USA MAY 0>0.7[1.1]
G4 FNT-PGD MAY 0>0.3[0.4]
G4 FNT-SFB MAY 0>0.5[0.7]
G4 FSD-SFB MAY 0>0.4[0.3]
G4 FWA-PGD MAY 0>0.5[0.4]
G4 FWA-PIE MAY 0>0.5[0.6]
G4 FWA-SFB MAY 0>0.3[0.5]
G4 GRR-JAX MAY 0>0.3[0]
G4 GRR-LAS MAY 0>0.6[0.5]
G4 GRR-PIE MAY 0>0.8[1.0]
G4 GRR-SAV MAY 0>0.2[0]
G4 GRR-SFB MAY 0>0.9[1.1]
G4 GSO-SFB MAY 0>0.3[0.4]
G4 GSP-PIE MAY 0>0.3[0.5]
G4 HTS-PIE MAY 0>0.5[0.6]
G4 HTS-SFB MAY 0>0.4[0.8]
G4 IAG-PGD MAY 0>0.3[0.4]
G4 IAG-SFB MAY 0>0.3[0.4]
G4 ICT-VPS MAY 0>0.4[0]
G4 IND-LAS MAY 0>0.3[0.4]
G4 IND-PBI MAY 0>0.3[0]
G4 IND-PGD MAY 0>0.5[0.7]
G4 IND-PIE MAY 0>0.8[0.9]
G4 IND-SRQ MAY 0>0.5[0.4]
G4 JAX-ORF MAY 0>0.3[0.2]
G4 JAX-PIT MAY 0>0.3[0.4]
G4 LAS-MFE MAY 0>0.7[1.0]
G4 LAS-MFR MAY 0>0.3[0.4]
G4 LAS-MOT MAY 0>0.3[0.4]
G4 LAS-OAK MAY 0>0.5[1.0]
G4 LAS-PIA MAY 0>0.3[0.4]
G4 LAS-PSC MAY 0>0.3[0.4]
G4 LAS-RDM MAY 0>0.3[0]
G4 LAS-RNO MAY 0>0.6[0.9]
G4 LAS-SCK MAY 0>0.6[1.7]
G4 LAS-SGF MAY 0>0.3[0.4]
G4 LAS-SHV MAY 0>0.3[0.4]
G4 LAS-SMX MAY 0>0.3[0.5]
G4 LAS-XNA MAY 0>0.3[0.4]
G4 LAX-OKC MAY 0>0.2[0.3]
G4 LAX-TUL MAY 0>0.2[0.3]
G4 LCK-MYR MAY 0>0.3[0.6]
G4 LCK-PGD MAY 0>0.4[0.5]
G4 LCK-SAV MAY 0>0.4[0.3]
G4 LCK-SFB MAY 0>0.4[0.6]
G4 LEX-PGD MAY 0>0.4[0.5]
G4 LEX-SFB MAY 0>0.6[0.8]
G4 MCI-VPS MAY 0>0.4[0.5]
G4 MDT-PIE MAY 0>0.3[0.5]
G4 MDT-SFB MAY 0>0.8[1.1]
G4 MEM-SFB MAY 0>0.3[0.5]
G4 MFE-SFB MAY 0>0.3[0.2]
G4 MSY-USA MAY 0>0.3[0.4]
G4 OKC-VPS MAY 0>0.4[0.6]
G4 ORF-SFB MAY 0>0.3[0.4]
G4 OWB-SFB MAY 0>0.3[0.4]
G4 PBG-SFB MAY 0>0.4[0.5]
G4 PBI-PIT MAY 0>0.3[0]
G4 PBI-TYS MAY 0>0.3[0]
G4 PGD-PIA MAY 0>0.3[0.4]
G4 PGD-PIT MAY 0>0.4[0.5]
G4 PGD-SDF MAY 0>0.3[0.4]
G4 PGD-SPI MAY 0>0.2[0.3]
G4 PGD-SWF MAY 0>0.2[0.3]
G4 PGD-TYS MAY 0>0.4[0.5]
G4 PIA-PIE MAY 0>0.3[0.4]
G4 PIE-PIT MAY 0>0.4[0.6]
G4 PIE-RFD MAY 0>0.3[0.5]
G4 PIE-SBN MAY 0>0.2[0.3]
G4 PIE-SCE MAY 0>0.2[0]
G4 PIE-SDF MAY 0>0.3[0.4]
G4 PIE-SGF MAY 0>0.5[0.6]
G4 PIE-SYR MAY 0>0.5[0.6]
G4 PIE-TOL MAY 0>0.3[0.4]
G4 PIE-TVC MAY 0>0.2[0]
G4 PIE-TYS MAY 0>0.8[1.1]
G4 PIE-USA MAY 0>0.7[1.0]
G4 PIT-SAV MAY 0>0.4[0.3]
G4 PIT-SFB MAY 0>0.3[0.4]
G4 ROA-SFB MAY 0>0.4[0.5]
G4 SAV-SDF MAY 0>0.3[0.4]
G4 SBN-SFB MAY 0>0.3[0.5]
G4 SDF-SFB MAY 0>0.4[0.5]
G4 SDF-VPS MAY 0>0.3[0.2]
G4 SFB-SGF MAY 0>0.4[0.6]
G4 SFB-SYR MAY 0>0.3[0.4]
G4 SFB-TOL MAY 0>0.3[0.4]
G4 SFB-TVC MAY 0>0.3[0]
G4 SFB-TYS MAY 0>0.8[1.6]
G4 SFB-USA MAY 0>0.6[0.9]
G4 SFB-XNA MAY 0>0.4[0.5]
G4 SGF-VPS MAY 0>0.3[0.2]
G4 SRQ-TYS MAY 0>0.3[0]
G4 TYS-VPS MAY 0>0.3[0.2]
G4 VPS-XNA MAY 0>0.4[0.5]
HA HNL-ITO MAY 13>11[15]
HA HNL-JFK MAY 1.0>0.7[1.0]
HA HNL-KOA MAY 18>15[19]
HA HNL-LAS MAY 3>1.9[3]
HA HNL-LGB MAY 1.0>0.7[1.0]
HA HNL-LIH MAY 18>14[18]
HA HNL-OAK MAY 1.0>0.7[1.0]
HA HNL-OGG MAY 25>20[27]
HA HNL-PDX MAY 1.0>0.7[1.0]
HA HNL-PHX MAY 1.0>0.7[1.0]
HA HNL-SAN MAY 1.0>0.7[1.0]
HA HNL-SJC MAY 1.0>0.7[1.0]
HA HNL-SMF MAY 1.0>0.7[1.0]
HA ITO-OGG MAY 2>1.5[2]
HA KOA-LAX MAY 1.0>0.7[1.0]
HA KOA-LIH MAY 1.0>0.7[1.0]
HA KOA-OGG MAY 3>2[3]
HA LAX-LIH MAY 1.0>0.7[1.0]
HA LIH-OAK MAY 1.0>0.7[1.0]
HA LIH-OGG MAY 4>3[3]
HA OAK-OGG MAY 1.0>0.7[1.0]
HA OGG-PDX MAY 1.0>0.7[1.0]
HA OGG-SAN MAY 1.0>0.7[1.0]
HA OGG-SEA MAY 1.0>0.7[1.0]
HA OGG-SFO MAY 1.0>0.7[1.0]
HA OGG-SJC MAY 1.0>0.7[1.0]
HA OGG-SMF MAY 1.0>0.7[1.0]
IB BOS-MAD MAY 0.5>0[1.0]
IB IAD-MAD MAY 0.3>0[0]
IB JFK-MAD MAY 1.1>0.2[2]
IB LAX-MAD MAY 0.4>0[0.7]
IB MAD-MIA MAY 1.1>0.3[2]
IB MAD-ORD MAY 0.5>0.3[1.0]
IB MAD-SFO MAY 0.2>0[0.5]
J5 AGN-JNU MAY 1.4>0.8[1.4] JUN 3>0.9[3]
J5 AGN-TKE MAY 0.8>0[0.7] JUN 0.5>0[0]
J5 ELV-JNU MAY 1.8>0.6[1.5] JUN 3>0.5[3]
J5 ELV-PEC MAY 0.6>0.3[0.6] JUN 0>0.5[0]
J5 HNH-JNU MAY 6>0.7[5] JUN 7>1.7[6]
J5 HNS-JNU MAY 8>1.2[8] JUN 8>1.3[8]
J5 HNS-SGY MAY 0.0>0.3[0.0] JUN 0>0.4[0]
J5 JNU-KAE MAY 2.0>0.7[1.9] JUN 2>0.9[2]
J5 JNU-PEC MAY 1.6>1.0[1.5] JUN 3>0.5[3]
J5 JNU-SGY MAY 7>0.3[7] JUN 7>1.3[7]
J5 JNU-SIT MAY 3>0.4[3] JUN 3>0.4[3]
J5 JNU-TKE MAY 1.1>0.4[1.8] JUN 1.5>0.4[3]
J5 KAE-SIT MAY 1.0>0[1.0] JUN 1.0>0[1.0]
J5 KLW-SIT MAY 2.0>0.4[2] JUN 2>0.4[2]
KL AMS-IAH MAY 0>0.3[1.0] JUN 0>0.3[1.0]
KL AMS-LAX JUN 1.4>0.4[1.9]
LA BEL-MIA MAY 0.3>0[0]
LA BOS-GRU MAY 0.7>0[0]
LA FOR-MIA MAY 0.7>0[0]
LA GRU-JFK MAY 0.9>0[0]
LA GRU-MCO MAY 1.0>0[0]
LA GRU-MIA MAY 2.0>0.4[0]
LA JFK-LIM MAY 1.0>0[1.0]
LA JFK-SCL MAY 1.0>0[1.0]
LA LAX-LIM MAY 1.7>0[1.7]
LA LAX-SCL MAY 1.0>0[0.7]
LA LIM-MCO MAY 1.0>0[1.0]
LA LIM-MIA MAY 2.0>0[2]
LA MIA-SCL MAY 1.4>0.8[1.7]
LO ORD-WAW MAY 1.6>2[1.4]
LV EWR-ORY MAY 0.9>0.5[0.6]
LX IAD-ZRH JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 0.9>0[0] NOV 0.7>0[0] DEC 0.7>0[0] JAN 0.7>0[0]
LY EWR-TLV MAY 0.8>0.6[1.1]
LY JFK-TLV MAY 0.9>0.7[1.9]
MF LAX-XMN MAY 0.3>1.2[0.5]
MU JFK-PVG MAY 1.8>0.2[2]
MU LAX-PVG MAY 1.8>0.0[2]
MU ORD-PVG MAY 0.9>0.0[0.7]
MU PVG-SFO MAY 0.9>0.0[1.0]
NH HND-HNL MAY 0.5>0[1.0]
NH HND-IAD MAY 0.5>0[0]
NH HND-IAH MAY 0.5>0[0]
NH HND-JFK MAY 0.5>0[1.0]
NH HND-LAX MAY 1.0>0[1.0]
NH HND-ORD MAY 0.5>0[1.0]
NH HND-SEA MAY 0.5>0[0]
NH HND-SFO MAY 0.3>0[0]
NH HND-SJC MAY 0.5>0[0]
NH HNL-NRT MAY 1.0>0[2]
NH JFK-NRT MAY 0.5>0.1[1.0]
NH NRT-ORD MAY 0.7>0.5[1.0]
NH NRT-SFO MAY 0.5>0[1.0]
Gutting. Very little left.
