Miami
Plane Crash in Waller County, Texas
Tue Oct 19, 2021 4:00 pm
Possible fatal crash in Texas.
Details unknown at this time however it appears to be either a DC-9 or MD-80.
https://fb.watch/8KF1TfrKmH/
- Miami
KPDX
Re: Plane Crash in Waller County, Texas
Tue Oct 19, 2021 4:01 pm
It's N987AK. Private MD-87 based near Houston.
Last ADS-B Exchange info shows it doing 150 kts near the end of the runway on departure from Houston Executive Airport (KTME).
Sooner787
Tue Oct 19, 2021 4:05 pm
KHOU is reporting 21 people onboard, all got out, no fatalities....
Miami
Tue Oct 19, 2021 4:07 pm
Overran runway 36 at KTME. Possible now that there is no fatalities.
https://twitter.com/TheAstroN8/status/1 ... 99394?s=20
md80fanatic
Tue Oct 19, 2021 4:31 pm
If everyone got out alive, I doubt the MD-87 ever became airborne. Likely a rejected TO.
NIKV69
Tue Oct 19, 2021 4:35 pm
Thank God!
Miami
Tue Oct 19, 2021 4:40 pm
Confirmed everyone survived and only one injured which appears to be minor.
Newark727
Tue Oct 19, 2021 4:47 pm
Huge relief - "crash of an MD-87 with 21 aboard" had me fearing the worst.
FlyingElvii
Tue Oct 19, 2021 4:55 pm
Owned by “987 Investments” in Spring Texas, and tracking blocked. Some photos of it in Las Vegas. High Roller Casino Shuttle?
blackbox67
Both reversers seem to be in the stowed position.
https://twitter.com/JacdecNew/status/14 ... 2384951299
tenHangar
Tue Oct 19, 2021 5:01 pm
Did the wings rip off? Don't see in photos/video.
Revelation
Tue Oct 19, 2021 5:03 pm
Interesting text and video coverage at https://abc13.com/plane-crash-katy-toda ... /11143371/ ...
Currently showing LIVE coverage of press conference , also has some recorded video segments too.
TWA302
Tue Oct 19, 2021 5:08 pm
Headed to BOS, probably charter for the ALCS.
If this photo is from prior to take-off, does it look like the slats are retracted?
Revelation
Tue Oct 19, 2021 5:11 pm
ABC-13 coverage (link above) just confirmed this, reporter says she spoke to the plane's owner, says the pax were friends and family of the plane's owner going to Boston to see the Astros play in the ALCS, with one pax as young as 10 years old.
Armodeen
Tue Oct 19, 2021 5:13 pm
You can see tyre marks all the way off the end of the runway in the overheads, you were right.
Revelation
Tue Oct 19, 2021 5:17 pm
ABC-13 helicopter video shows end of runway and skid marks to final resting point, with no evidence of the wings being ripped off and left behind. Do see some small trees/shrubs that have burned but again we only see wreckage in one place. Fire has consumed the wreckage but I think I see the outline of the right wing, the left wing is not as clear to me.
A320FlyGuy
Tue Oct 19, 2021 5:21 pm
Thank Goodness there were no fatalities - except for the plane.
Sad that a relatively rare aircraft has come to grief....be interesting to see what the NTSB report shows. If that picture that was posted earlier in the thread was from the attempted flight today, it does look like the slats are retracted...I wonder if this might be similar to the Northwest Airlines crash back in the 80s....hopefully there is enough left of the cockpit to see if the aural warning circuit breaker was in or not.
Of course, right now, this is all speculation on my part...
Revelation
Tue Oct 19, 2021 5:22 pm
https://abc13.com/plane-crash-j-alan-ke ... /11143659/ provides a name for the owner, and as below, it was friends and family going to Boston to watch the Astros vs Red Sox ALCS game.
FLALEFTY
Tue Oct 19, 2021 5:36 pm
KTME is located on very flat terrain. The one runway, 18/36 is 6,610 ft. long and 100 ft. wide, which normally would be plenty of runway for a MD87 to safely operate. It appears to have reached Morton Rd., which is about 1,000 feet from the end of runway 36, which also took out some fencing and overhead power lines.
https://flightaware.com/resources/airport/KTME/map
TWA302
Tue Oct 19, 2021 5:46 pm
Here is a clip of some good aerial footage that shows that it came down just past the end of the runway. Hard to tell if it actually became airborne (attempted) or went straight through. As previously noted, thrust reverser deployment is evident.
https://twitter.com/i/status/1450490601368076290
2eng2efficient
Tue Oct 19, 2021 6:03 pm
Very difficult to tell but it is possible the flaps are not configured for takeoff there…
I’m getting some Spanair 5022 vibes. Thank God everyone survived; extremely dangerous situation.
