Scarebus34
Southwest faces another IT outage, all flights stopped.
Tue Jun 15, 2021 6:16 pm
Southwest is facing its second system-wide IT outage in as many days. All flights currently stopped. No resolution time given.
lightsaber
Re: Southwest faces another IT outage, all flights stopped.
Tue Jun 15, 2021 6:19 pm
Flights resumed:
https://www.msn.com/en-us/travel/news/s ... NewsSearch
Interesting that weather information stopped them.
Lightsaber
Scarebus34
Tue Jun 15, 2021 6:21 pm
lightsaber wrote:
Flights resumed:
Lightsaber
That article is referencing their outage last night. They have another one occurring at this moment.
https://twitter.com/southwestair/status ... 06182?s=21
jholio
Tue Jun 15, 2021 6:28 pm
lightsaber wrote:
Flights resumed:
Lightsaber
As the other poster said, this is new and current. I was listening to KDAL tower around 12:45p central time and the controller mentioned Southwest was in a ground stop, so it was a great time to fly into the airfield. There were WN flights already airborne still arriving, but none leaving.
av8tiongeek
You get a Yeti. You get a Yeti. You all get a Yeti.
orlandocfi
Tue Jun 15, 2021 6:38 pm
Kinda sucks that these outages are overshadowing the celebratory mood of anniversary week.
DEN1895
Tue Jun 15, 2021 6:46 pm
Currently 22 aircraft on the ground in DEN with no available gates, nearly every deice pad full.
QXAS
Tue Jun 15, 2021 6:57 pm
Southwest flights appear to be pushing back at PHX. Although they could be empty jets moving to stands to open up gates for arriving flights.
Edit: WN4165 just departed for ONT, 3 hours late.
av8tiongeek
Tue Jun 15, 2021 7:00 pm
Some systems have returned to normal.
dabpit
Tue Jun 15, 2021 7:07 pm
Has it been reported which system crashed this time? Surprised they haven’t had more issues with all the patch work that has been done with all their systems.
aviationjunky
Tue Jun 15, 2021 7:14 pm
WN3256 just departed LAS for ELP, almost 2 hours late.
Sooner787
Tue Jun 15, 2021 7:18 pm
SWABIZ is offline right now ( 1417 cdt ) and we have couple travelers in middle of their trips to DAL.
I think the 50% off fare sale may have crashed their system LOL
AWACSooner
Tue Jun 15, 2021 7:24 pm
I know I took advantage of that this morning.
Still...WTH, WN? Unless it's a third-party hack, having your system crash twice in less than 24 hours shows how fragile and vulnerable your IT system is.
Eiszeit
Tue Jun 15, 2021 7:32 pm
That would be crazy, there is no way operation critical systems have any connection to a sales system... But sometimes the crazy stuff is not as crazy as we think. :?:
catiii
Tue Jun 15, 2021 7:43 pm
It wasn't their system yesterday. It was their weather provider's system, the failure of which would not allow them to dispatch.
MO11
Tue Jun 15, 2021 7:45 pm
Different systems. Yesterday was the weather vendor which also affected AS and DL.
AWACSooner
Tue Jun 15, 2021 7:58 pm
I stand corrected...but still concerning.
lightsaber
Tue Jun 15, 2021 8:04 pm
jholio wrote:
lightsaber wrote:
Flights resumed:
Lightsaber
Well, I picked the wrong week to quit sniffing glue!
https://youtu.be/KAccN64YmCs
Not good news.
What level of operation are they up to?
Lightsaber
Sooner787
Tue Jun 15, 2021 8:07 pm
SWABIZ update 1506 cdt .... appears to be back online. I was just able to complete
a booking. Now let's hope WN get their ops back to normal soon.
vatveng
Tue Jun 15, 2021 8:10 pm
As someone who maintains a (non-aviation) cobbled-together multi-vendor legacy I.T. system that I neither designed nor have the authority to replace, I can say with confidence that systems that have nothing to do with each other and shouldn't have any communication do sometimes cause each other to crash. Yes, it is crazy. And infuriating, and frustrating. A joke I tell at work is that these systems are so bizarrely interconnected in ways they shouldn't be that sometimes when you flip a light switch in a storage closet, the fire hydrant out front explodes.
Really the only way to fix it is to replace everything, all at once. Even if you have access to enough capital to do that, it's incredibly disruptive and the replacement comes with training and teething issues of its own. Often companies decide to stick with the devil you know. But eventually you get to a point where the legacy systems cause more PR disasters than the shareholders will tolerate. Then, and only then, will companies like Southwest replace their legacy systems.