NK ACY-ATL JUN 0.7>0[1.0]
NK ACY-FLL MAY 0.9>0[2] JUN 1.7>0[1.7]
NK ACY-MCO MAY 1.0>0.4[2] JUN 1.7>0.4[2]
NK ACY-MYR JUN 1.1>0.4[1.0]
NK ACY-RSW MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ACY-TPA MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ATL-AUS JUN 0.7>0[1.0]
NK ATL-BOS JUN 0.7>0[1.0]
NK ATL-BWI MAY 0.9>0[3] JUN 2>0[3]
NK ATL-CLE MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ATL-DFW MAY 0.9>0[2.0] JUN 1.7>0[2]
NK ATL-DTW JUN 2>1.0[3]
NK ATL-EWR MAY 0.8>0[1.0] JUN 1.0>0[1.0]
NK ATL-FLL MAY 1.4>0[4] JUN 4>0[4]
NK ATL-IAH MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ATL-LAS JUN 1.4>0[1.4]
NK ATL-LAX JUN 1.4>0[1.0]
NK ATL-MCO MAY 0.6>0[2] JUN 1.6>0[2.0]
NK ATL-MSP JUN 0.7>0[1.0]
NK ATL-MSY MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ATL-ORD MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ATL-PHL MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ATL-TPA MAY 0.9>0[1.6] JUN 1.7>0[1.9]
NK AUS-BNA JUN 0.7>0[0]
NK AUS-BWI JUN 0.7>0[1.0]
NK AUS-CUN JUN 0.4>0[0]
NK AUS-DEN JUN 0.7>0[1.0]
NK AUS-DTW JUN 0.7>0[1.0]
NK AUS-EWR JUN 0.7>0[0]
NK AUS-FLL MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK AUS-LAS JUN 0.7>0[1.0]
NK AUS-LAX JUN 0.7>0[1.0]
NK AUS-MCO MAY 0.9>0.3[1.0] JUN 1.4>0.4[1.0]
NK AUS-MSY JUN 0.7>0[1.0]
NK AUS-ORD JUN 0.7>0[1.0]
**NK AVL-GSO MAY 0>0.2[0]
**NK AVL-MCO MAY 0>0.2[0.6] JUN 0.7>0.4[0.6]
NK AXM-FLL JUN 0.3>0[0.4]
NK BAQ-FLL JUN 0.3>0[0]
**NK BDL-FLL MAY 0>0.4[1.0] JUN 0.7>0.4[1.0]
NK BDL-MCO JUN 1.4>0[2]
NK BDL-MYR MAY 0.6>0[1.3] JUN 1.6>0[1.3]
NK BGA-FLL JUN 0.3>0[0]
NK BNA-BWI JUN 0.7>0[0]
NK BNA-CUN JUN 0.3>0[0]
NK BNA-EWR JUN 0.7>0[0]
NK BNA-FLL MAY 0.6>0.3[0] JUN 0.9>0.3[0]
NK BNA-LAS JUN 0.7>0[0]
NK BNA-LAX JUN 0.7>0[0]
NK BNA-MCO MAY 0.6>0[0] JUN 1.2>0[0]
NK BNA-MSY JUN 0.7>0[0]
NK BNA-TPA JUN 0.7>0[0]
NK BOG-FLL JUN 0.7>0[1.0]
NK BOG-MCO JUN 0.7>0[1.0]
NK BOS-BWI JUN 1.4>0[2]
NK BOS-CLE JUN 0.7>0[1.0]
NK BOS-DFW JUN 0.7>0[1.0]
NK BOS-DTW JUN 0.7>0[1.0]
NK BOS-FLL MAY 0.7>0.5[2] JUN 1.6>0.4[2]
NK BOS-LAS JUN 0.7>0[1.0]
NK BOS-MCO MAY 0.5>0[2] JUN 1.6>0[2]
NK BOS-MSY JUN 0.7>0[1.0]
NK BOS-MYR MAY 0.6>0[1.0] JUN 1.4>0[1.0]
NK BOS-ORD JUN 0.7>0[1.0]
NK BOS-SJU JUN 0.7>0[0]
NK BQN-FLL JUN 0.7>0[0.9]
NK BQN-MCO JUN 0.7>0[1.0]
NK BUR-LAS MAY 0.6>0[0] JUN 1.6>0.4[1.1]
NK BUR-SEA JUN 0.7>0[0]
NK BWI-CLT JUN 0.7>0[0.4]
NK BWI-CUN JUN 0.7>0[1.0]
NK BWI-DEN JUN 0.7>0[1.0]
NK BWI-DFW MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK BWI-DTW JUN 0.7>0[1.0]
NK BWI-FLL MAY 0.9>0[3] JUN 3>0[3]
NK BWI-IAH MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK BWI-JAX JUN 0.7>0.3[1.0]
NK BWI-LAS MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK BWI-LAX JUN 0.7>0[1.0]
NK BWI-MBJ JUN 0.7>0[1.0]
NK BWI-MCO MAY 1.0>0.4[3] JUN 3>0.5[2]
NK BWI-MSP JUN 0.7>0[1.0]
NK BWI-MSY MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK BWI-MYR MAY 0.6>0[1.5] JUN 1.6>0[1.6]
NK BWI-ORD MAY 0.6>0[2.0] JUN 1.6>0[2]
NK BWI-RDU JUN 0.7>0[2]
NK BWI-SAL JUN 0.7>0[0]
NK BWI-SEA JUN 0.7>0[1.0]
NK BWI-SJU JUN 1.4>0[1.0]
NK BWI-TPA MAY 0.5>0[1.6] JUN 1.6>0[1.6]
NK CAK-MCO MAY 0.5>0[1.0] JUN 0.9>0.2[1.0]
NK CLE-CUN JUN 0.4>0[0]
NK CLE-DFW JUN 0.7>0[1.0]
NK CLE-FLL MAY 0.9>0[1.0] JUN 1.7>0[1.0]
NK CLE-LAS MAY 0.5>0[1.0] JUN 1.6>0[1.0]
NK CLE-LAX JUN 0.7>0[1.0]
NK CLE-MCO MAY 0.9>0.3[1.0] JUN 2>0.4[1.9]
NK CLE-MSY JUN 0.3>0[0.4]
NK CLE-MYR MAY 0.5>0[1.0] JUN 1.4>0[1.0]
NK CLE-TPA JUN 0.7>0[0]
NK CLO-FLL JUN 0.7>0[1.0]
NK CLT-EWR JUN 0.7>0[0.4]
NK CLT-FLL MAY 0.6>0.3[0] JUN 0.9>0.4[0.4]
NK CLT-MCO MAY 0.6>0[0] JUN 0.9>0[0.4]
NK CMH-FLL MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK CMH-LAS JUN 0.7>0[1.0]
NK CMH-MCO MAY 0.9>0.3[1.0] JUN 1.0>0.4[1.0]
NK CMH-MSY JUN 0.3>0[0.4]
NK CMH-MYR JUN 0.2>0[0.6]
NK CRW-MYR JUN 0.2>0[0.3]
NK CTG-FLL JUN 0.4>0[0.6]
NK CTG-MCO JUN 0.2>0[0.3]
NK CUN-DFW JUN 0.7>0[1.0]
NK CUN-DTW JUN 0.7>0[0.2]
NK CUN-FLL JUN 0.7>0[1.0]
NK CUN-IAH JUN 0.7>0[1.0]
NK CUN-MSY JUN 0.4>0[0]
NK CUN-ORD JUN 0.7>0[0.3]
NK CUN-PHL JUN 0.7>0[0]
NK CUN-PIT JUN 0.3>0[0]
NK DEN-DTW JUN 0.7>0[1.0]
NK DEN-FLL MAY 0.4>0[1.0] JUN 1.6>0[1.0]
NK DEN-IAH JUN 0.7>0[1.0]
NK DEN-LAS MAY 0.9>0.6[2.0] JUN 1.7>0.6[2]
NK DEN-LAX JUN 0.7>0[1.0]
NK DEN-MCO JUN 0.7>0[1.0]
NK DEN-MSP JUN 0.7>0[1.0]
NK DEN-ORD JUN 1.4>0[2]
NK DFW-DTW MAY 0.6>0.4[1.4] JUN 1.2>0.4[1.4]
NK DFW-FLL MAY 0.6>0[3] JUN 2>0[3]
NK DFW-LAS MAY 0.5>0.1[4] JUN 3>0[4]
NK DFW-LAX JUN 3>0.6[4]
NK DFW-LGA JUN 0.7>0[1.0]
NK DFW-MCO MAY 0.6>0.3[3] JUN 2>0.6[3]
NK DFW-MSY JUN 0.7>0[1.0]
NK DFW-MYR JUN 0.3>0[0.4]
NK DFW-ORD JUN 1.4>0[2]
NK DFW-PHL JUN 0.7>0[1.0]
NK DFW-PHX MAY 0.7>0.3[1.0] JUN 0.9>0.4[1.0]
NK DFW-SAN JUN 0.7>0[1.0]
NK DFW-SJD JUN 0.4>0[0.6]
NK DFW-TPA JUN 0.7>0[1.0]
NK DTW-FLL MAY 0.9>0[2] JUN 1.7>0[2]
NK DTW-IAH JUN 0.7>0[1.0]
NK DTW-LAS JUN 3>1.0[3]
NK DTW-LAX JUN 1.4>0[2]
NK DTW-LGA MAY 1.7>0.4[2] JUN 2>0.4[2]
NK DTW-MCI JUN 0.9>0.4[1.0]
NK DTW-MCO JUN 2>0.6[3]
NK DTW-MSP JUN 0.9>0.4[1.0]
NK DTW-MSY MAY 0.9>0[1.0] JUN 1.0>0[1.0]
NK DTW-MYR MAY 0.6>0[1.2] JUN 0.9>0[1.0]
NK DTW-OAK JUN 0.7>0[1.0]
NK DTW-PHL JUN 0.7>0[1.0]
NK DTW-RDU JUN 0.7>0[1.0]
NK DTW-RSW JUN 0.7>0[0.9]
NK DTW-SAN JUN 0.7>0[1.0]
NK DTW-SEA JUN 0.7>0[1.0]
NK DTW-TPA MAY 0.7>0.5[0.9] JUN 0.9>0.4[0.9]
NK EWR-FLL MAY 0.9>0[2] JUN 1.7>0.7[2]
NK EWR-IAH MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK EWR-LAS JUN 0.7>0[1.0]
NK EWR-MCO MAY 0.9>0[3] JUN 2>0[3]
NK EWR-MSY JUN 0.7>0[1.0]
NK EWR-MYR MAY 0.9>0[1.0] JUN 1.1>0[1.0]
NK EWR-RSW JUN 0.7>0[0]
NK EWR-SJU JUN 1.4>0[0]
NK EWR-TPA JUN 0.7>0[0]
NK FLL-GUA JUN 1.1>0[1.0]
NK FLL-GYE JUN 0.7>0[1.0]
*NK FLL-IAG MAY 0>0.2[0.3]
NK FLL-IAH MAY 0.7>0[2.0] JUN 1.6>0[2]
NK FLL-KIN JUN 0.7>0[1.0]
NK FLL-LAS JUN 0.7>0[1.0]
NK FLL-LAX JUN 0.7>0[1.0]
NK FLL-LBE JUN 0.7>0[0.9]
NK FLL-LGA MAY 0.9>0[4] JUN 3>0[4]
NK FLL-LIM JUN 0.7>0[1.0]
NK FLL-MBJ JUN 0.7>0[1.0]
NK FLL-MCO JUN 1.4>0[2]
NK FLL-MDE JUN 0.7>0[1.0]
NK FLL-MGA JUN 0.7>0[1.0]
NK FLL-MSY MAY 1.0>0.6[2.0] JUN 1.7>0.6[2]
NK FLL-MYR MAY 0.6>0[1.3] JUN 1.6>0[1.3]
NK FLL-OAK MAY 0.5>0[0] JUN 0.9>0[0]
NK FLL-ORD JUN 2>1.0[2]
NK FLL-PAP JUN 0.7>0[1.0]
*NK FLL-PBG MAY 0>0.2[0.3]
NK FLL-PHL MAY 1.0>0.4[2] JUN 3>0.4[2]
NK FLL-PIT MAY 0.9>0[1.0] JUN 1.7>0.3[1.0]
NK FLL-PTY JUN 0.7>0[1.0]
NK FLL-PUJ JUN 0.7>0[1.0]
NK FLL-RDU JUN 0.9>0.4[1.0]
NK FLL-RIC MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK FLL-SAL JUN 0.9>0[0.6]
NK FLL-SAP JUN 0.7>0[1.0]
NK FLL-SDQ JUN 1.4>0[1.0]
NK FLL-SJO JUN 1.4>0[1.9]
NK FLL-SJU JUN 1.6>0.4[1.3]
NK FLL-STI JUN 0.4>0[0.6]
NK FLL-STT JUN 0.9>0.4[1.0]
NK FLL-STX JUN 0.8>0.1[0.6]
NK FLL-TPA JUN 1.4>0[1.0]
*NK GSO-MCO MAY 0>0.2[0.6] JUN 0.7>0.4[0.6]
NK GUA-IAH JUN 0.4>0[0.6]
NK GUA-MCO JUN 0.4>0[0.6]
NK IAG-MYR MAY 0.3>0[0.7] JUN 0.4>0[0.7]
*NK IAG-PBG MAY 0>0.2[0]
NK IAH-LAS JUN 2>0.7[2]
NK IAH-LAX MAY 0.6>0[2] JUN 2>0[2]
NK IAH-MCO MAY 0.6>0[2] JUN 2>0[2]
NK IAH-MSY MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK IAH-MYR JUN 0.2>0[0.3]
NK IAH-OAK JUN 0.7>0[1.0]
NK IAH-ORD JUN 1.4>0.3[2]
NK IAH-SAL JUN 0.3>0[0.4]
NK IAH-SAN JUN 0.7>0[1.0]
NK IAH-SAP JUN 0.3>0[0.4]
NK IAH-SEA JUN 0.7>0[1.0]
NK IAH-SJD JUN 0.4>0[0.6]
NK IAH-TPA JUN 0.7>0[1.0]
NK IND-LAS JUN 0.7>0[1.0]
NK IND-MCO MAY 0.6>0.4[1.0] JUN 0.9>0.4[1.0]
NK IND-RSW JUN 0.7>0[0]
NK IND-TPA JUN 0.7>0[0]
*NK JAX-ORD MAY 0>0.2[0.9]
*NK JAX-RSW MAY 0>0.2[0]
NK LAS-LAX MAY 0.6>0[3] JUN 2>0[3]
NK LAS-MCI MAY 0.9>0[1.0] JUN 1.7>0[1.0]
NK LAS-MCO JUN 0.7>0[1.0]
NK LAS-MSP JUN 0.7>0[1.0]
NK LAS-MSY MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK LAS-OAK MAY 0.6>0.3[4] JUN 3>0.4[4]
NK LAS-ORD JUN 2>0.7[3]
NK LAS-PDX MAY 0.6>0.3[3] JUN 2>0.4[3]
NK LAS-PHL JUN 0.7>0[1.0]
NK LAS-PIT MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK LAS-SAN MAY 0.7>0.5[4] JUN 2>0.4[4]
NK LAS-SEA MAY 1.0>0.3[4] JUN 2>0.6[4]
NK LAS-SMF MAY 0.6>0.3[0] JUN 2>0.4[1.1]
NK LAS-TPA JUN 0.7>0[1.0]
NK LAX-MCI MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK LAX-MSP JUN 0.7>0[1.0]
NK LAX-MSY MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK LAX-OAK MAY 0.9>0[2.0] JUN 1.7>0[2]
NK LAX-ORD JUN 1.7>1.0[2]
NK LAX-PHL JUN 0.7>0[1.0]
NK LAX-PIT MAY 0.6>0[1.0] JUN 1.6>0[1.0]
NK LBE-MCO MAY 0.6>0.2[1.0] JUN 0.9>0.4[1.0]
NK LBE-MYR JUN 1.0>0[1.4]
*NK LBE-PIT MAY 0>0.2[0]
NK LGA-MCO MAY 0.9>0[0] JUN 1.0>0[0]
NK LGA-MYR MAY 0.6>0[2] JUN 1.6>0[2]
NK LGA-ORD JUN 0.7>0[2]
NK MBJ-MCO JUN 0.3>0[0.6]
NK MCI-MCO MAY 0.9>0[1.0] JUN 1.0>0[1.0]
NK MCO-MDE JUN 0.3>0[0.3]
NK MCO-MSP JUN 0.7>0[1.0]
NK MCO-MSY MAY 0.6>0[1.0] JUN 1.6>0[1.0]
NK MCO-MYR JUN 0.2>0[0.3]
NK MCO-ORD MAY 0.8>0[1.0] JUN 1.0>0[1.0]
NK MCO-PHL MAY 1.0>0.6[3] JUN 2>0.6[3]
NK MCO-PIT MAY 0.8>0.2[1.0] JUN 1.3>0.1[1.0]
NK MCO-RDU MAY 0.6>0[1.0] JUN 1.6>0[1.0]
NK MCO-RIC MAY 0.6>0.3[1.0] JUN 0.9>0.4[1.0]
