enilria
OAG Changes 8/18/2020:FALL FALLING;AA/AS/DL Cuts;AC Drops SNAYVR;UA Adds LGA-Florida,SAL-IAD/LAX,DENCYS,IADPQI,IAHTLH
Tue Aug 18, 2020 1:25 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M BIM-FLL SEP 0.4>0[0.5]
3M ELH-FLL SEP 0.7>0.3[0.8] OCT 0.8>0.3[1.7]
3M FLL-GGT SEP 0.4>0.1[0.5] OCT 0.5>0.2[1.1]
3M HSV-MCO SEP 0.9>0[1.0] OCT 1.0>0.6[1.0]
4B ATL-MSL SEP 3>1.7[3] OCT 3>1.7[4] NOV 3>1.7[4] DEC 3>1.7[3] JAN 0.4>0.2[4]
4B BNA-MSL SEP 0>1.7[0] OCT 0>1.7[0] NOV 0>1.7[0] DEC 0>1.7[0] JAN 0>0.3[0]
NOTE: 9K appears to have ongoing issues with the TECNAM not appearing in the data
9X ACK-EWB SEP 0>1.3[0] OCT 0>0.6[0]
9X ACK-OWD SEP 0.8>1.7[0.5] OCT 0.4>0.7[0.7]
AA ABQ-DFW SEP 5>4[8]
AA ABQ-LAX SEP 0.7>0[3]
AA ABQ-PHX SEP 2>1.6[4]
AA ALB-ORD SEP 2>1.4[3]
AA ALB-PHL SEP 3>1.8[5]
AA ALO-ORD SEP 1.4>1.0[1.9]
AA ASE-DFW SEP 1.1>1.6[1.0]
AA ASE-ORD SEP 0.8>0.6[0.2]
AA ATL-DCA SEP 0.6>0.2[4]
AA ATL-PHL SEP 3>1.8[5]
AA AUS-LAX SEP 0.5>0[3]
AA AVL-PHL SEP 0.7>0[1.0]
AA BDL-DCA SEP 0.8>0.2[5]
AA BDL-PHL SEP 3>1.7[6]
AA BGR-PHL SEP 3>1.8[5]
AA BHM-ORD SEP 1.4>1.0[2]
AA BNA-LAX SEP 0.7>0[1.8]
AA BNA-PHL SEP 3>1.8[6]
AA BOI-DFW SEP 3>1.9[3]
AA BOS-LAX SEP 0.7>0[5]
AA BOS-PHL SEP 6>5[13]
AA BTV-DCA SEP 0.4>0[3]
AA BUF-DCA SEP 0.9>0.2[3]
AA BUF-PHL SEP 3>1.8[5]
AA CHO-ORD SEP 0.6>0[1.8]
AA CHO-PHL SEP 1.0>0.8[1.9]
AA CID-DFW SEP 3>2[4]
AA CID-ORD SEP 3>2[5]
AA CLE-DCA SEP 0.8>0.2[3]
AA CLL-DFW SEP 3>2[4]
AA CLT-GNV SEP 3>2[4]
AA CLT-HVN SEP 1.1>0.7[1.9]
AA CLT-IPT SEP 2>1.3[1.9]
AA CLT-ITH SEP 1.1>0.7[2]
AA CLT-YYZ SEP 1.7>1.0[5]
AA CMH-PHL SEP 3>1.8[6]
AA CMI-ORD SEP 1.9>0.5[4]
AA COU-ORD SEP 1.5>0.0[3]
AA CVG-DCA SEP 1.0>0.3[3]
AA CVG-PHL SEP 1.7>1.1[5]
AA DAY-ORD SEP 1.6>1.2[4]
AA DAY-PHL SEP 2>1.6[4]
AA DBQ-ORD SEP 2>1.1[3]
AA DCA-ECP SEP 1.0>0.3[1.0]
AA DCA-GRR SEP 0.9>0.2[1.6]
AA DCA-ILM SEP 1.0>0.3[1.0]
AA DCA-JAX SEP 1.0>0.3[3]
AA DCA-MCI SEP 0.8>0.3[2]
AA DCA-MEM SEP 1.0>0.8[2]
AA DCA-MYR SEP 0.6>0.3[1.0]
AA DCA-ORD SEP 5>4[9]
AA DCA-PIT SEP 0.5>0[3]
AA DCA-ROC SEP 1.1>0.4[3]
AA DCA-SDF SEP 1.0>0.3[3]
AA DCA-SRQ SEP 0.8>0.5[1.0]
AA DCA-SYR SEP 0.7>0.2[3]
AA DFW-FSD SEP 3>2[3]
AA DFW-HKG SEP 0.8>0[1.0] OCT 1.0>0.3[1.0]
AA DFW-HND SEP 1.0>0.3[1.0] OCT 1.0>0.3[0]
AA DFW-LAW SEP 3>1.9[4]
AA DFW-LRD SEP 3>2.0[4]
AA DFW-ORD SEP 10>9[14]
AA DFW-PHX SEP 10>9[12]
AA DFW-ROW SEP 1.8>1.1[3]
AA DFW-SJT SEP 4>3[6]
AA DFW-TYR SEP 3>2[4]
AA DTW-PHL SEP 2>1.7[5]
AA ELP-ORD SEP 1.5>1.1[2]
AA ELP-PHX SEP 3>1.9[5]
AA FLL-PHL SEP 3>1.9[4]
AA GCM-MIA SEP 0.5>0[1.6]
AA GRR-PHL SEP 1.6>1.0[3]
AA HAV-MIA SEP 2>1.0[5]
AA HNL-LAX SEP 2>1.0[4]
AA HSV-ORD SEP 0.7>0.0[1.9]
AA IAH-LAX SEP 0.6>0[3]
AA ICT-ORD SEP 2>1.4[3]
AA ILM-ORD SEP 0.4>0[0.1]
AA ILM-PHL SEP 1.6>1.0[3]
AA IND-PHL SEP 3>1.8[5]
AA JAX-PHL SEP 2.0>1.6[3]
AA LAS-PHL SEP 1.6>1.1[4]
AA LAX-MEX SEP 0.5>0[1.0]
AA LAX-MIA SEP 5>4[9]
AA LAX-PDX SEP 0.7>0[3]
AA LAX-SEA SEP 1.5>0.2[4]
AA LAX-SFO SEP 3>2.0[7]
AA LGA-TVC JUN 0>0.3[0]
AA LIT-ORD SEP 2>0.2[3]
AA MCI-PHX SEP 1.8>1.1[2]
AA MCO-PHL SEP 6>4[8]
AA MEM-ORD SEP 3>1.7[5]
AA MEX-PHX SEP 0.4>0[1.0]
AA MHK-ORD SEP 1.9>0[3]
AA MHT-PHL SEP 2>1.7[5]
AA MIA-MID SEP 0.5>0[1.0]
AA MIA-SAL SEP 0.5>0.3[1.0]
AA MIA-SAP SEP 0.6>0.4[1.0]
AA MIA-TGU SEP 0.6>0.3[1.0]
AA MRY-PHX SEP 3>2.0[3]
AA MSP-PHL SEP 1.9>1.5[4]
AA MYR-PHL SEP 1.7>1.1[3]
AA OKC-PHX SEP 1.8>1.2[2]
AA ONT-PHX SEP 3>2.0[5]
AA ORD-PDX SEP 1.5>1.1[2]
AA ORD-PHL SEP 8>6[12]
AA ORD-PHX SEP 6>5[9]
AA ORD-RST SEP 3>1.7[3]
AA ORD-RSW NOV 1.0>2.0[2.0] DEC 2>3[3]
AA ORD-SAT SEP 1.1>0.0[3]
AA ORD-SAV OCT 0.8>1.0[0.9] NOV 0>0.6[1.0] DEC 0>0.5[0.1]
**AA ORD-SCE SEP 1.1>0[0.3] OCT 0.3>0[1.9]
AA ORD-SDF SEP 2>1.2[5]
AA ORD-SJC SEP 0.6>0.2[3]
AA ORD-SMF SEP 0.7>0[1.0]
AA ORD-SNA SEP 2>1.7[5]
AA ORD-SUX SEP 1.5>1.1[1.9]
AA ORD-TOL SEP 1.3>0.1[3]
AA ORD-XNA SEP 2>1.6[5]
AA ORF-PHL SEP 3>1.7[6]
AA PBI-PHL SEP 3>2[5]
AA PHF-PHL SEP 1.6>1.0[3]
AA PHL-PIT SEP 4>2[6]
AA PHL-PNS SEP 1.0>0.8[1.0]
AA PHL-PVD SEP 3>1.7[5]
AA PHL-PWM SEP 2>1.7[5]
AA PHL-RDU SEP 3>2[6]
AA PHL-RIC SEP 3>1.8[6]
AA PHL-ROA SEP 1.4>0.8[1.9]
AA PHL-RSW SEP 3>2[5]
AA PHL-SAN SEP 1.4>0.8[3]
AA PHL-SAV SEP 1.5>0.9[3]
AA PHL-SBY SEP 1.8>1.4[3]
AA PHL-SCE SEP 1.9>1.5[4]
AA PHL-SEA SEP 0.7>0.5[3]
AA PHL-SJU SEP 2.0>1.0[1.2]
AA PHL-SYR SEP 2>1.7[5]
AA PHL-TPA SEP 5>3[6]
AA PHL-TYS SEP 1.5>0.9[3]
AA PHL-YUL SEP 1.9>0.9[5]
AA PHL-YYZ SEP 1.9>0.9[5]
AA PHX-SBA SEP 3>1.9[5]
AC ATL-YYZ SEP 4>0[5]
AC AUS-YYZ SEP 1.4>0[1.7]
AC BNA-YYZ SEP 1.5>0[2]
AC BOS-YHZ SEP 1.5>0[2]
AC BOS-YOW SEP 1.5>0[2]
AC BOS-YUL SEP 4>0.9[5]
AC BOS-YYZ SEP 6>1.0[7]
AC BWI-YYZ SEP 2>0[3]
AC CLE-YYZ SEP 2>0[3]
AC CLT-YYZ SEP 1.5>0[2]
AC CMH-YYZ SEP 3>0[4]
AC CVG-YYZ SEP 2>0[3]
AC DCA-YOW SEP 1.4>0[1.9]
AC DCA-YUL SEP 1.5>0[2]
AC DCA-YYZ SEP 3>0.9[4]
AC DEN-YUL SEP 0.7>0[0.9]
AC DEN-YVR SEP 1.4>0[1.7]
AC DEN-YYZ SEP 1.5>0[2]
AC DFW-YUL SEP 0.8>0[1.0]
AC DFW-YVR SEP 0.8>0[1.0]
AC DFW-YYZ SEP 3>0[4]
AC DTW-YYZ SEP 3>0[4]
AC EWR-YOW SEP 2>0[3]
AC EWR-YUL SEP 4>2[4]
AC EWR-YVR SEP 1.5>0[1.5]
AC EWR-YYC SEP 0.7>0[1.0]
AC EWR-YYZ SEP 6>3[7]
AC FLL-YUL SEP 0.8>0.3[2]
AC FLL-YYZ SEP 0.7>0.3[1.7]
AC HNL-YVR SEP 0.8>0[1.2]
AC IAD-YUL SEP 0.8>0[1.0]
AC IAD-YYZ SEP 1.8>1.0[2]
AC IAH-YUL SEP 1.5>0[2]
AC IAH-YYC SEP 1.5>0[2]
AC IAH-YYZ SEP 3>1.0[3]
AC LAS-YUL SEP 1.5>0[2]
AC LAS-YVR SEP 1.5>0[2]
AC LAS-YYC SEP 0.8>0[1.0]
AC LAS-YYZ SEP 1.5>0[3]
AC LAX-YUL SEP 2>0[3]
AC LAX-YVR SEP 5>0.9[5]
AC LAX-YYC SEP 1.5>0[2]
AC LAX-YYZ SEP 4>0.7[5]
AC LGA-YUL SEP 6>0.8[8]
AC LGA-YYZ SEP 10>2[12]
AC MCI-YYZ SEP 0.8>0[1.0]
AC MCO-YUL SEP 1.1>0[1.9]
AC MCO-YYZ SEP 1.5>0[3]
AC MEM-YYZ SEP 0.8>0[1.0]
AC MIA-YUL SEP 0.4>0[0.8]
AC MIA-YYZ SEP 0.8>0[1.6]
AC MKE-YYZ SEP 1.4>0[1.9]
AC MSP-YYZ SEP 2>0[3]
AC MSY-YYZ SEP 0.8>0[1.0]
AC OGG-YVR SEP 0.8>0[1.1]
AC ORD-YUL SEP 4>0.7[5]
AC ORD-YVR SEP 1.5>0[1.8]
AC ORD-YYZ SEP 7>2.0[8]
AC PDX-YVR SEP 3>0.7[3]
AC PDX-YYC SEP 0.8>0[1.0]
AC PHL-YUL SEP 2>0[3]
AC PHL-YYZ SEP 4>0[5]
AC PHX-YUL SEP 0.3>0[0.5]
AC PHX-YVR SEP 0.8>0.1[1.0]
AC PHX-YYC SEP 0.8>0[1.0]
AC PHX-YYZ SEP 0.8>0[1.2]
AC PIT-YUL SEP 0.8>0[1.0]
AC PIT-YYZ SEP 3>0[4]
AC RDU-YUL SEP 0.8>0[1.0]
AC RDU-YYZ SEP 2>0[3]
AC RSW-YYZ SEP 0.3>0[0.9]
AC SAN-YVR SEP 2>0[3]
AC SAN-YYZ SEP 0.8>0[1.0]
AC SEA-YVR SEP 4>1.0[5]
AC SEA-YYZ SEP 1.5>0[1.4]
AC SFO-YEG SEP 0.8>0[1.0]
AC SFO-YUL SEP 2>0[2]
AC SFO-YVR SEP 3>0.9[4]
AC SFO-YYC SEP 1.5>0[2]
AC SFO-YYZ SEP 4>0.6[5]
AC SJC-YVR SEP 2>0[3]
AC SMF-YVR SEP 0.8>0[1.0]
**AC SNA-YVR SEP 0.8>0[1.0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0] APR 1.0>0[0]
AC STL-YYZ SEP 1.5>0[2]
AC TPA-YYZ SEP 0.8>0[1.6]
AD FLL-VCP OCT 1.0>0.5[1.1]
AD MCO-VCP OCT 1.0>0[1.1]
AI BOM-EWR SEP 1.0>0.6[1.0] OCT 1.0>0.6[1.0]
AI DEL-JFK SEP 1.0>0.5[1.0] OCT 1.0>0.7[1.0]
AI DEL-ORD SEP 1.0>0.3[1.0] OCT 1.0>0.4[1.0]
AI DEL-SFO SEP 1.3>0.6[1.3] OCT 1.3>0.7[1.3]
AM JFK-MEX NOV 3>0[2] DEC 3>0[2.0] JAN 3>0[3]
AM LAX-MEX NOV 4>0[1.1] DEC 5>0[1.0] JAN 4>0[1.6]
AR EZE-JFK SEP 0.3>0.1[0.5]
AR EZE-MIA SEP 0.4>0.2[0.7]
AS ABQ-SEA OCT 2>1.0[1.9] NOV 2>1.4[2]
AS ADQ-ANC OCT 1.8>1.4[1.7]
AS ANC-BET OCT 2>1.4[2]
AS ANC-BRW OCT 0.5>1.0[0.5] NOV 0.5>0.8[0.5]
AS ANC-HNL OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS ANC-JNU OCT 4>3[3] NOV 4>3[4]
AS ANC-LAX SEP 0.7>0[0.7] OCT 0.7>0[0.6] NOV 0.7>0.4[0.6]
AS ANC-OME OCT 1.5>1.0[1.5] NOV 1.5>1.1[1.6]
AS ANC-ORD OCT 0.2>0[0.9]
AS ANC-OTZ OCT 1.5>1.0[1.4] NOV 1.5>1.1[1.5]
AS ANC-PDX OCT 4>1.0[3] NOV 4>2[3]
AS ANC-SEA OCT 15>11[17] NOV 14>12[14]
AS ATL-SEA SEP 1.9>1.1[3] OCT 3>1.9[1.8] NOV 3>2[1.9]
AS AUS-PDX SEP 1.0>0[2] OCT 2>0.8[1.0] NOV 1.6>0.9[1.0]
AS AUS-SAN OCT 2>1.0[1.0] NOV 2>1.4[1.0]
AS AUS-SEA OCT 3>2[1.9] NOV 3>2[2]
AS AUS-SFO OCT 2>1.0[1.8] NOV 2>1.4[1.9]
AS AUS-SJC OCT 2>1.0[1.8] NOV 2>1.4[1.9]
AS BLI-SEA OCT 4>2[5] NOV 4>3[5]
AS BOI-GEG OCT 4>2[2] NOV 4>3[2]
AS BOI-PAE OCT 1.0>0[0] NOV 1.0>0.4[0]
AS BOI-PDX OCT 7>4[7] NOV 8>6[8]
AS BOI-SEA OCT 10>9[11]
AS BOI-SFO SEP 2>1.0[2]
AS BOI-SJC SEP 2>1.0[2]
AS BOI-SMF OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS BOS-LAX OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS BOS-PDX SEP 1.0>0[1.3] OCT 1.2>0.9[1.9]
AS BOS-SAN SEP 0.9>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS BOS-SEA OCT 4>2[3] NOV 4>2[3]
AS BOS-SFO OCT 2>1.0[1.8] NOV 2.0>1.4[1.9]
AS BRW-FAI OCT 0.5>0[0.5] NOV 0.5>0.2[0.5]
AS BRW-SCC OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS BUR-PDX OCT 2>1.0[1.9] NOV 3>1.7[2]
AS BUR-SEA SEP 4>3[4] OCT 4>2[4] NOV 4>3[4]
AS BWI-SEA OCT 2>1.0[1.9] NOV 2.0>1.4[2]
AS BZN-PDX OCT 1.2>0.1[1.0] NOV 1.0>0.4[1.0]
AS BZN-SEA OCT 4>3[3]
AS CHS-SEA OCT 1.0>0.7[0.8]
AS DAL-LAX OCT 3>0[3] NOV 3>1.1[3]
AS DAL-PDX OCT 3>0[1.9] NOV 3>1.1[2]
AS DAL-SEA OCT 4>1.9[3] NOV 4>3[3]
AS DAL-SFO OCT 3>1.0[1.9] NOV 3>1.7[2]
AS DCA-PDX SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS DCA-SEA OCT 2>1.1[1.9] NOV 2>1.4[2]
AS DCA-SFO SEP 1.0>0.6[1.0]
AS DEN-SEA OCT 5>4[6]
AS DFW-SEA SEP 4>3[3] OCT 3>4[3]
AS EAT-SEA OCT 3>2[3] NOV 3>2[3]
AS EUG-PDX OCT 3>0[3] NOV 3>0.7[3]
AS EUG-SEA SEP 5>4[5]
AS EWR-LAX OCT 3>0.8[3] NOV 3>1.7[3]
AS EWR-PDX OCT 1.0>0[0.8] NOV 1.0>0.4[0.9]
AS EWR-SAN OCT 1.0>0[0.8] NOV 1.0>0.4[0.9]
AS EWR-SEA SEP 2>1.2[3] OCT 3>1.8[2] NOV 3>2[3]
AS EWR-SFO OCT 3>0.7[3] NOV 3>1.5[3]
AS EWR-SJC OCT 0.8>0[0.8] NOV 0.9>0.3[0.9]
AS FAI-SCC OCT 0.4>0[0.3] NOV 0.3>0.1[0.4]
AS FAI-SEA OCT 4>2[4] NOV 4>3[4]
AS FAT-LAX OCT 2>1.1[0] NOV 2>1.4[0]
AS FAT-PDX OCT 2>1.0[1.9] NOV 2>1.4[2]
AS FAT-SAN SEP 2>1.0[4] OCT 4>1.9[3] NOV 4>3[3]
AS FAT-SEA SEP 3>2[3]
AS FLL-LAX OCT 0.8>0[1.0] NOV 1.4>0.7[1.0]
AS GDL-SJC OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS GEG-PAE OCT 1.0>0[0] NOV 1.0>0.4[0]
AS GEG-PDX OCT 7>4[8] NOV 7>5[9]
AS GEG-SAN OCT 2>1.0[1.0] NOV 2>1.4[1.0]
AS GEG-SEA OCT 17>12[16] NOV 16>13[17]
