Dutchy wrote:Will be much more technically challenging than the Channel Tunnel. The strait of Gibraltar is a seismically active region and the strait is actually quite deep, 300 and 900 meters. The Tunnel's maximum depth is 115meter.
Would be interesting to see how it is going to work, just looked at the distances involved. Marrocco - Spain is around 15/6 kilometers and Marrocco - Gibraltar, given that they probably want to avoid Cueta - Spanish territorial within Marrocco - around 22 km, so quite a bit more and thus way more expensive to build.
So it will be interesting to see if it is going to be built. Would be great for commerce and geopolitical relationships though.
johns624 wrote:But would it be iconic...
Aesma wrote:The article is misleading, saying "Strait of Gibraltar, which is under British sovereignty". Gibraltar is under British sovereignty, not the Strait !
The tunnel would be extremely difficult to build and maintain because of the depth, it would cause all kinds of issues. The floating bridge seem to make more sense, apparently Norway is studying building several of these.
I think using Gibraltar is a bad idea for two reasons : most of the traffic would come from Spain and further, so with Gibraltar you just add borders and complications. And you need significant space to set up the entry/exit point of the tunnel, space for hundreds of trucks etc., I doubt Gibraltar has such space available.
Also the Strait is the deepest there...
Kiwirob wrote:johns624 wrote:But would it be iconic...
Millions of tourists will flock to it, there will be so many they will need to build museums and hotels at both portals, just like the Channel Tunnel portals packed with day trippers, staying at fancy tent hotels visiting the museums at both ends, eating tunnel cake and going on day trips into the tunnels to play spot the economic migrant.
Kiwirob wrote:there will be so many they will need to build museums and hotels at both portals
tommy1808 wrote:Dutchy wrote:Will be much more technically challenging than the Channel Tunnel. The strait of Gibraltar is a seismically active region and the strait is actually quite deep, 300 and 900 meters. The Tunnel's maximum depth is 115meter.
Maybe go the submerged floating tunnel route. Aside from the challenges that has, it would remove lots of the "down in the rock" problems.
https://en.wikipedia.org/wiki/Submerged_floating_tunnel
best regards
Thomas
Aesma wrote:I'm talking about floating bridges of the scale we're talking about, more than 10Km long, with something like giant oil platforms supporting it, anchored on the seabed.
As for a floating underwater tunnel, that seems a bit scary to be honest. Imagine a submarine hitting it !
cjg225 wrote:Aesma wrote:I'm talking about floating bridges of the scale we're talking about, more than 10Km long, with something like giant oil platforms supporting it, anchored on the seabed.
Beat me to it. I was going to post about navies needing to update navigational charts and have a restricted depth band when transiting the strait.
