kabq737
Advantages of a pullback vs a pushback?
Thu May 21, 2020 7:25 pm
Hey everybody
I recently came across this video of a Korean Air 747 being pulled back as opposed to pushed back.
https://www.instagram.com/tv/CAZcFofgQf ... b0bzbvxhdh
Is there an advantage to this sort of thing? How common is it?
Kabq737
Been on: 320, 321, 333, 733, 73G, 738, 739, 744, 752, 763, 764, 772, 789, C208, CR7, CR9, BE20, MD83, MD88, MD90, E70, E75, E90, TRIM
Flown: SEEKER, C150M C172N, C172R, C172S, C182RG, DA40, PA-46
strfyr51
Re: Advantages of a pullback vs a pushback?
Thu May 21, 2020 8:19 pm
kabq737 wrote:
Hey everybody
Kabq737
It depends on what the need is. the 747 can be moved by towing from the front or pushing from the back. The tug driver? Had better know what they're doing though.
I've done it and seen it done both ways. Especially docking into a Hangar with access scaffolding all around it.
fr8mech
Fri May 22, 2020 12:29 am
Really, just different technique. As noted, if towing from below, you can get into a tighter space.
I've found that towing from below is a little quicker, and you don't have very much counter steering to get the aircraft where you want it. You just need to be sure you keep the tug pointed between the wing gear, because you no longer have nose gear visibility, depending on how you set up the tug.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
kabq737
Fri May 22, 2020 2:29 am
That’s interesting thanks for the answers everyone.
Can all aircraft have a tow bar connected from the rear?
StereoTechque
Fri May 22, 2020 3:15 am
Nope not all aircrafts have that luxury.
There is a provision on the A320 MLG so that it can be pulled back in case of NLG overrun.
Looking California.. Feeling Minnesota.... R. I.P. Chris Cornell...
vikkyvik
Fri May 22, 2020 4:26 am
I've never seen this before....kinda crazy!
I'm obviously no expert, but I'd imagine being able to see the nose gear and the airplane, without turning your head back and forth, would be one advantage of a pushback.
fr8mech
Fri May 22, 2020 4:32 am
That type of tug can be driven from either end. The way the guy on the video was is doing it was frowned upon by one of my employers. You hooked the aircraft up, then went to the other cab and faced the direction of travel during the actual push.
vikkyvik
Fri May 22, 2020 4:34 am
But doesn't that mean you still have to turn around to see the nose gear?
fr8mech
Fri May 22, 2020 4:46 am
Yes. But the spots we used this type of push on...in the hangar area...was a quick turn to a straight back push for a hundred yards or so, then stop and drop the aircraft. Spent almost the entire push looking at the main gear.
vikkyvik
Fri May 22, 2020 2:36 pm
Gotcha, thanks.
DFW17L
Sun May 24, 2020 5:18 pm
I remember when AA used TRs for “pullback” on the MD80s at DFW. The sequence would start with a momentary forward motion, then you’d hear the TRs engage before starting your pullback. Except for the slight forward motion, it was pretty cool.
AirKevin
Tue May 26, 2020 6:42 pm
Kind of curious if there's a tug that's small enough to fit under some of these planes, like a 737.
Captain Kevin
strfyr51
Tue May 26, 2020 10:24 pm
No, the belly has to be more than 6' above the ground to even do that, so not may Airliners have that clearance.
strfyr51
Tue May 26, 2020 10:34 pm
the tug driver could have driven that TL from either end. while I do not agree with the way he did it? He didn't damage the airplane so? It was ok.
fr8mech
Wed May 27, 2020 12:33 am
I don't disagree. Just saying the way he did it was frowned upon by one of my employers. Another employer didn't really address it one way or the other. I've done it both ways, depending on the situation. I just preferred to drive "forward".
If done right, it's perfectly safe.
StereoTechque
Wed May 27, 2020 2:17 am
It was called Powerback. Saved a few minutes of time but it is expensive.
RetiredWeasel
Wed May 27, 2020 3:41 am
Not really that expensive depending on the price of fuel. Many out stations during my 727 days had limited tugs if you could even get one and my company paid some of these contractors a bunch for pushbacks. Cheaper to do a powerback I was told. Still needed a marshaller and wing walker.
FGITD
Wed May 27, 2020 3:54 am
One of the more fun marshalling signals though. Definitely required a little more skill and a quick talk with the pilots. You'd be hard pressed to find a team that would know how to do it these days.
Users browsing this forum: shamrock137 and 9 guests
