LCDFlight wrote:Is it being implied that the B789 is getting a new expansion of range, or just that UAL is upgrading to a higher thrust version?
Airlines0613 wrote:It has been reported that UA plans to upgrade the software in a sub-fleet and eventually all 789s. This software upgrade will increase thrust and improve the fuel management systems, thus increasing the range and capabilities of the aircraft. The software update is what will allow SFO-BLR and EWR-JNB possible.
https://onemileatatime.com/united-airli ... BPguQEjWjg
What are your thoughts of such an upgrade? Was this and upgrade in conjunction with Boeing, a third party company, or on their own? Will the update then be extended to the 788 and 78X to improve their range and capabilities? Finally, will other airlines follow suit?
Please do not remove, this post is not fully about UA and should not be consolidated.
zeke wrote:When i look at that link...it has nothing in it regarding a thrust bump or a range increase.
thepinkmachine wrote:I understand higher thrust - but software changes to the fuel management system. What could it be?
Perhaps fuel tank capacity change a’la A350ULR, without any physical change to the tanks?
Stitch wrote:The reason I think it may be related to the thrust increase is that the change is only being made on the handful of UA 787-9 getting the thrust increase now and then will be rolled out to the entire fleet (so they will all be certified for a higher thrust and receive the fuel management system update).
Stitch wrote:zeke wrote:When i look at that link...it has nothing in it regarding a thrust bump or a range increase.
This one does mention it: https://crankyflier.com/2020/09/10/unit ... long-haul/
Specifically, it has increased engine thrust and altered the fuel management system to squeeze more range out of the fleet. (Both of these are software changes.
moyangmm wrote:This one does mention it: https://crankyflier.com/2020/09/10/unit ... long-haul/
zeke wrote:moyangmm wrote:This one does mention it: https://crankyflier.com/2020/09/10/unit ... long-haul/
In the article it saysSpecifically, it has increased engine thrust and altered the fuel management system to squeeze more range out of the fleet. (Both of these are software changes.
I don’t believe the article, aircraft cannot just increase thrust in engines, as minimum control speeds are based upon the thrust, controllability, and rudder size. Like I said in my previous post I think it’s a thrust bump which maintains the rated thrust to a higher density altitude, the maximum thrust remains the same.
Most bloggers would have no idea of control speeds etc and think that thrust is actually increasing, when it isn’t increasing, it is not degrading or degrading at a lower rate with the increase in density height.
United857 wrote:zeke wrote:moyangmm wrote:This one does mention it: https://crankyflier.com/2020/09/10/unit ... long-haul/
What I suspect UA is doing is upgrading the GEnx to the 787-10 spec, which has already been certified on the 787-9 as a high thrust option concurrently with the 787-10 certification in 2018 (see page 9-10 at https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/39719ee9447ccc67862585e300696651/$FILE/T00021SE_Rev34.pdf). It simply means writing a check to GE for the higher-thrust FADEC plug.
moyangmm wrote:Since they use 787 they have advantages on fuel efficiency over their competitors.
VSMUT wrote:As Zeke correctly wrote, you can't just increase thrust. Controllability and rudder size play a role. The 787-10 can have more powerful engines because it is longer, so the rudder acts on a longer arm.
I for one think Zeke is right about this being a thrust bump for certain conditions, allowing them to uplift more.
thepinkmachine wrote:One thing worth mentioning here is Thrust Asymmetry Protection - a 787 feature, which automatically reduces thrust on the live engine, when speed drops below V2, in order to maintain better controllability at low weights. Boeing says it doesn't adversely affect the performance, as reduced asymmetry drag offsets lower thrust.
I'm not sure to what extent it lowers certified Vmc speeds, but if it could be taken into account, then it could enable installing more powerful engines without eg. increasing the vertical stabilizer area
VSMUT wrote:At low weights is the key word. A 787-9 flying long distances won't be at low weights. The last thing you want at MTOM after an engine failure is for the remaining engine to deliver less power. IMO, it's a safety feature, not a performance booster.
flipdewaf wrote:The BLR route does throw up some interesting questions as it is indeed ~250nm further than the SFO sin route that struggled. My take here though is that whilst the two routes might superficially look similar the likely hood of encountering the winds that made the SFO-SIN route so difficult may well be very different.
zeke wrote:flipdewaf wrote:The BLR route does throw up some interesting questions as it is indeed ~250nm further than the SFO sin route that struggled. My take here though is that whilst the two routes might superficially look similar the likely hood of encountering the winds that made the SFO-SIN route so difficult may well be very different.
I ran plans SFO-BLR and BLR-SFO, SFO-BLR carried around 34 tonnes, flight time 16:55, and the reverse same payload 16:40.
flipdewaf wrote:zeke wrote:16:40 and 16:55 suggests about 3kts effective head/tailwind, so low.
Is that for the 789? the loads look high.
Fred
I for one think Zeke is right about this being a thrust bump for certain conditions, allowing them to uplift more.moyangmm wrote:Since they use 787 they have advantages on fuel efficiency over their competitors.
