Sokes
How many runways does an airport need?
Tue Jan 05, 2021 12:57 am
What are factors to consider?
Examples of airports that added one and a description how that one changed operations are also welcome.
Why can't the world be a little bit more autistic?
e38
Re: How many runways does an airport need?
Tue Jan 05, 2021 1:26 am
one.
e38
Tue Jan 05, 2021 4:02 am
Factors to consider are primarily traffic volume, prevailing winds, obstacles, FIR/national boundaries.
bradyj23
Tue Jan 05, 2021 6:10 pm
one.
e38
So does that make it technically 2?
seb146
Tue Jan 05, 2021 6:57 pm
MFR (Rogue Valley International, Medford Oregon) only has 32/14. They had a smaller runway that ran SE/NW but that was removed, so they are down to the one. MFR is busy with flights from SEA, PDX, SFO, DEN, SLC, PHX, LAX and occasionally LAS. That seems to work fine for them.
You bet I'm pumped!!! I just had a green tea!!!
GalaxyFlyer
Tue Jan 05, 2021 7:15 pm
One works pretty well at Gatwick and Luton, both fairly busy. Gatwick is, I think, the busiest single runway airport in the world. Mumbai has two, but essentially can use only one at a time due to the configuration. Carriers can trap one plane every 45 seconds with one “runway” aka flight deck.
PatrickZ80
Tue Jan 05, 2021 7:31 pm
It really depends on the airport.
Up to a certain traffic volume, one runway is sufficient. However it has the disadvantage that the same runway is to be used by both landing and departing aircraft, so there can be queues of departing aircraft waiting for landing aircraft. It's only manageable to a certain degree.
If an airport has more traffic than that, it needs a second runway. That way landings and departures can be handled independent from each other, they both got their own runway.
Only if an airport sees extremely high traffic numbers more than two runways are needed, but this is really rare. However sometimes it can make sense due to the wind direction.
e38
Tue Jan 05, 2021 7:57 pm
Quoting bradyj23 (Reply # 4), "So does that make it technically 2?"
No, one.
Just as an example, do you look at the airport diagram for Dallas/Fort Worth International Airport (KDFW) and say, "Wow, that airport has fourteen runways?"
there is a difference between a "runway," and takeoffs and landings in two directions.
e38
CosmicCruiser
Wed Jan 06, 2021 2:47 pm
Reading this post, I was visualizing Fedex having only one runway during the afternoon and night arrivals and departures. They will use 3 and sometimes all 4 at MEM.
stratclub
Fri Jan 08, 2021 3:23 am
Also at the end of the day, your successful take offs should equal your successful landings. :-)
aklrno
Fri Jan 08, 2021 3:48 am
Not true at PAE and RNT, for example
VSMUT
Fri Jan 08, 2021 12:01 pm
I always wondered what the total takeoff and landing figures looked like in the logbook of a fighter pilot who ejected from his aircraft. Do they list one more takeoff than landing?
CosmicCruiser
Fri Jan 08, 2021 4:57 pm
As long as you have your "D" ring to prove it. LOL!
GalaxyFlyer
Sun Jan 10, 2021 12:15 am
I could at my Form 5, but i can’t recall if the flight was even logged.
bluecrew
Mon Jan 11, 2021 9:02 am
Well... let's see.
How many arrivals do you get? What's your ideal AAR?
Are these runways parallel? Where is each intersection of crossing runways?
If these runways are parallel, what sort of approaches do you need? Are we talking simultaneous instruments (many), or trips (DFW), or quads (ORD), or just one instrument and the rest tied visual (BOS)?
If you've got parallels, how far apart are they? Can you comfortably work your volume with that under 2500ft same runway separation rule, or do you need to build a new runway 2501ft away from your existing one (DFW)? Or maybe you need a third parallel. That's the ticket (SEA). Let's build a frickin' island and stick that sucker on there.
Do you need an offset due to departure procedures and missed approach procedures (JFK)?
What's the noise situation? Is one runway entirely useless for departures because of De Blasio (I'm kidding)?
Or, do you just hang on to vestigial runways because they're sentimental and remind you of a different, simpler time (MSP, DTW, LGW)?
Perhaps you have runways going in every single direction because YOLO and we're on a manmade island (BOS)?
There is no answer to your question.
TheWorm123
Mon Jan 11, 2021 10:18 pm
The benefit of parallel runways:
https://youtu.be/X5gGSWg_KcE
The SFO synchronised landings are a thing of beauty.
B752 B753 A332 A321 B738
GalaxyFlyer
Tue Jan 12, 2021 1:45 am
Or a source of delays back to Nebraska
Moose135
Tue Jan 12, 2021 2:04 am
If it's circular, you only need one...
Users browsing this forum: FlyingHollander, jetblastdubai and 84 guests
