AC02
Post Screening - AC02
Thu Apr 30, 2020 7:09 pm
Hi, I had a photo rejected twice for the reason of Blurry and I cannot see why.
In the second rejection, the screener also commented "Portions of the AC are blurry and blurry is impossible to fix.", but under 100% view the original doesn't look blurry at all. Can someone point out the blurry parts in my uploaded version? I'll post the original 100% view of those parts here accordingly so that everyone can look into it.
I'll also keep using this topic for future post-screening stuff.
JakTrax
Re: Post Screening - AC02
Thu Apr 30, 2020 7:57 pm
Generally looks okay to me but there are small areas that for some reason appear soft/blurry. If you say the original is tack sharp you have your answer, however: it's obviously the edit. I've had it where pin-sharp photos have looked dodgy after processing and I have found that uploading at a larger size sorts it.
Can you not just post the full-sized original somewhere, rather than just parts of it?
AC02
Thu Apr 30, 2020 10:23 pm
Thanks for the reply. I think it's not 100% "tack" sharp, but definitely fixable. Here's the 100% view.
JakTrax
Thu Apr 30, 2020 10:32 pm
Possibly slight micro-blur in parts but should be fixable. I'd expect the registration and '747' titles at the rear to look soft/blurry since there are very high contrast edges causing CA. More worrying is the level of noise, however.
Karl
AC02
Thu Apr 30, 2020 10:48 pm
Karl
I‘ll try a different sharpness & contrast setting for this photo. Thanks Karl!
For the 100% view above I reset all my sharpness/noise reduction settings to reflect the original appearance.
kann123air
Sun May 03, 2020 4:46 am
I agree with Karl in that noise is the biggest (and honestly the only) problem here, though a little sharpening increase wouldn't hurt. Excited to see this shot up on the DB. A great one for sure.
Going for great
Users browsing this forum: No registered users and 4 guests
