bkmbr
Airworthiness Directive for the 777's GE GE90
Thu May 14, 2020 12:30 am
I haven't found any post about this new airworthiness directive for the 777's GE engines
The FAA is adopting a new airworthiness directive (AD) for all General Electric Company (GE) GE90-110B1 and GE90-115B model turbofan engines with a certain interstage high-pressure turbine (HPT) rotor seal installed. This AD requires initial and repetitive ultrasonic inspections (USIs) of the interstage HPT rotor seal and, depending on the results of the inspection, replacement of the interstage HPT rotor seal with a part eligible for installation. This AD also requires the removal of the interstage HPT rotor seal at the next engine shop visit. This AD was prompted by investigative findings from an event involving an uncontained interstage HPT rotor seal failure that resulted in debris penetrating the fuselage and the other engine. The FAA is issuing this AD to address the unsafe condition on these products.
https://www.federalregister.gov/documen ... an-engines
https://rgl.faa.gov/Regulatory_and_Guid ... -10-04.pdf
Aesma
Re: Airworthiness Directive for the 777's GE GE90
Thu May 14, 2020 1:31 am
I believe this is the uncontained failure that led to the AD : http://avherald.com/h?article=4ce47f3f&opt=0
vikkyvik
Thu May 14, 2020 2:35 pm
I find it interesting that there are apparently zero US-registered airplanes that this affects.
The FAA estimates that this AD affects 0 engines installed on airplanes of U.S. registry.
Does this somehow apply to international airlines flying to the US? Or are they only covered by their home country's aviation regulating agency?
Have other agencies adopted similar ADs?
Users browsing this forum: 817Dreamliiner and 5 guests
