zanl188 wrote:Adiabatic cooling occurs as an aircraft climbs, this is due to the change in pressure. As an aircraft climbs into the flight levels all aircraft use a standardized altimeter setting to ensure separation. As an aircraft descends out of the flight levels local atmospheric pressure, from the arrival airfield, is used for the altimeter setting.
CarlosSi wrote:Basically asking if airplanes flying an IAP have to correct for cold temperatures if marked in the approach chart (and it is cold enough), does something similar apply to the flight levels if the temperature is much colder than usual (i.e., -100 deg F at FL270. Random number)
CarlosSi wrote:zanl188 wrote:Adiabatic cooling occurs as an aircraft climbs, this is due to the change in pressure. As an aircraft climbs into the flight levels all aircraft use a standardized altimeter setting to ensure separation. As an aircraft descends out of the flight levels local atmospheric pressure, from the arrival airfield, is used for the altimeter setting.
Mmmm yes I'm aware everybody uses 29.92 inHg above FL180, though I'm wondering if even at that same setting do the pressure levels "condense".
LH707330 wrote:CarlosSi wrote:zanl188 wrote:Adiabatic cooling occurs as an aircraft climbs, this is due to the change in pressure. As an aircraft climbs into the flight levels all aircraft use a standardized altimeter setting to ensure separation. As an aircraft descends out of the flight levels local atmospheric pressure, from the arrival airfield, is used for the altimeter setting.
Short answer is yes, at below-standard temps or weird lapse rates the actual differences will be less than the 1,000 feet indicated. That's not much of an issue, because even in extreme outlying cases it will probably still be 9xx feet.
zeke wrote:CarlosSi wrote:Basically asking if airplanes flying an IAP have to correct for cold temperatures if marked in the approach chart (and it is cold enough), does something similar apply to the flight levels if the temperature is much colder than usual (i.e., -100 deg F at FL270. Random number)
No, while aircraft true altitudes are a function of temperature and pressure, we still fly at indicated 1000 ft separation. Yes it does overread the 1000 ft however it is not significant as the aircraft below and above are exposed to the same temperature profile at that geographic location.
There was talk of using GPS true altitude at all levels to remove barometric errors however the rate things change in aviation I cannot see that in my lifetime.
And what kind of temperature profile is the default for pressure-temperature conversion? I assume upper troposphere has to follow certain seasonal trends, so whatever profile is assumed, it will be only that accurate.
