ELBOB
Re: Was the V22 tilt rotor the only candidate to replace the C2 ?
Wed May 05, 2021 6:46 am
RJMAZ wrote:
The V-22 can carry approximately 3 times as much a seahawk and deliver it twice the distance.
Cost per flight hour:
V-22 $11,000
H-60 $2,200
( US DoD data )
Cost scales faster than capability.
It seems entirely possible that the traditional COD-to-carrier and distribute by heli pattern is considerably cheaper than point-to-point with V-22s.
RJMAZ
Wed May 05, 2021 8:37 am
V-22 $11,000
H-60 $2,200
( US DoD data )
How do you calculate that? Cost scales slower with capability. You have clearly cherry picked the situation where you are putting a small 1,000kg load in both aircraft and have them fly a short distance.
How about setting an actual mission situation. 40,000kg that has to be moved to the carrier 400nm off the coast in 8 hours. Two V-22 would be needed to move that cargo in three trips per V-22. 6,666kg per trip.
The H-60 would need 15 helicopters. Two trips per helicopter with 1,333kg per helicopter as it needs maximum fuel capacity.
15 H-60 helicopters at $2,200 is $33,000 per hour.
2 V-22 is only $22,000 per hour.
The V-22 is then two thirds of the cost. Usually the bigger you go the cheaper things get per kg That's why all the air freight is in 747-8 and 777F aircraft.
No chance. You are replacing a whole aircraft type. Three V-22 on the carrier would be able to approximately replace 2 C-2 and 6 H-60. The V-22 option has fewer aircraft, fewer pilots and takes up less space in the carrier for extra offensive firepower.
Having cargo distribution taking up space on the carrier is reducing the sortie rate of the fighters.
ThePointblank
Wed May 05, 2021 6:23 pm
There's also the option to base V-22's off the carrier as well as tanker assets, instead of abusing Super Hornets in the buddy refuelling role. The USMC has already developed an aerial refuelling kit for their V-22's, which has demonstrated success in testing.
Users browsing this forum: kitplane01 and 12 guests