Not really tho. If you really are right about this upgrade, don't forget that you get more power by essentially burning more fuel. That will probably put it at a disadvantage compared to an A350-900 and certainly against a normal 787-9. You also wear out the components faster. Nothing is free.
moyangmm wrote:zeke wrote:moyangmm wrote:This one does mention it: https://crankyflier.com/2020/09/10/unit ... long-haul/
But ULR doesn't mean more thrust, does it? A359ULR has the same thrust as regular A359. ULR only requires more fuel and less payload.
‘ULR’ doesn’t actually refer to anything on a technical basis, it is a marketing moniker.
With reference to the A350 it started as a higher weight variant and the only available model with 280t was the ULR, it only later became the standard weight(as did the winglets I believe). The A350ULR also allows greater fuel volume to enable the longer routes to be operated according to the standards of the airlines.
With regard to higher thrust engines allowing greater range it is the case that when weight is limited by field length that a higher thrust would allow higher TOW and so allow greater fuel uplift and therefore greater range at a given payload. This is likely the case for the JNB-NYC route.
Fred
Okcflyer wrote:yes, I’m aware of the changes but I was referring to there not being a specific technical hurdle or test before an aircraft can be called a ULR variant.
Actually, ULH does have some technical differences to enable higher fuel capacity. Extra fuel pumps, modified systems, etc to enable greater fuel volume. That extra system is not standard on regular 280T A359’s and frankly not needed.
Okcflyer wrote:Actually, ULH does have some technical differences to enable higher fuel capacity. Extra fuel pumps, modified systems, etc to enable greater fuel volume. That extra system is not standard on regular 280T A359’s and frankly not needed.
zeke wrote:Okcflyer wrote:Actually, ULH does have some technical differences to enable higher fuel capacity. Extra fuel pumps, modified systems, etc to enable greater fuel volume. That extra system is not standard on regular 280T A359’s and frankly not needed.
Incorrect, no additional pumps, the configuration is now standard as far as I am aware. The main changes were related to fuel sensing and software.
Okcflyer wrote:Fuel pumps is a mistake. That said I understand the inerting system was upgraded along with the additional sensors?
Okcflyer wrote:That said I understand the inerting system was upgraded along with the additional sensors?
Are you able to check and confirm?
747classic wrote:The T/O thrust will then be increased from 76700 lbs to 78500 lbs.
Stitch wrote:If the thrust bump just helps "hot and high" ops, I wonder why UA is planning to add it to the entire 787-9 fleet (as the articles state) and not just the frames that will be dedicated to serving these two routes. Yes, it offers a bigger pool of frames for substitution reasons, but seems an unnecessary expense for an option that sounds like it would be unnecessary for most ops.
Qantas744er wrote:Some facts for a change:
UAL B789s are all powered by GEnx-1B74/75/P2 (76,600Lbs).
Small note Zeke: /P2 is flat rated to 32.8C ( /P1 refers to flat rated to 30C),both at sea level as you already mentioned.
The highest available GEnx-1B rating on the B789 is the -1B76A/P2 (78,500Lbs). As previously mentioned above by another user, UA can cut GE and Boeing a check for the new FADEC rating plug and FCOM revision.
FYI, the highest thrust rating on the GEnx-1B is the -1B78/P2 (80,400Lbs).
Note, this rating is FAA certified since April 12, 2013. However it has yet to be certified on the 787-9 or even 787-10. In other words, while GE has long ago received FAA certification for the rating itself, Boeing has not yet received FAA certification for use the 787-9 or 787-10. This is current as of Sept. 11 2020. This does not rule out that certification of the -1B78/P2 on 787-9 or 787-10 is currently in process/pending.
I am not aware of any customer optioning their GEnx powered 787-9/10 with this rating and that would explain why Boeing has in turn not yet applied for and received FAA certification.
Okcflyer wrote:Qantas744er wrote:Some facts for a change:
Is 1B76A/P2 flat rated to 32.8*C?
Qantas744er wrote:Small note Zeke: /P2 is flat rated to 32.8C ( /P1 refers to flat rated to 30C),both at sea level as you already mentioned.
zeke wrote:Qantas744er wrote:Small note Zeke: /P2 is flat rated to 32.8C ( /P1 refers to flat rated to 30C),both at sea level as you already mentioned.
Not according to the TCDS when installed on the 787, where is your data from ?
Qantas744er wrote:zeke wrote:Qantas744er wrote:Small note Zeke: /P2 is flat rated to 32.8C ( /P1 refers to flat rated to 30C),both at sea level as you already mentioned.
My apologies Zeke, I mixed up the GEnx-1 model designators. /P2 alone only refers to the second PiP
And /P1 to the first PiP.
The -76A/P2 is Flat rated to 32.8C as previously mentioned. While a -76/P2 is flat rated to the standard 30.0C.
You can verify the above in FAA TCDS 00078NE (GEnx-1B and -2B).
The -76/P2 has not to be certified (yet) at the 787-9 according the 787 TCDS (page 10/26), only the -76A/P2
On the 787-10 both are certified.
Qantas744er wrote:A paperwork exercise at best. Especially considering the only difference between a -76/P2 and -76A/P2 is a different FADEF plug.