NK MCO-SAL JUN 0.2>0[0.3]
NK MCO-SAP JUN 0.2>0[0.3]
NK MCO-SJO JUN 0.7>0[1.0]
NK MCO-SJU JUN 3.1>0.6[3.6]
NK MSP-MSY JUN 0.4>0[0.6]
NK MSP-MYR JUN 0.2>0[0.4]
NK MSY-ORD MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK MSY-PHL JUN 0.4>0[0.6]
NK MSY-RDU JUN 0.7>0[1.0]
NK MSY-SAP JUN 0.3>0[0]
NK MSY-TPA MAY 0.9>0[1.0] JUN 1.0>0[1.0]
NK MYR-ORD MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK MYR-PHL MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK MYR-PIT MAY 0.5>0[1.0] JUN 1.4>0[1.0]
NK OAK-ORD JUN 0.7>0[1.0]
NK ORD-RDU JUN 0.7>0[1.0]
NK ORD-RSW JUN 0.7>0.4[1.0]
NK ORD-SAN JUN 0.7>0[1.0]
NK ORD-SEA JUN 0.7>0[1.0]
NK ORD-TPA MAY 0.5>0[1.0] JUN 0.9>0[1.0]
NK PHL-SJU MAY 0.5>0[0.3] JUN 1.6>0[1.0]
NK SJU-TPA JUN 0.7>0[1.0]
OB MIA-VVI MAY 1.0>0.6[0.6]
OZ HNL-ICN MAY 1.0>0[0.9]
OZ ICN-JFK MAY 2.0>1.0[1.0]
OZ ICN-LAX MAY 2>1.0[2]
OZ ICN-SEA MAY 0.7>0[1.0]
OZ ICN-SFO MAY 1.0>0.5[1.0]
QR DOH-IAD MAY 0.5>0.0[1.0]
SQ EWR-SIN MAY 1.0>0.5[1.0]
SQ IAH-MAN MAY 0.7>0.4[0.7]
SQ LAX-NRT MAY 1.0>0.5[1.0]
SQ LAX-SIN MAY 1.0>0.7[1.5]
SQ SEA-SIN MAY 0.6>0.3[0]
SQ SFO-SIN MAY 1.4>0.7[1.5]
SU IAD-SVO MAY 0.2>0[0.4]
SU JFK-SVO MAY 1.5>0[3]
SU LAX-SVO MAY 0.5>0[1.0]
SU MIA-SVO MAY 0.3>0[0.5]
TA MGA-MIA MAY 0>0.3[0.9] JUN 1.0>0.3[1.0]
TP BOS-LIS JUL 1.0>1.7[1.0]
TP EWR-LIS JUL 2>3[1.0]
TP LIS-MIA JUL 1.5>3[1.0]
UA ABE-ORD MAY 1.9>0.5[1.8]
UA ABQ-DEN MAY 4>2.0[4]
UA ABQ-IAH MAY 4>1.9[4]
UA ABQ-ORD MAY 0.9>0[1.1]
UA ABQ-SFO MAY 1.8>0[1.7]
UA ACV-LAX MAY 1.7>0[1.1]
UA ACV-SFO MAY 3>1.9[3]
UA AEX-IAH MAY 3>0.5[3]
UA ALB-EWR MAY 3>0[5]
UA ALB-IAD MAY 3>1.0[3]
UA ALB-ORD MAY 4>1.9[4]
UA AMA-DEN MAY 1.9>0.7[2]
UA AMA-IAH MAY 3>0.1[3]
UA ANC-DEN MAY 1.0>0.5[1.0]
UA ANC-ORD MAY 1.5>0[2]
UA ASE-DEN MAY 6>1.8[5]
UA ATL-DEN MAY 3>0.1[4]
UA ATL-EWR MAY 6>0.8[6]
UA ATL-IAD MAY 4>0.9[4]
UA ATL-IAH MAY 6>2[5]
UA ATL-ORD MAY 7>2.0[6]
UA ATL-SFO MAY 1.6>0[1.8]
UA ATW-DEN MAY 0.9>0[1.0]
UA ATW-ORD MAY 7>2.0[5]
UA ATY-ORD MAY 1.0>0.7[0]
UA AUS-DEN MAY 4>1.1[5]
UA AUS-EWR MAY 4>0[4]
UA AUS-IAD MAY 3>0[3]
UA AUS-IAH MAY 8>2[9]
UA AUS-ORD MAY 4>1.0[4]
UA AUS-SFO MAY 4>0[5]
UA AVL-EWR MAY 0.8>0[1.1]
UA AVL-IAD MAY 3>1.0[2]
UA AVP-IAD MAY 1.8>0.1[2]
UA AVP-ORD MAY 1.9>1.0[3]
UA AZO-ORD MAY 3>0.5[3]
**UA BCN-EWR JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA BDL-DEN MAY 0.9>0[1.0]
UA BDL-IAD MAY 4>1.0[4]
UA BDL-ORD MAY 4>1.9[3]
UA BFF-PIR MAY 0>0.9[0]
UA BFL-DEN MAY 1.9>0.9[2]
UA BFL-SFO MAY 0.9>0.5[1.0]
UA BGR-EWR MAY 1.8>0[2]
UA BGR-IAD MAY 0.1>1.0[0]
UA BHM-DEN MAY 1.9>0.1[2]
UA BHM-IAH MAY 5>2[5]
UA BHM-ORD MAY 3>0.2[4]
UA BIL-DEN MAY 5>1.9[4]
UA BIS-DEN MAY 4>1.9[4]
UA BNA-DEN MAY 4>0.1[4]
UA BNA-EWR MAY 6>0.4[6]
UA BNA-IAD MAY 3>1.1[3]
UA BNA-IAH MAY 6>2.0[6]
UA BNA-ORD MAY 6>2.0[7]
UA BOI-DEN MAY 4>1.9[4]
UA BOI-LAX MAY 1.8>0[2]
UA BOI-ORD MAY 3>1.0[2]
UA BOI-SFO MAY 5>1.9[5]
UA BOS-DEN MAY 4>0[5]
UA BOS-EWR MAY 9>0.8[9] JUN 10>9[10]
UA BOS-IAD MAY 4>1.1[4]
UA BOS-IAH MAY 4>0.9[5]
UA BOS-LAX MAY 1.7>0[2]
UA BOS-ORD MAY 7>2[8]
UA BOS-SFO MAY 5>0.9[6]
UA BQN-EWR MAY 0.4>0[1.0]
UA BRO-IAH MAY 4>1.5[4]
UA BTR-IAH MAY 6>1.9[7]
UA BTV-EWR MAY 3>0[4]
UA BTV-IAD MAY 3>1.0[2]
UA BTV-ORD MAY 4>1.9[4]
UA BUF-EWR MAY 4>0[6]
UA BUF-IAD MAY 4>1.1[4]
UA BUF-ORD MAY 4>2.0[4]
UA BUR-DEN MAY 1.9>1.0[2]
UA BUR-SFO MAY 5>1.5[6]
UA BWI-DEN MAY 1.9>0.1[2]
UA BWI-IAH MAY 2>0.1[2]
UA BWI-ORD MAY 4>1.9[3]
UA BZN-DEN MAY 4>2.0[4]
UA BZN-LAX MAY 0.9>0[1.0]
UA BZN-SFO MAY 1.0>0[1.0]
UA CAE-IAD MAY 3>1.0[3]
UA CAE-ORD MAY 3>0.8[3]
UA CAK-IAD MAY 3>0[0]
UA CAK-ORD MAY 4>1.1[3]
UA CGI-PAH MAY 0>1.4[1.9]
UA CHA-ORD MAY 3>0.6[1.9]
UA CHO-IAD MAY 2>1.0[3]
UA CHO-ORD MAY 1.9>0.1[2]
UA CHS-DEN MAY 0.9>0[0]
UA CHS-EWR MAY 4>0[5]
UA CHS-IAD MAY 4>1.1[4]
UA CHS-IAH MAY 3>1.0[3]
UA CHS-MYR MAY 0>0.5[0]
UA CHS-ORD MAY 3>0.5[3]
UA CID-DEN MAY 3>0.1[2]
UA CID-ORD MAY 6>2[5]
UA CLE-DEN MAY 3>0.1[3]
UA CLE-EWR MAY 6>0.8[6]
UA CLE-FLL MAY 0.3>0[0]
UA CLE-IAD MAY 4>1.1[4]
UA CLE-IAH MAY 4>0.2[5]
UA CLE-LAX MAY 1.6>0[1.0]
UA CLE-MCO MAY 1.0>0[1.0]
UA CLE-ORD MAY 7>2.0[8]
UA CLE-RSW MAY 0.3>0[0]
UA CLE-SFO MAY 1.6>0[1.9]
UA CLL-IAH MAY 3>0.5[3]
UA CLT-DEN MAY 1.9>0.1[2]
UA CLT-EWR MAY 4>0.4[5]
UA CLT-IAD MAY 4>1.0[4]
UA CLT-IAH MAY 4>1.9[5]
UA CLT-ORD MAY 5>1.1[5]
UA CMH-DEN MAY 1.9>0.1[2]
UA CMH-EWR MAY 7>0.4[7]
UA CMH-IAD MAY 4>1.1[4]
UA CMH-IAH MAY 4>0.2[4]
UA CMH-ORD MAY 6>2[7]
UA CMX-DLH MAY 0>0.5[0]
UA CMX-EAU MAY 0>0.9[0]
UA CMX-ORD MAY 2>0.6[2]
UA CNY-VEL MAY 0>0.9[0]
UA COD-DEN MAY 3>1.0[2]
UA COS-DEN MAY 8>2[9]
UA COS-IAH MAY 3>0.1[3]
UA COS-LAX MAY 2>0[2]
UA COS-ORD MAY 3>0.1[3]
UA COU-DEN MAY 1.0>0.1[1.0]
UA COU-ORD MAY 3>1.0[3]
UA CPR-DEN MAY 4>2.0[4]
UA CRP-IAH MAY 6>2[6]
UA CRW-ORD MAY 3>0.5[3]
UA CVG-DEN MAY 1.9>0.1[2]
UA CVG-EWR MAY 5>0[5]
UA CVG-IAD MAY 4>1.0[3]
UA CVG-IAH MAY 4>0.1[5]
UA CVG-ORD MAY 6>2.0[7]
UA CWA-ORD MAY 3>1.0[3]
UA DAY-DEN MAY 1.8>0.1[2]
UA DAY-IAD MAY 3>1.0[2]
UA DAY-ORD MAY 5>2[6]
UA DCA-EWR MAY 11>0.8[8] JUN 12>11[7]
UA DCA-IAH MAY 7>1.9[8]
UA DCA-ORD MAY 13>2[14] JUN 14>13[14]
UA DCA-SFO MAY 1.0>0.1[1.0]
UA DDC-HYS MAY 0>0.3[0]
UA DEC-ORD MAY 1.8>1.4[0]
UA DEC-SPI MAY 0>0.3[0]
UA DEN-DFW MAY 5>2.0[5]
UA DEN-DIK MAY 1.7>1.0[1.7]
UA DEN-DRO MAY 7>2[6]
UA DEN-DSM MAY 5>2.0[5]
UA DEN-DTW MAY 1.9>0.1[2]
UA DEN-EAR MAY 1.8>0.8[1.7]
UA DEN-EGE MAY 1.6>1.0[2]
UA DEN-ELP MAY 4>0.2[4]
UA DEN-EUG MAY 3>2.0[2]
UA DEN-EWR MAY 7>1.9[8]
UA DEN-FAR MAY 4>2[4]
UA DEN-FAT MAY 4>2.0[3]
UA DEN-FCA MAY 3>1.0[3]
UA DEN-FLG MAY 1.9>1.0[2]
UA DEN-FLL MAY 1.9>0.1[2]
UA DEN-FSD MAY 4>2.0[4]
UA DEN-GCC MAY 2>0.7[2]
UA DEN-GEG MAY 3>1.0[2]
UA DEN-GJT MAY 5>1.1[5]
UA DEN-GRR MAY 1.8>0[2]
UA DEN-GSP MAY 1.0>0.1[0]
UA DEN-GTF MAY 1.9>0.1[2]
UA DEN-GUC MAY 1.0>0.5[1.0]
UA DEN-HDN MAY 1.9>0.7[1.7]
UA DEN-HLN MAY 1.9>1.0[2]
UA DEN-HNL MAY 0.9>0[1.0]
UA DEN-HOB MAY 0.8>0[0]
UA DEN-HSV MAY 1.9>0.1[2]
UA DEN-HYS MAY 1.8>1.4[1.7]
UA DEN-IAD MAY 6>2[7]
UA DEN-IAH MAY 9>3[11]
UA DEN-ICT MAY 5>2[4]
UA DEN-IDA MAY 4>2[3]
UA DEN-IND MAY 3>0.2[3]
UA DEN-JAC MAY 3>2[2]
UA DEN-JAX MAY 0.9>0[1.0]
UA DEN-KOA MAY 0.9>0[1.0]
UA DEN-LAS MAY 5>2[6]
UA DEN-LAX MAY 8>2.0[7]
UA DEN-LBB MAY 1.9>0.1[2]
UA DEN-LBL MAY 1.7>0.8[0.9]
UA DEN-LGA MAY 5>0[7]
**UA DEN-LHR JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[0.8]
UA DEN-LIH MAY 0.9>0[1.0]
UA DEN-LIT MAY 3>0.2[3]
UA DEN-LNK MAY 3>1.0[3]
UA DEN-MAF MAY 4>1.7[4]
UA DEN-MCI MAY 4>2[5]
UA DEN-MCO MAY 4>1.0[4]
UA DEN-MEM MAY 2>0.1[3]
UA DEN-MFR MAY 3>1.1[3]
UA DEN-MKE MAY 3>1.0[3]
UA DEN-MLI MAY 1.9>0.1[2]
UA DEN-MOT MAY 1.9>0.6[2]
UA DEN-MRY MAY 1.8>0.1[2]
UA DEN-MSN MAY 2>1.0[3]
UA DEN-MSO MAY 1.9>1.0[3]
UA DEN-MSP MAY 4>0.1[4]
UA DEN-MSY MAY 2>0.1[3]
UA DEN-MTJ MAY 4>2.0[3]
UA DEN-OGG MAY 0.9>0[1.0]
UA DEN-OKC MAY 5>1.1[5]
UA DEN-OMA MAY 5>2.0[4]
UA DEN-ONT MAY 3>1.0[2]
UA DEN-ORD MAY 9>3[10]
UA DEN-ORF MAY 0.9>0[1.0]
UA DEN-PAE MAY 2>0.1[2]
UA DEN-PDX MAY 4>1.9[5]
UA DEN-PHL MAY 1.9>0.1[2]
UA DEN-PHX MAY 5>2.0[5]
UA DEN-PIR MAY 1.8>0.8[1.9]
UA DEN-PIT MAY 1.9>0.1[3]
UA DEN-PRC MAY 1.4>1.0[1.0]
UA DEN-PSC MAY 1.9>0.7[3]
UA DEN-PSP MAY 3>1.9[3]
UA DEN-RAP MAY 6>2[6]
UA DEN-RDM MAY 3>1.0[2]
UA DEN-RDU MAY 1.9>0.1[2]
UA DEN-RIC MAY 1.8>0[2]
UA DEN-RIW MAY 1.8>0.1[0]
UA DEN-RKS MAY 1.9>0.7[2]
UA DEN-RNO MAY 3>2[3]
UA DEN-RSW MAY 1.0>0.1[1.1]
UA DEN-SAF MAY 3>1.0[3]
UA DEN-SAN MAY 4>1.9[5]
UA DEN-SAT MAY 3>0.2[4]
UA DEN-SAV MAY 1.0>0.1[0]
UA DEN-SBA MAY 3>0.6[3]
UA DEN-SBP MAY 3>1.1[2]
UA DEN-SDF MAY 1.9>0.1[2]
UA DEN-SEA MAY 4>1.9[5]
UA DEN-SFO MAY 9>3[10]
UA DEN-SGF MAY 4>2[3]
UA DEN-SGU MAY 2.0>0.7[3]
UA DEN-SHR MAY 0.9>0.1[0]
UA DEN-SHV MAY 0.9>0[1.0]
UA DEN-SJC MAY 4>2[4]
UA DEN-SLC MAY 6>2.0[6]
UA DEN-SLN MAY 1.0>0.1[0]
UA DEN-SMF MAY 4>2.0[4]
UA DEN-SNA MAY 4>2[4]
UA DEN-STL MAY 5>0.2[5]
UA DEN-STS MAY 0.9>0[1.0]
UA DEN-SUN JUN 0.4>0.2[0.4]
UA DEN-SYR MAY 0.9>0[0]
UA DEN-TPA MAY 3>0.1[3]
UA DEN-TUL MAY 4>0.1[5]
UA DEN-TUS MAY 5>2[4]
UA DEN-TYS MAY 1.9>0.1[2]
UA DEN-VEL MAY 1.7>0.8[1.7]
UA DEN-XNA MAY 2>0.2[3]
UA DEN-XWA MAY 3>1.0[0]
UA DEN-YEG MAY 1.8>0[2]
UA DEN-YVR MAY 1.9>0[2]
UA DEN-YWG MAY 1.7>0[1.9]
UA DEN-YYC MAY 3>0[3]
UA DEN-YYZ MAY 1.8>0[2]
UA DFW-EWR MAY 5>0.4[5]
UA DFW-IAD MAY 3>1.0[3]
UA DFW-IAH MAY 7>2[8]
UA DFW-ORD MAY 6>1.9[7]
UA DFW-SFO MAY 3>0[4]
UA DLH-ORD MAY 3>0.6[3]
UA DSM-IAH MAY 3>0.1[3]
UA DSM-ORD MAY 5>2.0[6]
UA DTW-EWR MAY 5>0.4[6]
UA DTW-IAD MAY 4>1.1[4]
UA DTW-IAH MAY 5>0.2[5]
UA DTW-ORD MAY 6>2[6]
UA EAR-LBF MAY 0>0.9[0]
UA ECP-IAH MAY 1.9>1.0[3]
**UA EDI-EWR JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA ELP-IAH MAY 5>1.9[5]
UA ELP-ORD MAY 1.0>0.1[2]
UA ERI-ORD MAY 1.9>0.5[2.0]
UA EUG-LAX MAY 1.3>0[2]
UA EUG-SFO MAY 4>1.6[4]
UA EVV-ORD MAY 3>0.5[3]
UA EWR-EYW MAY 1.8>0[1.0]
UA EWR-FLL MAY 7>0.8[8]
UA EWR-GRR MAY 2>0[1.9]
UA EWR-GSO MAY 4>0[4]
UA EWR-GSP MAY 3>0[3]
