keesje wrote:One with variable fan blade angles? https://youtu.be/zW66-EFvj64?t=60
Article: https://travelandaviation.com/rolls-roy ... t-in-2022/
rjsampson wrote:keesje wrote:One with variable fan blade angles? https://youtu.be/zW66-EFvj64?t=60
I've been following the Ultrafan since its inception, and it seems that the variable fan blades were dropped from all renderings, marketing materials, etc. a few years ago (and doesn't show up in the linked article or video).
If someone could correct me on that, that'd be amazing.
keesje wrote:Rolls will start testing its Ultrafan demonstrator. It features a gearbox "working with two carbon composite fan systems"
I wonder what that means. One with variable fan blade angles? https://youtu.be/zW66-EFvj64?t=60
keesje wrote:rjsampson wrote:keesje wrote:One with variable fan blade angles? https://youtu.be/zW66-EFvj64?t=60
You are correct it is no longer metionef recently. It won't be on the big demonstrator. Recently it popped up (don't remember where) so I starting doubting if it was back. Apparently RR feel the new gearbox, fan, core is enough for now.
Still wondering what "two carbon composite fan systems" means though.
There are some performance and design considerations (slip off the tonque) in this 1 hr RAES Ultrafan video with an chief engineer. https://youtu.be/sRAt8mn3HyY .
Apparently RR is closely working with Airbus on the Ultrafan. This engine could be fit under an A350 efficiently because the smaller sized LP turbine makes installation possible. The A350 wing and longitudinal stability (rudder) can handle the bigger heavier engine, which should be ~ 10% better sfc than the Trend XWB.
Taxi645 wrote:As the engine will be heavier and there will be more parasitic drag from the bigger nacelles, the SFC gain would have to be larger than 10% to get to the 10% at the aircraft level unless you take into account you have to fly less fuel to burn fuel.
zeke wrote:Taxi645 wrote:As the engine will be heavier and there will be more parasitic drag from the bigger nacelles, the SFC gain would have to be larger than 10% to get to the 10% at the aircraft level unless you take into account you have to fly less fuel to burn fuel.
A reduction in fuel burn, means a reduction in the total fuel required, and this then reduces the loads the airframes needs to carry to carry the same payload over a particular range.
Aerospice wrote:I expect the statement "working with two carbon composite fan systems" means two different designs of fan and casing will be tested in the Ultrafan engine test programme. Most likely thus is two different fixed pitches (and maybe casing designs) being tested and no variable pitch technology.
frmrCapCadet wrote:Aerospice wrote:I expect the statement "working with two carbon composite fan systems" means two different designs of fan and casing will be tested in the Ultrafan engine test programme. Most likely thus is two different fixed pitches (and maybe casing designs) being tested and no variable pitch technology.
One of the constants in competing aircraft is efficiency taking off and getting to altitude, versus efficiency at altitude. So could RR offer two fans for that?
CowAnon wrote:I don't understand why it's taking so long for the big 3 engine makers to produce a high-volume engine with variable pitch fans. Rolls-Royce and SNECMA were planning for one a half-century ago, and even tested a demonstrator engine in the 1970s.
Here's a 1971 magazine article about the M45S variable-pitch engine: Rolls-Royce design for quieter airliners.
And here's the M45 SD-02 demonstrator on display in what looks like a public library:
So if the VP fan actually ends up on the Ultrafan, does that mean Ultrafan-powered widebodies become viable on short-range routes?
snasteve wrote:This type of fan is very complicated and making it reliable durable affordable all at once it is quite challenging.
It’s too risky at this point they will probably continue to work on it and I’m sure when they are confident they will bring it out to market.
As long as there are more practical less risky avenues to improve their products these will usually get priority.
In other words they still have plenty of low hanging fruit to pick.
And finally you could say that this is a form of vaporware. I mean if you want to take an extremely cynical viewpoint you could say that this is a lot like the ultra fan it is going to go nowhere but Airbus or Rolls-Royce will get a lot of press out of it and a way to keep them selves in the minds of a lot of industry and forum posters here as a company we think of with high technology. Well not actually delivering such a promising product.