AS GTF-SEA OCT 2>1.1[1.5] NOV 2>1.4[1.6]
AS HNL-LAX OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS HNL-OAK OCT 0.5>0[0.4] NOV 0.4>0.2[0.4]
AS HNL-SEA OCT 3>2[3] NOV 3>2[3]
AS HNL-SFO OCT 0.5>0[1.0] NOV 0.8>0.4[1.0]
AS IAD-LAX OCT 2>0[1.8] NOV 2>0.7[1.9]
AS IAD-SEA OCT 3>1.7[1.8] NOV 3>2[1.9]
AS IAD-SFO OCT 2>0[1.9] NOV 2>0.7[2]
AS IAH-SEA OCT 2>1.0[1.8] NOV 2>1.4[1.9]
AS JFK-LAX OCT 5>0[5] NOV 5>1.8[5]
AS JFK-PDX OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS JFK-SEA OCT 3>2[3] NOV 3>2[3]
AS JFK-SFO SEP 1.0>0.7[4] OCT 4>0.9[4] NOV 4>2[4]
AS JNU-SEA NOV 3>2[4]
AS JNU-SIT OCT 1.7>1.0[1.9] NOV 1.8>1.3[1.9]
AS KOA-OAK OCT 0.5>0[0.6] NOV 0.6>0.2[0.6]
AS KOA-PDX OCT 1.0>0[0] NOV 1.0>0.7[0]
AS KOA-SAN OCT 1.0>0.5[0.4] NOV 1.0>0.7[0.5]
AS KOA-SEA OCT 3>1.9[1.4] NOV 3>2[2]
AS KTN-SEA OCT 3>2[4] NOV 3>2[3]
AS KTN-SIT OCT 1.0>0.0[1.0] NOV 1.0>0.4[1.1]
AS LAS-LAX OCT 2>0[3] NOV 2>0.7[4]
AS LAS-PAE OCT 2>1.0[1.9] NOV 2>1.4[2]
AS LAS-SEA OCT 9>7[8] NOV 9>7[8]
AS LAX-LIR OCT 0.5>0[0.5] NOV 0.7>0.3[0.6]
AS LAX-MSO OCT 1.0>0[0] NOV 1.0>0.4[0]
AS LAX-MZT OCT 0.5>0.3[0.3] NOV 0.8>0.5[0.6]
AS LAX-OGG OCT 0.7>0[1.0] NOV 0.8>0.4[1.0]
AS LAX-ORD OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS LAX-PAE OCT 2>0.9[3] NOV 2>1.4[3]
AS LAX-PDX OCT 8>5[8] NOV 10>7[8]
AS LAX-SEA SEP 10>9[14] OCT 14>8[13] NOV 14>10[14]
AS LAX-SFO SEP 8>5[13] OCT 13>6[9] NOV 13>9[10]
AS LAX-SJC SEP 4>2[7] OCT 7>3[4] NOV 7>4[4]
AS LAX-SJD OCT 3>2.0[1.5]
AS LAX-STS SEP 2>1.0[3] OCT 3>1.9[3]
AS LIH-OAK OCT 0.5>0[0.4] NOV 0.4>0.1[0.5]
AS LIH-PDX OCT 0.6>0[0]
AS LIH-SAN OCT 1.0>0.5[0.6] NOV 1.0>0.6[0.6]
AS MCO-PDX OCT 1.0>0.5[1.0] NOV 1.0>0.7[1.0]
AS MCO-SAN SEP 0.3>0[1.0] OCT 1.0>0.8[0.7] NOV 2>1.3[0.7]
AS MCO-SEA OCT 3>2[1.9] NOV 3>2[2]
AS MFR-PDX SEP 2>1.5[6] OCT 6>1.9[5] NOV 6>3[6]
AS MRY-SAN SEP 1.0>0.5[2] OCT 2>1.0[1.0] NOV 2>1.4[1.0]
AS MSO-PDX SEP 1.0>0[1.3] OCT 1.2>0.9[1.0]
AS MSP-PDX SEP 1.0>0[1.0]
AS MSY-SEA OCT 1.8>1.0[1.0] NOV 2>1.4[2]
AS OAK-OGG OCT 0.5>0[1.0] NOV 0.6>0.2[1.0]
AS OAK-PDX OCT 4>0.9[3] NOV 4>1.7[3]
AS OAK-SEA OCT 4>3[4]
AS OGG-SEA OCT 3>2[1.9]
AS OGG-SFO OCT 0.5>0[1.0] NOV 0.6>0.4[1.0]
AS OME-OTZ OCT 0.5>0[0.5] NOV 0.5>0.2[0.5]
AS ONT-PDX OCT 2>1.0[1.9] NOV 3>1.7[2]
AS ONT-SEA OCT 3>2[3] NOV 3>2[3]
AS ORD-SEA OCT 5>4[5] NOV 5>4[5]
AS ORD-SFO OCT 2>1.0[1.9] NOV 2>1.4[2]
AS PAE-PDX OCT 2>0[4] NOV 2>0.7[4]
AS PAE-PHX OCT 2>1.0[1.9] NOV 2>1.4[2]
AS PAE-SAN OCT 2>0[1.9] NOV 2>0.7[2]
AS PAE-SFO OCT 2>0[1.9] NOV 2>0.7[2]
AS PAE-SJC OCT 2>0[1.9] NOV 2>0.7[2]
AS PAE-SNA OCT 1.2>0[1.0] NOV 1.0>0.4[1.0]
AS PDX-RDM OCT 4>2[4] NOV 4>3[4]
AS PDX-RNO OCT 4>2[4] NOV 4>3[4]
AS PDX-SAN SEP 5>4[6] OCT 6>4[4] NOV 6>5[4]
AS PDX-SBP OCT 1.0>0[0] NOV 1.0>0.4[0]
AS PDX-SEA OCT 18>17[21]
AS PDX-SFO SEP 5>4[7] OCT 7>5[6] NOV 7>6[7]
AS PDX-SJC OCT 5>2[5] NOV 5>3[5]
AS PDX-SLC SEP 2>1.0[2]
AS PDX-SMF OCT 4>2[4] NOV 4>3[4]
AS PDX-SNA SEP 3>2[4] OCT 4>3[4]
AS PDX-STS OCT 2>1.0[1.9] NOV 2>1.4[2]
AS PDX-YVR OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS PHL-SFO OCT 1.0>0[1.0] NOV 1.0>0.4[1.0]
AS PHX-SEA OCT 6>7[6]
AS PHX-SFO OCT 2>1.0[0] NOV 2>1.4[0]
AS PSC-SEA OCT 6>4[5] NOV 6>5[6]
AS PSP-SEA OCT 4>5[1.1]
AS PSP-SFO OCT 5>3[4] NOV 5>4[4]
AS PUW-SEA OCT 4>2[0.8] NOV 4>3[3]
AS PVR-SAN NOV 1.0>0.5[0.3]
AS PVR-SJC OCT 1.0>0.2[0] NOV 1.0>0.5[0]
AS RDM-SEA SEP 5>4[6] OCT 6>5[5]
AS RDM-SFO OCT 1.0>0.1[0] NOV 1.0>0.4[0]
AS RDU-SEA OCT 2>1.0[1.0] NOV 2>1.4[1.0]
AS RNO-SEA OCT 4>3[5]
AS SAN-SBP OCT 1.0>0[0] NOV 1.0>0.4[0]
AS SAN-SEA SEP 7>6[9] OCT 9>6[8] NOV 10>7[8]
AS SAN-SFO SEP 5>3[8] OCT 8>4[4] NOV 8>5[5]
AS SAN-SJC SEP 3>2[8] OCT 8>2[4] NOV 7>3[4]
AS SAN-SJD OCT 1.8>1.0[1.7] NOV 2>1.4[1.7]
AS SAN-STS OCT 2>1.0[1.0] NOV 2>1.4[1.0]
AS SEA-SFO SEP 8>6[13] OCT 13>7[11] NOV 13>9[12]
AS SEA-SJC OCT 9>4[7] NOV 9>6[8]
AS SEA-SLC SEP 5>4[5] OCT 5>3[5] NOV 5>4[6]
AS SEA-SMF OCT 6>4[6] NOV 6>5[6]
AS SEA-SNA OCT 8>4[8] NOV 8>5[8]
AS SEA-STS OCT 4>2[3] NOV 4>2[2]
AS SEA-YEG SEP 1.0>0[3] OCT 3>0.9[3] NOV 3>1.7[3]
AS SEA-YKM OCT 3>2[3] NOV 3>2[3]
AS SEA-YLW SEP 1.0>0[1.0]
AS SEA-YVR SEP 4>2[6] OCT 6>4[6] NOV 6>5[6]
AS SEA-YYC SEP 1.0>0[3] OCT 3>0.9[3] NOV 3>1.7[3]
AS SEA-YYJ SEP 1.0>0[4] OCT 4>0.9[3] NOV 4>2[4]
AS SFO-SLC OCT 2>1.0[1.0] NOV 2>1.4[1.0]
AS SFO-SNA SEP 4>2[7] OCT 7>4[6] NOV 7>5[6]
AS SJC-SJD OCT 1.6>1.0[0.7] NOV 1.8>1.4[0.9]
AS SNA-STS OCT 2>1.0[1.0] NOV 1.6>1.0[1.0]
AT CMN-IAD SEP 0.6>0.4[0.4]
AT CMN-JFK SEP 1.5>0.9[1.0]
AV IAD-SAL SEP 1.0>0.4[1.5]
AV JFK-SAL SEP 1.0>0.4[1.3]
AV LAX-SAL SEP 2>0.8[3]
AV MIA-SAL SEP 0.4>0.1[0.7]
AV SAL-SFO SEP 0.6>0.2[0.9]
AZ JFK-MXP SEP 0.4>0[1.0]
B0 EWR-NCE SEP 0.4>0.2[0]
B0 EWR-ORY SEP 1.6>0.8[2]
B6 FLL-PAP SEP 1.3>2[1.3]
BA ATL-LHR SEP 1.0>0[1.0]
BA BOS-LHR SEP 2>1.0[4]
BA BWI-LHR SEP 0.6>0[1.0]
BA DEN-LHR SEP 0.6>0[1.0]
BA EWR-LHR SEP 1.0>0[2]
BA IAH-LHR SEP 0.7>0.4[2]
BA JFK-LHR SEP 4>2[8]
BA LAS-LGW SEP 0.9>0.0[0.9]
BA LAS-LHR SEP 1.0>0[1.0]
BA LAX-LHR SEP 2>1.0[3]
BA LGW-MCO SEP 1.0>0[1.9]
BA LHR-ORD SEP 2>1.0[2]
BA LHR-PHL SEP 1.0>0[1.5]
BA LHR-PHX SEP 0.4>0[1.0]
BR IAH-TPE SEP 0.8>0.1[1.0] OCT 1.0>0.4[0.8]
BR JFK-TPE SEP 1.0>0.4[1.0] OCT 1.0>0.5[1.0]
BR LAX-TPE SEP 3>0.6[3] OCT 3>1.1[3]
BR ORD-TPE SEP 0.7>0.3[1.0] OCT 1.0>0.5[0.7]
BR SEA-TPE SEP 1.7>0.4[1.8] OCT 1.7>0.7[1.4]
BR SFO-TPE SEP 3>0.4[3] OCT 3>1.0[3]
CA EWR-PEK SEP 1.0>0[1.0] OCT 0.9>0.2[0.8]
CA IAD-PEK SEP 1.0>0[1.0] OCT 0.9>0.2[0.9]
CA IAH-PEK SEP 0.8>0[0.9] OCT 0.8>0.2[0.7]
CA IAH-PTY SEP 0.3>0[0.3] OCT 0.3>0.1[0.3]
CA JFK-PEK SEP 2.0>0[2] OCT 1.9>0.4[1.9]
CA LAX-PEK SEP 3>0[3] OCT 3>0.6[3]
CA LAX-SZX SEP 0.4>0[0.4] OCT 0.4>0.1[0.3]
CA PEK-SFO SEP 1.0>0[1.0] OCT 1.0>0.2[1.3]
CI JFK-TPE SEP 0.6>0.1[0.6]
CI LAX-TPE SEP 1.4>0.3[1.5] OCT 1.5>1.1[1.0]
CI SFO-TPE SEP 1.0>0.3[1.0]
D7 HNL-KIX SEP 1.0>0[1.0]
DL AMS-DTW OCT 2>1.3[4]
DL AMS-JFK OCT 1.9>1.2[1.9]
DL AMS-MSP OCT 1.3>0.5[3]
DL AMS-PDX OCT 1.0>0.3[1.0]
DL AMS-SLC OCT 1.0>0.2[1.0]
DL ATH-JFK OCT 0.7>0[1.9]
DL ATL-AUA OCT 1.2>0.9[1.1]
DL ATL-BCN OCT 0.3>0[1.0]
DL ATL-BTV OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.5[0.9]
DL ATL-BZE OCT 0.7>0.5[0.7]
DL ATL-CDG OCT 1.8>1.0[1.9]
DL ATL-DUB OCT 0.3>0[1.0]
DL ATL-FCO OCT 1.0>0.2[1.9]
DL ATL-FRA OCT 1.0>0.7[1.0]
DL ATL-GCM SEP 0.6>0[1.2] OCT 1.0>0.3[0.8]
DL ATL-GGT DEC 0.4>0.2[0.6]
DL ATL-JNB OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.4[0.9]
DL ATL-KIN OCT 1.0>0.6[1.0]
DL ATL-LIR OCT 1.0>0.6[1.0]
DL ATL-MAD OCT 0.3>0[1.0]
DL ATL-MUC OCT 1.0>0.6[1.0]
DL ATL-OAK OCT 1.0>0[0.5] NOV 1.0>0[0.5] DEC 0.6>0.1[0.5]
DL ATL-PTY OCT 1.0>0.6[1.0]
DL ATL-SAL OCT 1.0>0.6[1.0]
DL ATL-SAP OCT 1.0>0.6[1.0]
DL ATL-SJO OCT 1.0>0.6[1.9]
DL ATL-STT DEC 1.5>2.1[0.9]
DL AUA-JFK OCT 1.0>0.7[1.0]
DL AUS-RDU OCT 1.0>0[0.6] NOV 1.0>0[0.6] DEC 1.0>0.5[0.7]
DL BCN-JFK OCT 1.0>0.6[1.0]
DL BDA-BOS DEC 0.6>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[1.0]
DL BDA-JFK OCT 1.0>0.6[1.0] NOV 1.0>0.6[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.1]
DL BDL-CLE OCT 0.9>0[0.7] NOV 0.9>0[0.8] DEC 0.5>0.1[0.8]
DL BDL-CVG OCT 0.8>0[0.8] NOV 0.9>0[0.9] DEC 0.5>0.1[0.7]
DL BDL-RDU OCT 1.0>0[0.8] NOV 1.0>0[0.9] DEC 1.0>0.5[0.8]
DL BNA-JFK SEP 0.8>0.5[3]
DL BNA-RDU OCT 1.8>0[1.6] NOV 1.9>0[1.8] DEC 1.1>0.1[1.6]
DL BOS-BUF OCT 3>0[2] NOV 3>0[3] DEC 1.7>0.2[2]
DL BOS-CDG SEP 0.3>0[1.0] OCT 0.9>0.2[1.0]
DL BOS-LHR OCT 1.0>0.8[1.0]
DL BOS-MEM OCT 0.9>0[0] NOV 1.0>0[0] DEC 0.6>0.1[0]
DL BOS-MIA OCT 2>0[0] NOV 2>0[0] DEC 2>1.0[0]
DL BOS-ORF OCT 1.0>0[0.8] NOV 1.0>0[0.9]
DL BRU-JFK OCT 1.0>0.7[1.0]
DL BTV-LGA OCT 1.8>0[1.9] NOV 1.9>0[1.8] DEC 1.9>0.9[1.8]
DL BUF-MSP OCT 1.0>0[1.0] NOV 1.0>0[1.0]
DL BWI-RDU OCT 2>0[1.6] NOV 2>0[1.6] DEC 1.2>0.1[1.5]
DL CDG-MSP OCT 1.0>0.3[1.0]
DL CDG-RDU OCT 0.9>0.2[1.0]
DL CDG-SEA OCT 1.0>0.7[1.0]
DL CHA-LGA OCT 1.0>0[0.9] NOV 1.0>0[1.0] DEC 0.5>0.1[0.8]
DL CHO-LGA OCT 3>0[2] NOV 3>0[3] DEC 1.9>0.6[2]
DL CHS-JFK SEP 1.0>0.7[3]
DL CLE-RDU OCT 0.8>0[0.7] NOV 0.9>0[0.9] DEC 0.5>0.1[0.8]
DL CLE-SLC OCT 1.0>0[0.8] NOV 1.0>0[0.9] DEC 1.0>0.5[0.8]
DL CMH-RDU OCT 1.8>0[1.4] NOV 1.9>0[1.6] DEC 1.1>0.1[1.4]
DL CMH-SLC OCT 1.0>0[0.9] NOV 1.0>0[1.0] DEC 1.0>0.5[0.9]
DL CUN-MSP NOV 0.8>1.0[0.1]
DL CVG-IAH OCT 1.7>0[1.2] NOV 1.0>0[1.5] DEC 1.0>0.5[0.8]
DL CVG-MCI OCT 1.7>0[1.3] NOV 1.7>0[1.5] DEC 1.0>0.1[1.3]
DL CVG-STL OCT 1.7>0[1.3] NOV 1.7>0[1.5] DEC 1.0>0.1[1.3]
DL DFW-JFK SEP 0.6>0[3]
DL DSM-LGA OCT 1.7>0[1.5] NOV 1.7>0[1.5] DEC 1.4>0.5[1.2]
DL DSM-SLC OCT 1.0>0[0.9] NOV 1.0>0[1.0] DEC 1.4>0.9[0.9]
DL DTW-HPN OCT 4>0[3] NOV 4>0[3] DEC 4>1.6[3]
DL DTW-HSV OCT 1.0>0[1.0] NOV 1.0>0[0.9] DEC 0.6>0.0[0.9]
DL DTW-LHR OCT 1.0>0.3[1.9]
DL DTW-LIT OCT 0.9>0[0.8] NOV 0.9>0[0.8]
DL DTW-PBI OCT 1.0>0[0.8] NOV 1.0>0[1.0] DEC 1.4>0.9[0.9]
DL DTW-SAV OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.5[0.9]
DL DTW-SJC OCT 1.0>0[0.6] NOV 1.0>0[0.7] DEC 1.0>0.5[0.8]
DL DTW-SMF OCT 0.8>0[0.6] NOV 0.9>0[0.7] DEC 0.8>0.3[0.6]
DL DTW-SNA OCT 0.6>0[0.8] NOV 0.6>0[0.7] DEC 0.9>0.5[0.6]
DL DUB-JFK OCT 1.0>0.7[1.0]
DL EDI-JFK OCT 1.0>0.3[1.0]
DL FCO-JFK OCT 0.9>0.6[1.0]
DL FRA-JFK OCT 1.0>0.7[1.0]
DL FWA-MSP OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.5[1.0]
DL GRU-JFK SEP 0.3>0[0.5] OCT 0.5>0.1[1.0]
DL IND-MCO OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.5[0.9]
DL IND-RDU OCT 2>0[1.6] NOV 2>0[1.8] DEC 1.4>0.4[1.5]
DL IND-SEA OCT 1.0>0[0.7] NOV 0.9>0[0.9] DEC 0.8>0.3[0.7]
DL JAX-MSP OCT 0.8>0[0.7] NOV 0.9>0[0.9] DEC 0.8>0.3[0.7]
DL JFK-LAS SEP 1.9>1.1[5]
DL JFK-LHR OCT 2>1.5[1.9]
DL JFK-LIS OCT 0.9>0.2[1.0]
DL JFK-MAD OCT 0.9>0.5[1.0]
DL JFK-MBJ OCT 1.0>0.7[1.0]
DL JFK-MXP OCT 1.0>0.8[1.0]
DL JFK-ORF OCT 3>0[3] NOV 3>0[3] DEC 3>1.5[3]
DL JFK-PUJ OCT 1.0>0[1.0] NOV 1.0>0.3[1.0]
DL JFK-SAV SEP 1.0>0.7[2]
DL JFK-SJC OCT 0.8>0[1.0] NOV 0.9>0[1.0] DEC 0.8>0.3[0.9]