UA EWR-HNL MAY 0.9>0[1.0]
UA EWR-IAD MAY 6>2[6]
UA EWR-IAH MAY 8>2.0[9]
UA EWR-IND MAY 7>0.4[7]
UA EWR-JAX MAY 4>0[5]
UA EWR-LAS MAY 7>0[8] JUN 6>5[7]
UA EWR-LAX MAY 10>3[11] JUN 11>10[11]
**UA EWR-LIM JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0.1[0.9]
**UA EWR-LIS JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
**UA EWR-MAD JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA EWR-MCI MAY 4>0[4]
UA EWR-MCO MAY 11>0.8[11] JUN 9>8[9]
UA EWR-MEM MAY 3>0[4]
UA EWR-MIA MAY 7>0.8[6]
UA EWR-MKE MAY 3>0[3]
UA EWR-MSN MAY 1.7>0[2.0]
UA EWR-MSP MAY 4>0[5]
UA EWR-MSY MAY 5>0[6]
UA EWR-MYR MAY 1.7>0[1.3]
**UA EWR-NAP JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.9>0[1.0] OCT 0.5>0[0.6]
UA EWR-OKC MAY 0.8>0[1.0]
**UA EWR-OPO JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
UA EWR-ORD MAY 9>2[10] JUN 11>10[10]
UA EWR-ORF MAY 5>0[5]
UA EWR-PBI MAY 7>0.7[6]
UA EWR-PHX MAY 4>0[3]
UA EWR-PIT MAY 8>0.8[7] JUN 7>6[7]
UA EWR-PQI MAY 1.5>0[1.7]
UA EWR-PVD MAY 3>0[3]
UA EWR-PWM MAY 4>0.4[4]
UA EWR-RDU MAY 8>0.8[9]
UA EWR-RIC MAY 5>0.4[6]
UA EWR-ROC MAY 4>0[4]
UA EWR-RSW MAY 4>0.8[4]
UA EWR-SAN MAY 3>0[3]
UA EWR-SAT MAY 1.8>0[1.9]
UA EWR-SAV MAY 3>0[4]
UA EWR-SDF MAY 3>0[3]
UA EWR-SFO MAY 12>3[14] JUN 14>13[14]
UA EWR-SJU MAY 0.8>0[1.3]
UA EWR-SNA MAY 3>0[3]
UA EWR-SRQ MAY 1.8>0[1.9]
UA EWR-STL MAY 5>0.4[5]
UA EWR-SYR MAY 3>0[4]
UA EWR-TPA MAY 6>0.8[6]
**UA EWR-VCE JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
UA EWR-YHZ MAY 1.8>0[3]
UA EWR-YQB MAY 3>0[3]
UA EWR-YUL MAY 3>0[3]
UA EWR-YYZ MAY 4>0[4]
UA EYW-ORD MAY 0.4>0.1[1.0]
UA EYW-RSW MAY 0>0.9[0]
UA FAI-ORD MAY 0.8>0[1.0]
UA FAR-ORD MAY 3>0.1[4]
UA FAT-LAX MAY 3>0[3]
UA FAT-SFO MAY 4>1.9[4]
UA FLL-IAD MAY 3>1.0[2]
UA FLL-IAH MAY 5>1.0[5]
UA FLL-ORD MAY 3>1.0[3]
UA FNT-ORD MAY 3>1.0[4]
UA FSD-ORD MAY 4>1.9[4]
UA FWA-ORD MAY 3>1.0[3]
UA GCC-SHR MAY 0>0.7[0]
UA GEG-SFO MAY 1.8>0[2]
UA GJT-MTJ MAY 0>0.9[0]
UA GPT-IAH MAY 3>1.9[3]
UA GRB-ORD MAY 5>0.8[5]
UA GRK-IAH MAY 3>0.5[3]
UA GRR-ORD MAY 7>2[6]
UA GSO-IAD MAY 3>1.0[3]
UA GSO-ORD MAY 4>1.0[3]
UA GSP-IAD MAY 3>1.1[3]
UA GSP-IAH MAY 1.9>1.0[1.8]
UA GSP-ORD MAY 3>1.9[4]
UA GTF-HLN MAY 0>0.9[0]
**UA GUC-IAH JUN 0.4>0[0.9] JUL 1.0>0[1.0] AUG 0.5>0[0.6]
UA HHH-IAD MAY 1.3>0.1[2]
UA HHH-SAV MAY 0>0.9[0]
UA HNL-IAD MAY 0.5>0[0.4]
UA HNL-IAH MAY 0.9>0[1.0]
UA HNL-LAX MAY 4>0[4]
UA HNL-ORD MAY 0.9>0[1.0]
UA HNL-SFO MAY 4>1.0[4]
UA HOB-IAH MAY 1.7>0.4[1.9]
UA HPN-ORD MAY 3>0[3]
UA HRL-IAH MAY 4>1.4[5]
UA HSV-IAD MAY 1.8>1.0[2.0]
UA HSV-IAH MAY 3>1.9[3]
UA HSV-ORD MAY 1.9>0.1[1.9]
UA HYS-SLN MAY 0>0.9[1.7]
UA IAD-IAH MAY 4>3[5]
UA IAD-ILM MAY 3>1.0[1.9]
UA IAD-IND MAY 4>1.2[4]
UA IAD-ITH MAY 3>1.0[3]
UA IAD-JAX MAY 3>1.0[3]
UA IAD-LAS MAY 1.8>0[2.0]
UA IAD-LAX MAY 6>1.1[6]
UA IAD-LEX MAY 1.9>0.1[2]
UA IAD-LGA MAY 3>0.9[4]
**UA IAD-LIS JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
UA IAD-MCI MAY 3>0.1[2]
UA IAD-MCO MAY 5>1.1[5]
UA IAD-MDT MAY 3>1.0[4]
UA IAD-MHT MAY 3>0.1[2]
UA IAD-MIA MAY 1.1>0.1[0]
UA IAD-MSN MAY 1.5>0[0]
UA IAD-MSP MAY 1.9>0.0[2]
UA IAD-MSY MAY 3>0.9[3]
UA IAD-OKC MAY 1.8>0.1[1.0]
UA IAD-ORD MAY 5>3[5]
UA IAD-ORF MAY 4>1.1[4]
UA IAD-PBI MAY 1.0>0.6[0]
UA IAD-PHL MAY 3>0.8[0]
UA IAD-PHX MAY 1.8>0[1.0]
UA IAD-PIT MAY 4>1.1[4]
UA IAD-PQI MAY 0.1>1.0[0]
UA IAD-PVD MAY 3>0.1[3]
UA IAD-PWM MAY 3>1.0[3]
UA IAD-RDU MAY 4>1.0[4]
UA IAD-RIC MAY 4>1.0[4]
UA IAD-ROA MAY 4>1.0[2]
UA IAD-ROC MAY 4>1.1[3]
UA IAD-RSW MAY 2>1.1[0]
UA IAD-SAN MAY 3>0.9[3]
UA IAD-SAT MAY 1.8>0[2]
UA IAD-SAV MAY 3>1.0[3]
UA IAD-SCE MAY 3>0.9[3]
UA IAD-SDF MAY 3>1.0[2]
UA IAD-SEA MAY 3>0[3]
UA IAD-SFO MAY 7>1.1[8]
UA IAD-SHD MAY 1.9>0.7[1.0]
UA IAD-SRQ MAY 1.0>0.1[0]
UA IAD-STL MAY 3>0.2[3]
UA IAD-STT MAY 0.9>0[0.1]
UA IAD-SYR MAY 3>1.1[4]
UA IAD-TPA MAY 3>1.0[3]
UA IAD-TYS MAY 3>1.0[3]
UA IAD-YOW MAY 3>0[3]
UA IAD-YUL MAY 3>0[3]
UA IAD-YYZ MAY 4>0[4]
UA IAH-ICT MAY 4>1.6[4]
UA IAH-IND MAY 4>0.1[5]
UA IAH-JAN MAY 5>1.9[5]
UA IAH-JAX MAY 4>1.5[4]
UA IAH-LAS MAY 6>1.0[6]
UA IAH-LAX MAY 8>2[8]
UA IAH-LBB MAY 4>2.0[4]
UA IAH-LCH MAY 3>2[3]
UA IAH-LFT MAY 6>2[6]
UA IAH-LGA MAY 7>0.9[8]
**UA IAH-LHR JUN 1.8>0[2] JUL 2>0[2] AUG 2>0[2] SEP 2>0[2] OCT 2>0.5[2]
UA IAH-LIT MAY 5>1.9[6]
UA IAH-LRD MAY 3>1.4[3]
UA IAH-MAF MAY 6>2[7]
UA IAH-MCI MAY 5>2[5]
UA IAH-MCO MAY 6>1.9[7]
UA IAH-MEM MAY 5>2[5]
UA IAH-MFE MAY 6>2[6]
UA IAH-MIA MAY 4>1.0[5]
UA IAH-MKE MAY 2>0.1[1.9]
UA IAH-MLU MAY 1.9>0.5[1.8]
UA IAH-MOB MAY 5>2[5]
UA IAH-MOT MAY 0.3>0[0.2]
UA IAH-MSP MAY 5>0.2[5]
UA IAH-MSY MAY 7>2[7]
UA IAH-OKC MAY 7>2.0[8]
UA IAH-OMA MAY 4>0.1[3]
UA IAH-ORD MAY 9>4[9]
UA IAH-ORF MAY 1.7>0[1.9]
UA IAH-PBI MAY 1.0>0.1[1.0]
UA IAH-PDX MAY 1.8>0[3]
UA IAH-PHL MAY 4>0.1[5]
UA IAH-PHX MAY 5>1.0[5]
UA IAH-PIT MAY 5>0.1[5]
UA IAH-PNS MAY 5>2.0[6]
UA IAH-RDU MAY 5>1.1[4]
UA IAH-RIC MAY 2>0[1.8]
UA IAH-RSW MAY 3>1.0[2]
UA IAH-SAN MAY 4>1.0[5]
UA IAH-SAT MAY 7>2[8]
UA IAH-SAV MAY 2>1.0[2]
**UA IAH-SCL JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA IAH-SDF MAY 3>0.1[4]
UA IAH-SEA MAY 4>0[5]
UA IAH-SFO MAY 8>3[8]
UA IAH-SGF MAY 1.9>0.1[2]
UA IAH-SHV MAY 4>2.0[4]
UA IAH-SJO MAY 0.4>0.2[2]
UA IAH-SLC MAY 5>0.1[4]
UA IAH-SMF MAY 3>0[2]
UA IAH-SNA MAY 3>0.9[4]
UA IAH-STL MAY 4>0.0[5]
UA IAH-TPA MAY 4>1.0[5]
UA IAH-TUL MAY 7>2[7]
UA IAH-TUS MAY 4>1.0[3]
UA IAH-TYS MAY 3>1.0[4]
UA IAH-VPS MAY 3>0.5[3]
UA IAH-XNA MAY 4>2.0[5]
UA IAH-YYC MAY 1.6>0[1.9]
UA IAH-YYZ MAY 1.7>0[3]
UA ICT-ORD MAY 4>2[4]
UA IND-ORD MAY 9>2[8]
UA ITO-LAX MAY 0.8>0[0.7]
UA JAX-ORD MAY 3>1.1[3]
UA KOA-LAX MAY 1.5>0[2]
UA KOA-LIH MAY 0>0.3[0]
UA KOA-SFO MAY 3>0.3[3]
UA LAN-ORD MAY 3>0.5[3]
UA LAS-LAX MAY 4>0.0[5]
UA LAS-ORD MAY 5>1.0[5]
UA LAS-SFO MAY 8>1.9[9]
UA LAX-LIH MAY 1.0>0[1.1]
UA LAX-MCO MAY 1.8>0[1.7]
UA LAX-MFR MAY 1.5>0[1.7]
UA LAX-MMH JUN 0.9>0.1[1.0]
UA LAX-MRY MAY 3>0[4]
UA LAX-OGG MAY 1.9>0[2]
UA LAX-ORD MAY 8>2[10]
UA LAX-PHX MAY 1.9>0[3]
UA LAX-PRC MAY 0.9>0[1.0]
UA LAX-PSP MAY 0.9>0[1.0]
UA LAX-RDD MAY 1.0>0[1.0]
UA LAX-RDM MAY 0.9>0[1.0]
UA LAX-RNO MAY 2>0[3]
UA LAX-SAN MAY 3>0[5]
UA LAX-SBA MAY 3>0[3]
UA LAX-SBP MAY 3>0[3]
UA LAX-SEA MAY 1.7>0[2]
UA LAX-SFO MAY 11>2[11] JUN 11>10[11]
UA LAX-SLC MAY 1.8>0[2]
UA LAX-SMF MAY 3>0[3]
UA LAX-SUN JUN 0.4>0.2[0.4]
UA LAX-YVR MAY 0.9>0[1.0]
UA LEX-ORD MAY 4>1.9[4]
UA LGA-ORD MAY 13>2[16] JUN 14>13[15]
UA LIH-SFO MAY 1.8>0.3[2]
UA LIT-ORD MAY 3>0.0[3]
UA LNK-ORD MAY 4>2[4]
UA LWB-ORD MAY 1.3>1.0[1.0]
UA MBS-MKG MAY 0>0.3[0]
UA MBS-ORD MAY 3>0.4[3]
UA MCI-ORD MAY 6>1.9[6]
UA MCO-ORD MAY 5>1.1[6]
UA MCO-SFO MAY 3>0[3]
UA MDT-ORD MAY 4>1.9[4]
UA MEM-ORD MAY 4>0.2[4]
UA MFR-SFO MAY 4>1.6[4]
UA MIA-ORD MAY 2>0.2[2]
UA MKE-ORD MAY 9>2[8]
UA MLI-ORD MAY 4>2[4]
UA MRY-SFO MAY 1.8>0.9[2]
UA MSN-ORD MAY 7>2[7]
UA MSP-ORD MAY 8>2.0[7]
UA MSP-SFO MAY 1.6>0[1.9]
UA MSY-ORD MAY 3>0.1[3]
UA MYR-ORD MAY 0>0.5[0.3]
UA OGG-ORD MAY 0.2>0[0.1]
UA OGG-SFO MAY 3>0.6[4]
UA OKC-ORD MAY 3>0.2[3]
UA OKC-SFO MAY 0.9>0[1.0]
UA OMA-ORD MAY 5>2[5]
UA ONT-SFO MAY 4>1.0[5]
UA ORD-ORF MAY 3>2.0[3]
UA ORD-PAH MAY 2>0.6[1.9]
UA ORD-PDX MAY 3>0.1[3]
UA ORD-PHL MAY 5>2.0[6]
UA ORD-PHX MAY 5>1.0[5]
UA ORD-PIA MAY 5>1.8[5]
UA ORD-PIT MAY 5>2[6]
UA ORD-PNS MAY 1.8>0.1[2]
UA ORD-PVD MAY 2>0.1[3]
UA ORD-PWM MAY 3>1.0[3]
UA ORD-RAP MAY 1.5>0[1.2]
UA ORD-RDU MAY 5>2.0[5]
UA ORD-RIC MAY 5>2.0[4]
UA ORD-ROA MAY 3>2.0[3]
UA ORD-ROC MAY 4>1.9[4]
UA ORD-RST MAY 3>1.0[3]
UA ORD-RSW MAY 2>1.0[2]
UA ORD-SAN MAY 4>1.0[4]
UA ORD-SAT MAY 3>1.0[4]
UA ORD-SAV MAY 3>0.1[3]
UA ORD-SBN MAY 6>1.8[4]
UA ORD-SCE MAY 3>1.1[3]
UA ORD-SDF MAY 6>2[6]
UA ORD-SEA MAY 4>0.1[4]
UA ORD-SFO MAY 9>3[10]
UA ORD-SGF MAY 4>0.1[4]
UA ORD-SLC MAY 3>0.1[3]
UA ORD-SLN MAY 1.0>0.7[0.9]
UA ORD-SMF MAY 1.8>0[3]
UA ORD-SNA MAY 3>0.1[3]
UA ORD-SPI MAY 3>0.4[3]
UA ORD-SRQ MAY 1.9>1.0[2]
UA ORD-STL MAY 8>2[9]
UA ORD-SYR MAY 4>1.9[4]
UA ORD-TPA MAY 3>1.0[3]
UA ORD-TUL MAY 4>0.2[4]
UA ORD-TUS MAY 1.0>0.1[1.0]
UA ORD-TVC MAY 3>1.9[4]
UA ORD-TYS MAY 5>2[5]
UA ORD-XNA MAY 4>0.1[4]
UA ORD-YQB MAY 0.8>0[2]
UA ORD-YUL MAY 3>0[3]
UA ORD-YVR MAY 0.9>0[3]
UA ORD-YWG MAY 1.7>0[2]
UA ORD-YYC MAY 1.8>0[3]
UA ORD-YYZ MAY 6>0[7]
UA OTH-SFO MAY 1.0>0.6[1.0]
UA PDX-SFO MAY 6>1.9[7]
UA PHX-SFO MAY 4>1.0[4]
UA PSC-SFO MAY 1.7>0.0[1.0]
UA PSP-SFO MAY 4>1.0[5]
UA RDD-SFO MAY 3>1.0[3]
UA RDM-SFO MAY 3>1.5[5]
UA RIW-RKS MAY 0>0.7[0]
UA RNO-SFO MAY 4>1.9[5]
UA SAN-SFO MAY 8>1.9[8]
UA SBA-SFO MAY 5>1.6[6]
UA SBP-SFO MAY 3>1.6[4]
UA SEA-SFO MAY 6>1.9[8]
UA SFO-SLC MAY 5>1.0[4]
UA SFO-SMF MAY 4>1.0[5]
UA SFO-SNA MAY 6>2[7]
UA SFO-STS MAY 1.0>0.5[1.0]
UA SFO-TUS MAY 4>1.9[4]
UA SFO-YVR MAY 4>0[4]
UA SFO-YYC MAY 1.8>0[1.9]
VH CTG-MIA MAY 0.2>0[0] JUN 0.8>0[0] JUL 1.0>0[0] AUG 0.8>0[0]
VH MDE-MIA MAY 1.0>0[0.3]
VS ATL-LHR MAY 0.7>0.5[1.0]
VS ATL-MAN MAY 0.7>0.5[1.0]
VS BOS-LHR MAY 1.3>0.9[2]
VS IAD-LHR MAY 0.7>0.5[1.0]
