FlyingHonu001
787 Paint adhesion issues
Sat Jun 12, 2021 5:56 pm
Recently KL sent PH-BHA to VCV to deal with apparent paint adhesion issues. More 789's within the KL fleet are suffering from this issues, you can spot them with various patches of speedtape on her wings. For window-seated pax, it might not be a reassuring view... :?
Image Image
Do any other airlines have this issue as well?
Opus99
Re: 787 Paint adhesion issues
Sat Jun 12, 2021 6:06 pm
I’ve seen this on other 787s
Opus99
Sat Jun 12, 2021 6:08 pm
Flight Radar has PH-BHA scheduled to do a flight on the 14th of June from Amsterdam to Kilimanjaro
hayzel777
Sat Jun 12, 2021 7:30 pm
It’s a well known issue. Boeing says that UV Rays are weakening the paint cohesion.
https://www.faa.gov/other_visit/aviatio ... O20006.pdf
TC957
Sat Jun 12, 2021 10:04 pm
I would have thought that if the QR 787's had this issue we would have heard about it publicly from AAB by now...
Guillaume787
Sat Jun 12, 2021 10:11 pm
Image Image
I’ve seen several AA787-8s with exactly the same issue using speed tape on the wings.
skipness1E
Sun Jun 13, 2021 1:45 am
BA had one in Dublin recently for a wing paint repair, assume it was the same issue.
Leej
Sun Jun 13, 2021 11:05 pm
So should we expect the A350 to have the same issues?
9Patch
Sun Jun 13, 2021 11:08 pm
And the A220, and the 777X?
CWL757
Mon Jun 14, 2021 12:35 am
The BA 789 fleet seem to slowly be making their way through SNN for wing repaints too.
Noshow
Mon Jun 14, 2021 6:44 am
Would this degrade airflow and affect performance?
CarbonFibre
Mon Jun 14, 2021 7:16 am
Some UA 767s painted at VCV also had this problem.
JDubman
Tue Jun 15, 2021 4:30 am
I wonder to what degree wing flex contributes to this. The increased wing flex of a composite wing would definitely place more tension and compression forces on the paint, perhaps to the point of premature failure. Not sure if the 787 gets different type of paint (perhaps one with more flexibility?) than other aircraft models.
ClipperMonsoon
Tue Jun 15, 2021 3:18 pm
Do a search, the A350 has had it's issues already with the wing surface under the paint, doesn't mean every new aircraft will suffer from this, and i dont think it's a safety issue.
Sooner787
Tue Jun 15, 2021 3:26 pm
I've seen 787 wings unloaded from Dreamlifters that already appear painted white?
do the wings get another coat of paint when the rest of the plane is painted or is that the final layer?
9Patch
Tue Jun 15, 2021 7:29 pm
Could it be a carbon wing issue?
iamlucky13
Fri Jun 18, 2021 7:30 am
Yes, the FAA link hayzel777 posted above indicates it is UV related damage to the resin. They don't state if it occurs prior to painting, or somehow through the paint.
They do mention a maintenance safety issue when using vacuum cups to attach fall arrest devices, but don't mention flight safety issues.
There has been recent discussion about paint issues with A350's, although it's not clear if they're related. I haven't seen anything about the CSeries paint so far, and of course, with the 777X not yet in service, there's probably not been a lot of opportunity to discover issues.
https://www.reuters.com/world/middle-ea ... 021-06-08/