DL JFK-YYZ SEP 1.0>0.2[4]
DL JFK-ZRH OCT 1.0>0.7[1.0]
DL LAX-OGG SEP 1.7>0.7[1.7]
DL LAX-OMA OCT 0.9>0[0] NOV 0.9>0[0] DEC 0.9>0.5[0.7]
DL LAX-SAN OCT 5>0[5] NOV 5>0[5] DEC 5>2[5]
DL LEX-LGA OCT 0.8>0[1.0] NOV 0.9>0[0.8] DEC 0.5>0.1[0.8]
DL LEX-MSP OCT 1.0>0[0.8] NOV 1.0>0[0.9]
DL LGA-PBI SEP 1.0>0.7[4]
DL LGA-SRQ OCT 1.0>0[0.7] NOV 1.0>0[1.0] DEC 1.0>0.5[0.9]
DL LHR-MSP OCT 1.0>0.3[1.0]
DL MCI-SEA OCT 1.0>0[0.8] NOV 1.0>0[0.9] DEC 1.0>0.5[0.8]
DL MCO-MIA OCT 5>0[0] NOV 5>0[0] DEC 4>1.6[0]
DL MIA-MSP SEP 1.0>0.7[2]
DL MIA-RDU OCT 2>0[0] NOV 2>0[0] DEC 2>1.0[0]
DL MIA-SLC OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0.5[0]
DL MIA-TPA OCT 5>0[0] NOV 5>0[0] DEC 4>1.6[0]
DL MSN-SLC OCT 0.8>0[0.8] NOV 0.9>0[0.9] DEC 0.8>0.3[0.7]
DL MSP-ORF OCT 0.9>0[0.8] NOV 0.9>0[0.8]
DL MSP-ROC OCT 0.9>0[0.8] NOV 0.9>0[0.9] DEC 0.9>0.5[0.8]
DL MSP-SYR OCT 0.9>0[0.8] NOV 0.9>0[0.9]
DL MSP-TPA SEP 1.0>0.7[2]
DL MSP-TYS OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 0.6>0.0[0.9]
DL MSP-YYC SEP 1.0>0.4[3]
DL PHL-RDU OCT 3>0[3] NOV 3>0[4] DEC 2>0.6[3]
DL PIT-RDU OCT 0.8>0[0.9] NOV 0.9>0[1.0] DEC 0.5>0.1[0.9]
DL SEA-TPA OCT 1.0>0[0] NOV 0.9>0[0] DEC 0.8>0.4[0]
DL SEA-YVR SEP 3>2[6]
EI BDL-DUB SEP 1.0>0.3[1.0]
EI BOS-DUB SEP 2>1.3[2]
EI BOS-SNN SEP 1.0>0.3[1.0]
EI DUB-EWR SEP 1.0>0.3[1.0]
EI DUB-IAD SEP 1.0>0.3[1.0]
EI DUB-JFK SEP 2>1.3[2]
EI DUB-LAX SEP 1.0>0.3[1.0]
EI DUB-MCO SEP 0.9>0.3[0.9]
EI DUB-MIA SEP 0.4>0.1[0]
EI DUB-MSP SEP 0.7>0.2[0]
EI DUB-ORD SEP 2>1.3[2]
EI DUB-PHL SEP 1.0>0.3[1.0]
EI DUB-SEA SEP 1.0>0.3[1.0]
EI DUB-SFO SEP 1.0>0.3[1.0]
EI JFK-SNN SEP 1.0>0.3[1.0]
EK DFW-DXB SEP 0.6>0[1.0]
EK DXB-IAH OCT 1.0>0.5[1.0]
EK DXB-SEA SEP 1.0>0.5[1.0]
EK DXB-SFO SEP 1.0>0.5[1.0]
ET IAH-LFW OCT 0.4>0.1[0]
EW FRA-PHX NOV 0.7>0[0] DEC 0.7>0[0] JAN 0.7>0[0] FEB 0.7>0[0] MAR 0.7>0.1[0]
FI BOS-KEF SEP 0.8>0.4[1.0]
FI DEN-KEF SEP 0.6>0[0.9]
FI EWR-KEF SEP 0.5>0[1.0]
FI IAD-KEF SEP 0.6>0.1[1.0]
FI JFK-KEF SEP 0.6>0.2[1.0]
FI KEF-MCO SEP 0.4>0[1.0]
FI KEF-MSP SEP 0.5>0[0.9]
FI KEF-ORD SEP 0.5>0[1.0]
FI KEF-SEA SEP 0.8>0.2[1.0]
HA BOS-HNL SEP 0.7>0.3[0.8]
HA CTS-HNL SEP 0.4>0.2[0.5]
HA FUK-HNL SEP 0.6>0.3[0.6]
HA HND-HNL SEP 3>1.3[3]
HA HND-KOA SEP 0.4>0.2[0.4]
HA HNL-ICN SEP 0.7>0.3[0.8]
HA HNL-ITO SEP 13>12[14]
HA HNL-JFK SEP 1.0>0.5[1.0]
HA HNL-KIX SEP 1.0>0.5[1.0]
HA HNL-KOA SEP 19>14[20]
HA HNL-LAS SEP 3>1.3[3]
HA HNL-LAX SEP 3>2[3]
HA HNL-LGB SEP 1.0>0.5[1.0]
HA HNL-LIH SEP 19>14[19]
HA HNL-NRT SEP 1.0>0.5[1.0]
HA HNL-OAK SEP 1.0>0.5[1.0]
HA HNL-OGG SEP 25>19[26]
HA HNL-PHX SEP 1.0>0.5[1.0]
HA HNL-SJC SEP 1.0>0.5[1.0]
HA HNL-SMF SEP 1.0>0.7[1.0]
HA ITO-OGG SEP 2>1.5[2]
HA KOA-LAX SEP 1.0>0.5[1.0]
HA KOA-LIH SEP 1.0>0.5[1.0]
HA KOA-OGG SEP 3>2[3]
HA LAX-LIH SEP 1.0>0.5[1.0]
HA LAX-OGG SEP 1.0>0.5[1.0]
HA LIH-OAK SEP 1.0>0.5[1.0]
HA LIH-OGG SEP 4>3[4]
HA OAK-OGG SEP 1.0>0.5[1.0]
HA OGG-PDX SEP 1.0>0.5[1.0]
HA OGG-SAN SEP 1.0>0.5[1.0]
HA OGG-SEA SEP 1.0>0.5[1.0]
HA OGG-SFO SEP 1.0>0.5[1.0]
HA OGG-SJC SEP 1.0>0.5[1.0]
HA OGG-SMF SEP 1.0>0.5[1.0]
IB JFK-MAD OCT 2>1.2[1.9]
IB MAD-MIA OCT 1.9>1.2[1.9]
IB MAD-ORD SEP 0.6>0.3[1.0] OCT 1.0>0.5[1.0]
JL DFW-HND SEP 0.3>0.6[1.0]
JL NRT-SFO SEP 0.3>0.6[1.0]
KG MSP-TVF NOV 0>1.7[0] DEC 0>1.7[0]
KQ JFK-NBO JUN 0>0.7[0.3]
LA LIM-MIA SEP 2>1.0[3] OCT 2>1.5[1.9]
NK ATL-DTW SEP 1.0>1.4[1.9]
NK ATL-FLL SEP 2.0>2[4]
NK BWI-FLL SEP 1.0>1.3[4]
NK CUN-DFW SEP 0>0.3[0.7]
NK DTW-FLL SEP 0.9>1.1[3]
NK DTW-LAS SEP 1.1>1.8[4]
NK DTW-MCO SEP 0.8>1.0[2]
NK DTW-RSW SEP 0.2>0.6[0.6]
NK FLL-MSY SEP 0.6>0.9[1.7]
NK FLL-PAP SEP 0.8>1.0[0.8]
NK FLL-SAP SEP 1.0>0.4[1.0]
NK IAH-LAS SEP 0.9>1.7[2]
NK IAH-SAP SEP 0>0.3[0.4]
OS IAD-VIE SEP 0.7>0.4[1.0]
OZ ICN-JFK SEP 2.0>1.0[2]
OZ ICN-LAX SEP 2>1.3[2]
OZ ICN-SEA SEP 1.0>0.4[1.0]
OZ ICN-SFO SEP 1.0>0.6[1.0]
QR DOH-IAH SEP 0>0.4[0.2] OCT 0.2>0.5[1.0]
QR DOH-JFK SEP 1.4>2[1.6] OCT 1.5>2[1.9]
QR DOH-PHL OCT 0.3>0.7[1.0]
SA ACC-IAD SEP 1.0>0[1.0]
SA JFK-JNB SEP 1.0>0[1.0]
SK CPH-IAD SEP 1.0>0.8[1.0]
SQ EWR-SIN SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
SQ FRA-JFK SEP 0.9>0[1.0]
SQ HKG-SFO SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
SQ IAH-MAN SEP 0.7>0[0.7] OCT 0.7>0.2[0.7]
SQ LAX-NRT SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
SQ LAX-SIN SEP 1.4>0.4[1.4] OCT 1.4>0.5[1.4]
SQ SEA-SIN SEP 0.7>0[0.7] OCT 0.7>0.2[0.4]
SQ SFO-SIN SEP 1.4>0[1.5] OCT 1.4>0.3[1.4]
TK EWR-IST SEP 0.6>0[1.0] OCT 1.0>0.7[0] NOV 1.0>0.3[0]
TP BOS-PDL SEP 0.7>0.5[0.6]
UA BOS-FLL NOV 0>1.3[0] DEC 0>1.7[0] JAN 0>0.6[0]
UA BOS-MCO NOV 0>1.3[0] DEC 0>1.7[0] JAN 0>0.6[0]
UA BOS-RSW NOV 0>0.6[0] DEC 0>1.3[0] JAN 0>0.6[0]
UA BOS-TPA NOV 0>0.6[0] DEC 0>1.3[0] JAN 0>0.6[0]
UA CLE-FLL NOV 0>0.6[0] DEC 0.5>1.1[0] JAN 1.0>1.2[0.9]
UA CLE-MCO OCT 1.0>0.7[1.0] NOV 1.0>0.7[1.2] JAN 1.0>1.2[1.1]
UA CLE-RSW NOV 0>0.6[0] JAN 1.0>1.2[1.0]
UA CLE-TPA NOV 0>0.6[0] DEC 0>0.8[0] JAN 0>0.3[0.1]
**UA CMH-RSW DEC 0>0.4[0] JAN 0>0.3[0]
**UA CYS-DEN NOV 0>0.7[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
UA EWR-GUA OCT 0.2>0.6[0.1] NOV 0.3>1.0[0.1] DEC 1.1>1.5[0.3] JAN 0.4>1.1[1.0] FEB 0.3>1.0[0.4] MAR 0.4>0.9[0.3]
UA EWR-PQI OCT 1.7>1.0[1.7] NOV 1.7>1.0[1.8] DEC 1.7>1.0[1.7] JAN 1.7>1.0[1.8] FEB 1.7>1.0[1.8] MAR 1.7>1.0[1.6] APR 1.7>1.0[1.8] MAY 1.7>1.0[1.7] JUN 1.7>1.0[1.6]
*UA EWR-SAL OCT 0.0>0.6[0] NOV 0.1>1.0[0] DEC 0.3>1.0[0.2] JAN 0.2>1.0[0.3] FEB 0.3>1.0[0.2] MAR 0.3>0.9[0.3]
UA EWR-SAP OCT 0.0>0.5[0] NOV 0.1>1.0[0] DEC 0.3>1.0[0.2] JAN 0.2>1.0[0.3] FEB 0.1>1.0[0.2] MAR 0.1>0.9[0.2]
*UA EWR-SJU OCT 1.9>4[1.0] NOV 1.4>4[1.0] DEC 2.2>4[1.5] JAN 2.3>4[2.1] FEB 2.0>4[2.4] MAR 2.1>3.7[1.9]
UA EWR-STI OCT 2.0>3[1.0] NOV 2>3[1.0] DEC 2>3[1.0] JAN 2>3[1.4] FEB 2>3[1.2] MAR 1.9>3[0.9]
**UA FLL-LGA NOV 0>1.4[0] DEC 0>1.7[0] JAN 0>0.6[0]
UA GUA-IAD OCT 0>0.7[0] NOV 0>1.0[0] DEC 0.1>1.0[0] JAN 0.0>1.0[0.1] FEB 0>1.0[0.0] MAR 0.1>0.9[0]
UA GUA-IAH FEB 2>3[3]
UA GUA-LAX OCT 0>0.6[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.9[0]
**UA IAD-PQI OCT 0>0.7[0] NOV 0>0.7[0] DEC 0>0.7[0] JAN 0>0.7[0] FEB 0>0.7[0] MAR 0>0.7[0] APR 0>0.7[0] MAY 0>0.7[0] JUN 0>0.7[0.1]
**UA IAD-SAL OCT 0>0.8[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.9[0]
UA IAD-SJO DEC 0.1>0.5[0]
UA IAD-SJU OCT 0.4>1.0[0.1] DEC 1.5>1.9[1.0] JAN 1.1>1.9[1.4] FEB 1.2>1.9[1.2] MAR 1.3>1.7[1.1]
UA IAH-PTY SEP 0.7>0.3[3]
UA IAH-SAL FEB 2>3[3] MAR 2>3[2]
UA IAH-SAP OCT 1.0>1.2[1.0] NOV 1.0>2[1.0] DEC 1.5>2[1.0] JAN 1.1>2[1.4] FEB 1.0>3[1.2] MAR 1.0>3[0.9]
UA IAH-SJU OCT 1.5>2.2[1.0] NOV 2.1>3.0[1.4] JAN 2.3>3.0[2.5] FEB 2.0>3.0[2.4] MAR 2.3>2.9[1.9]
**UA IAH-TLH NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
UA IND-RSW DEC 0>0.5[0] JAN 0>0.3[0]
**UA LAX-SAL OCT 0>0.7[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.9[0]
**UA LGA-MCO NOV 0>1.3[0] DEC 0>1.7[0] JAN 0>0.6[0]
**UA LGA-RSW NOV 0>0.6[0] DEC 0>1.3[0] JAN 0>0.6[0]
**UA LGA-TPA NOV 0>0.6[0] DEC 0>1.3[0] JAN 0>0.6[0]
**UA MKE-RSW DEC 0>0.4[0] JAN 0>0.3[0]
**UA MKE-TPA DEC 0>0.4[0] JAN 0>0.3[0]
UA ORD-SJO DEC 0.2>0.6[0]
UA ORD-SJU NOV 1.0>2.0[1.0] DEC 1.5>2.0[1.0] JAN 1.4>2.0[1.4] FEB 1.3>2.0[1.4] MAR 1.4>1.9[1.2]
**UA PIT-RSW DEC 0>0.5[0] JAN 0>0.3[0]
VA BNE-LAX NOV 0.7>0[0.9] DEC 0.8>0[0.6] JAN 0.8>0[0.9] FEB 0.9>0[0.9] MAR 0.9>0[0.8] APR 0.8>0[0.9] MAY 0.9>0[0] JUN 0.9>0[0]
VA LAX-MEL NOV 0.6>0[0.7] DEC 0.7>0[0.6] JAN 0.7>0[0.7] FEB 0.7>0[0.8] MAR 0.7>0[0.7] APR 0.7>0[0.7] MAY 0.7>0[0] JUN 0.7>0[0]
VA LAX-SYD NOV 0.7>0[1.0] DEC 0.9>0[0.7] JAN 1.0>0[1.0] FEB 1.0>0[1.1] MAR 1.0>0[0.9] APR 1.0>0[1.0] MAY 1.0>0[0] JUN 1.0>0[0]
VH MDE-MIA OCT 0>0.7[0.6]
WN ABQ-AUS JAN 0.1>1.0[1.1] FEB 0>1.0[1.2] MAR 0>1.0[1.1] APR 0>0.4[1.4]
WN ABQ-BWI JAN 0.1>1.0[1.1] FEB 0>1.0[1.1] MAR 0>1.1[0.9] APR 0>0.4[1.2]
WN ABQ-DAL JAN 0.6>5[5] MAR 0>5[4] APR 0>1.8[5]
WN ABQ-DEN JAN 0.5>4[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.3[3]
WN ABQ-HOU JAN 0.3>2[3] FEB 0>2[3] APR 0>0.8[2]
WN ABQ-LAS JAN 0.4>3[3] MAR 0>4[3] APR 0>1.5[4]
WN ABQ-LAX JAN 0.4>2.0[3] FEB 0>1.9[1.6] MAR 0>2.0[1.5] APR 0>0.7[3]
WN ABQ-MCI JAN 0.1>1.0[1.0] FEB 0>1.0[0.8] MAR 0>0.9[0.6] APR 0>0.3[0.9]
WN ABQ-MDW JAN 0.3>1.1[2] FEB 0>1.0[1.2] MAR 0>1.2[0.9] APR 0>0.5[1.2]
WN ABQ-OAK JAN 0.3>1.6[3] FEB 0>1.6[1.5] MAR 0>1.7[1.3] APR 0>0.6[1.4]
WN ABQ-PHX JAN 0.7>6[5] MAR 0>6[5] APR 0>2[5]
WN ABQ-SAN JAN 0.3>1.9[1.9] MAR 0>1.8[1.5] APR 0>0.6[1.7]
WN ALB-BWI JAN 0.6>4[5] APR 0>1.5[4]
WN ALB-DEN FEB 0>0.6[0] MAR 0>1.0[0] APR 0>0.4[0.7]
WN ALB-FLL MAR 0>0.2[0.9]
WN ALB-MCO JAN 0.1>1.3[2] FEB 0>1.9[2] APR 0>0.8[2]
WN ALB-MDW JAN 0.2>1.9[2] MAR 0>1.8[1.6] APR 0>0.6[1.8]
WN ALB-RSW FEB 0>0.8[0.1] MAR 0>0.5[0.2]
WN ALB-TPA JAN 0.1>1.0[0.7] FEB 0>1.6[1.3] MAR 0>1.0[1.2] APR 0>0.3[1.5]
WN AMA-DAL JAN 0.5>4[4] MAR 0>4[3] APR 0>1.3[4]
WN AMA-HOU JAN 0.1>0.8[0.2] FEB 0>0.9[0.1] MAR 0>0.9[0.1] APR 0>0.3[0.2]
WN AMA-LAS JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN ATL-AUS JAN 0.5>3[3] FEB 0>3[2] MAR 0>3[1.8] APR 0>1.0[2]
WN ATL-BNA JAN 0.6>3[3] FEB 0>3[4] MAR 0>3[4] APR 0>1.1[4]
WN ATL-BWI JAN 0.9>5[6] MAR 0>5[4] APR 0>2[6]
WN ATL-CLE JAN 0.3>1.7[1.8] MAR 0>1.7[1.6] APR 0>0.6[1.5]
WN ATL-CMH JAN 0.4>3[1.8] MAR 0>3[2] APR 0>1.0[2]
WN ATL-DAL JAN 0.9>7[6] MAR 0>7[6] APR 0>2[6]
WN ATL-DCA JAN 0.5>4[3] APR 0>1.3[4]
WN ATL-DEN JAN 0.5>4[4] MAR 0>4[3] APR 0>1.7[4]
WN ATL-ECP MAR 0>0.7[0] APR 0>0.4[0]
WN ATL-FLL JAN 0.5>4[4] FEB 0>4[5] APR 0>1.6[5]
WN ATL-GSP JAN 0.3>3[3] APR 0>1.0[3]
WN ATL-HOU JAN 0.6>5[5] FEB 0>5[6] APR 0>1.8[5]
WN ATL-IAD JAN 0.4>2[2] FEB 0>1.9[3] MAR 0>2.0[3] APR 0>0.7[3]
WN ATL-IND JAN 0.4>3[2] APR 0>1.0[2]
WN ATL-JAX JAN 0.4>3[2.0] FEB 0>3[2] MAR 0>3[2] APR 0>1.0[2]
WN ATL-LAS JAN 0.4>2[2] MAR 0>2[1.7] APR 0>0.8[2]
WN ATL-LGA JAN 0.6>5[5] MAR 0>5[4] APR 0>1.8[5]
