Max Q
Iran Air 747 Combi ?
Sun May 16, 2021 4:03 am
Interesting picture of this Classic 747 on the home page, unable to link
Not only does it have the rear freight door but it has passenger windows and a swing nose
Looks more like a Convertible ?
Just to make it more unique it has the wing to body fairing from the 400 series
Can anyone shed any more light on this aircraft?
TheFlyingDisk
Re: Iran Air 747 Combi ?
Sun May 16, 2021 5:01 am
I believe it was an ex-Martinair Convertible registered PH-MCF.
Bought by IR in 2008 mainly for cargo. Fairly young at 33 years of age.
7673mech
Sun May 16, 2021 5:04 am
As stated it is a convertible. Convertibles had the swing nose and an optional side door also.
VirginFlyer
Sun May 16, 2021 5:29 am
Here is the pic:
To post pics from the database, you need to find the photo ID number (at the top of the page, and also in the URL). Then you use the photoid tags:
[photoid]6419235[/photoid]
You can also use the tags twoid or threeid to post two or three photos respectively, separating the ID number with commas:
[twoid]6138139,5857289[/twoid]
[threeid]6190451,6175993,4226009[/threeid]
V/F
Max Q
Sun May 16, 2021 6:22 am
Very interesting, thanks for the additional photos, I don’t think many convertibles were made
Fascinating to look inside on these freighters and see overhead bins installed inside the swing nose itself
They were truly ‘ready for anything’ !
And unique I think to see one with a -400 wing to body fairing, I’ve only seen those on late model Classics before
ZK-NBT
Sun May 16, 2021 8:00 am
L/N 712 built in the late 1980s, a pretty late build 747 Classic.
Interesting aircraft though for sure.
unimproved
Sun May 16, 2021 11:35 am
They were really built for quick changing, IIRC 1 full day (in the purpose built MP hangar with seat storage next to the cargo door). Flew holiday charters in summer and cargo in winter.
747classic
Tue May 18, 2021 7:14 am
I was surprised that (most of) the provisions for installation of the full pax configuration kit are still present, while the aircraft has been operated for the last 15+ years in the full cargo mode.
This will lower the max payload (highter OEW) and available volume (max 8 ft high), due the lowered ceiling with brackets for the Passenger Service Units (PSU) and bagage bins still installed.
EP-ICD, Lowered ceiling, restricting pallet height to 8 ft, note : gasper air ducts still present
EP-ICD, Unique double purpose nose section, nose door with partly present lining of the full pax configuration, while in cargo mode.
Max Q
Wed May 19, 2021 2:11 am
Thanks for the additional photos and insight, this must be one of very few if not the only Classic operating in this configuration?
Perhaps Iran Air occasionally does convert it back for passenger use otherwise it does seem pointless to limit its freight potential as you describe
Boeing757100
Wed May 19, 2021 2:47 pm
I never knew that 747-200Fs could have the hinge nose? Thought it was only the factory built 747-400Fs and 747-8Fs?
VirginFlyer
Wed May 19, 2021 8:10 pm
They were present from the start I believe. Here’s the second 747-200F a week after delivery with its nose open:
V/F
TUGMASTER
Wed May 19, 2021 8:41 pm
Remember seeing these every Saturday morning parked at LHR in the Cargo apron.
Early 80’s…..
Max Q
Wed May 19, 2021 11:59 pm
Yes,
In a previous thread there’s a discussion on the original Classic freighters, the first production examples actually had only the swing nose incorporated with no side door
These models were all modified later to include a side door and later production 200 freighters all came with nose and side doors as standard
747classic
Thu May 20, 2021 6:17 am
Max Q wrote:
Yes,
The first 747-200F's and -200C's were built with only the (hinged) Nose Door.
After introducing the Side Cargo Door (SCD) at the Sabena 747-100combi, the SCD was an option on the -200F and -200C, later it was standard at the 747-200F.
At several early built aircraft the SCD was later added, but not with all aircraft without SCD.
See : viewtopic.php?f=3&t=1450431
TheFlyingDisk
Thu May 20, 2021 11:49 am
Is the nose door not used in this case, given the presence of the overhead baggage bins at the nose section?
747classic
Thu May 20, 2021 12:40 pm
The nose door is in use (fully functional), but the provisions for installation of the passenger configuration (incl. fwd part of the ceiling incl PSU's and overhead bin lining) are not fully removed.
DL_Mech
Sun May 23, 2021 9:03 am
I’ve always wondered if those forward pax windows ever went through any impact testing similar to cockpit windows. I assume that they are standard pax windows?
Also, are those yellow actuators some type of locking mechanism?
Sun May 23, 2021 9:07 am
The angle is quite significant, to be fair. It isn't like you can see forward in any significant way. I imagine any large avian creature impacting would not have nearly as much of an impact (heh...) as one hitting the forward cockpit windows.
747classic
Sun May 23, 2021 9:58 am
The picture of EP-ICD was taken during maintenance, but in active full cargo configuration, even a lot more of the ful pax lining was still in place (increasing the OEW), see below.
Martinair Sister ship 747-21AC, PH-MCE, HKG, Feb 1989
747classic
Fri May 28, 2021 11:54 am
I found a production picture of the first ever built section 41 for a 747-200C (World Airways 747-273C)
Section 41 of L/N 209, Wichita, Jan 6 - 1973
Credit : AW&ST Archives, see : https://aviationweek.com/air-transport/ ... 7f2053cde3
Aircraft data : B747-273C, L/N 209, c/n 20651, N747WA, F/F 73-03-23, Delivered 73-04-27, Basic number R4005, Variable number RJ131, World Airways
744lover
Fri May 28, 2021 4:31 pm
They are the gears that turn the long screw you see and that push the nose up. Interestingly they are operated by a single electrical motor in the upper-center part of the nose. This motor has two flexible shafts, one to each of these yellow gears. Once the 16 locks are free, the motor engages and the gears start rotating the screw, therefore pushing the nose.
Here's a video description https://www.youtube.com/watch?v=cTXUtetGsfo
BR,
744lover
DL_Mech
Fri May 28, 2021 5:20 pm
744lover wrote:
Interesting video.
747classic
Sat May 29, 2021 8:55 am
Manual opening of the nose door is possible (powertool), but takes a very ......... long time.
A latch can be closed/opened manual, but some latches are hard to reach.
You may depart with one latch not closed, or one latch missing. (MMEL, ATA 52, see : https://fsims.faa.gov/wdocs/mmel/b-747-400_r28.pdf )
It maintained regulary, the system functions ok, only when one of the flexible shafts of the powerlift system fails (jammed), you are in deep trouble.
