bearnard123
Space junk
Thu May 27, 2021 2:53 pm
The consideration to keep in mind is called space junk, we got quite some trash up there in orbit of our planet. It's considered not to be a problem due that the size of the object would burn in our atmosphere. But we of Asgardia want to go to space and we require to keep in mind out of the prospect of security, what do we do about the space junk?
CDNlaxdad
Re: Space junk
Thu May 27, 2021 3:44 pm
Why bot of just said space junk is an increasing problem and how can we deal with it,...
Bearnard - lay off the stuff before you post...
MadAstronaut
Re: Space junk
Fri May 28, 2021 10:01 pm
The most obvious decision we can take is to reduce the number of launches. However, we all understand that it's impossible now and will hardly ever be possible. That's why space agencies work on numerous projects that aim to clean the orbit. Some of them presuppose the use of satellites, and they seem the most interesting to me. I have just started to monitor dragonflyaerospace.com, a promising South-African endeavor that manufactures satellite imagers that can do good for such mission I suppose. I may tell you more about them if you want.
bearnard123
Re: Space junk
Sat May 29, 2021 8:44 am
I guess it`s impossible to decrease the number of launches. I heard that some space agencies are going to make some ``cleaning`` missions. I guess the easiest way to cope with space junk is to make them burn down in the atmosphere. However, it depends on the size of some space debris. It can be so large that it won't just burn down in the atmosphere
MadAstronaut
Re: Space junk
Sat May 29, 2021 8:47 am
Large particles can be split into several small pieces by laser or any other technology.
bearnard123
Re: Space junk
Sat May 29, 2021 8:52 am
The big number of space junk can damage expensive spacecrafts The growing number of space items can lead to the state where the object density is so high that one collision is enough to generate a cascade effect, leading to further collisions.
bearnard123
Re: Space junk
Sat May 29, 2021 9:03 am
The growing number of space items can lead to what is known as the ‘Kessler syndrome’, which represents a state where the object density is so high that one collision is enough to generate a cascade effect, leading to further collisions.
bearnard123
Re: Space junk
Sat May 29, 2021 1:46 pm
I`ve heard the mission called the ``Claw`` is gonna work according to the method I`ve mentioned previously in this thread. This mission is about to be launched in 2025.
MadAstronaut
Re: Space junk
Mon May 31, 2021 2:17 pm
There's also a mission that aims to launch a CubeSat that'll clean up the space junk and deorbit by tethers and nets. It's called OSCaR.
MadAstronaut
Re: Space junk
Tue Jun 01, 2021 12:18 pm
The ISS recently suffered a clash with a piece of space junk that hit its robotic arb. Isn't it an important signal for us to start doing something with it...
bearnard123
Re: Space junk
Tue Jun 01, 2021 2:31 pm
A recent inspection of the International Space Station's Canadarm2 has revealed that it was hit by orbital debris. See the hole that was created and a time-lapse of the robotic arm in action.
https://www.youtube.com/watch?v=VFijTNJqnYA
tommy1808
Re: Space junk
Thu Jun 03, 2021 11:13 am
Or make de-orbit mandatory, including requiring insurance for clean up if the de-orbit fails.
Best regards
Thomas
bearnard123
Re: Space junk
Fri Jun 04, 2021 11:20 am
Best regards
Thomas
I guess scientists should work on the issue of the short lifespan of microsatellites. I hope that in some time scientists will succeed and solve that issue. By doing that scientists can reduce the number of launches and the number of dead satellites in the orbit of Earth.
tommy1808
Re: Space junk
Fri Jun 04, 2021 12:04 pm
bearnard123 wrote:
Best regards
Thomas
That is already solved: Put it in an orbit that decays within a reasonable time or give it enough delta-V to de-orbit itself at the end of its useful life.
Both costs money in all cases where such orbit isn´t conductive to the mission objective, either by shortening it or requiring to lift more fuel into orbit.
best regards
Thomas
WIederling
Re: Space junk
Fri Jun 04, 2021 1:36 pm
What is your position on commercial entities setting up massive space segments for some project or other?
( Starlink comes to mind. beside introducing a massive amount of junk into space the design would allow to
use the individual retargetable sats as space denial tool. Ops! sorry Russia, to hit your freshly started space asset.)
tommy1808
Re: Space junk
Fri Jun 04, 2021 2:06 pm
Deorbit them, pay someone to de-orbit them or be made to pay to de-orbit them at the end of their operation lifetime.