WN ATL-MCI JAN 0.4>3[3] MAR 0>3[2] APR 0>1.1[3]
WN ATL-MCO JAN 0.7>6[4] MAR 0>6[5] APR 0>2[6]
WN ATL-MDW JAN 0.9>6[6] MAR 0>6[5] APR 0>2[6]
WN ATL-MEM JAN 0.3>1.7[0] FEB 0>1.7[0] MAR 0>1.8[0] APR 0>0.7[1.5]
WN ATL-MKE JAN 0.3>1.9[1.9] MAR 0>1.9[1.5] APR 0>0.7[1.6]
WN ATL-MSY JAN 0.5>4[3] APR 0>1.4[4]
WN ATL-OKC JAN 0.4>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>0.9[0]
WN ATL-OMA JAN 0.4>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>0.9[0]
WN ATL-PBI JAN 0.4>2.0[1.0] FEB 0>1.9[1.8] MAR 0>2.0[1.3] APR 0>0.7[1.8]
WN ATL-PHL JAN 0.4>2[1.4] FEB 0>2[1.6] MAR 0>2[1.3] APR 0>1.0[1.7]
WN ATL-PHX JAN 0.3>2[2] MAR 0>3[2] APR 0>1.0[3]
WN ATL-PIT JAN 0.2>1.8[1.7] FEB 0>1.9[2] MAR 0>2.0[2] APR 0>0.7[3]
WN ATL-RDU JAN 0.5>4[1.9] FEB 0>4[3] MAR 0>4[2] APR 0>1.2[2]
WN ATL-RIC JAN 0.4>3[3] APR 0>1.0[3]
WN ATL-RSW JAN 0.3>2[1.3] MAR 0>2[1.8] APR 0>0.8[2.0]
WN ATL-SAT JAN 0.2>1.9[1.9] MAR 0>1.9[1.6] APR 0>0.7[1.3]
WN ATL-SDF JAN 0.4>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>0.9[0]
WN ATL-STL JAN 0.5>4[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.4[4]
WN ATL-TPA JAN 0.7>5[5] MAR 0>6[4] APR 0>2[6]
WN AUA-BWI JAN 0.1>1.1[0.9] FEB 0>1.1[1.2] MAR 0>1.2[1.1] APR 0>0.5[1.3]
WN AUS-BNA JAN 0.5>4[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.4[3]
WN AUS-BWI JAN 0.4>3[3] MAR 0>3[2] APR 0>1.0[3]
WN AUS-CUN FEB 0>0.5[0.2] MAR 0>0.9[0] APR 0>0.4[0.8]
WN AUS-DAL JAN 1.3>9[8] FEB 0>9[11] APR 0>3[10]
WN AUS-DCA JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN AUS-DEN JAN 0.8>6[5] MAR 0>6[5] APR 0>2[5]
WN AUS-ELP JAN 0.4>2.0[3] FEB 0>2.0[1.6] MAR 0>2[1.2] APR 0>0.8[2]
WN AUS-FLL JAN 0.2>1.1[1.1] FEB 0>1.0[1.2] MAR 0>1.7[0.6] APR 0>0.7[1.4]
WN AUS-HOU JAN 0.6>4[5] FEB 0>4[5] APR 0>1.4[4]
WN AUS-HRL JAN 0.1>1.0[0.9] FEB 0>1.0[0.9] MAR 0>0.9[0.8] APR 0>0.3[0.9]
WN AUS-LAS JAN 0.5>4[4] MAR 0>4[3] APR 0>1.5[4]
WN AUS-LAX JAN 0.5>2[2] FEB 0>1.9[2] MAR 0>3[2] APR 0>1.0[2]
WN AUS-LBB JAN 0.1>0.9[0.9] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN AUS-LGB JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN AUS-MCI JAN 0.1>1.1[1.0] FEB 0>1.1[1.0] MAR 0>1.0[0.8] APR 0>0.4[1.2]
WN AUS-MCO JAN 0.5>3[3] APR 0>1.1[3]
WN AUS-MDW JAN 0.6>3[4] MAR 0>4[2] APR 0>1.4[4]
WN AUS-MSY JAN 0.4>3[2] APR 0>1.0[2]
WN AUS-OAK JAN 0.1>0.9[0.9] FEB 0>0.9[1.0] MAR 0>1.1[0.9] APR 0>0.4[1.2]
WN AUS-PHX JAN 0.6>5[4] FEB 0>5[4] MAR 0>5[4] APR 0>1.7[4]
WN AUS-RDU JAN 0.1>0.9[0.2] FEB 0>0.9[0.0] MAR 0>0.9[0] APR 0>0.3[0.1]
WN AUS-SAN JAN 0.4>3[3] MAR 0>3[2] APR 0>1.0[3]
WN AUS-SJC JAN 0.4>3[2] MAR 0>3[2] APR 0>0.9[2]
WN AUS-SMF JAN 0.1>1.0[0.9] FEB 0>1.0[0.9] MAR 0>1.0[0.8] APR 0>0.4[0.9]
WN AUS-STL JAN 0.3>1.9[1.9] FEB 0>1.9[2.0] MAR 0>1.9[1.7] APR 0>0.7[1.8]
WN AUS-TPA JAN 0.3>1.9[1.7] MAR 0>2[1.7] APR 0>0.7[1.4]
WN BDL-BWI JAN 0.6>4[5] FEB 0>4[5] MAR 0>4[5] APR 0>1.7[4]
WN BDL-DEN JAN 0.1>0.9[1.0] FEB 0>1.0[0.3] MAR 0>1.0[0.2] APR 0>0.4[0.7]
WN BDL-FLL FEB 0>0.8[1.3] MAR 0>0.5[1.2]
WN BDL-MCO JAN 0.1>2[3] APR 0>0.9[2]
WN BDL-MDW JAN 0.4>2[2] FEB 0>1.9[2.0] MAR 0>1.8[1.6] APR 0>0.6[1.6]
WN BDL-RSW FEB 0>0.9[1.2] APR 0>0.4[1.0]
WN BDL-STL JAN 0.1>0.9[0.9] FEB 0>0.9[1.0] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN BDL-TPA JAN 0.1>1.0[1.5] FEB 0>1.8[2] MAR 0>1.5[2] APR 0>0.5[1.8]
WN BHM-BWI JAN 0.3>1.0[1.9] FEB 0>0.9[1.1] MAR 0>1.0[0.7] APR 0>0.4[1.0]
WN BHM-DAL JAN 0.3>2[2] APR 0>0.8[2]
WN BHM-DEN JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN BHM-HOU JAN 0.3>1.6[1.5] FEB 0>1.6[1.9] MAR 0>1.8[1.5] APR 0>0.7[1.9]
WN BHM-LAS JAN 0.1>1.0[0.2] FEB 0>1.0[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN BHM-MCO JAN 0.3>2[2] APR 0>0.7[2]
WN BHM-MDW JAN 0.1>1.0[1.9] FEB 0>1.0[1.7] MAR 0>1.6[1.4] APR 0>0.7[1.8]
WN BHM-TPA JAN 0.1>1.0[1.7] FEB 0>1.0[1.3] MAR 0>1.6[1.2] APR 0>0.7[1.9]
WN BNA-BOS JAN 0.5>3[3] APR 0>1.3[3]
WN BNA-BUR JAN 0.1>1.0[0.2] FEB 0>1.0[0.0] MAR 0>1.0[0] APR 0>0.4[0.1]
WN BNA-BWI JAN 0.9>6[5] MAR 0>6[5] APR 0>2[5]
WN BNA-CHS JAN 0.3>1.3[1.8] FEB 0>1.6[1.3] MAR 0>1.5[1.1] APR 0>0.5[1.3]
WN BNA-CLE JAN 0.4>2[1.4] APR 0>0.8[2]
WN BNA-CLT JAN 0.3>1.9[1.8] FEB 0>1.9[1.7] MAR 0>1.9[1.6] APR 0>0.7[1.9]
WN BNA-CMH JAN 0.3>1.9[1.9] FEB 0>1.9[1.6] MAR 0>1.9[1.6] APR 0>0.7[1.9]
WN BNA-DAL JAN 0.9>7[5] MAR 0>6[5] APR 0>2[6]
WN BNA-DCA JAN 0.5>4[4] APR 0>1.4[4]
WN BNA-DEN JAN 0.8>5[5] MAR 0>6[4] APR 0>2[5]
WN BNA-DTW JAN 0.4>3[2] MAR 0>3[2] APR 0>0.9[3]
WN BNA-ECP SEP 2>3[2] JAN 0.3>2[2] MAR 0>2[1.9] APR 0>0.9[2]
WN BNA-FLL JAN 0.5>5[4] FEB 0>5[4] MAR 0>6[4] APR 0>2[6]
WN BNA-HOU JAN 0.6>4[4] FEB 0>4[3] MAR 0>4[3] APR 0>1.5[3]
WN BNA-JAX JAN 0.4>2[3] MAR 0>3[1.8] APR 0>1.1[3]
WN BNA-LAS JAN 0.5>3[3] APR 0>1.2[3]
WN BNA-LAX JAN 0.4>3[3] APR 0>1.0[2]
WN BNA-LGA JAN 0.5>4[4] APR 0>1.4[4]
WN BNA-MCI JAN 0.5>3[3] FEB 0>3[2] MAR 0>3[2] APR 0>1.2[3]
WN BNA-MCO JAN 0.8>6[5] MAR 0>6[5] APR 0>3[7]
WN BNA-MDW JAN 1.0>6[6] MAR 0>7[5] APR 0>2[6]
WN BNA-MKE JAN 0.3>2[1.2] FEB 0>2[1.9] MAR 0>2[1.7] APR 0>0.7[1.8]
WN BNA-MSP JAN 0.3>1.9[1.4] FEB 0>1.9[1.8] MAR 0>1.8[1.6] APR 0>0.6[1.8]
WN BNA-MSY JAN 0.6>4[3] MAR 0>4[3] APR 0>1.4[4]
WN BNA-OAK JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN BNA-OKC JAN 0.1>1.0[0.2] FEB 0>1.0[0.9] MAR 0>1.0[1.4] APR 0>0.4[1.2]
WN BNA-PHL JAN 0.4>2[3] FEB 0>1.9[3] MAR 0>1.9[2] APR 0>0.7[2]
WN BNA-PHX JAN 0.6>4[4] MAR 0>4[3] APR 0>1.5[4]
WN BNA-PIT JAN 0.3>1.9[1.9] FEB 0>1.9[2] MAR 0>2.0[1.5] APR 0>0.7[1.7]
WN BNA-PNS SEP 1.5>2[2] JAN 0.3>2[2] MAR 0>2[1.9] APR 0>0.7[2]
WN BNA-RDU JAN 0.4>3[3] APR 0>1.0[3]
WN BNA-RSW JAN 0>0.9[0.1] FEB 0>1.0[0.2] MAR 0>1.4[0.3] APR 0>0.6[1.3]
WN BNA-SAN JAN 0.3>1.9[1.9] FEB 0>1.9[1.6] MAR 0>2.0[1.6] APR 0>0.7[1.7]
WN BNA-SAT JAN 0.4>2[1.9] MAR 0>3[1.7] APR 0>1.0[2]
WN BNA-SJC JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.7] APR 0>0.4[1.0]
WN BNA-SNA JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN BNA-STL JAN 0.5>3[3] MAR 0>4[2] APR 0>1.3[3]
WN BNA-TPA JAN 0.6>5[5] FEB 0>5[4] MAR 0>5[4] APR 0>2[6]
WN BOI-DEN JAN 0.4>3[2.0] FEB 0>3[1.9] MAR 0>3[1.6] APR 0>1.0[1.9]
WN BOI-LAS JAN 0.3>2[2.0] MAR 0>2[1.9] APR 0>0.7[2]
WN BOI-OAK JAN 0.3>2[1.9] MAR 0>2[1.9] APR 0>0.7[2]
WN BOI-PHX JAN 0.4>2[1.7] FEB 0>1.9[1.3] MAR 0>2.0[1.1] APR 0>0.7[1.4]
WN BOI-SAN JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[0.9]
WN BOI-SJC JAN 0.2>1.8[1.7] FEB 0>1.9[1.2] MAR 0>1.8[0.9] APR 0>0.6[1.6]
WN BOI-SMF JAN 0.3>1.0[1.8] FEB 0>0.9[1.0] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN BOS-BWI JAN 1.0>8[9] FEB 0>8[9] MAR 0>8[7] APR 0>3[8]
WN BOS-DEN JAN 0.3>1.9[2] FEB 0>2.0[2] MAR 0>2[1.8] APR 0>0.7[1.6]
WN BOS-MDW JAN 0.6>4[5] FEB 0>4[3] MAR 0>4[3] APR 0>1.4[3]
WN BOS-STL JAN 0.4>2[3] FEB 0>2[3] APR 0>1.0[2]
WN BUF-BWI JAN 0.6>4[4] FEB 0>4[5] APR 0>1.4[4]
WN BUF-DEN JAN 0.1>1.0[0.5] FEB 0>1.0[0.1] MAR 0>1.0[0] APR 0>0.4[0.7]
WN BUF-FLL JAN 0.1>1.3[1.0] FEB 0>1.9[2] MAR 0>1.5[2] APR 0>0.4[2]
WN BUF-LAS JAN 0>0.3[1.0] FEB 0>0.7[1.0] MAR 0>0.4[0.9]
WN BUF-MCO JAN 0.3>2[3] APR 0>1.3[3]
WN BUF-MDW JAN 0.2>1.9[3] FEB 0>1.9[1.8] MAR 0>1.9[1.6] APR 0>0.7[1.9]
WN BUF-PHX FEB 0>0.7[0.4] MAR 0>1.0[0.3] APR 0>0.4[0.9]
WN BUF-RSW FEB 0>0.9[0.3] MAR 0>1.2[0.5] APR 0>0.4[1.0]
WN BUF-TPA JAN 0.3>1.3[1.8] MAR 0>2[2.0] APR 0>0.9[2]
WN BUR-DAL JAN 0.1>0.9[1.7] FEB 0>0.9[1.0] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN BUR-DEN JAN 0.5>3[3] FEB 0>3[2] MAR 0>4[2] APR 0>1.3[3]
WN BUR-HOU JAN 0.1>0.9[1.0] FEB 0>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[0.5]
WN BUR-LAS JAN 1.1>9[9] MAR 0>10[9] APR 0>3[10]
WN BUR-MDW MAR 0>0.7[0.8] APR 0>0.4[1.0]
WN BUR-OAK JAN 1.3>9[12] FEB 0>9[13] MAR 0>9[11] APR 0>3[13]
WN BUR-PHX JAN 0.9>6[6] FEB 0>6[7] MAR 0>7[5] APR 0>2[6]
WN BUR-SFO JAN 0.6>5[4] APR 0>1.6[6]
WN BUR-SJC JAN 1.2>9[10] FEB 0>9[12] MAR 0>9[10] APR 0>3[11]
WN BUR-SLC JAN 0.1>1.0[0.3] FEB 0>1.0[0.9] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN BUR-SMF JAN 1.2>8[8] FEB 0>8[11] MAR 0>8[9] APR 0>3[10]
WN BWI-CHS JAN 0.5>3[4] APR 0>1.2[3]
WN BWI-CLE JAN 0.4>3[4] APR 0>1.0[3]
WN BWI-CLT JAN 0.3>3[3] MAR 0>3[2] APR 0>1.2[3]
WN BWI-CMH JAN 0.4>3[4] MAR 0>3[1.9] APR 0>1.1[3]
WN BWI-CUN JAN 0.3>2[2] APR 0>0.9[2]
WN BWI-CVG JAN 0.4>3[2] APR 0>1.0[3]
WN BWI-DAL JAN 0.7>5[5] MAR 0>5[4] APR 0>1.8[5]
WN BWI-DEN JAN 0.9>5[5] MAR 0>6[4] APR 0>2[5]
WN BWI-DTW JAN 0.4>2[3] FEB 0>2[3] MAR 0>2[3] APR 0>1.0[3]
WN BWI-FLL JAN 1.4>10[9] FEB 0>11[9] MAR 0>11[8] APR 0>4[9]
WN BWI-GRR JAN 0.1>0.9[1.0] FEB 0>0.9[1.1] APR 0>0.3[1.0]
WN BWI-GSP JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN BWI-HOU JAN 0.5>3[5] MAR 0>4[3] APR 0>1.4[3]
WN BWI-IND JAN 0.4>3[4] MAR 0>3[2] APR 0>1.1[3]
WN BWI-ISP JAN 0.5>4[4] FEB 0>4[3] MAR 0>4[3] APR 0>1.3[4]
WN BWI-JAX JAN 0.5>4[4] FEB 0>4[3] MAR 0>4[3] APR 0>1.7[4]
WN BWI-LAS JAN 0.5>4[4] APR 0>1.5[4]
WN BWI-LAX JAN 0.4>3[4] APR 0>1.0[2]
WN BWI-MBJ JAN 0.3>2[2] MAR 0>2[1.9] APR 0>0.7[2]
WN BWI-MCI JAN 0.4>2.0[3] FEB 0>1.9[2.0] MAR 0>2[1.6] APR 0>1.0[2]
WN BWI-MCO JAN 1.3>11[10] MAR 0>11[10] APR 0>4[11]
WN BWI-MDW JAN 0.9>6[6] MAR 0>7[5] APR 0>3[7]
WN BWI-MEM JAN 0.3>1.0[1.9] FEB 0>0.9[1.1] MAR 0>1.1[0.8] APR 0>0.4[1.2]
WN BWI-MHT JAN 0.6>5[5] FEB 0>5[4] MAR 0>5[4] APR 0>1.7[5]
WN BWI-MKE JAN 0.4>2[3] FEB 0>1.9[2] MAR 0>2[1.1] APR 0>0.9[1.7]
WN BWI-MSP JAN 0.1>0.9[1.7] FEB 0>0.9[1.4] MAR 0>1.0[0.9] APR 0>0.4[1.6]
WN BWI-MSY JAN 0.5>3[4] MAR 0>4[3] APR 0>1.5[3]
WN BWI-NAS JAN 0.1>1.0[0.7] FEB 0>1.0[0.3] MAR 0>1.0[0.3] APR 0>0.4[0.9]
WN BWI-ORF JAN 0.6>4[4] MAR 0>4[3] APR 0>1.6[4]
WN BWI-PBI JAN 0.5>4[4] MAR 0>5[4] APR 0>1.8[5]
WN BWI-PHX JAN 0.4>3[3] APR 0>1.1[3]
WN BWI-PIT JAN 0.4>3[2] MAR 0>3[1.9] APR 0>1.0[2]
WN BWI-PUJ JAN 0.1>1.0[1.1] FEB 0>1.1[1.2] MAR 0>1.1[1.0] APR 0>0.4[1.3]
WN BWI-PVD JAN 0.6>4[7] FEB 0>4[5] APR 0>1.5[4]
WN BWI-PWM JAN 0.4>3[4] APR 0>1.1[3]