PANAMsterdam
Tue Oct 19, 2021 6:10 pm
I'm not a MD expert, but I assume these birds have a take off configuration warning as well?
2eng2efficient
Tue Oct 19, 2021 6:20 pm
Yes, it does. And in 1987, after the Northwest 255 accident, MD recommended operators check the T/O Warning System (TOWS) before each flight. The Spanair crew failed to do this.
The NTSB subsequently identified an electrical relay onboard the DC-9/MD-80 series that can malfunction and inadvertently disable TOWS on the ground. If the crew follows SOP and checks the system, this failure alone shouldn’t endanger the aircraft.
More info here:
https://www.ntsb.gov/safety/safety-recs ... _67_71.pdf
The Swiss cheese model exists for a reason.
par13del
Tue Oct 19, 2021 6:35 pm
So we all believe that the still photo is actually form the flight today, actually asking.
I assume it was a stock photo of the a/c from some other time, my reason, if a photographer was there taking pictures they would also have photos immediately after the crash, maybe they do and they are just being sold to the highest bidder.
Best part of the news video is at the end where they zoom out to show the crash location in relation to the runway.
Good news all survived, just hope the Astros are not affected and they win tonight, not a fan of either team but cant stand Boston more than the cheaters.
Gotsumpnferya
Tue Oct 19, 2021 6:44 pm
A couple of things looked odd to me.
In the video, the initial roll showed a quick puff of smoke from one or both of the engines. Also, the grass looked charred only behind the #1 engine at the crash scene. Also, wouldn't the reversers have been deployed during an RTO? Maybe they were past V1 but not configured correctly. I thought this type had a TO config warning.
Just observations of course.
TWA302
Tue Oct 19, 2021 6:47 pm
I didn't say I believe that the photo was from today, I said, "IF this photo is from today" throwing it out there as a possibility and having an observation based off of what I am possibly seeing.
F9Animal
Tue Oct 19, 2021 6:58 pm
The very first thing that came to mind was flaps/slats when I heard it was an MD-80. Guess we will know soon. Thankfully everyone is safe!
FLALEFTY
Tue Oct 19, 2021 6:59 pm
It appears the photo might be from a PTZ security cam installed by the FBO to keep an eye on their ramp.
I also imagine the plane was fairly heavy, tanking enough fuel to make the trip out and back from KBOS. Jet A at KTME is $5.00 per gallon, but at KBOS it is $9.37 per gallon.
FlyingElvii
Tue Oct 19, 2021 7:16 pm
Am MD-87 that light would have an amazing range, especially if it was an LR version.
Revelation
Tue Oct 19, 2021 7:31 pm
ABC13 showed surveillance cam video of the ramp. This very well could be a still grabbed from that video. Won't say for sure, though am saying it is quite possible. I don't have time to re-watch their video, but I did post some links above.
nm2582
Uninformed speculation:
The ground behind #2 makes me wonder if it was running at some above-idle power setting for at least a moment after the aircraft came to rest.
The unaffected ground behind #1 also makes me wonder.
phatfarmlines
Tue Oct 19, 2021 7:36 pm
Does this mark the 2nd consecutive commercial hull loss in the Houston metro area in the past two years?
FLALEFTY
Tue Oct 19, 2021 7:39 pm
http://www.gcmap.com/mapui?P=KTME-BOS&MS=wls&DU=nm
As you can see, KTME to KBOS is 1,417 nm, so the accident MD87 might have been carrying enough fuel to fly the 2,834 nm R/T, plus 45 minute reserves. I imagine being a corporate version it has additional aux fuel tanks, which could push its range 3,500~4,000 nm +/-. At MTOW & at sea level ISA the MD87 needs 7,500 ft. of runway per MD's spec sheet. I don't think this was anywhere near MTOW, but it was probably heavier than their normal ops and they may have gotten their T/O performance numbers wrong.
The other theory, incorrect flap setting, might have been a factor, too?
JBirdAV8r
Tue Oct 19, 2021 7:54 pm
Hard to speculate whether that still image was from today.
It’s hard to tell if slats/flaps are extended. They very well could be. That picture looks like a low res still from a video. All the exterior lights appear to be on, which could be an indication it’s either taking off or it’s imminent. That could be operator dependent, but it’s unusual for taxi (especially in broad daylight).
861tw
Tue Oct 19, 2021 8:04 pm
The image is from a video shot as the aircraft was on its takeoff roll. Unfortunately it doesn't show the complete roll down the runway. You can see a puff of white smoke from one of the engines very early in the roll.