VS JFK-LHR MAY 4>2[6]
VS JFK-MAN MAY 0.7>0.5[1.0]
VS LAS-LHR MAY 0.7>0.5[1.0]
VS LAX-LHR MAY 2.0>1.4[2]
VS LGW-MCO MAY 1.2>0.8[1.9]
VS LHR-MIA MAY 0.7>0.5[1.0]
VS LHR-SEA MAY 1.1>0.7[1.0]
VS LHR-SFO MAY 1.4>0.9[1.8]
VS MAN-MCO MAY 1.2>0.8[1.6]
**VW LRD-MEX JUL 0>0.4[0] AUG 0>0.5[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
VW MEX-MFE MAY 0.7>0.1[0.7]
My asterick button ran out of ink
WN ABQ-AUS JUL 1.0>0[0.5] AUG 1.1>0.8[1.2]
WN ABQ-BWI JUL 2>1.0[2.0]
WN ABQ-DAL JUL 5>3[5]
WN ABQ-HOU JUN 0.3>0[3] JUL 2>0[3] AUG 3>1.9[3]
WN ABQ-LAS JUL 4>2[3]
WN ABQ-LAX JUL 3>1.0[2]
WN ABQ-MCI JUL 0.9>0[1.0] AUG 0.8>0.6[0.9]
WN ABQ-MDW JUL 1.6>1.0[1.4]
WN ABQ-SAN JUL 1.9>0[2] AUG 1.4>0.8[1.9]
WN ALB-BWI MAY 2>1.5[4]
WN ALB-DEN MAY 1.0>0.7[0.9]
WN ALB-MCO JUL 1.1>0[1.1] AUG 1.1>0.8[1.2]
WN ALB-TPA JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN AMA-DAL JUL 4>3[4]
WN AMA-HOU JUL 0.9>0[0] AUG 0.8>0.6[0]
WN AMA-LAS JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN ATL-AUS JUN 1.2>1.5[2] JUL 3>1.9[2]
WN ATL-BNA JUL 4>1.7[4]
WN ATL-BWI JUL 6>4[6] AUG 7>6[7]
WN ATL-CHS JUL 1.0>0[0] AUG 0.3>0[0]
WN ATL-CLE JUL 1.4>0[1.8] AUG 1.6>1.2[1.8]
WN ATL-CMH JUL 3>1.8[3]
WN ATL-CUN JUL 0.7>0[1.1] AUG 0.3>0[0.7]
WN ATL-DAL JUL 6>4[5]
WN ATL-DCA JUL 4>3[4]
WN ATL-DEN JUL 4>3[5]
WN ATL-ECP JUL 1.0>0[0] AUG 0.3>0[0]
WN ATL-FLL JUL 5>3[4]
WN ATL-HOU JUL 6>4[6]
WN ATL-IAD JUL 3>2[2.0]
WN ATL-LAS JUL 2>1.9[2]
WN ATL-LAX JUL 3>1.8[2]
WN ATL-LGA JUL 5>3[5]
WN ATL-MCI JUL 3>1.0[4]
WN ATL-MCO JUL 5>3[5] AUG 6>5[5]
WN ATL-MDW JUL 6>3[5] AUG 7>5[6]
WN ATL-MKE JUN 0.2>0[1.6] JUL 2>0[1.5] AUG 1.9>1.3[2]
WN ATL-MSY JUN 1.9>2[4]
WN ATL-ORF JUL 1.0>0[0] AUG 0.3>0[0]
WN ATL-PBI JUL 1.1>0[1.7] AUG 1.2>0.8[1.1]
WN ATL-PHL JUL 3>1.9[2.0]
WN ATL-PHX JUL 2>1.0[2]
WN ATL-PIT JUL 1.9>1.0[2]
WN ATL-PUJ JUL 0.5>0[1.1] AUG 0.2>0[0.8]
WN ATL-RSW JUL 1.9>1.0[1.7]
WN ATL-SAN JUL 1.1>0[1.0] AUG 1.1>0.8[1.0]
WN ATL-SAT JUN 0.2>0[1.9] JUL 2>0[2] AUG 2>1.4[1.9]
WN ATL-STL JUL 4>2[4]
WN ATL-TPA JUL 5>3[6]
WN AUA-BWI JUL 1.3>0[1.3] AUG 0.7>0.3[0.5]
WN AUA-FLL JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN AUS-BNA JUL 4>3[3]
WN AUS-BOS JUL 1.0>0[0.9] AUG 0.4>0.1[1.0]
WN AUS-BWI JUL 2>1.9[3]
WN AUS-CUN JUL 1.1>0[1.0] AUG 0.4>0[0.2]
WN AUS-DAL JUL 9>5[9] AUG 9>8[9]
WN AUS-DEN JUL 5>4[6]
WN AUS-ECP JUL 0.3>0[0.3]
WN AUS-ELP JUN 0.3>0[3] JUL 2>0[3] AUG 3>1.8[3]
WN AUS-FLL JUL 1.9>0[2.0] AUG 1.3>0.7[1.3]
WN AUS-HOU JUL 5>3[5]
WN AUS-HRL JUL 0.9>0[1.0] AUG 0.8>0.6[0.9]
WN AUS-LAS JUL 4>1.9[4]
WN AUS-LAX JUL 3>1.0[1.7]
WN AUS-LBB JUL 1.0>0[1.0] AUG 0.9>0.6[0.9]
WN AUS-MCI JUL 1.1>0[1.0] AUG 1.0>0.7[0.9]
WN AUS-MCO JUL 3>1.8[3]
WN AUS-MSY JUL 2>1.0[3]
WN AUS-OAK JUL 0.3>1.0[1.3] AUG 0.7>0.9[0.9]
WN AUS-RDU JUL 0.3>0[1.0]
WN AUS-SAN JUN 0.3>0.1[3] JUL 3>1.0[3]
WN AUS-SJC JUL 1.8>0[2] AUG 2>1.7[3]
WN AUS-SJD JUL 0.3>0[0.3]
WN AUS-SMF JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN AUS-STL JUL 3>2[1.8]
WN AUS-TPA JUN 0.2>0[1.4] JUL 1.9>0[1.5] AUG 1.3>0.7[1.2]
WN BDL-BWI JUN 1.6>2[6] JUL 5>3[5]
WN BDL-MCO JUL 1.6>2[3]
WN BDL-MDW JUL 3>1.0[3]
WN BDL-STL JUL 0.8>0[1.0] AUG 0.9>0.7[1.0]
WN BDL-TPA JUL 1.8>1.0[2.0]
WN BHM-BWI JUL 1.8>0[1.1] AUG 1.2>0.7[1.2]
WN BHM-HOU JUN 0.3>0[1.8] JUL 3>0[1.8] AUG 2>1.7[2]
WN BHM-MCO JUL 1.6>2[2.0]
WN BHM-MDW JUL 1.4>0[2.0] AUG 1.8>1.4[2.0]
WN BHM-TPA JUL 1.1>0[1.1] AUG 0.5>0.1[1.1]
WN BNA-BOS JUL 4>2[4]
WN BNA-BUF JUL 0.3>0[0]
WN BNA-BUR JUL 0.8>0[1.0] AUG 0.2>0[0.2]
WN BNA-CHS JUL 1.4>1.0[1.4]
WN BNA-CLE JUL 3>1.0[3]
WN BNA-CLT JUN 0.2>0[1.8] JUL 1.9>0[1.8] AUG 1.8>1.3[1.7]
WN BNA-CMH JUL 1.9>1.0[2]
WN BNA-DAL JUL 6>4[5]
WN BNA-DCA JUL 4>3[4]
WN BNA-DEN JUL 5>4[6]
WN BNA-ECP JUL 2>3[2]
WN BNA-FLL JUL 5>3[4]
WN BNA-HOU JUL 5>2[4] AUG 5>4[4]
WN BNA-JAX JUL 3>1.0[3] AUG 3>2[3]
WN BNA-LAS JUL 3>1.9[3]
WN BNA-LGA JUL 4>2[3]
WN BNA-MCI JUL 4>2[3]
WN BNA-MCO JUL 6>4[5]
WN BNA-MDW JUL 8>6[7]
WN BNA-MKE JUL 1.5>2[2.0]
WN BNA-MSP JUL 1.4>1.0[1.9]
WN BNA-MSY JUL 3>2[4]
WN BNA-OMA JUL 1.0>0[0.1] AUG 0.5>0.2[0.1]
WN BNA-ORF JUL 0.3>0[0.3]
WN BNA-PHL JUL 2>3[3]
WN BNA-PHX JUL 3>2[3]
WN BNA-PIT JUL 1.7>1.0[2]
WN BNA-RDU JUL 3>2[3]
WN BNA-SAN JUL 2>1.0[2]
WN BNA-SAT JUL 3>2[2.0]
WN BNA-SEA JUL 0.4>0[0.3] AUG 0.3>0.1[0.2]
WN BNA-TPA JUL 5>3[4] AUG 5>4[3]
WN BOI-DEN JUL 2>3[2]
WN BOI-GEG JUL 1.7>0[1.8] AUG 1.7>1.2[1.7]
WN BOI-LAS JUL 2>1.0[2]
WN BOI-OAK JUL 1.9>3[2.0]
WN BOI-PHX JUL 1.1>0[1.0] AUG 1.2>0.8[1.0]
WN BOI-SAN JUL 0.9>0[1.0] AUG 0.9>0.7[1.0]
WN BOI-SMF JUL 1.4>0[1.0] AUG 1.1>0.7[1.0]
WN BOS-BWI JUL 9>5[9] AUG 10>8[9]
WN BOS-CMH JUL 1.5>0[1.7] AUG 1.5>1.2[1.7]
WN BOS-DAL JUL 1.1>0[1.0] AUG 0.6>0.2[1.1]
WN BOS-HOU JUL 0.3>0[1.0]
WN BUF-BWI JUL 5>4[5]
WN BUF-DEN MAY 1.0>0.8[0]
WN BUF-LAS JUL 1.0>0[1.0] AUG 1.1>0.8[1.1]
WN BUF-MDW JUL 2>3[3]
WN BUF-PHX JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN BUF-TPA MAY 1.1>0.9[2.0]
WN BUR-DAL JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN BUR-LAS JUL 10>5[10] AUG 11>9[10]
WN BUR-MDW JUL 1.4>0[1.7] AUG 1.1>0.7[0.9]
WN BUR-OAK JUL 12>5[12] AUG 12>10[13]
WN BUR-PDX JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN BUR-PHX JUL 6>4[6]
WN BUR-SJC JUL 11>5[10] AUG 11>9[11]
WN BUR-SLC JUL 0.9>0[1.0] AUG 0.8>0.6[0.9]
WN BUR-SMF JUL 9>4[10] AUG 10>8[10]
WN BWI-CHS JUN 1.3>1.6[4] JUL 4>2[4]
WN BWI-CVG JUL 2>3[3]
WN BWI-DAL JUL 5>3[4]
WN BWI-DEN JUL 6>4[5]
WN BWI-DTW JUL 3>2[3]
WN BWI-ECP JUL 1.1>0[1.1] AUG 0.5>0.1[0.2]
WN BWI-FLL JUL 10>6[8] AUG 9>8[8]
WN BWI-GCM JUL 0.3>0[0.1]
WN BWI-GSP JUL 1.0>0[0] AUG 1.0>0.7[0]
WN BWI-HOU JUL 4>3[5]
WN BWI-ISP JUL 4>3[5]
WN BWI-JAX JUL 4>3[4]
WN BWI-LAX JUL 3>1.9[3]
WN BWI-MBJ JUL 2>1.0[2]
WN BWI-MCI JUN 1.3>1.0[3] JUL 4>1.0[3] AUG 3>2[3]
WN BWI-MCO JUL 11>7[9] AUG 11>10[9]
WN BWI-MDW JUL 8>6[7]
WN BWI-MEM JUN 0.2>0[1.3] JUL 1.9>0[1.1] AUG 1.7>1.2[1.1]
WN BWI-MHT JUL 6>3[6] AUG 6>5[6]
WN BWI-MKE JUL 3>2[3]
WN BWI-MSP JUN 0.2>0[1.9] JUL 2>0[2] AUG 3>1.8[2]
WN BWI-OKC JUL 0.7>1.0[1.0]
WN BWI-PIT JUN 1.1>1.5[3]
WN BWI-PNS JUL 1.0>0[0] AUG 0.4>0.1[0]
WN BWI-PUJ JUN 0.2>0[1.9] JUL 2>0[2] AUG 1.4>0.7[1.5]
WN BWI-PVD JUL 7>4[7] AUG 7>6[6]
WN BWI-PWM JUL 4>3[4]
WN BWI-RDU JUL 6>4[7]
WN BWI-ROC MAY 2>1.6[3]
WN BWI-SAN JUL 2>1.0[2]
WN BWI-SAT JUL 2>1.0[2]
WN BWI-SEA JUL 1.0>0[0.9] AUG 1.0>0.7[1.0]
WN BWI-SJU JUL 2.2>1.0[2.1] AUG 1.6>1.2[1.3]
WN BWI-TPA JUL 8>6[7]
WN BWI-TUL JUL 1.0>0[0] AUG 0.3>0[0]
WN BZE-FLL JUL 1.0>0[1.0] AUG 0.4>0.1[0.3]
WN BZE-HOU JUL 1.1>0[1.1] AUG 1.1>0.7[1.0]
WN CHS-DEN JUL 0.3>0[0.3]
WN CHS-HOU JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN CHS-MDW JUL 1.4>1.0[2]
WN CHS-STL JUL 0.3>0[0.3]
WN CLE-DEN JUL 1.6>2[1.7]
WN CLE-MKE JUL 0.9>0[1.6]
WN CLE-PHX JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN CLE-STL JUN 0.2>0.6[3] JUL 2>1.0[3]
WN CLT-DAL JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN CLT-HOU JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN CLT-MDW JUN 0.2>0[3] JUL 2>0[3] AUG 2>1.8[3]
WN CMH-DCA JUL 1.7>1.0[1.9]
WN CMH-DEN JUL 1.8>1.0[1.9]
WN CMH-FLL JUL 1.2>0[1.0] AUG 1.1>0.7[1.0]
WN CMH-HOU JUL 0.2>1.0[1.0] AUG 0.7>1.0[1.0]
WN CMH-MDW JUL 6>4[5]
WN CMH-PHX JUL 1.0>0[1.0] AUG 1.1>0.8[1.0]
WN CMH-STL JUL 1.9>1.0[1.9]
WN CMH-TPA JUL 2>1.0[2] AUG 2>1.7[2]
WN CRP-HOU JUL 4>2[4]
WN CUN-DEN JUL 1.3>1.0[1.3]
WN CUN-FLL JUN 0.2>0[2] JUL 2>0[2] AUG 1.3>0.7[1.2]
WN CUN-MDW JUL 1.3>0[1.3] AUG 1.2>0.8[1.2]
WN CUN-SAT JUL 1.0>0[1.0] AUG 0.3>0[0.2]
WN CUN-STL JUL 1.0>0[0.3] AUG 0.5>0.2[0.2]
WN CVG-DEN JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN CVG-MCO JUL 0.3>0[0.1]
WN CVG-MDW JUL 4>3[5]
WN CZM-HOU JUN 0.2>0[0] JUL 2>0[0] AUG 1.3>0.7[0]
WN DAL-DCA JUL 5>3[5]
WN DAL-DEN JUL 9>5[7] AUG 9>8[7]
WN DAL-DTW JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DAL-ELP JUL 4>3[4]
WN DAL-HOU JUL 19>10[19] AUG 18>16[18]
WN DAL-IND JUL 1.4>0[1.3] AUG 1.9>1.4[1.1]
WN DAL-JAX JUL 0.3>0[1.0]
WN DAL-LAS JUL 5>4[5]
WN DAL-LAX JUL 5>3[5]
WN DAL-LBB JUL 5>3[5]
WN DAL-LGA JUL 5>3[5]
WN DAL-MAF JUL 4>3[4]
WN DAL-MCI JUL 6>4[6]
WN DAL-MCO JUL 5>4[4]
WN DAL-MDW JUL 8>6[7]
WN DAL-MEM JUL 1.8>1.0[3]
WN DAL-MKE JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DAL-MSP JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DAL-MSY JUL 7>4[7] AUG 7>6[7]
WN DAL-OAK JUL 1.7>1.0[1.8]
WN DAL-ONT JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DAL-PDX JUL 1.0>0[1.0] AUG 0.5>0.2[1.0]
WN DAL-PHL JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DAL-PHX JUL 6>4[6] AUG 7>6[6]
WN DAL-RDU JUL 1.1>0[1.1] AUG 1.1>0.7[1.0]
WN DAL-SAN JUL 4>1.9[4]
WN DAL-SAT JUL 9>5[9] AUG 9>8[9]
WN DAL-SDF JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DAL-SEA JUL 1.0>0[1.0] AUG 0.5>0.2[1.0]
WN DAL-SJC JUN 0.2>0.6[1.7] JUL 2>1.0[1.7]
WN DAL-SLC JUL 1.1>0[1.0] AUG 1.2>0.8[1.0]
WN DAL-STL JUL 6>4[6]
WN DAL-TPA JUL 3>2[3]