WN BWI-RDU JAN 0.8>5[6] MAR 0>5[4] APR 0>1.9[6]
WN BWI-ROC JAN 0.5>3[3] APR 0>1.0[3]
WN BWI-RSW JAN 0.5>6[4] MAR 0>6[5] APR 0>2[6]
WN BWI-SAN JAN 0.3>1.3[3] FEB 0>1.1[2] MAR 0>1.7[1.9] APR 0>0.7[3]
WN BWI-SAT JAN 0.3>1.9[3] FEB 0>1.9[2] MAR 0>2[1.6] APR 0>0.8[1.8]
WN BWI-SDF JAN 0.4>3[3] FEB 0>3[2] MAR 0>3[1.8] APR 0>1.0[3]
WN BWI-SJU JAN 0.3>2.3[2.0] FEB 0>2.3[2.3] APR 0>0.9[2.5]
WN BWI-SLC JAN 0>0.3[0.9] FEB 0>0.7[1.0] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN BWI-STL JAN 0.5>3[4] MAR 0>4[2] APR 0>1.4[4]
WN BWI-TPA JAN 1.0>8[7] FEB 0>8[7] MAR 0>9[7] APR 0>3[9]
WN CHS-DAL MAR 0>0.7[0] APR 0>0.4[0.8]
WN CHS-HOU JAN 0>0.7[1.0] FEB 0>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN CHS-MDW JAN 0.3>1.1[1.9] FEB 0>1.1[1.2] MAR 0>1.6[0.9] APR 0>0.7[1.7]
WN CLE-DEN JAN 0.4>1.3[1.5] FEB 0>1.0[1.1] MAR 0>1.6[0.9] APR 0>0.7[1.8]
WN CLE-LAS MAR 0>0.2[0.3]
WN CLE-MCO JAN 0>0.3[0.4] APR 0>0.3[0.6]
WN CLE-MDW JAN 0.5>4[5] MAR 0>4[3] APR 0>1.3[4]
WN CLE-PHX JAN 0.1>1.0[0.3] FEB 0>1.0[0.3] MAR 0>1.2[0.3] APR 0>0.5[1.1]
WN CLE-STL JAN 0.4>3[1.8] MAR 0>3[2] APR 0>0.9[2]
WN CLT-DAL JAN 0.1>1.0[1.1] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN CLT-DEN JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN CLT-HOU JAN 0.1>0.7[1.0] FEB 0>0.8[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN CLT-MDW JAN 0.4>1.9[3] FEB 0>1.7[1.8] MAR 0>2[1.4] APR 0>0.9[2]
WN CMH-DAL JAN 0.1>1.0[1.8] FEB 0>1.0[1.3] APR 0>0.4[1.3]
WN CMH-DCA JAN 0.3>1.3[1.9] FEB 0>1.1[1.9] MAR 0>1.1[1.6] APR 0>0.4[1.8]
WN CMH-DEN JAN 0.4>2[1.7] FEB 0>1.9[1.3] MAR 0>2[1.1] APR 0>1.0[1.5]
WN CMH-FLL JAN 0.1>1.3[1.9] FEB 0>1.8[1.5] MAR 0>2[1.4] APR 0>0.9[1.6]
WN CMH-HOU JAN 0.1>0.9[1.0] FEB 0>0.9[1.0] MAR 0>1.0[0.8] APR 0>0.4[0.9]
WN CMH-LAS JAN 0.3>2[1.2] MAR 0>2[1.8] APR 0>0.7[2]
WN CMH-MCO JAN 0.4>4[4] FEB 0>4[5] MAR 0>5[4] APR 0>1.8[5]
WN CMH-MDW JAN 0.6>4[4] MAR 0>4[3] APR 0>1.6[4]
WN CMH-PHX JAN 0.4>2[1.0] FEB 0>1.9[1.2] MAR 0>2[1.1] APR 0>0.8[1.5]
WN CMH-RSW JAN 0.3>2[3] FEB 0>2[1.9] MAR 0>3[2.0] APR 0>1.2[3]
WN CMH-STL JAN 0.3>1.9[1.8] FEB 0>1.9[2.0] MAR 0>1.8[1.4] APR 0>0.6[1.0]
WN CMH-TPA JAN 0.4>2[3] MAR 0>3[1.9] APR 0>1.4[3]
WN CRP-HOU JAN 0.5>3[3] FEB 0>3[4] APR 0>1.0[4]
WN CUN-DEN JAN 0.3>1.3[1.5] FEB 0>1.3[1.2] MAR 0>1.7[1.1] APR 0>0.7[1.2]
WN CUN-FLL JAN 0.1>1.0[2] FEB 0>1.0[2] MAR 0>1.0[1.9] APR 0>0.4[2]
WN CUN-HOU JAN 0.4>3[3] APR 0>1.1[3]
WN CUN-MDW JAN 0.1>1.0[2] FEB 0>1.0[0.6] MAR 0>1.2[0.3] APR 0>0.5[1.1]
WN CVG-DEN JAN 0.1>0.9[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN CVG-MDW JAN 0.6>4[4] MAR 0>4[3] APR 0>1.5[4]
WN DAL-DCA JAN 0.6>5[5] MAR 0>5[4] APR 0>1.7[5]
WN DAL-DEN JAN 1.3>10[9] FEB 0>10[9] MAR 0>10[7] APR 0>4[9]
WN DAL-ECP SEP 1.4>2[1.2] OCT 1.1>1.3[2] FEB 0>0.7[0.3] MAR 0>1.7[0.2] APR 0>0.7[1.5]
WN DAL-ELP JAN 0.5>4[4] APR 0>1.5[4]
WN DAL-FLL JAN 0.4>4[3] APR 0>1.6[4]
WN DAL-HDN JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
WN DAL-HOU JAN 2>15[16] FEB 0>15[20] MAR 0>15[18] APR 0>5[19]
WN DAL-IND JAN 0.3>1.1[1.9] FEB 0>1.0[1.2] MAR 0>1.1[0.9] APR 0>0.4[1.3]
WN DAL-JAX MAR 0>0.2[0]
WN DAL-LAS JAN 0.8>7[4] FEB 0>7[6] APR 0>2[6]
WN DAL-LAX JAN 0.6>5[5] FEB 0>5[6] APR 0>1.7[6]
WN DAL-LBB JAN 0.6>5[4] MAR 0>5[4] APR 0>1.7[5]
WN DAL-LGA JAN 0.5>4[5] FEB 0>4[5] APR 0>1.5[5]
WN DAL-LIT JAN 0.3>2[3] APR 0>0.7[2]
WN DAL-MAF JAN 0.6>4[4] FEB 0>4[5] APR 0>1.6[5]
WN DAL-MCI JAN 0.8>6[6] FEB 0>6[7] APR 0>2[7]
WN DAL-MCO JAN 0.8>6[5] MAR 0>6[5] APR 0>2[6]
WN DAL-MDW JAN 1.0>8[7] MAR 0>8[7] APR 0>3[8]
WN DAL-MEM JAN 0.3>1.9[3] FEB 0>1.9[2] MAR 0>2.0[1.7] APR 0>0.7[2]
WN DAL-MKE JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DAL-MSP JAN 0.1>0.7[1.0] FEB 0>0.8[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DAL-MSY JAN 0.9>7[7] FEB 0>7[8] MAR 0>7[8] APR 0>3[8]
WN DAL-OAK JAN 0.3>1.9[1.8] FEB 0>1.9[1.8] MAR 0>1.8[1.6] APR 0>0.6[1.8]
WN DAL-OMA JAN 0.1>1.0[1.8] FEB 0>1.0[1.2] MAR 0>1.1[0.9] APR 0>0.4[1.2]
WN DAL-ONT JAN 0.1>1.1[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DAL-PHX JAN 1.0>8[6] FEB 0>8[7] MAR 0>8[7] APR 0>3[7]
WN DAL-PIT JAN 0.1>1.0[1.7] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DAL-PNS MAR 0>0.2[0]
WN DAL-RDU JAN 0.1>1.0[1.7] FEB 0>1.0[1.2] APR 0>0.4[1.2]
WN DAL-RNO JAN 0>0.7[0] FEB 0>0.9[0] MAR 0>1.0[0] APR 0>0.4[0.3]
WN DAL-RSW JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DAL-SAN JAN 0.5>5[4] FEB 0>5[4] MAR 0>5[4] APR 0>1.7[4]
WN DAL-SAT JAN 1.2>10[7] FEB 0>10[11] MAR 0>9[10] APR 0>3[10]
WN DAL-SDF JAN 0.1>0.9[1.0] FEB 0>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DAL-SJC JAN 0.4>3[3] MAR 0>3[2] APR 0>0.8[3]
WN DAL-SLC JAN 0.3>2[1.1] FEB 0>2[1.3] MAR 0>1.5[1.2] APR 0>0.5[1.3]
WN DAL-SMF JAN 0.2>1.0[1.1] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DAL-SNA JAN 0.1>1.0[0.9] FEB 0>1.0[0.1] MAR 0>1.0[0] APR 0>0.4[0]
WN DAL-STL JAN 0.8>6[7] FEB 0>6[7] APR 0>2[6]
WN DAL-TPA JAN 0.4>4[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.5[4]
WN DAL-TUL JAN 0.5>3[3] FEB 0>3[4] APR 0>1.0[4]
WN DCA-FLL JAN 0.3>2[2] APR 0>0.9[2]
WN DCA-HOU JAN 0.4>3[3] APR 0>1.1[3]
WN DCA-MCI JAN 0.3>1.9[1.9] FEB 0>1.9[2] MAR 0>1.9[1.7] APR 0>0.7[1.9]
WN DCA-MCO JAN 0.3>2[3] FEB 0>2[3] APR 0>0.9[2]
WN DCA-MDW JAN 0.8>6[5] MAR 0>6[5] APR 0>2[6]
WN DCA-MKE JAN 0.3>1.9[1.9] FEB 0>1.9[2] MAR 0>1.9[1.7] APR 0>0.7[2]
WN DCA-MSY JAN 0.3>2[2] APR 0>0.7[2]
WN DCA-OKC JAN 0.1>1.0[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DCA-OMA JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DCA-PBI JAN 0>0.9[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN DCA-PVD JAN 0.3>1.7[2] FEB 0>1.7[2] APR 0>0.6[1.9]
WN DCA-STL JAN 0.5>4[4] APR 0>1.4[4]
WN DCA-TPA JAN 0.3>2[3] APR 0>0.9[2]
WN DEN-DSM JAN 0.3>1.1[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0.8]
WN DEN-DTW JAN 0.3>1.1[1.9] FEB 0>1.0[1.2] MAR 0>1.5[0.9] APR 0>0.6[1.6]
WN DEN-ELP JAN 0.1>0.9[1.0] FEB 0>0.9[1.0] MAR 0>0.9[0.8] APR 0>0.3[0.9]
WN DEN-FLL JAN 0.3>2[2] FEB 0>2[3] MAR 0>3[2] APR 0>1.1[3]
WN DEN-GEG JAN 0.4>2[2] MAR 0>2[1.8] APR 0>1.0[2]
WN DEN-GRR JAN 0.3>1.0[0.9] FEB 0>0.9[0.1] MAR 0>1.0[0] APR 0>0.4[0.8]
WN DEN-HDN DEC 0>1.3[0] JAN 0>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>0.5[0]
WN DEN-HOU JAN 1.1>8[7] FEB 0>8[7] MAR 0>8[6] APR 0>3[7]
WN DEN-IAD JAN 0.4>2[3] MAR 0>2[1.7] APR 0>1.0[3]
WN DEN-ICT JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN DEN-IND JAN 0.5>3[4] APR 0>1.1[3]
WN DEN-JAX JAN 0.1>1.0[1.1] FEB 0>1.0[1.1] MAR 0>1.1[0.9] APR 0>0.4[1.2]
WN DEN-LAS JAN 1.2>10[7] FEB 0>10[9] MAR 0>10[8] APR 0>4[10]
WN DEN-LAX JAN 1.0>7[7] FEB 0>6[7] MAR 0>7[6] APR 0>3[7]
WN DEN-LGA JAN 0.5>3[4] FEB 0>3[4] APR 0>1.2[4]
WN DEN-LGB JAN 0>0.9[0.3] FEB 0>1.0[0.3] MAR 0>1.0[0.3] APR 0>0.4[0.3]
WN DEN-LIT JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN DEN-MCI JAN 0.9>6[6] MAR 0>7[5] APR 0>2[6]
WN DEN-MCO JAN 0.6>5[4] FEB 0>5[4] MAR 0>5[4] APR 0>1.8[5]
WN DEN-MDW JAN 1.3>8[8] MAR 0>9[7] APR 0>3[9]
WN DEN-MEM JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DEN-MKE JAN 0.5>3[3] APR 0>1.3[3]
WN DEN-MSP JAN 0.8>5[4] FEB 0>5[4] MAR 0>5[4] APR 0>1.9[5]
WN DEN-MSY JAN 0.5>3[3] FEB 0>3[2] MAR 0>4[2] APR 0>1.3[3]
WN DEN-OAK JAN 0.8>5[5] FEB 0>5[4] MAR 0>5[4] APR 0>1.9[5]
WN DEN-OKC JAN 0.5>3[4] MAR 0>3[2] APR 0>1.0[3]
WN DEN-OMA JAN 0.5>4[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.3[2]
WN DEN-ONT JAN 0.6>3[3] FEB 0>3[2] MAR 0>3[1.6] APR 0>1.3[2]
WN DEN-PDX JAN 0.6>4[5] MAR 0>5[3] APR 0>1.8[4]
WN DEN-PHL JAN 0.4>2[2] MAR 0>2[1.6] APR 0>1.0[3]
WN DEN-PHX JAN 1.5>12[10] FEB 0>12[11] MAR 0>13[10] APR 0>5[12]
WN DEN-PIT JAN 0.3>1.9[1.8] FEB 0>1.9[2] MAR 0>2.0[1.2] APR 0>0.7[1.8]
WN DEN-PVR JAN 0.1>1.0[0.9] MAR 0>1.2[0.9] APR 0>0.5[1.3]
WN DEN-RDU JAN 0.3>1.1[2.0] FEB 0>1.5[1.2] MAR 0>1.9[0.9] APR 0>0.7[1.5]
WN DEN-RNO JAN 0.4>2.0[1.9] FEB 0>2[1.2] MAR 0>3[0.5] APR 0>1.0[1.6]
WN DEN-RSW JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0.1]
WN DEN-SAN JAN 0.9>7[6] FEB 0>7[6] MAR 0>7[5] APR 0>3[7]
WN DEN-SAT JAN 0.5>3[3] MAR 0>4[2] APR 0>1.4[2]
WN DEN-SDF JAN 0.1>0.9[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DEN-SEA JAN 0.8>4[4] FEB 0>4[3] MAR 0>4[3] APR 0>1.5[3]
WN DEN-SFO JAN 0.6>4[5] MAR 0>4[3] APR 0>1.4[3]
WN DEN-SJC JAN 0.8>5[4] FEB 0>5[4] MAR 0>5[3] APR 0>1.7[3]
WN DEN-SJD JAN 0.1>1.1[0.9] FEB 0>1.1[1.2] MAR 0>1.2[1.1] APR 0>0.5[1.4]
WN DEN-SLC JAN 0.9>6[4] MAR 0>6[5] APR 0>2[6]
WN DEN-SMF JAN 0.7>5[4] FEB 0>5[4] MAR 0>5[4] APR 0>1.9[4]
WN DEN-SNA JAN 0.6>5[4] FEB 0>5[4] MAR 0>5[4] APR 0>1.7[5]
WN DEN-STL JAN 0.7>6[6] MAR 0>6[5] APR 0>2[6]
WN DEN-TPA JAN 0.5>4[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.5[4]
WN DEN-TUL JAN 0.4>2[1.9] FEB 0>1.9[2] MAR 0>2[1.7] APR 0>1.0[1.9]
WN DEN-TUS JAN 0.4>3[3] FEB 0>3[2] MAR 0>3[2] APR 0>1.1[2]
WN DSM-LAS JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN DSM-STL JAN 0.3>1.9[1.9] FEB 0>1.9[2.0] MAR 0>1.9[1.7] APR 0>0.7[1.9]
WN DTW-MDW JAN 0.5>4[3] MAR 0>4[3] APR 0>1.3[3]
WN DTW-PHX FEB 0>0.7[0.1] MAR 0>1.2[0.2] APR 0>0.5[0.3]
WN DTW-STL JAN 0.4>2[3] FEB 0>1.9[2] MAR 0>1.8[2] APR 0>0.6[3]
WN ECP-HOU JAN 0.1>0.9[1.1] FEB 0>0.9[1.0] MAR 0>1.0[0.8] APR 0>0.4[1.2]
WN ECP-MDW MAR 0>0.2[0]
WN ECP-STL MAR 0>0.8[0] APR 0>0.4[1.0]
WN ELP-HOU JAN 0.4>3[4] MAR 0>3[2] APR 0>1.0[3]
WN ELP-LAS JAN 0.3>2[1.9] APR 0>0.9[2]
WN ELP-LAX JAN 0.1>0.9[1.9] FEB 0>0.9[1.8] MAR 0>1.0[1.3] APR 0>0.4[1.4]
WN ELP-PHX JAN 0.5>4[2] FEB 0>4[2] MAR 0>4[2] APR 0>1.5[2]
WN ELP-SAT JAN 0.3>1.9[2.0] MAR 0>2[1.8] APR 0>0.7[2]
WN FLL-HOU JAN 0.5>3[3] MAR 0>4[3] APR 0>1.5[3]
WN FLL-IND JAN 0.1>2[2] MAR 0>2[1.9] APR 0>1.0[2]
WN FLL-ISP JAN 0>0.9[1.7] FEB 0>1.1[1.2] MAR 0>1.0[1.1] APR 0>0.4[1.0]
WN FLL-MBJ JAN 0.1>1.0[2] FEB 0>1.0[2] MAR 0>1.0[1.9] APR 0>0.4[2]