Northwest1988
Tue Oct 19, 2021 8:25 pm
First and foremost, so glad that everyone got out!
Next, any plane crash is terrible, but from a very passionate MD fanboy, this is even more sad!
MareBorealis
Tue Oct 19, 2021 8:26 pm
The history:
rbavfan
Tue Oct 19, 2021 9:01 pm
Was reported it did not lift off & overran the runway. Sounds like flaps were up for T-O. If the alarm did not sound that would make me believe they may have bypassed the alarm circuit that was commonly done before the NW crash. My best guess opinion only. We will see what the bxes show.
rbavfan
Tue Oct 19, 2021 9:03 pm
And one of the rare models.
FlyingViking
Tue Oct 19, 2021 9:32 pm
The ABC13 feed has a very short view from the right rear down. I think I can just catch the trailing edge of the right wing. Looks like flaps were extended.
FlyingElvii
Tue Oct 19, 2021 9:33 pm
That picture makes it look like an engine fail on takeoff?
flyPIT
Tue Oct 19, 2021 9:53 pm
Does this airport not have appropriate ARFF? Pretty painful watching the local VFD put out that fire with a squirt gun.
btfarrwm
Tue Oct 19, 2021 9:58 pm
Jammed elevator similar to the Ameristar MD-83 incident in Michigan a few years ago?
IAHWorldflyer
Tue Oct 19, 2021 10:03 pm
I am not positive, but I do not think this airport has any on-site ARFF. The guys in the video probably drove over from the town of Brookshire, which is like 5 miles away. I happen to work out in this vicinity, and this is a pretty small airport. I was shocked when I found out an MD-87 was suing that runway. Most everything I ever see coming out of there is single engine prop planes. I was working from home today though, so only have seen the TV reports.
DL_Mech
Tue Oct 19, 2021 10:16 pm
N987AK is owned by James Alan Kent
http://jalankent.com/founder/
KCaviator
Wow, yet another Part 91/135 accident...
Skid marks appear to by visible near the end of the runway. Tire marks in the grass make it obvious the aircraft never got off the ground. Couple things immediately come to mind here:
1) Eerily similar to the accident with the University of Michigan basketball team.
2) Possibly not configured for takeoff?
The runway is 6610 feet, more than enough for this aircraft. This plane didn't fly either due to a botched rejected takeoff, control issue, or incorrect takeoff configuration. That's my way-too-early-to-tell prediction at least.
Boeing757100
Tue Oct 19, 2021 10:19 pm
Could the aircraft have been overloaded? Though maybe not, since it is likely the takeoff was rejected. So maybe some sudden brake/reverse thrust failure or the engine(s) were somehow stuck on full power. Or, more likely, the pilots were too late in aborting the takeoff because they had already reached V1/commitment speed and didn't have enough runway left to stop.
So, basically, here are my (very basic) theories
- Overloaded
- Brake/Reverse thrust failure when trying to abort T/O
- Engines stuck on full power when trying to abort T/O (this is probably the least likely out of my very basic theories)
- Pilot error (they chose to abort their takeoff too late and didn't have enough runway to stop)
- Pilot error (didn't have correct T/O config, like forgetting flaps or something)
Anyone more experienced and knowledgeable can expound further (or disprove) my list of theories. I'll wait for the official reports before I speculate further.
GalaxyFlyer
Tue Oct 19, 2021 10:23 pm
Classic case when the question is why are charters/private aircraft more hazardous than airlines. The fact the plane had the runway performance to operate out of KTME, which was probably chosen for convenience, doesn’t mean there are risks that are associated with doing so, which are not a factor in an airline. No ARFF is pretty common at GA airports, but when nothing goes wrong, no one is concerned. Overrun and catch fire, it’s luck that determines the outcome. Here, it was a lucky day. At KHOU, the full ARFF complement would have made a difference.
The CT bizjet accident a few weeks ago—same thinking. The runway meets the performance required, but didn’t have the runway end safety areas, so a relatively benign overrun (see Oroville accident same type) turned catastrophic.
GalaxyFlyer
Tue Oct 19, 2021 10:28 pm
With 21 passengers, it’d have to have some mighty heavy catering to be over gross. RTO, a possibility. TO Config warning should have caught a failure to set flaps early.
Fortunately, lots of grass beyond the end.
YoungDon
Tue Oct 19, 2021 10:29 pm
True, but at KHOU a runway overrun like this would likely have resulted in a completely different outcome since the area around the airport is so densely populated. The real luck here was that they had a clear area straight ahead of the runway - the airport fence is mainly wire and wood poles and the other side of Morton Road is just vacant land.
This would not have been pretty had it happened at KHOU unless it was contained completely on the airport property (unlikely).