32andBelow
Tue Jun 15, 2021 8:25 pm
Everything in an airline is connected to the res system. You have to be able to pull flight manifests to dispatch a flight. The red system IS critical.
Not saying that is what happened but it’s all certainly connected.
dtdude
Tue Jun 15, 2021 8:41 pm
Southwest's systems are fairly new, IIRC. They switched away from an older proprietary reservations system to Sabre not long ago. I would image this would require significant hardware investment.
But...who knows. This could be a shoddy implementation of Sabre. If could be failed hardware. It could be a WAN connectivity issue (which if done right should NEVER be an issue). Could be lots of things.
WN732
Tue Jun 15, 2021 8:49 pm
From an IT perspective, I generally am really interested in what the innards of the WN network are and what kind of failover and backup systems they have. They just had a job posting for a Veeam specialist the other day, and other jobs for Office 365 Admin, etc. None of that is cheap, and it shows that at least outside of the reservations system (which has seen some recent major overhaul), their IT has kept up with the times.
dtdude
Tue Jun 15, 2021 9:05 pm
Travelers are reporting that NOTHING works. Not even internal on-net telephone calls in Denver (Cisco CUCM, I believe). That really makes me think it's more along the lines of an AD/DNS/DHCP failure, or an issue at a datacenter (although you would think they'd have a local domain controller and a CUCM subscriber node). Could sit and speculate all day long, but definitely sounds network related and not specific to any 1 system.
But yes, I am very curious about the inner-workings.
lightsaber
Tue Jun 15, 2021 9:19 pm
2nd glitch making financial news just within last hour:
Southwest Airlines said it was working Tuesday to restore normal operations after a technology-related issue interfered with flights for the second straight day.
By midafternoon, the nation’s fourth-largest airline had canceled about 500 flights and delayed nearly 1,300 others, according to tracking service FlightAware. The combination of cancellations and delays affected about half of Southwest’s planned flights for the day.
Oops.
What more can be said. Without knowing the inner workings... If due to obsolete systems, that could be a huge job ahead.
Lightsaber
chrisp390
Tue Jun 15, 2021 9:36 pm
How likely is it that this is a foreign hacking and extortion operation similar to the Colonial Pipeline hack and others recently?
Speedy752
Tue Jun 15, 2021 9:41 pm
There were more issues than that across a number of carriers yesterday, but I don't know if they were related. DL had some sort of booking engine burp last night that resulted in no Main Cabin fares being displayed across some large number of city pairs. I can't believe that's related to weather but maybe there was something else on the back end that was bigger than just WN?
This was a system wide glitch? I was checking out Hawaii fares and thought maybe it was just demand into all city pairs
bnatraveler
Tue Jun 15, 2021 9:42 pm
Southwest actually swapped AWAY from their Sabre-hosted SAAS system (which has heritage back to Braniff's Cowboy system) to Amadeus. Amadeus is a solid solution and if they were down, you'd see lots of airlines impacted. They also moved away from a very old (mainframe hosted) accounting system to SAP which is also hosted by a third party. Southwest also has spend a huge sum of money to build an alternate/backup data center for their operations. Amadeus isn't hosted in-house, nor is SAP, but they rely on traffic paths that go through their data centers.
The brittle part of the airline, as I understand it, is their dispatch system that was written in house in the late 90s/early 2000s. I think the system is called fetch or rover or something like that. Obviously, it has been substantially updated over time, but I understand that it needs wholesale replacement. Southwest is a much more complex airline now than it was then.
Also, I understand that their passenger revenue accounting system needs work in order to accommodate passenger fare/service purchase transactions in currencies other than USD. Not sure where that stands on the list of replacement priorities.
dtdude
Tue Jun 15, 2021 9:57 pm
Ah, thanks for the correction. I had their new content deals with Sabre in mind. I forgot that they moved to Amadeus.
UPNYGuy
Tue Jun 15, 2021 10:45 pm
Same here. I re-rated 2 flights I have in biz select and got back roughly $1500
Cubsrule
Tue Jun 15, 2021 10:57 pm
I don’t know if it was systemwide but I can say with certainty that it was not just demand related and seemed to be resolved this morning.
FlyingElvii
Tue Jun 15, 2021 11:35 pm
Sabre....
A system still based on the late 70’s Cray.
SuseJ772
Tue Jun 15, 2021 11:51 pm
As someone who led just that (in non-aviation), I would agree. It also doesn't have to be as expensive as everyone always thinks it is, but few, very few in technology actually care about saving money so it ends up costing 5x as much and takes 2x as long.
