Strebav8or wrote:Speaking as a private pilot, that experienced the loss of the right main on the day of my solo.....
1. Aviate. Fly the airplane. Fly it safely. Altitude and airspeed will always be your friend. Remain calm and work the relevant checklist, if one, for the situation. No checklist, go to your basic airmanship and ensure the public's and your safety.
2. Navigate. determine your best course of action. In my case, we (my instructor was still with me) looked at a ditching near Homestead Bayfront Park, calling the Air Force Base to foam the runway, or which farmer's field was freshly plowed for the softest touchdown.
3. Communicate. Once you have achieved the first two, successfully, then make your radio call. Let the ATC, and other aircraft know of your intentions.
These have to be done in this order and calmly. Panic or do these out of order and your are endangering lives.
When you say "loss of the right main" I assume you mean the right main wheel. If that's the case, why would you consider landing off airport or ditching as an option? That doesn't make much sense to me at all.
About the OP's post, GalaxyFlyer is right on. Before every engine shutdown you verify that it's the correct engine by retarding the throttle first. TransAsia 235 is a prime example of why you do this.