WN DCA-FLL JUL 2>1.0[2]
WN DCA-HOU JUL 3>1.0[3] AUG 3>2[3]
WN DCA-MCI JUL 2>1.0[1.9]
WN DCA-MCO JUL 2>1.0[2]
WN DCA-MDW JUL 6>5[6]
WN DCA-MKE JUL 2>1.0[1.9]
WN DCA-MSY JUL 2>1.0[2]
WN DCA-STL JUL 4>3[4]
WN DCA-TPA JUL 2>1.0[2]
WN DEN-DTW JUL 1.5>1.0[1.8]
WN DEN-ELP JUL 1.0>0[1.0] AUG 0.9>0.6[1.0]
WN DEN-GRR JUL 1.0>2[1.0] AUG 1.0>1.3[1.0]
WN DEN-HOU JUL 7>6[7]
WN DEN-IAD JUL 3>2[3]
WN DEN-LAS JUL 10>7[9] AUG 10>9[9]
WN DEN-LAX JUL 7>6[7]
WN DEN-LBB JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DEN-LGB JUL 0.3>0[1.0]
WN DEN-MCI JUL 7>4[6] AUG 7>6[6]
WN DEN-MDW JUL 9>7[9]
WN DEN-MSP JUL 5>3[5]
WN DEN-OAK JUL 6>4[5]
WN DEN-ONT JUL 3>4[3]
WN DEN-PDX JUL 4>3[5]
WN DEN-PHX JUL 11>8[10] AUG 12>11[11]
WN DEN-PIT JUL 1.4>2[2]
WN DEN-PNS JUL 0.3>0[0.3]
WN DEN-PVR JUL 1.0>0[0.9] AUG 0.4>0.1[0.3]
WN DEN-RNO JUL 2>1.0[2]
WN DEN-SAN JUL 6>4[6]
WN DEN-SAT JUL 4>1.9[3]
WN DEN-SEA JUL 6>4[5]
WN DEN-SLC JUL 6>4[6]
WN DEN-SNA JUN 3>4[4] JUL 4>5[4]
WN DEN-STL JUN 3>4[6] JUL 6>5[6]
WN DEN-TPA JUL 3>2[2]
WN DEN-TUL JUL 2.0>1.0[2]
WN DEN-TUS JUL 2>3[2]
WN DSM-LAS JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN DTW-PHX JUL 1.1>0[1.0] AUG 1.1>0.7[1.0]
WN DTW-STL JUN 0.2>0[2] JUL 2>0[3] AUG 2>1.7[3]
WN ECP-MCI JUL 0.3>0[0.1]
WN ECP-MDW JUL 0.3>0[0.3]
WN ECP-STL JUL 1.3>1.7[1.3]
WN ELP-HOU JUN 0.3>0[3] JUL 3>0[3] AUG 3>1.9[3]
WN ELP-LAS JUL 2>1.0[2]
WN ELP-LAX JUL 1.3>0[1.9] AUG 1.8>1.4[1.7]
WN ELP-SAN JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN ELP-SAT JUL 1.7>0[2] AUG 2>1.5[2]
WN FLL-GCM JUL 1.0>0[1.0] AUG 0.8>0.5[1.0]
WN FLL-HAV JUN 0.3>0[3] JUL 3>0[3] AUG 3>2[3]
WN FLL-IND JUL 1.5>0[1.1] AUG 1.2>0.7[1.0]
WN FLL-MBJ JUN 0.2>0[2] JUL 2>0[2] AUG 2>1.4[2]
WN FLL-MCI JUL 1.2>0[1.3] AUG 1.1>0.7[1.1]
WN FLL-MDW JUL 4>3[4]
WN FLL-NAS JUN 0.2>0[2] JUL 2>0[2] AUG 2>1.4[2]
WN FLL-PHX JUL 1.1>0[1.0] AUG 1.0>0.6[1.1]
WN FLL-PIT JUL 1.2>0[1.1] AUG 1.2>0.8[1.0]
WN FLL-PLS JUL 1.0>0[1.0] AUG 0.8>0.5[1.0]
WN FLL-PUJ JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN FLL-PVD JUL 0.3>0[0.3]
WN FLL-RDU JUL 0.3>0[1.1]
WN FLL-SAT JUL 0.9>0[1.0] AUG 0.5>0.2[1.0]
WN FLL-SJO JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN FLL-SJU JUL 3.0>1.0[2.3] AUG 2.3>1.7[2.1]
WN GCM-HOU JUL 1.0>0[0.3] AUG 0.3>0[0.1]
WN GEG-PHX JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN GEG-SJC JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN GEG-SMF JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN GRR-MDW JUL 3>1.0[2] AUG 3>2[3]
WN HOU-HRL JUL 5>2[5]
WN HOU-JAX JUL 1.9>1.0[1.0] AUG 1.3>1.0[1.0]
WN HOU-LAS JUL 6>4[5]
WN HOU-LAX JUL 4>3[5]
WN HOU-LBB JUL 1.0>0[0.1] AUG 1.0>0.7[0.1]
WN HOU-LGA JUL 3>2[3]
WN HOU-LIR JUL 1.3>0[1.3] AUG 0.9>0.5[1.1]
WN HOU-LIT JUL 1.1>0[0] AUG 1.0>0.7[0]
WN HOU-MAF JUN 0.4>1.1[4] JUL 4>2[4]
WN HOU-MBJ JUL 1.3>0[1.3] AUG 0.6>0.2[0.5]
WN HOU-MCI JUN 0.4>0.1[3] JUL 3>1.0[3] AUG 3>2[3]
WN HOU-MCO JUL 5>4[5]
WN HOU-MDW JUN 3>4[6] JUL 7>6[6]
WN HOU-MEM JUN 0.2>0[1.8] JUL 1.9>0[1.8] AUG 1.8>1.3[1.8]
WN HOU-MKE JUL 1.3>1.0[1.0]
WN HOU-MSY JUL 8>4[9] AUG 9>8[9]
WN HOU-OAK JUL 2>1.0[3]
WN HOU-OMA JUL 0.4>0[1.0] AUG 0.9>0.7[1.0]
WN HOU-PDX JUL 0.8>0[1.0] AUG 0.3>0.1[0.2]
WN HOU-PHX JUL 5>4[4]
WN HOU-PIT JUL 1.0>0[1.0]
WN HOU-PUJ JUL 0.3>0[0.1]
WN HOU-PVR JUL 1.3>0[1.3] AUG 1.1>0.7[1.1]
WN HOU-RDU JUL 1.2>0[1.0] AUG 1.1>0.7[1.0]
WN HOU-SAN JUL 3>1.0[2]
WN HOU-SEA JUL 1.0>0[1.0] AUG 0.4>0.1[0.2]
WN HOU-SJC JUL 0.3>0[1.0]
WN HOU-SJD JUL 2>1.0[1.3]
WN HOU-SJO JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN HOU-SJU JUL 1.3>0[0.4] AUG 0.6>0.2[0.2]
WN HOU-SLC JUL 0.3>0[0.3]
WN HOU-SMF JUL 1.0>0[0.1] AUG 1.0>0.7[0.1]
WN HOU-STL JUN 1.3>1.8[4] JUL 4>3[3]
WN HOU-TUL JUN 0.3>0[3] JUL 3>0[3] AUG 3>1.9[3]
WN ICT-LAS JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN IND-LAS JUL 3>2[3]
WN IND-LAX JUL 1.0>0[1.0] AUG 0.3>0[0.9]
WN IND-MCI JUL 1.6>0[1.8] AUG 1.5>1.1[1.8]
WN IND-MCO JUL 3>2[4]
WN IND-MDW JUL 1.0>0[1.0] AUG 1.0>0.7[1.2]
WN IND-OAK JUL 0.9>0[0.1] AUG 0.3>0[0]
WN IND-PHX JUL 2.0>1.0[1.2]
WN IND-RSW JUL 1.3>0[1.4] AUG 1.4>0.9[1.1]
WN IND-SAN JUL 0.9>0[1.0] AUG 0.3>0[0.2]
WN IND-TPA JUL 3>1.0[3] AUG 1.7>1.2[1.4]
WN ISP-MCO MAY 1.1>0.7[2]
WN ISP-PBI JUL 1.7>0[1.9] AUG 1.3>0.8[2.0]
WN ISP-TPA JUL 0.9>0[1.1] AUG 0.9>0.7[1.0]
WN JAX-MDW JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN LAS-LAX JUL 10>6[10] AUG 10>9[11]
WN LAS-LGB JUL 0.5>0[3] AUG 0.6>0.4[3]
WN LAS-LIT JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN LAS-MCI JUL 4>1.9[4]
WN LAS-MCO JUL 1.7>1.0[2]
WN LAS-MDW JUL 8>7[8]
WN LAS-MKE JUL 3>1.0[2] AUG 2>1.8[2]
WN LAS-OAK JUL 9>5[9] AUG 9>7[8]
WN LAS-OKC JUL 1.8>1.0[1.8]
WN LAS-OMA JUL 3>2[3]
WN LAS-PDX JUL 4>3[4]
WN LAS-PHX JUL 10>6[9] AUG 11>10[10]
WN LAS-RDU JUL 1.1>0[1.1] AUG 1.0>0.7[1.0]
WN LAS-RNO JUL 10>5[9] AUG 10>9[9]
WN LAS-SAN JUL 11>6[11] AUG 12>10[10]
WN LAS-SAT JUL 3>2[4]
WN LAS-SDF JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN LAS-SEA JUL 3>1.8[3]
WN LAS-SFO JUL 5>4[6]
WN LAS-SJC JUL 11>6[10] AUG 11>10[10]
WN LAS-SLC JUL 5>3[5]
WN LAS-SMF JUL 9>5[7] AUG 9>8[8]
WN LAS-TPA JUL 1.1>0[0.3] AUG 1.2>0.8[0.9]
WN LAS-TUL JUL 1.1>0[1.1] AUG 1.1>0.8[1.1]
WN LAS-TUS JUL 2>3[3]
WN LAX-MCI JUL 2>1.0[3]
WN LAX-MDW JUL 6>4[5]
WN LAX-MKE JUL 0.2>0[1.0]
WN LAX-MSY JUL 0.7>0[1.8]
WN LAX-OAK JUL 12>6[12] AUG 12>10[13]
WN LAX-PDX JUL 0.2>0[2]
WN LAX-PHX JUL 8>4[8] AUG 8>7[8]
WN LAX-RNO JUL 3>1.0[3]
WN LAX-SAT JUL 1.4>0[1.6] AUG 1.7>1.3[1.8]
WN LAX-SFO JUL 6>4[8]
WN LAX-SJC JUL 10>5[11] AUG 10>9[10]
WN LAX-SJD JUL 1.0>0[1.0] AUG 0.5>0.2[0.7]
WN LAX-SLC JUL 1.8>1.0[3]
WN LAX-SMF JUL 8>5[8]
WN LAX-STL JUN 1.2>1.6[3] JUL 3>1.9[3]
WN LAX-TUS JUL 3>1.0[3]
WN LGA-MDW JUL 7>5[6]
WN LGA-STL JUL 4>2[3]
WN LGA-TPA JUL 1.7>0[1.7] AUG 1.7>1.2[1.7]
WN LIT-PHX JUL 0.9>0[1.1] AUG 0.9>0.7[1.0]
WN MBJ-MDW JUL 1.1>0[1.1] AUG 0.6>0.2[0.3]
WN MBJ-STL JUL 0.3>0[0.1]
WN MCI-MCO JUL 3>2[3] AUG 2>1.5[2]
WN MCI-MDW JUL 8>5[7] AUG 8>7[8]
WN MCI-MKE JUL 1.8>0[1.8] AUG 1.8>1.3[1.8]
WN MCI-MSP JUL 1.2>0[1.7] AUG 1.4>1.1[1.7]
WN MCI-MSY JUL 1.1>0[1.1] AUG 1.2>0.8[1.1]
WN MCI-PDX JUL 1.0>0[1.0] AUG 0.5>0.2[1.0]
WN MCI-PNS JUL 0.3>0[0.3]
WN MCI-RDU JUL 0.7>0[1.0] AUG 0.8>0.6[0.9]
WN MCI-RSW JUL 0.3>0[0.3]
WN MCI-SAN JUN 0.2>0[1.7] JUL 2.0>0[1.5] AUG 1.4>0.8[1.7]
WN MCI-SAT JUL 0.9>0[1.0] AUG 0.9>0.7[1.0]
WN MCI-SEA JUL 1.0>0[1.0] AUG 0.5>0.2[1.0]
WN MCI-STL JUL 3>2[3]
WN MCI-TPA JUN 0.2>0.6[1.8] JUL 1.9>1.0[1.9] AUG 1.3>1.0[1.0]
WN MCO-MHT JUL 1.2>2[1.3]
WN MCO-MSY JUL 3>1.9[4]
WN MCO-OMA JUL 0.2>0[0.3]
WN MCO-ORF JUL 1.1>0[1.3] AUG 1.1>0.7[1.2]
WN MCO-PHX JUL 1.4>1.0[1.3]
WN MCO-PIT JUL 4>3[4]
WN MCO-RDU JUL 3>1.0[3] AUG 2>1.9[2]
WN MCO-RIC JUL 0.3>0[0]
WN MCO-ROC JUL 1.0>0[1.0] AUG 0.5>0.2[1.0]
WN MCO-SAT JUL 2>1.0[2] AUG 1.5>1.0[1.4]
WN MCO-SDF JUL 1.4>1.0[1.4]
WN MCO-SJU JUL 7>4[7] AUG 4>3.3[3.6]
WN MDW-MSP JUL 6>5[7]
WN MDW-MSY JUL 4>3[4]
WN MDW-OAK JUL 3>2[3]
WN MDW-OMA JUL 4>3[4]
WN MDW-ONT JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN MDW-ORF JUL 1.1>0[1.4] AUG 1.3>0.9[1.3]
WN MDW-PDX JUL 2.0>1.0[0.1] AUG 1.4>1.1[0.9]
WN MDW-PHL JUL 5>3[5]
WN MDW-PHX JUL 7>5[6]
WN MDW-PIT JUL 4>3[4]
WN MDW-PNS JUL 0.3>0[0.4]
WN MDW-RDU JUL 3>2[4]
WN MDW-RNO JUL 1.0>0[1.1] AUG 0.4>0.1[1.0]
WN MDW-SAN JUL 4>3[4]
WN MDW-SEA JUL 3>2[3]
WN MDW-SFO JUL 1.6>2[1.1]
WN MDW-SJC JUL 1.7>1.0[1.6]
WN MDW-SJU JUL 1.0>0[0.3]
WN MDW-SLC JUL 3>2[2.0]
WN MDW-SMF JUL 1.9>1.0[1.8]
WN MDW-STL JUL 8>5[7]
WN MEM-TPA JUL 1.0>0[1.0] AUG 0.4>0.1[0.9]
WN MKE-PHX JUL 1.7>2[1.8]
WN MKE-SFO JUL 0.3>0[1.0]
WN MKE-STL JUL 3>1.0[1.8]
WN MKE-TPA JUL 1.2>3[1.0] AUG 1.0>1.4[0.9]
WN MSP-OAK JUL 1.0>0[0.7] AUG 1.0>0.7[0.1]
WN MSP-PHX JUL 1.4>0[2.0] AUG 1.8>1.4[2]
WN MSP-STL JUN 0.2>0[3] JUL 2>0[3] AUG 2>1.7[3]
WN MSY-OAK JUL 0.2>1.0[1.0] AUG 0.7>0.9[0.9]
WN MSY-PHX JUL 0.3>1.0[1.0] AUG 0.8>1.0[1.0]
WN MSY-SAN JUL 1.0>0[1.0] AUG 0.9>0.6[0.9]
WN MSY-SAT JUL 0.9>0[1.7]
WN MSY-STL JUN 0.3>0[2] JUL 3>0[2] AUG 2>1.4[2]
WN MSY-TPA JUL 3>1.0[3]
WN OAK-ONT JUL 6>4[7]
WN OAK-PDX JUL 6>4[7]
WN OAK-PHX JUL 5>4[6]
WN OAK-PVR JUL 0.5>0[0.2] AUG 0.2>0[0.2]
WN OAK-RNO JUL 1.3>0[1.8] AUG 1.6>1.2[1.7]
WN OAK-SAN JUL 11>5[11] AUG 11>10[11]
WN OAK-SAT JUL 0.3>0[1.0]
WN OAK-SEA JUL 7>4[6] AUG 7>6[6]
WN OAK-SJD JUL 0.7>0[0.2] AUG 0.5>0.2[0.3]
WN OAK-SLC JUL 3>1.0[3] AUG 3>2[3]
WN OAK-SNA JUL 6>5[6]
WN OAK-STL JUL 0.3>1.0[1.0] AUG 0.9>1.1[1.0]
WN OGG-SAN JUL 1.0>0[0] AUG 1.0>0.7[0]
WN OKC-PHX JUL 3>1.0[2]
WN OKC-STL JUN 0.2>0.6[1.9] JUL 1.5>1.0[2.0]
WN OMA-SAN JUL 0.7>0[1.0] AUG 0.2>0[1.0]
WN OMA-STL JUL 3>2[3]
WN ONT-PDX JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN ONT-PHX JUL 6>4[6]
WN ONT-SFO JUL 3>0[3] AUG 3>2[4]
WN ONT-SMF JUL 7>4[6]
WN PDX-PHX JUN 0.3>0.1[4] JUL 3>1.0[4]
WN PDX-SAN JUL 1.0>0[3] AUG 0.4>0.1[3]
WN PDX-SJC JUL 6>3[6]
