Ak13
Camera recommendation (1500$ budget)
Tue Aug 24, 2021 9:33 am
One good thing about the pandemic is that i took up plane spotting. I've been spotting with a hand-me-down Nikon D3200 with 55-300mm F4.5-5.6 and i think it's due an upgrade. My budget is 1500$ and would ideally stick to Nikon but open to buy other brands as well (if I'm getting much more value than Nikon at the same price point). After some research I've narrowed down to D500. Do you guys think if it's worth it in 2021 or should i just go for cheaper D7500 or other brands/models?
Dazed767
Re: Camera recommendation (1500$ budget)
Thu Aug 26, 2021 12:14 am
https://www.photonstophotos.net/Charts/ ... on%20D7500
Both have the same dynamic range. Both are crop sensor DSLR's, while the D500 is a prosumer with beefier specs, the D7500 at $500 less will work just the same for aviation.
Check B&H's used section. A quick look I found this D500 with less than 2,000 shutter clicks for $1227.
https://www.bhphotovideo.com/c/product/ ... _body.html
Screeners
Screener
Sat Aug 28, 2021 11:43 am
Both are capable bodies. IMO, lenses play a larger role in image quality unless you are looking to do a lot of low/no light photography where you need the best sensor money can buy.
seahawk
Mon Aug 30, 2021 10:10 am
The cheaper body and a better lens. I would aim at least for a AF-P NIKKOR 70-300 mm 1:4,5-5,6E ED VR.