Best regards
Thomas
meecrob
Re: Space junk
Sat Jun 05, 2021 9:18 pm
The same starlink satellites that are designed to be de-orbited and have literally already done that? I don't know the actual cost of the propellants, but compared to the launch cost, its trivial. If you leave your garbage in orbit, its cuz you are a jerk, not because its difficult to remove it.
tommy1808
Re: Space junk
Sun Jun 06, 2021 4:35 am
Its not difficult, but the higher the orbit, the more expensive it gets.
Best regards
Thomas
MadAstronaut
Re: Space junk
Tue Jun 08, 2021 6:01 pm
SpaceX told their satellites can naturally deorbit themselves and burn in the Earth's atmosphere. Do they have another deorbiting system?
bearnard123
Re: Space junk
Fri Jun 11, 2021 1:18 pm
If I am not mistaken, some space company has already made such microsatellites, I mean with the same option of deorbiting themselves and burn in the Earth's atmosphere
Aesma
Re: Space junk
Fri Jun 11, 2021 2:05 pm
There are rules about satellites' end of life saying they should be put into specific orbits, however if something goes wrong, no rule is mandating you go up there to fix the problem. Yet.
meecrob
Re: Space junk
Fri Jun 11, 2021 11:28 pm
They have ion thrusters...and I'm not sure about this bit, but I remember hearing that future versions will turn their solar arrays broadside to the atmosphere to help as well.
art
Re: Space junk
Sat Jun 12, 2021 8:11 am
Fishing for knowledge here. Any answers welcome
How large/how much mass does something need to be to be counted as a unit of space junk? I presume that a dust cloud consisting in 10,000 particles does not count as 10,000 pieces of space junk.
What are the smallest/least massive objects currently trackable? How many orbiting objects are tracked (orbits known and recorded)?
If things are in geostationary orbit a long way from Earth, will it be hundreds/thousands of years before they return home?
mxaxai
Re: Space junk
Sat Jun 12, 2021 10:48 am
There is no minimum size for space junk. Even tiny paint chippings are counted as debris.
Any particles in space cause damage to satellites. 'Dust' will usually only cause superficial damage similar to sandblasting a surface.
Particles of a size <1 cm can create a small crater. Thin and soft parts like thermal shielding foils, cables or coolant lines may be penetrated; delicate small parts like sensors may be destroyed.
Solid particles with diameters of 1 - 10 cm can easily penetrate any primary structure, which can damage and destroy subsystems.
Particles >10 cm are generally expected to destroy a satellite. The lower limit for complete destruction is estimated at around 40 J/g when comparing the impactor energy to the satellite mass, so a 500g piece of Aluminum is more than sufficient for medium-sized satellites.
https://www.nap.edu/read/4765/chapter/7#99
Objects are tracked by radar. The smallest tracked objects used to have a (RCS) diameter of at least 10 cm, some newer systems are hoping to track parts as small as 1 cm. The smaller the object and the higher its altitude, the more difficult it can be to track them accurately. https://www.mdpi.com/2076-3417/11/4/1364/htm
For comparison, old stealth aircraft like the B-2 and F-117 have an RCS diameter of approx. 7-10 cm, while newer aircraft like the F-22 and F-35 are said to be around 1 cm or less. Birds are also around 10 cm. (rough orders of magnitude)
Yes. Atmospheric drag in GEO and the GEO graveyard orbit is basically zero. Even for GPS satellites, it's negligible. These satellites will only reenter if orbital mechanics and the solar pressure disturb their orbit so that their perigee drops low enough (<1000km). That takes time. Centuries in some cases, several millenia in others. To illustrate this, some satellites in graveyard orbits only 100 km above GEO will not drop below the GEO altitude within 200 years. https://conference.sdo.esoc.esa.int/pro ... /paper/864 https://www.sciencedirect.com/science/a ... 7701004471
WIederling
Re: Space junk
Mon Jun 14, 2021 4:48 pm
Where actually is the difference between 10k pieces of space junk and
commercial system consisting of the same number of independently orbiting items?
mxaxai
Re: Space junk
Mon Jun 14, 2021 5:14 pm
Working satellites, assuming they have some means to change their orbit, can avoid collisions and can be deorbited in a controlled fashion.
WIederling
Re: Space junk
Tue Jun 15, 2021 6:46 am
That makes the issue even bigger as unpredictable changes can occur.
And the operator has been shown to not bother by stepping on other users.
ref: https://futurism.com/spacex-starlink-sa ... -collision
Users browsing this forum: No registered users and 9 guests
