Kayro
Why can a pax stand upright in downstairs toilets?
Sat Apr 03, 2021 9:22 am
Hello
well, the question is in the title. A cargo compartment's height is 1,70 metres. A LD3-container's inner height
is even less, about 1,63metres and aren't the toilets built into these LD3-containers, e.g. in Lufthansa's A340-600?
But there are a couple of youtube videos where adults stand upright, my guess is about 1,8metres.
Do mechanics actually remove part of the floor/beams or how does it work?
masi1157
Re: Why can a pax stand upright in downstairs toilets?
Sat Apr 03, 2021 10:35 am
Those toilets are not installed inside the containers, obviously. They are installed where a part of the cargo hold would have been. You can have LD3-size crew rest containers attached to them that are sitting in the cargo hold when needed.
Gruß, masi1157
DL_Mech
Sat Apr 24, 2021 12:58 am
The L-1011 lower galley/lower lounge (PSA) had lowered floor beams compared to the normal C-1 or C-2 cargo compartments.
Dalmd88
Sat Apr 24, 2021 4:00 pm
One thing to remember is in a cargo bin area of the belly you have the container handling system installed in the floor. that takes up at least 6-8" (15-20mm). So if you were to put a permanent crew structure or passenger lav in that space the floor can be lower in the bilge area. There is a lot of room under the cargo bin floor. Too have a flat floor with a good size pallet area they have to leave a lot of empty space in the bilge.
ClipperYankee
Sun Apr 25, 2021 12:16 am
That brings up a question I've had. Let's say you're starting a flight at an airport with a remote stand and it is just pouring rain, with the passengers all getting rather wet while boarding and all the luggage getting wet while being loaded into the hold, etc. Is there a path for all that water to go, like a boat? Does it just eventually make it to the airplane's bilge and gets valved overboard?
Apols for going a bit off topic.
Sun Apr 25, 2021 12:40 am
There are indeed bilges and drains just like on a boat. The drain masts are heated so the water doesn't freeze.
Spacepope
Sun Apr 25, 2021 12:42 am
15-20cm, not mm. Big difference there
DL_Mech
Sun Apr 25, 2021 7:13 am
Oddly enough, an excellent picture appeared this week of the bilge drains. They are open on the ground and close with increased cabin pressure.
Wildlander
Mon Apr 26, 2021 11:12 am
On the few A330-200s and the DLH A340-600s with lower deck toilets the floor structure was modified to create the necessary standing height. One reason why this feature was not popular was that although there were design schemes (on the A330 at least) to insert a structural plug to bring the floor level back to the standard cargo compartment height the added complexity and downtime of having to rip out the existing toilets, replace the stair opening with seats and install extra main cabin toilets with water and waste connections to compensate for the removal of the lower deck ones was always going to be too much hassle. AFAIK DLH never envisaged converting their -600s back to regular lower deck configuration.
zanl188
Mon Apr 26, 2021 11:54 am
I see the drain masts. What are the buttons, for lack of a better word, along the keel?
Also a good view of LED landing lights on the Max.
acmx
Mon Apr 26, 2021 1:46 pm
They are the bilge drains. The drain masts are for things like lav and galley sinks usually.
Users browsing this forum: No registered users and 20 guests