WN FLL-MCI JAN 0.1>2[1.2] APR 0>0.9[2]
WN FLL-MCO JAN 0.3>3[3] APR 0>1.0[3]
WN FLL-MDW JAN 0.5>5[4] MAR 0>5[4] APR 0>2.0[6]
WN FLL-MKE JAN 0>1.1[1.0] FEB 0>1.3[1.2] MAR 0>1.3[1.1] APR 0>0.5[1.3]
WN FLL-MSY JAN 0.4>3[3] APR 0>1.0[3]
WN FLL-PHL JAN 0>0.3[1.2] FEB 0>0.3[1.2]
WN FLL-PHX JAN 0.1>1.0[1.1] FEB 0>1.0[0.4] MAR 0>1.2[0.3] APR 0>0.5[1.1]
WN FLL-PIT JAN 0.1>1.3[2.0] FEB 0>1.8[2] MAR 0>2[1.8] APR 0>0.8[1.8]
WN FLL-PVD JAN 0.1>1.1[1.8] FEB 0>1.8[2] MAR 0>1.5[2] APR 0>0.5[1.5]
WN FLL-RDU JAN 0>0.9[2] FEB 0>1.0[1.3] MAR 0>1.2[1.1] APR 0>0.5[1.3]
WN FLL-SJU JAN 0.1>1.9[2.7] FEB 0>2.0[3.2] MAR 0>2.0[2.8] APR 0>0.7[3.1]
WN FLL-STL JAN 0.3>3[3] FEB 0>3[2] MAR 0>3[1.9] APR 0>1.4[3]
WN FLL-TPA JAN 0.4>3[4] FEB 0>3[4] MAR 0>3[4] APR 0>1.1[4]
WN GEG-LAS JAN 0.3>2[1.7] MAR 0>2[1.9] APR 0>0.9[2]
WN GEG-OAK JAN 0.3>1.9[1.8] FEB 0>1.9[2] MAR 0>2.0[1.8] APR 0>0.7[2]
WN GEG-PHX JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.1[0.9] APR 0>0.4[1.0]
WN GEG-SJC JAN 0.1>0.9[0.3] MAR 0>0.9[0.8] APR 0>0.3[1.0]
WN GEG-SMF JAN 0.1>1.0[1.6] FEB 0>1.0[1.2] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN GRR-MCO JAN 0>0.9[0.1] MAR 0>0.7[1.2] APR 0>0.3[1.3]
WN GRR-MDW JAN 0.1>1.9[3] FEB 0>2[3] MAR 0>2[3] APR 0>0.7[3]
WN HAV-TPA JAN 0.1>1.1[1.1] FEB 0>1.1[1.2] APR 0>0.4[1.2]
WN HNL-ITO JAN 0.5>4[0] FEB 0>4[1.8] APR 0>1.5[4]
WN HNL-KOA JAN 0.5>4[4] APR 0>1.5[4]
WN HNL-LIH JAN 0.5>4[4] APR 0>1.5[4]
WN HNL-OAK JAN 0.3>2[2] MAR 0>2[1.9] APR 0>0.7[2]
WN HNL-OGG JAN 0.8>6[4] FEB 0>6[4] MAR 0>6[4] APR 0>2[4]
WN HNL-SAN JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN HNL-SJC JAN 0.3>2[1.0] FEB 0>2[1.1] MAR 0>2[0.9] APR 0>0.7[1.0]
WN HNL-SMF JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.1]
WN HOU-HRL JAN 0.5>4[3] FEB 0>4[5] APR 0>1.4[5]
WN HOU-IND JAN 0.1>0.9[1.5] MAR 0>1.2[0.9] APR 0>0.5[1.5]
WN HOU-JAX JAN 0.1>1.0[1.8] MAR 0>1.1[0.7] APR 0>0.4[1.1]
WN HOU-LAS JAN 0.6>5[4] MAR 0>5[4] APR 0>2.0[6]
WN HOU-LAX JAN 0.5>4[5] FEB 0>4[5] APR 0>1.5[4]
WN HOU-LBB JAN 0.1>0.9[0.3] FEB 0>0.9[0.2] MAR 0>0.9[0.1] APR 0>0.3[0.2]
WN HOU-LGA JAN 0.4>3[3] APR 0>1.0[3]
WN HOU-LIR JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.2]
WN HOU-LIT JAN 0.1>0.9[0] FEB 0>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN HOU-MAF JAN 0.5>3[3] FEB 0>3[4] MAR 0>4[3] APR 0>1.3[4]
WN HOU-MCI JAN 0.3>2[2] FEB 0>2[3] APR 0>1.2[3]
WN HOU-MCO JAN 0.8>5[5] MAR 0>5[4] APR 0>1.9[5]
WN HOU-MDW JAN 0.9>6[6] MAR 0>7[5] APR 0>3[7]
WN HOU-MEM JAN 0.3>1.9[1.9] FEB 0>1.9[2] MAR 0>1.9[1.5] APR 0>0.7[1.6]
WN HOU-MKE JAN 0.1>0.9[1.0] FEB 0>0.9[1.0] MAR 0>1.0[0.8] APR 0>0.4[0.5]
WN HOU-MSY JAN 0.9>7[7] FEB 0>7[9] MAR 0>7[8] APR 0>2[8]
WN HOU-OAK JAN 0.3>2[3] MAR 0>2[1.9] APR 0>0.7[2]
WN HOU-OKC JAN 0.5>4[4] FEB 0>4[5] APR 0>1.3[5]
WN HOU-OMA JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.1[0.9] APR 0>0.4[0.9]
WN HOU-ONT JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN HOU-PHX JAN 0.6>5[5] MAR 0>5[4] APR 0>2[4]
WN HOU-PIT JAN 0.1>0.9[1.4] FEB 0>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[0.9]
WN HOU-PNS JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN HOU-PVR JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.1[0.9] APR 0>0.4[1.2]
WN HOU-RDU JAN 0.1>1.0[1.7] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[0.9]
WN HOU-SAN JAN 0.4>2[3] FEB 0>2[3] MAR 0>3[2] APR 0>1.0[3]
WN HOU-SAT JAN 0.6>4[5] FEB 0>4[5] APR 0>1.5[5]
WN HOU-SDF JAN 0.1>0.9[1.0] FEB 0>0.9[1.0] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN HOU-SJC JAN 0.1>1.0[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN HOU-SJD JAN 0.3>2[2] MAR 0>2[1.9] APR 0>0.7[2]
WN HOU-SJU MAR 0>0.7[0.3]
WN HOU-SLC JAN 0.1>0.4[0.2] FEB 0>0.3[0.2] MAR 0>0.9[0.3] APR 0>0.5[0.4]
WN HOU-SMF JAN 0.1>0.9[0.2] FEB 0>0.9[0.0] MAR 0>1.0[0] APR 0>0.4[0]
WN HOU-SNA JAN 0.1>1.0[0.1] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN HOU-STL JAN 0.5>4[4] MAR 0>4[3] APR 0>1.5[4]
WN HOU-TPA JAN 0.5>4[4] FEB 0>4[3] MAR 0>4[3] APR 0>1.5[3]
WN HOU-TUL JAN 0.4>3[2] MAR 0>3[2] APR 0>1.0[3]
WN ICT-LAS JAN 0.1>0.4[1.0] FEB 0>0.7[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN ICT-PHX JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN ICT-STL JAN 0.2>1.8[1.9] FEB 0>1.9[2] MAR 0>1.9[1.7] APR 0>0.7[1.9]
WN IND-LAS SEP 1.2>1.9[2] JAN 0.1>2[2] MAR 0>2[1.9] APR 0>0.9[3]
WN IND-MCI JAN 0.1>0.9[1.7] FEB 0>0.9[1.8] MAR 0>0.9[1.0] APR 0>0.3[1.3]
WN IND-MCO JAN 0.4>4[3] MAR 0>5[4] APR 0>1.8[5]
WN IND-PHX JAN 0.4>2[1.7] MAR 0>3[1.9] APR 0>1.2[3]
WN IND-RSW JAN 0.1>3[2] FEB 0>4[3] MAR 0>4[3] APR 0>1.4[4]
WN IND-STL JAN 0.2>1.9[0] FEB 0>1.9[0] MAR 0>1.8[0] APR 0>0.6[0]
WN IND-TPA JAN 0.3>2[3] MAR 0>3[2] APR 0>1.4[4]
WN ISP-MCO JAN 0.1>2[3] MAR 0>2[2.0] APR 0>0.8[3]
WN ISP-PBI JAN 0.1>1.9[3] APR 0>0.8[2]
WN ISP-TPA JAN 0.1>0.9[1.8] FEB 0>1.0[1.2] MAR 0>1.0[0.9] APR 0>0.4[1.1]
WN JAX-MDW JAN 0.1>1.0[1.1] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN KOA-OAK JAN 0.1>1.0[0] FEB 0>1.0[0.3] MAR 0>1.0[0.5] APR 0>0.4[1.0]
WN KOA-OGG JAN 0.1>1.0[0] FEB 0>1.0[0.4] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN KOA-SJC JAN 0.1>1.0[0] FEB 0>1.0[0.2] MAR 0>1.0[0.4] APR 0>0.4[0.9]
WN LAS-LAX JAN 1.0>8[8] FEB 0>9[10] APR 0>3[11]
WN LAS-LBB JAN 0.1>1.0[1.1] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN LAS-LGB JAN 0.1>0.9[0.8] FEB 0>1.0[1.8] MAR 0>1.0[2] APR 0>0.4[1.9]
WN LAS-LIT JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN LAS-MAF JAN 0.1>1.0[1.8] FEB 0>1.0[1.3] MAR 0>1.0[1.1] APR 0>0.4[1.2]
WN LAS-MCI JAN 0.5>3[3] MAR 0>4[3] APR 0>1.5[4]
WN LAS-MCO JAN 0.1>1.3[1.2] MAR 0>1.2[1.1] APR 0>0.4[1.6]
WN LAS-MDW JAN 1.0>8[6] FEB 0>8[7] MAR 0>8[6] APR 0>3[9]
WN LAS-MKE SEP 1.3>2[2] JAN 0.3>3[2] APR 0>1.2[3]
WN LAS-MSY JAN 0.1>1.0[2] FEB 0>1.0[1.5] MAR 0>1.0[1.3] APR 0>0.4[1.4]
WN LAS-OAK JAN 1.2>9[9] MAR 0>9[8] APR 0>3[9]
WN LAS-OKC JAN 0.3>2[2.0] MAR 0>2[1.6] APR 0>0.8[2]
WN LAS-OMA JAN 0.3>2[1.9] MAR 0>2[1.9] APR 0>0.8[2]
WN LAS-ONT JAN 0.6>5[4] FEB 0>5[4] MAR 0>5[3] APR 0>1.7[3]
WN LAS-PDX JAN 0.4>3[2] MAR 0>4[3] APR 0>1.4[4]
WN LAS-PHX JAN 1.1>9[7] FEB 0>9[11] MAR 0>9[10] APR 0>3[10]
WN LAS-PIT JAN 0.1>1.0[1.1] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.7]
WN LAS-RNO JAN 1.1>8[8] FEB 0>8[10] APR 0>3[10]
WN LAS-SAN JAN 1.3>10[7] MAR 0>11[9] APR 0>4[11]
WN LAS-SAT JAN 0.5>4[3] APR 0>1.3[4]
WN LAS-SDF JAN 0.1>1.0[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[0.5]
WN LAS-SEA JAN 0.3>2[2] MAR 0>2[2.0] APR 0>0.8[2]
WN LAS-SFO JAN 0.5>4[5] FEB 0>4[6] MAR 0>4[5] APR 0>1.5[5]
WN LAS-SJC JAN 1.3>10[9] MAR 0>10[9] APR 0>4[10]
WN LAS-SLC JAN 0.6>5[3] FEB 0>5[4] MAR 0>5[4] APR 0>2[5]
WN LAS-SMF JAN 1.0>9[6] MAR 0>9[8] APR 0>3[9]
WN LAS-SNA JAN 1.0>7[5] FEB 0>7[5] MAR 0>7[5] APR 0>3[6]
WN LAS-STL JAN 0.5>3[3] MAR 0>4[3] APR 0>1.4[3]
WN LAS-TPA JAN 0.1>1.1[1.1] FEB 0>1.3[0.4] MAR 0>1.1[0.3] APR 0>0.4[1.0]
WN LAS-TUL JAN 0.1>1.0[1.8] FEB 0>1.0[1.3] APR 0>0.4[1.2]
WN LAS-TUS JAN 0.5>3[2] APR 0>1.2[3]
WN LAX-MCI JAN 0.4>1.9[3] MAR 0>1.8[1.1] APR 0>0.7[2]
WN LAX-MDW JAN 0.8>5[6] MAR 0>5[4] APR 0>1.9[4]
WN LAX-MSY JAN 0.3>1.1[1.6] FEB 0>1.4[1.2] MAR 0>1.7[1.4] APR 0>0.6[1.7]
WN LAX-OAK JAN 1.4>11[11] FEB 0>11[13] APR 0>4[12]
WN LAX-PHX JAN 1.2>9[8] FEB 0>9[8] MAR 0>9[7] APR 0>3[9]
WN LAX-RNO JAN 0.4>3[3] APR 0>1.0[3]
WN LAX-SAT JAN 0.4>1.1[1.9] FEB 0>0.9[1.4] MAR 0>1.5[1.1] APR 0>0.7[1.7]
WN LAX-SFO JAN 0.9>6[6] FEB 0>6[8] MAR 0>6[7] APR 0>2[8]
WN LAX-SJC JAN 1.2>8[9] FEB 0>8[11] MAR 0>8[9] APR 0>3[10]
WN LAX-SLC JAN 0.3>3[1.9] MAR 0>3[2] APR 0>1.0[2]
WN LAX-SMF JAN 1.0>7[7] FEB 0>7[9] APR 0>2[8]
WN LAX-STL JAN 0.4>3[3] MAR 0>3[2] APR 0>1.1[2]
WN LAX-TUS JAN 0.3>2[3] APR 0>0.7[3]
WN LGA-MCI JAN 0.1>0.9[1.9] FEB 0>0.9[1.8] MAR 0>1.0[1.4] APR 0>0.4[1.8]
WN LGA-MDW JAN 1.0>7[6] FEB 0>7[6] MAR 0>7[5] APR 0>3[6]
WN LGA-MSY JAN 0.1>0.9[1.2] FEB 0>0.9[1.1] APR 0>0.3[1.1]
WN LGA-STL JAN 0.5>4[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.3[3]
WN LGA-TPA JAN 0.4>3[1.9] FEB 0>3[2] MAR 0>3[1.7] APR 0>1.0[1.8]
WN LGB-OAK JAN 0.6>4[4] FEB 0>4[5] APR 0>1.5[4]
WN LGB-PHX JAN 0.4>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>1.1[0]
WN LGB-SJC JAN 0.5>3[4] FEB 0>3[4] MAR 0>3[4] APR 0>1.1[4]
WN LGB-SMF JAN 0.5>4[4] MAR 0>4[3] APR 0>1.5[4]
WN LIH-OAK JAN 0.1>1.0[0] FEB 0>1.0[0.2] MAR 0>1.0[0.4] APR 0>0.4[0.9]
WN LIH-SJC JAN 0.1>1.0[0] FEB 0>1.0[0.3] MAR 0>1.0[0.5] APR 0>0.4[1.0]
WN LIT-STL JAN 0.2>1.8[1.3] MAR 0>1.9[1.7] APR 0>0.7[1.9]
WN MBJ-MCO JAN 0.1>1.0[0.8] FEB 0>1.0[0.3] MAR 0>1.0[0.3] APR 0>0.4[0.9]
WN MCI-MCO JAN 0.3>3[2] APR 0>1.3[3]
WN MCI-MDW JAN 1.0>7[7] MAR 0>7[5] APR 0>2[7]
WN MCI-MKE JAN 0.1>0.9[1.1] FEB 0>0.9[1.4] MAR 0>0.9[1.2] APR 0>0.3[1.3]
WN MCI-MSP JAN 0.1>0.9[0.9] FEB 0>0.9[1.3] MAR 0>0.9[1.0] APR 0>0.3[1.0]
WN MCI-MSY JAN 0.1>1.0[1.2] FEB 0>1.0[1.2] APR 0>0.4[1.1]
WN MCI-OAK JAN 0.1>0.9[0.9] MAR 0>0.9[0.8] APR 0>0.3[0.9]
WN MCI-PHX JAN 0.6>5[4] FEB 0>5[4] MAR 0>5[4] APR 0>2.0[5]
WN MCI-RSW JAN 0>0.9[0.1] FEB 0>1.1[0.8] MAR 0>1.2[0.8] APR 0>0.5[1.1]
WN MCI-SAN JAN 0.1>1.0[1.8] FEB 0>1.0[1.9] MAR 0>1.1[1.5] APR 0>0.4[1.9]
WN MCI-SAT JAN 0.1>1.1[0.9] FEB 0>1.1[0.9] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN MCI-STL JAN 0.4>3[2] FEB 0>3[4] APR 0>1.0[3]
WN MCI-TPA JAN 0.3>1.1[1.4] FEB 0>1.6[1.2] MAR 0>2[1.1] APR 0>0.8[2]
WN MCO-MDW JAN 1.0>8[8] MAR 0>9[7] APR 0>4[10]
WN MCO-MEM JAN 0.1>1.1[2.0] FEB 0>1.1[1.3] MAR 0>1.3[1.5] APR 0>0.6[1.8]
WN MCO-MHT JAN 0.1>1.3[1.5] MAR 0>1.7[2] APR 0>0.6[2]
WN MCO-MKE SEP 1.1>1.9[3] JAN 0.4>3[3] FEB 0>4[3] MAR 0>4[3] APR 0>1.7[4]
WN MCO-MSY JAN 0.6>4[5] APR 0>1.5[4]
WN MCO-ORF JAN 0.1>1.3[1.8] FEB 0>1.3[1.4] APR 0>0.4[1.2]
WN MCO-PHL JAN 0.3>1.6[5] FEB 0>2[3] MAR 0>3[2] APR 0>1.2[3]
WN MCO-PHX JAN 0.4>2[1.1] FEB 0>2[1.3] MAR 0>1.6[1.1] APR 0>0.6[1.4]