WN PDX-SMF JUL 5>3[5]
WN PHL-PHX JUL 1.0>0[0.9] AUG 1.0>0.7[1.0]
WN PHL-STL JUL 2>1.0[3]
WN PHL-TPA JUL 1.3>0[1.3] AUG 1.2>0.8[1.1]
WN PHX-RDU JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN PHX-RNO JUL 2>1.0[2.0] AUG 2>1.9[2]
WN PHX-SAN JUL 11>5[10] AUG 11>9[10]
WN PHX-SAT JUL 2>3[3]
WN PHX-SDF JUL 1.0>0[1.1] AUG 1.0>0.7[1.0]
WN PHX-SEA JUN 1.3>1.0[4] JUL 4>1.0[4] AUG 5>4[4]
WN PHX-SFO JUL 4>3[4]
WN PHX-SJC JUL 6>4[6]
WN PHX-SLC JUL 5>3[5]
WN PHX-SMF JUL 5>4[6]
WN PHX-SNA JUL 6>5[7]
WN PHX-TPA JUL 1.1>0[1.0] AUG 1.0>0.6[0.9]
WN PHX-TUL JUL 1.1>0[1.5] AUG 1.1>0.7[1.7]
WN PIT-RSW JUL 1.1>0[1.1] AUG 0.5>0.1[0.4]
WN PIT-STL JUN 0.2>0.6[1.2] JUL 1.8>1.0[1.1]
WN PIT-TPA JUL 2>1.0[2] AUG 1.7>1.2[2]
WN PNS-STL JUL 0.3>0[0.3]
WN PUJ-STL JUL 0.3>0[0]
WN PVD-TPA JUL 1.1>0[1.9] AUG 1.2>0.8[1.1]
WN PVR-SAN JUL 0.3>0[0.3]
WN RDU-STL JUL 2.0>1.0[2.0]
WN RDU-TPA JUL 1.1>0[2.0] AUG 1.7>1.4[1.9]
WN RIC-TPA JUL 0.3>0[0]
WN RNO-SAN JUL 3>1.0[3] AUG 3>2[3]
WN RNO-SJC JUL 1.8>0[2] AUG 2>1.6[1.6]
WN RSW-STL JUL 1.5>1.0[1.4]
WN SAN-SAT JUL 1.3>0[1.6] AUG 1.7>1.4[1.6]
WN SAN-SEA JUL 1.0>0[2.0] AUG 0.4>0.1[1.2]
WN SAN-SFO JUL 7>4[8] AUG 7>6[7]
WN SAN-SJC JUL 15>7[14] AUG 14>12[15]
WN SAN-SJD JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN SAN-SLC JUL 1.0>0[2.0] AUG 1.5>1.2[1.8]
WN SAN-SMF JUL 14>7[13] AUG 14>12[14]
WN SAN-STL JUN 1.1>1.6[2]
WN SAN-TUS JUN 0.2>0[2.0] JUL 2>0[2.0] AUG 2>1.5[1.9]
WN SAT-STL JUN 0.3>0[2] JUL 2>0[2] AUG 2>1.3[1.9]
WN SAT-TPA JUL 1.1>0[1.0] AUG 0.5>0.1[1.0]
WN SDF-TPA JUL 1.3>0[1.3] AUG 1.2>0.8[1.1]
WN SEA-SJC JUL 5>3[4]
WN SEA-SMF JUL 6>3[5] AUG 6>5[5]
WN SEA-STL JUL 1.7>1.0[1.0]
WN SFO-STL JUL 1.0>0[1.0] AUG 1.0>0.7[1.0]
WN SJC-SLC JUL 1.0>0[1.8] AUG 1.0>0.7[1.8]
WN SJC-SNA JUL 10>5[9] AUG 9>8[10]
WN SJC-STL JUN 0.8>1.4[1.0] JUL 1.0>1.9[1.0] AUG 1.0>1.3[1.0]
WN SJC-TUS JUL 0.9>0[0.9] AUG 0.8>0.6[0.8]
WN SJD-SMF JUL 0.3>0[0.3]
WN SJU-TPA JUL 2.0>1.0[1.9]
WN SLC-SMF JUL 1.1>0[1.1] AUG 1.1>0.7[1.1]
WN SLC-STL JUL 0>1.0[0] AUG 0>0.3[0.0]
WN SMF-STL JUN 1.0>1.2[1.0]
WN STL-TPA JUN 1.3>1.6[2] JUL 3>2[2]
WO AZA-YEG JUN 0.3>0[0]
WO LAS-YEG JUN 1.0>0[1.0]
WO LAS-YHM JUN 0.6>0[0.6]
WO LAS-YWG JUN 0.3>0[0]
WO LAS-YXX JUN 0.3>0[0.3]
XL GYE-JFK MAY 1.0>0[1.0]
PSU.DTW.SCE
Re: OAG Changes 4/26/2020: Saturday Night Massacre
Sun Apr 26, 2020 12:22 pm
Incredible. May 2020 flying levels is Hopefully something we never see again for a whole variety of reasons.
Not a whole to comment on other than various strategies of where the respective airlines are leaving bare bones service.
It will be interesting to see when they roll forward June cuts.
Boof02671
Sun Apr 26, 2020 12:25 pm
Another poster in two other threads reported AA is adding back CLT to LHR and MUC on the 777. Along with a couple of other international flights from DFW it was loaded last minute.
SteveXC500
Sun Apr 26, 2020 12:26 pm
WTF. It’s all I got
Ishrion
Sun Apr 26, 2020 12:33 pm
Thanks as always!
Seriously? Pretty drastic increases compared to last year. Are cargo-only flights registered in the OAG?
MIflyer12
Sun Apr 26, 2020 12:46 pm
SteveXC500 wrote:
WTF. It’s all I got
Yeh, at this point UA and DL have pretty much cancelled TATL summer. I guess if they can't even expect 60 people a flight at decent fares to cover variable fuel and maintenance costs, this is what we get.
dfw88
Sun Apr 26, 2020 1:02 pm
I'm very confused about AA dropping CYS. They haven't applied for a CARES act exemption yet they're showing it as being gone for good. Anyone have any insights?
Chuska
Sun Apr 26, 2020 1:07 pm
Many new tags for United Express. Here's what I found:
BFF-PIR, CGI-PAH, CHS-MYR, CMX-DLH, CMX-EAU, CNY-VEL, DDC-HYS, DEC-SPI, EAR-LBF, GCC-SHR, GJT-MTJ, EYW-RSW, GTF-HLN, HYS-SLN, MBS-MKG, RKS-RIW.
Chuska
Sun Apr 26, 2020 1:26 pm
The new Alaska tags are only operating from May 3-9 at this time. Quite possible they'll be extended in next weeks massacre.
Gotta love the nostalgia going on here; ABQ-SAT was a big Continental route in regulation days, ICT-OKC was a Braniff route, and IND-STL a TWA route.
FlyPNS1
Sun Apr 26, 2020 1:33 pm
Interesting strategy by UA regarding IAD and EWR. Most smaller markets stay connected only to IAD in May, not EWR. IAD even gains a brand new route (IAD-PQI)!!
jayunited
Sun Apr 26, 2020 1:47 pm
This is like the Red Wedding on Game of Thrones, Saturday night massacre is an appropriate title. Airlines across the board have taken a machete to their May schedules in many cases the cuts are deeper than what we have seen in April.
Chuska
Sun Apr 26, 2020 1:48 pm
I know the city of CYS (or state of Wyoming, or both) is subsidizing AA for this. Its probably exempt from the CARES act. I think RIW and SHR are in the same boat however UA* is staying in both for now with one-stops to DEN instead of nonstops. A real shame that CYS just opened a nice new terminal.
mxaxai
Sun Apr 26, 2020 1:52 pm
Wow.
Is your database able to show the flights that are flown? In particular TATL would be interesting, I would guess that the list of cancelled routes next month is longer than the list of flown routes.
Nicknuzzii
Sun Apr 26, 2020 1:59 pm
What are the odds most of the UAX routes from EWR return in the future? I knew prior to this UA was shifting a lot to IAD and as you can see in today’s report most have temporarily shifted.
joeblow10
Sun Apr 26, 2020 2:07 pm
OO applied for the the exemption. It’s one of the very first items in the docket. And since it’s being subsidized by the state, you’re correct in that it should be exempt.
MIflyer12
Sun Apr 26, 2020 2:25 pm
Can you explain how a subsidized service is exempt from the Final Show Cause Order, please?
MIflyer12
Sun Apr 26, 2020 2:30 pm
Pretty good, at least for a substantial portion. Remember, partial of the rationale for moving EWR services to IAD was EWR overcrowding. That evaporates for the foreseeable future. When traffic rebounds the EWR hub will still be standing, and NYC-xxx O&D will still be standing.
IMHO part of the current shift to IAD is caused by the very high rate of infections in NY and NJ. Even if passengers are willing to risk exposure at EWR, it's prudent to minimize crew exposure. Now, some have argued recently that WAS confirmed infections haven't peaked yet so who knows how long this lasts.
joeblow10
Sun Apr 26, 2020 2:42 pm
It’s on Page 10 of the final order.
“The Department will... provide an industry wide exemption for circumstances in which direct financial support agreements between communities and airlines have ceased after... declaration of a public health emergency.” The order goes on to reference service at RKS, which I believe is also subsidized by the state of WY.
CIDFlyer
Sun Apr 26, 2020 2:46 pm
Many markets, like my hometown of CID, will only see one Delta flight a day. 1 CR9 to MSP and that’s it. Looks similar for MSN, DSM
As well. Lots more routes chopped from DTW. How many flights a day are being run from ATL? Would be curious to see.
Looks like G4 reversed course. It’s nice to have their service in case someone needs to fly and have that option. I know our family has snowbird friends in AZ and FL who are to be coming back next weekend.
I wonder if AA will make deeper cuts in May? They have been barely running one daily flight in my market. It seems to alternate too between ORD/CLT/DFW
GoncaloRibas
Sun Apr 26, 2020 2:50 pm
Ishrion wrote:
Thanks as always!
TP will only fly to BOS(A321neo LR), EWR and MIA(both with A339) at least until August with some frequencies per week. Probably next week we will see some changes in the systems
EssentialBusDC
Sun Apr 26, 2020 2:56 pm
That brings back some memories as I used to fly the Brasília for Mesa, based in SHR, via GCC to feed Denver back in 1995. So what’s old is new again
MIAFLLPBIFlyer
Appears NK had to agree to resume Niagara Falls and Plattsburgh service to get CARE $. Since both were being flown at the time of the shutdowns and were merely scheduled to be discontinued.
dfw88
Sun Apr 26, 2020 2:59 pm
Thank you. I forgot to check OO's exemption filing. Oops. So the fact that this route was scrubbed completely makes it seem that AA isn't planning on going back. Is OO switching mainline carriers like they did for MEI and PIB?
hiflyeras
Sun Apr 26, 2020 3:01 pm
And this will all change a week from now. Hell, it might have changed since it was posted here mere hours ago. I'm sure it's a big job every week...I know we all appreciate it...but Enrilia do you wonder sometimes if it's a waste of time right now?
aemoreira1981
Sun Apr 26, 2020 3:05 pm
Ishrion wrote:
Thanks as always!
At least I'm not the only one seeing that as a misfile.
Dominion301
Sun Apr 26, 2020 3:23 pm
Rather strange to see DL increasing SEA-YVR in May.