SuseJ772
Tue Jun 15, 2021 11:54 pm
SAP is rough. I know it is the "gold standard" but it always, always, always fails to meet expectations. Also, SAP = Sudden Additional People. You IT costs go through the roof and it makes it harder to approve future capital projects because the first one (SAP) usually goes so poorly.
Southwest, if you need need your in-house dispatch re-written, I'd love to take on that project and give me a call {wink}
alasizon
Wed Jun 16, 2021 12:03 am
My understanding is their whole domain was down so not really an issue with a particular program but rather the most modern portion of their system.
dtdude
Wed Jun 16, 2021 12:06 am
I guess someone applied those patches to their domain controllers without testing first ha!
CALMSP
Wed Jun 16, 2021 12:45 am
was flying through DEN on my way to GJT and every gate on C was full of WN and then I counted 27 just on the west side of the airport waiting for gates. What a mess.
smokeybandit
Wed Jun 16, 2021 1:03 am
"Oh we don't need this DNS entry, let me clean things up"
lightsaber
Wed Jun 16, 2021 1:58 am
Photos Please.
This is interesting...
Lightsaber
nine4nine
Wed Jun 16, 2021 2:42 am
I landed at SNA a little after 5pm today and counted 11 WN tails. Never seen that many at once at SNA.
DEN1895
Wed Jun 16, 2021 2:56 am
lightsaber wrote:
Photos Please.
Lightsaber
While not as exciting, here is the ground radar from 1230ish today. All 24 gates are full and the 4 main deice pads are full with a total of 22 aircraft waiting for gates, around this time is when the ground stop went into affect.
slcdeltarumd11
Wed Jun 16, 2021 3:09 am
Not ok. Even with all the IT meltdowns at WN that seems unacceptabe. Clearly WN was a mess and that IT meltdown drained alot of other resources for that happen.
BMWdrvr75
Wed Jun 16, 2021 5:08 am
what do y’all expect from an airline that can’t even do red eyes and their stewardesses still serve off trays??? Just saying!
ADent
Wed Jun 16, 2021 5:30 am
Some local press coverage:
Tonight:
Child Hospitalized For Dehydration After Long Delays On Southwest Airlines Flight
https://denver.cbslocal.com/2021/06/15/ ... pitalized/
Mid Day:
Southwest Airlines delays, cancellations at Denver International Airport caused by network issues
Southwest has 88 cancellations today at DIA
https://www.denverpost.com/2021/06/15/s ... l-airport/
Yesterday:
Dozens Of Flights Delayed Or Canceled At DIA After Southwest Airlines Computer Failure
https://denver.cbslocal.com/2021/06/15/ ... r-failure/
kwp302
Wed Jun 16, 2021 5:46 am
WN4030 just now departing DEN for SDF. Set to arrive at 3:56 AM EDT…over 4 hours late.
http://flightaware.com/live/flight/SWA4 ... /KDEN/KSDF
32andBelow
Wed Jun 16, 2021 6:47 am
Trays is way better. Doesn’t block the whole aisle for an hour
AA100
Wed Jun 16, 2021 7:14 am
Each to their own... he has a point... we are talking about IT systems, and it is fairly well known that red-eyes are limited by technology. They only recently were able to fly internationally.
I find the trays a bit odd, but it does seem to work albeit with a lot of running/shuffling from the poor crew. I think they use each drink slot for a seat number so it allows them to hustle drinks out. One person takes orders, one person makes drinks, one person serves them etc. I was impressed the entire 737 I was on from LAS to SAN offered a snack and a drink. So however their system works.. it works!
slcdeltarumd11
Wed Jun 16, 2021 8:18 am
Tonight:
Mid Day:
Yesterday:
This wasn't an IT failure this became an airline failure. How could they allow this to get so bad? Southwest needs to examine it's emergency plans to get passengers off planes and get gate space open. They just failed running an airline allowing all those planes to continue to land in Denver when they couldnt get the people off the planes already or get gates open. They didn't need an it system to move empty planes out of gates or to get people off those planes. Huge Fail by southwest airlines, let's hope they can make it thru this week. What a mess, again for southwest airlines.
slcdeltarumd11
Wed Jun 16, 2021 8:28 am
https://www.transportation.gov/individu ... mac-delays
Shouldn't the tarmac delays fine southwest airlines alot of money? Reading the various Denver media articles It looks like southwsst broke pretty much event tarmac rule having people sit there while they were totally out of control
Silver1SWA
Wed Jun 16, 2021 12:10 pm
It caused a ground stop. The planes waiting were already enroute when the system went down and with the arrival rate of a station the size of DEN things get backed up very quickly.