WN MCO-PIT JAN 0.4>3[4] FEB 0>4[5] APR 0>1.7[5]
WN MCO-PVD JAN 0.4>3[4] APR 0>1.2[3]
WN MCO-RDU JAN 0.3>2[3] APR 0>1.2[3]
WN MCO-ROC JAN 0.1>1.0[1.1] FEB 0>1.5[1.2] MAR 0>1.5[1.1] APR 0>0.5[1.3]
WN MCO-SAT JAN 0.3>1.1[2.0] FEB 0>1.5[1.3] MAR 0>2.0[1.0] APR 0>0.7[1.6]
WN MCO-SDF SEP 1.0>1.8[2] JAN 0.1>1.3[1.9] FEB 0>1.3[1.4] MAR 0>1.3[1.2] APR 0>0.5[1.8]
WN MCO-SJU JAN 0.6>4[4] MAR 0>5[3.9] APR 0>1.8[5]
WN MCO-STL JAN 0.5>6[5] FEB 0>6[5] MAR 0>6[5] APR 0>2[6]
WN MDW-MEM JAN 0.3>1.7[1.9] FEB 0>1.7[1.9] MAR 0>1.7[1.4] APR 0>0.6[1.7]
WN MDW-MHT FEB 0>0.6[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN MDW-MSP JAN 0.9>6[5] APR 0>1.9[6]
WN MDW-MSY JAN 0.4>3[3] MAR 0>4[3] APR 0>1.4[4]
WN MDW-OAK JAN 0.5>2[3] MAR 0>2[1.2] APR 0>1.0[1.8]
WN MDW-OKC MAR 0>0.7[0.2] APR 0>0.4[1.0]
WN MDW-OMA JAN 0.5>4[4] MAR 0>4[3] APR 0>1.5[5]
WN MDW-ONT JAN 0.3>1.1[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN MDW-ORF JAN 0.1>1.0[1.8] FEB 0>1.0[1.2] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN MDW-PDX JAN 0.1>1.0[1.2] FEB 0>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.5]
WN MDW-PHL JAN 0.6>4[5] MAR 0>5[3] APR 0>1.9[4]
WN MDW-PHX JAN 1.0>7[7] FEB 0>7[6] MAR 0>9[6] APR 0>4[9]
WN MDW-PIT JAN 0.5>3[4] FEB 0>3[5] MAR 0>4[3] APR 0>1.3[4]
WN MDW-PNS MAR 0>0.2[0]
WN MDW-PVD JAN 0.1>1.0[1.9] FEB 0>1.0[1.3] MAR 0>1.0[1.1] APR 0>0.4[1.1]
WN MDW-RDU JAN 0.5>3[4] APR 0>1.0[3]
WN MDW-RSW JAN 0.6>4[4] MAR 0>6[3] APR 0>2[6]
WN MDW-SAN JAN 0.5>3[4] MAR 0>4[3] APR 0>1.5[4]
WN MDW-SAT JAN 0.4>1.9[1.7] FEB 0>1.7[1.9] MAR 0>3[1.3] APR 0>1.0[3]
WN MDW-SDF JAN 0.4>3[3] MAR 0>3[2] APR 0>0.9[3]
WN MDW-SEA JAN 0.2>1.1[1.9] FEB 0>1.0[1.9] MAR 0>1.5[1.6] APR 0>0.6[1.9]
WN MDW-SFO JAN 0.3>1.1[1.8] FEB 0>1.0[1.9] MAR 0>1.5[1.6] APR 0>0.6[1.5]
WN MDW-SJC JAN 0.3>1.1[1.7] FEB 0>1.0[1.2] MAR 0>1.5[0.9] APR 0>0.6[1.0]
WN MDW-SLC JAN 0.2>2.0[2] MAR 0>2[1.9] APR 0>0.7[1.9]
WN MDW-SMF JAN 0.3>1.1[1.1] FEB 0>1.0[1.1] MAR 0>1.5[0.9] APR 0>0.6[1.0]
WN MDW-STL JAN 1.0>6[6] FEB 0>6[7] MAR 0>6[5] APR 0>2[6]
WN MDW-TPA JAN 0.8>5[6] MAR 0>6[4] APR 0>3[7]
WN MDW-TUS JAN 0.1>1.0[1.0] FEB 0>1.0[0.7] MAR 0>1.1[0.8] APR 0>0.4[1.2]
WN MEM-PHX JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN MEM-TPA JAN 0.1>0.9[1.1] FEB 0>0.9[1.1] APR 0>0.4[1.2]
WN MHT-TPA FEB 0>0.8[1.2] MAR 0>1.2[1.1] APR 0>0.5[1.3]
WN MKE-PHX JAN 0.4>3[2] MAR 0>4[3] APR 0>1.7[4]
WN MKE-RSW JAN 0.1>1.9[1.7] FEB 0>3[1.6] MAR 0>3[1.7] APR 0>1.2[3]
WN MKE-STL JAN 0.3>1.9[1.6] MAR 0>1.8[1.6] APR 0>0.6[1.9]
WN MKE-TPA JAN 0.3>1.1[1.5] FEB 0>1.8[1.3] MAR 0>3[1.2] APR 0>1.2[3]
WN MSP-PHX JAN 0.4>2[1.8] FEB 0>2[1.4] MAR 0>2[1.3] APR 0>1.0[1.7]
WN MSP-RSW MAR 0>0.2[0]
WN MSP-STL JAN 0.4>1.9[1.6] FEB 0>1.7[1.9] MAR 0>1.8[1.6] APR 0>0.7[1.9]
WN MSP-TPA MAR 0>0.2[0]
WN MSY-OAK JAN 0.1>0.9[0.9] FEB 0>1.0[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN MSY-PHX JAN 0.4>2[1.2] FEB 0>2[1.5] MAR 0>2[1.6] APR 0>0.7[1.6]
WN MSY-RDU JAN 0.1>0.9[0.1] FEB 0>0.9[0.1] MAR 0>0.9[0.1] APR 0>0.3[0.0]
WN MSY-SAN JAN 0.1>0.9[0.9] MAR 0>0.9[0.8] APR 0>0.3[0.9]
WN MSY-SAT JAN 0.3>1.1[1.2] FEB 0>1.1[1.2] MAR 0>1.0[1.5] APR 0>0.4[1.5]
WN MSY-STL JAN 0.2>1.9[1.6] APR 0>0.9[2]
WN MSY-TPA JAN 0.5>3[3] APR 0>1.2[3]
WN OAK-OGG JAN 0.3>2[2] MAR 0>2[1.9] APR 0>0.7[2]
WN OAK-ONT JAN 0.6>5[7] FEB 0>5[7] MAR 0>5[6] APR 0>1.8[6]
WN OAK-PDX JAN 0.5>4[6] FEB 0>4[5] APR 0>1.7[6]
WN OAK-PHX JAN 0.8>6[6] APR 0>2[6]
WN OAK-RNO JAN 0.3>1.9[1.6] FEB 0>1.9[1.2] MAR 0>1.9[1.3] APR 0>0.7[1.7]
WN OAK-SAN JAN 1.2>9[11] FEB 0>9[12] MAR 0>9[10] APR 0>3[12]
WN OAK-SEA JAN 0.8>5[6] FEB 0>5[6] APR 0>1.9[6]
WN OAK-SLC JAN 0.3>3[3] APR 0>1.0[3]
WN OAK-SNA JAN 0.8>6[6] MAR 0>7[6] APR 0>2[7]
WN OAK-STL JAN 0.1>0.9[0.9] MAR 0>0.9[0.8] APR 0>0.3[0.8]
WN OGG-SJC JAN 0.3>1.1[1.0] FEB 0>1.0[1.1] MAR 0>1.7[0.9] APR 0>0.7[1.0]
WN OGG-SMF JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0.8]
WN OKC-PHX JAN 0.4>3[2] MAR 0>3[2] APR 0>1.0[3]
WN OKC-STL JAN 0.3>1.9[2.0] FEB 0>1.9[2.0] MAR 0>1.9[1.6] APR 0>0.7[1.8]
WN OMA-PHX JAN 0.3>3[2] FEB 0>4[3] MAR 0>4[3] APR 0>1.5[4]
WN OMA-STL JAN 0.4>2[2] MAR 0>2[1.8] APR 0>0.7[2]
WN ONT-PHX JAN 0.9>6[5] MAR 0>6[5] APR 0>2[5]
WN ONT-SJC JAN 0.5>4[5] FEB 0>4[5] APR 0>1.4[4]
WN ONT-SMF JAN 0.8>6[7] FEB 0>6[7] APR 0>2[7]
WN ORF-SAN JAN 0>0.7[0] FEB 0>0.9[0] MAR 0>0.9[0] APR 0>0.3[0]
WN PDX-PHX JAN 0.6>3[4] FEB 0>4[3] MAR 0>4[3] APR 0>1.5[4]
WN PDX-SJC JAN 0.6>4[5] FEB 0>4[5] APR 0>1.8[5]
WN PDX-SMF JAN 0.5>4[5] FEB 0>4[5] APR 0>1.6[5]
WN PDX-STL JAN 0.1>0.9[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN PHL-STL JAN 0.4>2.0[2] FEB 0>1.9[2] APR 0>1.0[2]
WN PHL-TPA JAN 0.1>1.0[2] FEB 0>1.1[1.6] MAR 0>1.3[1.4] APR 0>0.6[1.9]
WN PHX-PIT JAN 0.3>1.1[1.0] FEB 0>1.0[1.1] MAR 0>1.1[0.9] APR 0>0.4[1.2]
WN PHX-PVR JAN 0.1>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
WN PHX-RDU JAN 0.3>1.1[1.0] FEB 0>1.0[0.4] MAR 0>1.0[0.3] APR 0>0.4[0.3]
WN PHX-RNO JAN 0.4>3[2] FEB 0>3[2] MAR 0>3[2.0] APR 0>1.0[2]
WN PHX-SAN JAN 1.2>9[8] FEB 0>9[11] APR 0>3[11]
WN PHX-SAT JAN 0.5>3[4] APR 0>1.1[3]
WN PHX-SDF FEB 0>0.7[0.4] MAR 0>1.0[0.3] APR 0>0.4[0.9]
WN PHX-SEA JAN 0.4>3[4] MAR 0>4[3] APR 0>1.4[4]
WN PHX-SFO JAN 0.6>4[4] MAR 0>4[3] APR 0>1.7[4]
WN PHX-SJC JAN 0.9>6[6] MAR 0>6[5] APR 0>2[6]
WN PHX-SJD JAN 0.3>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>0.7[0]
WN PHX-SLC JAN 0.6>6[4] MAR 0>6[5] APR 0>2[6]
WN PHX-SMF JAN 0.8>6[5] FEB 0>6[5] MAR 0>6[4] APR 0>2[5]
WN PHX-SNA JAN 1.0>7[6] FEB 0>7[6] MAR 0>7[5] APR 0>3[6]
WN PHX-STL JAN 0.6>4[4] MAR 0>5[4] APR 0>1.7[4]
WN PHX-TPA JAN 0.4>2[1.1] FEB 0>1.9[1.2] MAR 0>1.4[1.0] APR 0>0.4[1.3]
WN PHX-TUL JAN 0.1>1.1[1.9] FEB 0>1.1[1.3] MAR 0>1.2[1.1] APR 0>0.5[1.3]
WN PIT-RSW JAN 0.1>1.9[1.7] FEB 0>2[1.3] MAR 0>2[1.2] APR 0>0.7[1.8]
WN PIT-STL JAN 0.3>1.1[1.0] FEB 0>1.0[1.1] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN PIT-TPA JAN 0.3>2[2] APR 0>0.9[3]
WN PVD-RSW FEB 0>0.8[0.2] MAR 0>1.1[0.3] APR 0>0.4[1.0]
WN PVD-TPA JAN 0.1>1.0[1.8] FEB 0>1.6[1.3] MAR 0>1.4[1.2] APR 0>0.4[1.7]
WN RDU-STL JAN 0.3>1.1[2.0] FEB 0>1.1[0.6] MAR 0>1.5[0.7] APR 0>0.6[1.6]
WN RDU-TPA JAN 0.2>1.9[3] FEB 0>1.9[1.8] APR 0>0.7[1.4]
WN RNO-SAN JAN 0.3>3[3] MAR 0>3[2] APR 0>1.0[3]
WN RNO-SJC JAN 0.1>1.0[1.1] FEB 0>1.0[2] MAR 0>1.5[2] APR 0>0.6[2]
WN ROC-RSW FEB 0>0.7[0.1] MAR 0>0.4[0.2]
WN ROC-TPA JAN 0>1.0[0.9] FEB 0>1.3[0.3] MAR 0>0.6[0.3]
WN RSW-STL JAN 0.3>3[2] FEB 0>3[2] MAR 0>3[2] APR 0>1.1[3]
WN SAN-SAT JAN 0.1>1.1[1.6] FEB 0>1.1[1.8] MAR 0>1.0[1.6] APR 0>0.4[1.8]
WN SAN-SFO JAN 0.8>6[7] FEB 0>6[8] MAR 0>6[7] APR 0>2[7]
WN SAN-SJC JAN 1.5>12[14] FEB 0>12[16] MAR 0>12[14] APR 0>4[15]
WN SAN-SLC JAN 0.3>1.9[1.1] FEB 0>1.9[1.8] MAR 0>1.9[1.6] APR 0>0.7[1.8]
WN SAN-SMF JAN 1.5>11[12] FEB 0>11[15] MAR 0>11[13] APR 0>4[14]
WN SAN-STL JAN 0.3>1.9[2.0] FEB 0>1.9[2] MAR 0>1.9[1.8] APR 0>0.7[1.9]
WN SAN-TUS JAN 0.3>1.9[2] FEB 0>1.9[2] MAR 0>2[1.8] APR 0>0.8[2]
WN SAT-STL JAN 0.3>1.9[1.9] FEB 0>1.9[2] MAR 0>2.0[1.7] APR 0>0.7[2]
WN SAT-TPA JAN 0.3>1.1[1.0] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN SDF-TPA JAN 0.1>1.0[1.1] FEB 0>1.0[1.2] MAR 0>1.3[1.0] APR 0>0.6[1.5]
WN SEA-SJC JAN 0.5>4[4] APR 0>1.6[4]
WN SEA-SMF JAN 0.5>3[5] MAR 0>5[3] APR 0>1.7[4]
WN SEA-STL JAN 0.1>0.9[0.9] MAR 0>1.0[0.8] APR 0>0.4[1.0]
WN SFO-STL JAN 0.1>1.0[0.9] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN SJC-SLC JAN 0>0.9[1.1] FEB 0>1.0[1.9] MAR 0>1.0[1.7] APR 0>0.4[1.7]
WN SJC-SNA JAN 1.0>8[9] FEB 0>9[11] MAR 0>9[10] APR 0>3[11]
WN SJC-STL JAN 0.1>0.9[0.9] MAR 0>1.0[0.8] APR 0>0.4[0.3]
WN SJU-TPA JAN 0.3>1.3[1.4] MAR 0>1.2[1.1] APR 0>0.5[1.3]
WN SLC-SMF JAN 0.1>1.1[0.9] FEB 0>1.1[1.0] MAR 0>1.0[0.9] APR 0>0.4[1.0]
WN SLC-STL JAN 0.1>0.9[0.9] MAR 0>0.9[0.8] APR 0>0.3[0.9]
WN SMF-SNA JAN 0.7>6[6] MAR 0>6[5] APR 0>2[6]
WN SMF-STL JAN 0.1>0.9[0.9] FEB 0>1.0[0.9] MAR 0>1.0[0.9] APR 0>0.4[0.9]
WN STL-TPA JAN 0.5>3[2] MAR 0>3[2] APR 0>1.3[3]
WN STL-TUL JAN 0.2>1.9[1.9] FEB 0>1.9[2] MAR 0>1.9[1.7] APR 0>0.7[1.9]
WS ATL-YYC SEP 0.9>0.4[1.0]
WS AUS-YYC SEP 0.2>0[0.3] OCT 0.3>0[0.3]
WS BNA-YYC SEP 0.4>0[0.4] OCT 0.4>0[0.5] NOV 0.3>0[0.4]
WS BNA-YYZ SEP 1.1>0[1.2]
WS BOS-YYC SEP 0.8>0[0.4] OCT 0.4>0[0]
WS BOS-YYZ SEP 1.7>0[2]
WS DEN-YYC SEP 0.4>0[0.4]
WS FLL-YYZ SEP 0.8>0[1.3]
WS HNL-YVR SEP 0.8>0[1.1]
WS IAH-YYC SEP 1.5>0[1.8]
WS JFK-YYC SEP 0.9>0[0.9]
WS LAS-YEG SEP 0.5>0[0.6]
WS LAS-YVR SEP 1.3>0[1.8]
WS LAS-YWG SEP 0.2>0[0.3]
WS LAS-YYC SEP 3>0[4]
WS LAS-YYZ SEP 1.6>0[1.9]
WS LAX-YEG SEP 0.9>0[1.0]
WS LAX-YVR SEP 3>0[3]
WS LAX-YYC SEP 1.7>0.4[2]
WS LAX-YYZ SEP 1.7>0[1.8]
WS LGA-YYZ SEP 6>0[7] OCT 7>6[6]
WS MCO-YYC SEP 0.2>0[0.4]
WS MCO-YYZ SEP 1.6>0[2]
WS OGG-YVR SEP 0.7>0[1.2]
WS PDX-YYC SEP 1.7>0[1.1]
WS PHX-YYC SEP 1.7>0[2]
WS PSP-YVR SEP 0.4>0[1.4]
WS PSP-YYC SEP 0.7>0[1.6]
WS RSW-YYZ SEP 0.3>0[0.8]
WS SAN-YVR SEP 0.2>0[0.1]
WS SAN-YYC SEP 0.4>0[0.5]
WS SFO-YVR SEP 1.0>0[0.8] OCT 0.8>0[1.1]
WS SFO-YYC SEP 1.7>0[1.6] OCT 1.5>0[1.9]
WS SNA-YVR SEP 0.9>0[1.0]
WS TPA-YYZ SEP 0.4>0[0.6]
Y4 FAT-MEX NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.2[0]
Y4 IAH-MEX NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.2[0]
Y4 MEX-ONT NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
Y4 MEX-SJC NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
Y4 MEX-SMF NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
Miamiairport
Re: OAG Changes 8/18/2020:FALL FALLING;AA/DL Cuts;AC Drops SNAYVR;UA Adds LGA-Florida,SAL-IAD/LAX,DENCYS,IADPQI,IAHTLH
Tue Aug 18, 2020 1:39 pm
As usual thanks for the hard work Enilria. Only in some alternate universe could I have imagined UA adding FL flights from LGA. But here we are in this alternate universe.
chonetsao
Tue Aug 18, 2020 1:41 pm
Thanks for the hard work.