FYI AC have cancelled all transborder flying until late May. I suspect it will be extended beyond that though.
oosnowrat
Sun Apr 26, 2020 3:34 pm
CYS was suspended "indefinitely." The community is gathering funds with hopes of restoring service someday.
The DEN-Wyoming UAX service, DFW-CYS, and PHX-RAP are all OO prorate routes funded by state and local governments.
jfklganyc
You work so hard on this thread
It is always enjoyable...thank you
During these times I don’t know if it’s relevant anymore.
There are so many changes, most temporary, some not, that trying to have a discussion on route planning and weekly changes almost seems like spitting into the wind.
Again, I appreciate the work and I’m not knocking it in any way...But I wonder the relevance at this point
Nicknuzzii
Sun Apr 26, 2020 3:45 pm
So TAP just updated their June and July Schedule,
EWR -
2x - Late May
5x - June
Daily - July
JFK
No Flights
BOS
1x - Late May
3x - June
5x - July
MIA
1x - Late May
3x - June
5x - July
tphuang
Sun Apr 26, 2020 3:50 pm
enilria wrote:
AA BZE-MIA SEP 0>1.0[1.1] OCT 0.8>1.0[1.0]
AA GCM-MIA MAY 0.7>0[2] AUG 0.5>1.0[1.6] SEP 0>1.0[1.5] NOV 2>1.4[2] DEC 3>1.5[3] JAN 2>1.2[2]
*AA MAO-MIA JUN 0.9>0[0.9] JUL 1.0>0[1.0] AUG 0.9>0[1.0] SEP 0.7>0[0.8] OCT 0.7>0.2[0.7]
**DL AMS-MCO JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0[0.9] NOV 0.5>0[0.5] DEC 0.6>0[0.6] JAN 0.6>0[0.6]
**DL AMS-TPA JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.9>0[0.7] OCT 0.5>0[0.5]
**DL ATL-BCN JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL ATL-BOI JUL 0.6>0[0] AUG 1.0>0[0] SEP 0.6>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.6>0[0] JAN 0.7>0[0]
**DL ATL-BZN JUN 0.3>0[0.5] JUL 0.7>0[0.7] AUG 0.8>0[0.5] SEP 0.6>0[0] OCT 0.6>0[0] NOV 0.6>0[0] DEC 1.1>0.8[0.7]
**DL ATL-DUB JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL ATL-FCO JUN 1.9>0[2] JUL 2>0[2] AUG 2>0[2] SEP 2.0>1.0[2]
**DL ATL-GEG JUL 0.6>0[0] AUG 1.0>0[0] SEP 0.7>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.4>0[0] JAN 0.6>0[0]
**DL ATL-HNL JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[0.9]
**DL ATL-MAD JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0[0.9] NOV 0.7>0[0.8] DEC 0.7>0[0.7] JAN 0.6>0[0.5]
**DL ATL-RNO JUN 0.9>0[0] JUL 0.9>0[0] AUG 0.8>0[0] SEP 0.6>0[0] OCT 0.6>0[0] NOV 0.6>0[0] DEC 0.7>0.4[0.4]
**DL BOS-EDI JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.1]
**DL BOS-FCO JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 0.2>0[0]
DL BOS-LAX MAY 0.5>0[2]
**DL BOS-LGA MAY 1.0>0[14]
**DL BOS-LGW JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0]
**DL BOS-LIS JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.1]
**DL BOS-MAN JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 0.2>0[0]
DL BOS-SLC MAY 0.5>0[3]
**DL CDG-IND JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.7>0[0.7] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.4>0[0.4]
**DL CDG-SLC JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0[0.9] NOV 0.7>0[0.7] DEC 0.7>0[0.7] JAN 0.6>0[0.6]
**DL CMH-SEA JUN 0.8>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 0.6>0[0] JAN 0.9>0[0]
DL CVG-RDU JUN 2>1.6[1.8] JUL 2>1.6[1.5] AUG 3>1.7[1.8] SEP 2>1.7[1.7] OCT 3>1.7[1.6] NOV 3>1.7[1.5] DEC 2.0>1.5[1.5] JAN 3>1.9[1.5]
**DL DFW-SEA JUN 2>0[0] JUL 3>0[0] AUG 3>0[0] SEP 3>0[0] OCT 3>0[0] NOV 3>0[0] DEC 3>0[0] JAN 3>0[0]
DL DTW-MIA JUN 3>2.0[2] JUL 3>2[1.8] AUG 3>2[1.9] SEP 3>2[1.9] OCT 3>2[1.8] NOV 3>2[1.7] DEC 3>2[2] JAN 3>2[2]
DL GEG-LAX SEP 1.6>1.0[1.0] OCT 2>1.0[1.0] NOV 2>1.0[1.0] DEC 2>1.0[1.0] JAN 2>1.0[1.0]
**DL GLA-JFK JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
**DL HNL-MSP JUN 0.8>0[0.8] JUL 0.9>0[0.8] AUG 0.8>0[0.7]
**DL JFK-KEF JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.5>0[0.6]
**DL JFK-LOS JUN 0.4>0[0.4] JUL 0.5>0[0.5] AUG 0.9>0[0.4] SEP 0.5>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.5]
**DL JFK-NCE JUN 1.1>0[1.1] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL JFK-PRG JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL JFK-SNN JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
DL JFK-TLV JUN 1.5>1.0[1.5] JUL 1.6>1.0[2] AUG 1.6>1.0[2] SEP 1.6>1.0[1.7] OCT 1.7>1.3[1.5]
**DL JFK-TXL JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL JFK-VCE JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**DL JFK-YVR JUN 0.9>0[0.6] JUL 0.9>0[0.9] AUG 1.0>0[0.9] SEP 0.7>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.7>0[0] JAN 0.7>0[0]
DL MCI-SEA JUL 1.8>1.0[0.9] AUG 1.9>1.0[1.0] SEP 1.7>1.0[0.8] OCT 1.8>1.0[0.9] NOV 1.9>1.0[0.8] DEC 1.8>1.0[0.9] JAN 1.8>1.0[0.9]
DL MIA-MSP MAY 0.5>0[1.9] JUN 3>1.9[2.0] JUL 3>1.9[1.8] AUG 3>2[1.8] SEP 3>2[1.6] OCT 3>2[1.7] NOV 3>2[1.6] DEC 3>2[1.8] JAN 3>2[3]
G3 BSB-MCO JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0]
G3 BSB-MIA JUL 1.0>0[0.6] AUG 1.0>0[0.7] SEP 0.6>0[0.7] OCT 0.7>0[0.6] NOV 1.0>0[0.6]
G3 FOR-MCO JUL 1.0>0[1.0] AUG 1.0>0[0.1] SEP 0.4>0[0.2] OCT 0.6>0[0] NOV 1.0>0[0]
Thanks enilria for all the hard work.
Few things look at this.
I think AA will shrink MIA more than people expect.
WN still looks to be cutting way too little compared to other airlines.
Looks like UA/DL are a lot more certain about lack of demand in the coming months for long haul stuff vs domestic stuff.
For DL, looks like obvious move to cut the recent adds to SEA right before this all started. All the ATL to small west coast stuff that didn't make sense are cut like they should be. HNL stuff will route through LAX/SEA now. All the secondary TATL stuff is gone for this summer. One just needs to see how small DL is now at BOS (down to ATl/DTW/MSP/JFK) vs SEA (which actually got a few adds) and LAX to see where DL is going to shrink coming out of this. No reason to have a second TATL hub in northeast. MIA experiment is already rolled back.
What does G3 still have going to america?
Really strange to see TP adding capacity.
UAX will come back. If anything, UAX is needed to lower capacity and maintain schedule. IAD on the other hand is most likely going to get significantly downsized.
I'm still a little surprised NK decided to take the money.
If anyone is wondering if DL will leave SEA, you just need to look at the number of routes they added to on this update. Looks like DL is filling in for Canadian carriers temporarily withdrawing from the market.
panam330
Sun Apr 26, 2020 3:52 pm
Looks like lots of permanent TATL drops at DL and UA, as expected. Man, this sucks.
Planeboy17
Sun Apr 26, 2020 4:03 pm
Thank you again enilria.
Does anyone know why EI seems so optimistic? They seem to be flying to all of their destinations, with a reduced schedule of course, but still it seems surprising to see even BDL and MSP loaded.
Also, I read that EK will not resume any scheduled flying until July 1st now so I think what’s loaded today will be removed next week.
TW870
Sun Apr 26, 2020 4:05 pm
I think it is highly relevant for two reasons:
1. Historical: people are going to research and write about this event for literally the next century. This is a tremendous quick reference to see how a core industry responded to the worst black swan it has faced. I write about industry and crisis for a living, and believe me, things like this thread are hugely useful as a historical artifact.
2. Practical: many of us work jobs where we commute for a living, and sometimes on multiple markets out of multiple airports depending on the nature of our seasonal work. I and many others use this thread to keep tabs on service to all of our commuter airports. Right now, we are trying to figure out how and when we will be able to begin to actually operate our working lives again. This thread is one of many resources people use to evaluate our options - because all of the info is here with one click.
On a more detailed note, enilria and others, how are you reading the way Delta loaded the transatlantic cuts? For the routes that zero out through January such as AMS-TPA/MCO and JFK-LOS, am I right to read those as dropped routes - at least for now? It looks like the axed all the summer seasonal flying, which is to be expected. But I am trying to figure out where they are signaling long term cuts. LOS is likely to be a tougher market both because of the oil price collapse and the US immigration restrictions - and thus I assume they are pulling the plug on the JFK market?
AirFiero
Sun Apr 26, 2020 4:06 pm
Tag-o-rama + May is reduced to near statutory minimum under CARES
B6 is dropping all service to SJC. Isn’t there something in the CARES act that says you can’t take the money and drop cities? Is B6 not taking the money?
alasizon
Sun Apr 26, 2020 4:11 pm
RAP was covered by a SCASD grant, I don't believe there was much funding on the local side. From what I recall, they stopped receiving funding earlier this year (or maybe Q4 of last year) because the route was above the minimum revenue guarantee.
OO pulled all their CR2s from the AA system which is why you see all of those cuts (with PHX-SGU going to a CR7). Once the economy recovers I'm sure OO will jump back into the pro-rate game as recently it has been very profitable for them.
Cubsrule
Sun Apr 26, 2020 4:13 pm
I expect you’re right. People don’t realize just how far NYC flight counts have fallen. Yesterday, BNA had more (Part 121 passenger) movements than EWR and LGA combined. WN’s relatively lower number of cuts is part of the reason for that, of course, but it’s nevertheless a stunning datum.
icacti
Sun Apr 26, 2020 4:14 pm
Attempted to compile a list of TATL routes that have continuously operated (and those that were suspended anytime between March and now):
https://cactiaviation.wordpress.com/2020/03/12/eu-us-flights/
Aliqiout
Sun Apr 26, 2020 4:25 pm
Is SJC considered the "same city" as SFO, the CARES act only requires maintaining service to one airport in each city.
trueblew
SJC is in the SF Bay Area metro. Airlines are allowed to consolidate flying within metro areas, such as LA, SF, WAS, NYC, under the CARES Act.
StrandedAtMKG
Good lord. GRR is down from 6-7 DL GRR-DTW a day and 7 UA GRR-ORD to TWO? It's a bloodbath out there.
Aliqiout
Sun Apr 26, 2020 4:29 pm
I guess we know DL is committed to SEA now.
Some strange adds, AS ANC-SCC and DL SEA-KTN are both showing minor year over year increases.
OA412
Sun Apr 26, 2020 4:37 pm
DL has cut all seasonal flying this summer other than JFK-ATH.
Hughes Airwest - Top Banana In The West
Chuska
Sun Apr 26, 2020 4:51 pm
Enilria: Despite what some have said about if this thread is worthwhile any more, please keep it coming! Yes its been pretty dramatic the last few weeks and probably will continue for awhile as the big three have yet to hack their June and beyond schedules. I think the downward curve is now flattening and we're all beginning to understand what lies ahead. For me, I'm loving the tag-ons. Fill in those gaps that are without nonstop service and maintain the thin hub to spoke routes with one-stop service. They may not have much traffic but fuel is so cheap and the airlines have so many extra aircraft now, I believe it can be done.
mxaxai
Sun Apr 26, 2020 4:52 pm
Well that's a great compilation. Thanks for your effort. Let's hope that at least this minimum service survives throughout the summer.
travaz
Sun Apr 26, 2020 5:11 pm
I wonder if we will see the return of the "milk runs" . I remember the old Frontier Convairs doing PHX DEN via Winslow, Gallup, and Farmington. I could see WN doing some of this.
PSU.DTW.SCE
Sun Apr 26, 2020 5:16 pm
There are few things out there is see from a scheduling perspective, and basing on what DL is doing as I am most familiar with their network.
1. Suspending the summer seasonal TATL routes; these likely had to be done in coordination with AF/KL as rebooking is like to to be through AMS / CDG; these routes likely had proportionally more advanced bookings due to the leisure nature of these markets for summer travel but many people are probably going to end up just taking the cancellation refund due to the near term prognosis of the world.
2. Cutting almost all hub overflying except for core big city market, in many cases pulling down smaller markets to the closest hub for May.
3. Domestic cuts for June haven’t been made or loaded yet; I suspect a combination of just gettin May in place, still figuring out what June capacity may look like, and flattening the curve of rebooking/cancellation/call center demand
It’s going to be a new world in these threads and on this forum for years as we talk about routes that were flown for years before this event that may not return for years to come, if ever. Particularly all the long haul seasonal stuff.
B6JFKH81
Sun Apr 26, 2020 5:34 pm
Yikes, TPA is taking a bigger hit than I was expecting. Not good for my hometown airport :-(
3M CHS-TPA JUN 0.4>0[0]
3M EYW-TPA MAY 1.1>0[3]
3M FLL-TPA MAY 1.0>0.4[2]
3M NAS-TPA MAY 0.4>0[1.0]
3M PNS-TPA MAY 0.6>0[1.7]
3M TLH-TPA MAY 0.8>0.4[1.6]
B6 BDL-TPA MAY 0.4>0.0[1.0]
B6 BOS-TPA MAY 3>0.7[4]
B6 EWR-TPA MAY 1.0>0.1[2]
*B6 HPN-TPA JUN 0.7>0[1.0]
B6 JFK-TPA MAY 2>0.5[3]
B6 SJU-TPA MAY 0.6>0.1[2.0]
DL ATL-TPA MAY 3>2[13]
DL JFK-TPA MAY 0.5>0[4]
NK ACY-TPA MAY 0.6>0[1.0] JUN 0.9>0[1.0]
NK ATL-TPA MAY 0.9>0[1.6] JUN 1.7>0[1.9]
NK BNA-TPA JUN 0.7>0[0]
NK BWI-TPA MAY 0.5>0[1.6] JUN 1.6>0[1.6]
NK CLE-TPA JUN 0.7>0[0]
NK DFW-TPA JUN 0.7>0[1.0]
NK DTW-TPA MAY 0.7>0.5[0.9] JUN 0.9>0.4[0.9]
NK EWR-TPA JUN 0.7>0[0]
HardeesBiscuit
Sun Apr 26, 2020 5:39 pm
surprised there's not a big ** on G4
they seem to be stepping on the gas in May and re-starting many of the flights they had zeroed out...presumably CARES reasons? or do they have reason to think sometime in May their demand will tick up? Either way, it's counter to all the cutting everywhere else.
Thanks, Enliria
afcjets
Sun Apr 26, 2020 5:58 pm
It appears CLT is now AA's largest hub with way more flights than DFW. I wonder why that is and how long it will continue?
viewtopic.php?f=4&t=1445147
IPFreely
Sun Apr 26, 2020 6:25 pm
Looks like DL has gutted domestic connections thru DTW. There are cuts in ATL but the cuts in DTW are disproportionately high. Interesting strategy to protect as much traffic as possible in ATL since most connections from places like CID, MSN, and DSM make more geographic sense thru DTW than ATL.
