convair880mfan
What are the pros/cons of various airliner types to the situation of runaway trim and manual trimming?
Sat Sep 04, 2021 4:06 pm
I know that there are some differences in the way that Boeing and McDonnell Douglas aircraft approached how pilots dealt with manually trimming their aircraft and perhaps how they dealt with runaway trim. Don't know how Airbus and other airliners handle these issues. What do you see as the pros and cons of the various designs from a pilot's perspective? [MD suitcase handles versus large manual pitch trim wheels and so on]
Also . . . how difficult is it to fly various airliners with manual trim alone?
Thanks for any information and opinions.
fr8mech
Re: What are the pros/cons of various airliner types to the situation of runaway trim and manual trimming?
Sat Sep 04, 2021 7:08 pm
The large manual trim wheels went away with the B727 or the early B737, if I’m not mistaken. On the Boeing’s, you stop a runaway trim by flipping the Stab Trim cutout switches. This kills hydraulic power to the stab motors. Then you trim with the alternate trim, which is an electric trim.
When I get to work, I’ll see what Airbus and Douglas did, but I can’t imagine it’s much different.
Stop the runaway…or uncommanded trim. Then trim using the alternate method. If that doesn’t work…fly the aircraft.
Horstroad
Sat Sep 04, 2021 9:05 pm
On the MD-11 both the suitcase handles and the trim switches on the control wheel go to the same primary trim control valves. The suitcase handles are just a mechanical backup in case of an electric or electronic failure. I've never tried to override the solenoids with the suitcase handles, but from looking at the schematic it appears the mechanical controls should be able to override the electronic controls. So in case of a runaway due to a fault in the electronic controls all you can do is move the suitcase handles the other way or split them to stop the uncommanded trim and then open the circuit breaker hoping the manual trim switches caused the runaway and not the automatic trim, as the automatic trim signals come directly from the Flight Control Computers without a circuit breaker or cutout switch in between.
There's no backup in case of a hydraulic failure, so a scenario where you're left with no flight controls but stabilizer trim cannot exist (at least I can't think of one).
This system looks pretty unsafe from just looking at the schematics, with no backup in case of a hydraulic failure and no way to inhibit automatic trim... clearly designed in another time. But still, I've not heard of a DC-10 or MD-11 accident due to stabilizer runaway. Anyone?
I would be interested in a pilots perspective and what the actual procedures are in case of a stabilizer runaway on the MD-11 or DC-10. At the moment all I can do is look at the schematics and system descriptions.
GalaxyFlyer
Sat Sep 04, 2021 10:02 pm
The B707-B737 had true manual trimming but only as a backup to the normal trim pitch trim controls which were powered. Use of wheels was emergency only, not normal. All more recent airliner types used multiple means of actuating the power to trim the stab—electric or hydraulic motors.
Woodreau
Sat Sep 04, 2021 11:56 pm
First thought to my mind was Delta 1080
But then it was a L1011 and it was a jammed elevator not stab. So that’s not a valid answer
https://www.washingtonpost.com/archive/ ... 3a089bf6d/
Sun Sep 05, 2021 1:03 am
On the A330 and A350, trimming is done via trim wheels and trim switches respectively. On the older A330s, you have to manually set takeoff trim after engine start. On the newer A330s and on the A350, the process is automatic.
We never trim manually unless the flight controls degrade to direct law or backup.
The A330 and A350 have no backup in case of complete hydraulic failure. And there is no procedure for stabiliser runway.
Horstroad
Sun Sep 05, 2021 9:20 am
I just looked into the B777 and there's no electric backup either. It's similar to the MD-11. Actually it's almost the same setup except for the hydraulic shutoff controlled by the cutout switches. The alternate trim levers are just a mechanical backup routed to the same stabilizer trim control modules already controlled by the pitch trim switches.
What Boeing's do have electric trim? B757/B767?
Max Q
Sun Sep 05, 2021 9:42 am
If you oppose stab trim motion on the 727 with the yoke you will engage the stab trim brake and all trimming will stop
Good design as that would be your typical first reaction with a trim runaway
At that point you can decide whether to activate the stab trim cut out switches or release the trim brake, of course that decision would be made after completing the relevant checklist