Air Canada/BA/DL's cuts almost confirmed that US is not going to open up in September. And 70% chance it won't open in October neither. So when will AA/UA further cut the transatlantic capacity?
enilria
Tue Aug 18, 2020 1:47 pm
Thanks, yes that is jarring...when they have EWR! Imagine what craziness would happen if everybody had to use their slots now?
Thanks! up? No, Fall is a a disaster. I think we all knew that. That's part of why the CARES Act ended 9/30, I think people realized Fall is sink or swim.
nkops
Re: OAG Changes 8/18/2020:FALL FALLING;AA/AS/DL Cuts;AC Drops SNAYVR;UA Adds LGA-Florida,SAL-IAD/LAX,DENCYS,IADPQI,IAHTL
Tue Aug 18, 2020 1:51 pm
UA CMH-RSW? talk about out of nowhere.. what equip is that on?
Turn left heading 080 contact departure
tphuang
Tue Aug 18, 2020 1:54 pm
Thanks enilria for the update.
It's really interesting AA continues to be out of BOS-LAX. This is a market they used to dominate.
AS has now cut JFK-LAX all the until mid November. Not sure how they make a comeback here when every other airlines have been running multiple daily during this time.
DL made quite a few cuts until Christmas it looks. I'm assuming those are more likely to get the permanent cut than other ones. All the recent MIA adds have basically been cut down.
MIflyer12
Tue Aug 18, 2020 1:59 pm
Keeping with the sentiment of Fall Falling in enilria's title is Alaska's 8-K filing from last week:
Capacity Updates
The public health and economic crises resulting from the outbreak of COVID-19 has had an unprecedented impact on our business. We are uncertain what
shape the recovery will take, and we are continuously monitoring trends in demand to determine our capacity decisions as the situation unfolds. At this
time, our planning assumptions are for our third quarter capacity to be down approximately 50%.
The table below summarizes recent results and our current preliminary expectations for August.
May 2020 June 2020 July 2020 ExpectedAugust 2020
(a)
Revenue passengers (000s) 424 887 1,137 ~ 1,200-1,300
Revenue passengers year-over-year Down 90% Down 79% Down 74% Down 70-75%
ASMs year-over-year Down 79% Down 68% Down 63% Down ~ 50%
Passenger load factor 40% 52% 54% ~ 40-45%
Total revenue year-over-year Down 83% Down 75% Down 73% Down ~ 70-75%
They're not forecasting August passenger numbers really to be much better than July, and with more capacity that means even lower load factors. Ugh.
Link to the SEC filing 8/14/20: https://investor.alaskaair.com/static-f ... ab765b2793
Ishrion
Tue Aug 18, 2020 2:01 pm
E-175: https://hub.united.com/2020-08-12-adjus ... 62841.html
enilria
E7W
AS will probably finish liquidating VX routes.
seatback
Tue Aug 18, 2020 2:05 pm
[quote="chonetsao"]Thanks for the hard work.
Jarring? I'd say this is a reaction to B6's encroachment into EWR. UA has a lot of planes and employees sitting around...why not try to inflict a little pain on a growing competitor? Not much to lose for UA.
ScottB
Tue Aug 18, 2020 2:12 pm
Heck, they are adding BOS-Florida, too. That's even more crazy than LGA-Florida. CO used to run a couple of LGA-FLL back in the day with slots they needed to keep using (I'd presume left over from the days of when they operated LGA-DEN) and UA ran LGA-MIA to feed the hub they acquired from PA. I don't think CO or UA ever operated BOS-Florida non-stop.
seat1a
Tue Aug 18, 2020 2:23 pm
Thank you for the information. Relatively new to how to read this? Do I see that as going from 1 daily to less than one daily (i.e., Daily to Ex Mo, Tu)?
Rdh3e
Tue Aug 18, 2020 2:45 pm
It looks like an awful lot of non-B6 flights for this to be just a B6 thing?
32andBelow
Tue Aug 18, 2020 2:50 pm
Yah. .5 times a day. The days of week are not listed. So more like 3 times in a 7 day period.
MO11
Tue Aug 18, 2020 2:56 pm
That is not correct! In this case it means that flights are suspended through September 16, then (are scheduled to) resume daily on September 17.
FlyingElvii
Tue Aug 18, 2020 3:00 pm
Republic 175, same as Indy. Both are Republic bases. Not sure about the PIT flight.
Brickell305
Tue Aug 18, 2020 3:04 pm
Exactly. People are so stuck in their old ways of thinking about retaliatory routes and the “my airline vs yours” mentality. This is a new reality. No airline has money to waste on silly retaliation now. Furthermore, who is fighting for market share in an environment where demand is down 70% YoY. On top of that, UA is only flying these routes for a few months. UA is flying these routes because they are trying to tap into the little demand that exists. Unlike DL that has a hub in ATL that can be used to funnel Florida traffic and AA who has both MIA which can absorb a lot of the O&D into So. Fla and CLT which can funnel Florida traffic, UA essentially has to do it through nonstop flights as they don’t really have a natural hub for all that traffic to FL. As to why LGA vs EWR, it’s probably because the EWR has essentially been (temporarily) dismantled due to the lack of business travel and they probably feel that LGA gives them more O&D traffic.
SteveXC500
Tue Aug 18, 2020 3:05 pm
I thought it was completely canceled?
panam330
Tue Aug 18, 2020 3:15 pm
PIT is also a YX base.
MIflyer12
Tue Aug 18, 2020 3:21 pm
LGA expands the market, to the degree that some people just don't want to use EWR (or would need to be bribed with significantly lower fares from EWR than UA wants to offer). The downside to that UA will take longer to rebuild EWR volumes, and higher volumes can mean higher gauge/lower CASM, and more non-stop destinations - which can be leveraged to increase gauge and destination count yet further. I'm not arguing they're wrong (they have the fare data!) but it's hard to find obviously successful paths in any of this. That's why some carriers are playing things differently from others.
Miamiairport
Tue Aug 18, 2020 3:24 pm
I would assume airlines are looking at routes they can fill planes even if it's with low yield leisure travel. I doubt that in today's environment any airline will purposely lose more money to "get back at a competitor." LGA/FL in the winter time is a good bet for filling a plane with capacity that will bring in needed cash flow but probably still lose money.
Midwestindy
Tue Aug 18, 2020 3:37 pm
IND is an A320
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
Rdh3e
Tue Aug 18, 2020 4:18 pm
It can also mean they are flying daily for half the month. It doesn't distinguish when the flights are.
So flying daily for half the month is the same thing as flying 3-4 days a week in the report. I couldn't check all of these, but OAK-OGG is just not operating from Sep 1-16 and is operating Sep 17-30 in the schedule. Of course, that could be deleted later.
I would guess that is the case for all of these.
LAXdude1023
Tue Aug 18, 2020 4:21 pm
UA is making a hard push in Central America. Thats good!
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
avi8
Tue Aug 18, 2020 4:46 pm
Interesting to see UA beefing up service to SAL, GUA and SJO from IAD, LAX, IAH and EWR. I don’t think IAD has ever been daily and they only operated LAX from SAL for a brief period a few years ago.
avi8
LAXdude1023
Tue Aug 18, 2020 4:50 pm
If you think about it, UA is in perfect position to capture Central American traffic.
-It has a hub that is geographically situated to feed those markets in IAH
-It has hubs in 4 of the 5 largest Central American markets in the US with only MIA missing.
PBADC3
Tue Aug 18, 2020 4:55 pm
[quote="enilria"]
NOTE: 9K appears to have ongoing issues with the TECNAM not appearing in the data
9X ACK-EWB SEP 0>1.3[0] OCT 0>0.6[0]
9X ACK-OWD SEP 0.8>1.7[0.5] OCT 0.4>0.7[0.7]
Cape Air has parked all of the TECNAMs for the second time now due to an issue (IIRC) with elevator control questions.
PBADC3
Tue Aug 18, 2020 5:04 pm
LAXSAL was flown daily, with some holiday/peak adds for at least 10 years in the 2000s.
IADSAL flew during 2013 with a mix of daily and sub daily
ScottB
Tue Aug 18, 2020 5:09 pm
Well, LGA-Florida demand in winter (as with BOS-Florida) isn't all that great outside some spikes at Thanksgiving, Christmas/New Year's, and the MLK holiday. From Labor Day to Presidents' Day, there are typically bargain basement fares available outside those peaks. Patterns might be different this winter with distance learning and work-from-home continuing for many white collar workers -- so I could see people renting a house for a week or month in Florida to escape the cold.
evank516
Tue Aug 18, 2020 5:14 pm
It's a good bet in the winter time, but if the travel advisories are still up by then (and let's face it they most likely will be), then there goes any demand to Florida because everyone who isn't going down there to snow bird will have to quarantine when they get home.
FlyingElvii
Tue Aug 18, 2020 5:27 pm
Yes, but unsure about who is operating the flight.
FlyingElvii
Tue Aug 18, 2020 5:28 pm
Miamiairport
Tue Aug 18, 2020 5:47 pm
Based on what I see the quarantines such as they are (not or rarely enforced) will do little to slow down travel to FL. The big unknown I see is the job situation. Given the number of people thrown out of work, and continues at 1 million plus every week, and the reduction in unemployment compensation (with even the $300 Federal kicker not expect to last much past the of September) that could put a damper on travel-to anywhere. We shall see.
I walked by an MIA AA flight boarding to JFK this morning. The gate area was totally packed. And given the few connections out of JFK they were mostly all O&D. Quarantines didn't seem to be effecting that particular flight.
Judge1310
Tue Aug 18, 2020 7:07 pm
I'm not sure why so many folks here are surprised at BOS and LGA additions -- I venture to guess that maybe it's because most folks either didn't know or forgot that UA maintains a crew base out there in BOS (LGA is a co-terminal base with EWR). Thus, it's relatively easy to deploy readily available aircraft (loads of narrowbodies) with local crews to high demand markets when necessary.
The aircraft (and it's concombinant costs) and crews are still being paid for even whilst sitting around -- might as well deploy them and earn a little extra in the meantime. :)
evank516
Tue Aug 18, 2020 7:13 pm
You are indeed monitored in NY. I just got off of a 14-day quarantine a week and a half ago after returning from LAS.
FlyingElvii
Tue Aug 18, 2020 8:10 pm
Us is betting real cash that most of the restrictions and quarantines go away after Election Day....
FlyingElvii
FlyingElvii wrote:
UA is betting real cash that most of the restrictions and quarantines go away after Election Day....
klm617
Tue Aug 18, 2020 8:21 pm
How are these two even showing up when service to both has been dropped
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
flight152
Tue Aug 18, 2020 8:28 pm
The BOS base is strictly FA’s, not pilots.
jayunited
Tue Aug 18, 2020 8:38 pm
I can't speak for AA but UA's limited TATL flights have been operating for some time during this pandemic. In the past the reason these flights have not shown up on the OAG report is because UA has been running most of our TATL flights as cargo only flights.
With most of Europe remaining closed to nonessential U.S. travelers, what UA has done is open up some of these flights to essential travelers only. The amount of passengers on many of our European flights is so minuscule that the flights are still essentially a cargo flight. With so few passengers the ramp can fit all the bags either in the bulk pit or if necessary they may need up to 2 LD3 containers, the remainder of the aircraft's belly is filled with cargo. To outsiders it may look like UA is taking a gamble and operating more TATL flights than necessary, however I can assure you that is not the case. These aircraft are already flying back and forth to Europe with cargo what UA has done is open them up to essential travelers.
The lone exception to Europe that I've seen on the UA side are flights to FRA. We are seeing a lot more passengers traveling to/from (or transiting through) FRA. The higher passenger loads impacts the amount of cargo we can load. This is why UA has continued cargo only flights in addition to passenger service flights to/from FRA. UA is also still running a limited number of cargo only flights to/from LHR. However the number of cargo only has come down as a result of more UA passenger service flights operating, but our load factors to/from LHR are abysmal when compared to FRA which again is good for cargo.
enilria
Tue Aug 18, 2020 8:39 pm
Perhaps, but it isn't as if B6 controls LGA.
So it means that in SEP they had a flight scheduled every day (30) and now they have 15 (.5*30 days). I would bet they just deferred start to Sep 16.
In general I agree. I think they are just chasing cash. UA thinks there's more at LGA. Not sure I agree, though.
I'd say it was more copy-catting B6's idea to find cash with random Florida flights.
They probably pushed the start to 9/29 or smth.
I took this as SAL is one of the few places Americans can go...and perhaps they also gave UA money. Anybody think otherwise?
:o
Sort of, they can just drop the flights easily. It's customers who are betting really.
klm617 wrote:
EI DUB-MIA SEP 0.4>0.1[0]
EI DUB-MSP SEP 0.7>0.2[0]
IDK. I guess the flights were still loaded. Perhaps they had some number of bookings on those days and are waiting to see if anybody will really fly?
Dominion301
Tue Aug 18, 2020 8:45 pm
Indeed. In fact I'm pretty sure AC never operated a single SNA-YVR flight before cancelling. No point spending money opening a secondary station when you're already probably losing a pile of money at LAX these days.
Judge1310
Tue Aug 18, 2020 10:53 pm
I'm *very* aware of that, thank you. Doesn't negate what I stated, nonetheless.
klm617
Tue Aug 18, 2020 10:55 pm
Same as MIA which has also been suspended.
tphuang
Tue Aug 18, 2020 11:16 pm
The quarantines and restrictions are in place in NY/NJ/CT because we got COVID under control after the initial terrible outbreak and people don't want to get a second wave here. This politicization of public health actions taken to protect New Yorkers is really sickening.
There is a publicly known criteria on how a state is determined to require quarantine and the list is updated based on that criteria. Get your fact straight.
Chuska
Tue Aug 18, 2020 11:44 pm
**UA CYS-DEN NOV 0>0.7[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0}
With SkyWest starting back up in CYS on Nov. 12 as UA* to DEN, I'm guessing they won't return the AA* service to DFW that was dropped in March.
A333MSPtoAMS
Wed Aug 19, 2020 12:25 am
I thought this also.
As of Dec 2019 I've flown 457,440 miles on 270 flights on 54 airplane types with 60 airlines traveling thru 104 airports. I've visited 60 countries.
http://cronkflies.com
wedgetail737
Wed Aug 19, 2020 2:14 am
Airlines execs do change their minds periodically.
LAXdude1023
Wed Aug 19, 2020 3:01 am
Well, there seems to be a very strong correlation between Central American community size and growth and UA hubs. Since O&D to Central America is heavily tied to demographics, this is relevant.
Below is growth by metro area from 2013-2018:
Guatemala:
Los Angeles: 22,977
Atlanta: 17,882
Houston: 13,847
Washington DC: 12,109
Miami/Fort Lauderdale: 9,760
San Francisco: 9,157
Phoenix: 8,411
Boston: 8,104
Dallas/Fort Worth: 6,149
San Jose: 5,775
Las Vegas: 5,225
Honduras:
Houston: 37,905
Washington DC: 25,078
Miami/Fort Lauderdale: 18,069
Dallas/Fort Worth: 15,944
New Orleans: 7,742
Tampa: 6,634
New York: 6,393
El Salvador:
Houston: 46,089
Los Angeles: 45,610
Washington DC: 35,669
New York: 23,985
Dallas/Fort Worth: 21,802
Atlanta: 10,190
Boston: 10,112
Miami/Fort Lauderdale: 7,401
Baltimore: 7,089
Philadelphia: 6,677
Las Vegas: 5,883
Seattle/Tacoma: 5,637
avi8
Wed Aug 19, 2020 3:13 am
Guatemala:
Los Angeles: 22,977
Atlanta: 17,882
Houston: 13,847
Phoenix: 8,411
Boston: 8,104
San Jose: 5,775
Las Vegas: 5,225
Honduras:
Houston: 37,905
New Orleans: 7,742
Tampa: 6,634
New York: 6,393
El Salvador:
Houston: 46,089
Los Angeles: 45,610
New York: 23,985
Atlanta: 10,190
Boston: 10,112
Baltimore: 7,089
Philadelphia: 6,677
Las Vegas: 5,883
I also see it as an opportunity to seize market share. I also suspect heavy O/D destinations are the way to go to make money during these times. Also, GUA was having an incredible year in terms of tourism, which I hope will bounce back once all of this is over. SAL has had more VFR traffic to the US than GUA in the past, so not surprised to see these additions.
avi8
