Airstud
Death of a smoke detector
Fri Aug 06, 2021 11:54 pm
Apparently, smoke detectors can reach their "end of life" - I didn't know they could do that; thought they only ever needed their batteries changed.
Mine will therefore be chirping 5 times every minute till it's changed. I called First Alert and asked if there was a way to silence the chirping - for, say, a 24-hr span? A few hours? An hour at a time? Until I can have building management install a new one tomorrow. She said no.
Figured I'd nonetheless ask if anyone knows an unofficial hack TO GET THAT CHIRPING TO STOP (TEMPORARILY) !!!!!!
fr8mech
Re: Death of a smoke detector
Sat Aug 07, 2021 12:00 am
Airstud
Sat Aug 07, 2021 12:09 am
fr8mech wrote:
https://support.firstalert.com/s/article/What-do-the-Chirps-Mean
Try that
Hey wow!! I was all over that website last night and didn't find that!!! Thanks, fr8mech!!
Off to try it now...
ltbewr
Sat Aug 07, 2021 1:20 am
Some smoke/CO2 detectors have life limits, usually 7-10 years. Some have non-replaceable batteries. And yes, the chirp is annoying and even removing the battery won't stop it. If you own the unit or home, then it is your responsibility to get a new one or replace the batteries. If you rent, then the landlord should replace it or allow you to buy one ASAP and get reimbursed for it. Properly working smoke/CO2 detectors are legally required in all residences, especially multi-family ones and even some businesses by state or local laws. They do save lives so get it replaced ASAP.
Airstud
Sat Aug 07, 2021 1:46 am
Yes I am having it replaced in a couple of days; I just wanted the chirping silenced in the meantime. :smile:
fr8mech FTW
1337Delta764
Sat Aug 07, 2021 3:54 am
BTW, I recommend buying one with a photoelectric sensor. They are far superior at detecting slow smoldering fires and are less prone to false alarms.
Max Q
Sat Aug 07, 2021 4:37 am
Also recommend it’s hard wired into the homes electrical system, no more replacing batteries
And linked to your alarm system if installed, the fire department will respond
frmrCapCadet
Sat Aug 07, 2021 12:37 pm
The first fire alarms available (I believe they were made by GE) had a 'physical' red flag that was released when the battery went low. So easy to use, and more importantly no chirping false alarms. I got one as soon as they came out. Years later, after spending more than a few middle of the nights looking for which GD'd chirping low battery had gone off somewhere in the house I removed all of our hard wired alarms and put them where they could easily be reached and monitored (and and the malefactor turned off for the rest of the night). The Rotary club I was in did several community outreaches offering free alarms and explaining how to use them. I always want a couple working monitors anyplace I sleep. But the way they work is for the birds (and dead birds at that).
Hard wired could be good, but loss of power could be caused by the same fault somewhere in the house that also could start a fire. My preference is a mix - some hard wired, some battery, some photoelectric others ion - toss in a couple CO detectors too. And a close to the master bedroom monitoring panel showing which alarm was doing what. This is available by some companies but no easily and affordable system was available last I looked. Maybe something is available now.
dtw2hyd
Sat Aug 07, 2021 5:48 pm
Most cities now require smoke detectors with 10 year non-replaceable battery.
1337Delta764
Sat Aug 07, 2021 7:31 pm
That is if you don't have hardwired alarms. Hardwired interconnected alarms are still required in new construction, but typically most cities 10-year battery laws only apply to battery-only alarms, even though there are hardwired alarms with 10-year backup batteries available.
dtw2hyd
Sat Aug 07, 2021 11:00 pm
I am not aware of that exception. I was looking for replacement hardwired because I couldn't deal with chirping even after changing batteries, Home Depot had only 10 year sealed battery hardwired.
In the past I replaced one with ionization smoke detector near kitchen, nothing but trouble, replaced with photovoltaic.
fr8mech
Sun Aug 08, 2021 11:23 am
Smoke detectors should be replaced every 10 years regardless of power type. Batteries are only one if the things that can fail. Sensors can become fouled or contacts corroded. There is a normal service life for smoke detectors. I seem to recall that after 10 years, the expected failure rate is 30%.
CaptHadley
Sun Aug 08, 2021 3:43 pm
[photoid][/photoid]
Careful with that, some municipalities are now charging for false alarm runs, especially police departments.
Max Q
Sun Aug 08, 2021 10:40 pm
CaptHadley wrote:
[photoid][/photoid]
That’s correct
My local police department allows three false alarms a year after which they do charge for responding to one, it’s still well worth having a monitored alarm system against break ins and fire
FYI, if my smoke detector(s) activate, the fire department will respond and even as the homeowner I’m not permitted to cancel the call
There’s been many cases where people think they’ve put the fire out and they really haven’t
fr8mech
Sun Aug 08, 2021 11:06 pm
We would continue a commander and an engine to any fire alarm where there was an attempt to cancel. The commander would continue code 3 and the engine would slow to code 1.
WesternDC6B
Sun Aug 08, 2021 11:26 pm
When I had a house in Nevada, I couldn't cook anything without the nearest smoke detector going off. While I am far from a Cordon Bleu chef, I am not that bad a cook. Turns out the detector in this 17 year old house were the originals. I changed them out, and the problem went away.
One thing I have noticed about smoke detectors: regardless the brand, the manufacturer builds clocks into them. These clocks serve an interesting purpose. When the backup battery starts to go bad, the clock kicks in, and determines the time. It then sets things up for the chirp to start at 2 o'clock in the morning.
CaptHadley
Mon Aug 09, 2021 5:35 am
Not sure if you have them or not but our dogs lose their collective minds when the smoke detectors start their low battery chirp. They will literally walk around shaking.
dtw2hyd
Mon Aug 09, 2021 1:12 pm
Max Q wrote:
CaptHadley wrote:
[photoid][/photoid]
That’s correct
One option is to put smoke/fire/CO detectors tied to Home Automation/Security system in self-monitoring mode. You get audible/phone alerts, and fire department is not immediately dispatched without you calling them. Monitoring companies monitor only devices signed up for professional monitoring.
LCDFlight
Mon Aug 09, 2021 2:25 pm
Lol that’s a very deadpan joke, nice.
WesternDC6B
Mon Aug 09, 2021 2:59 pm
Who is joking?!? I've yet to hear The Dreaded Chirp start at a civilized time of day.
I solved that one years ago. Every year, on a set date , I change the batteries
737307
Mon Aug 09, 2021 3:00 pm
Why would a smoke detector beep if there is no battery in it?
fr8mech
Mon Aug 09, 2021 3:23 pm
End of life.
It is recommended that they are replaced every 10 years due to degradation of the sensing elements.
Plus, First Alert, et al., want to keep selling smoke detectors.
WesternDC6B
Mon Aug 09, 2021 10:47 pm
They have a capacitor in them that will run the detector after the battery is removed, for a period of time.
Users browsing this forum: B717fan, N626AA, TriJets and 29 guests
