convair880mfan
Double-hinged flap explained or shown??
Sun May 08, 2022 4:18 pm
In Terry Waddington's book on the DC-10, page 106, he describes a DC-10-60 series of planes pitched to the airlines but never developed. He writes: "But the biggest change was to the flap system. Its small vaned version of the standard DC-10 was [to be] replaced by a double-hinged flap that increased chord during takeoff and landing."
Can someone explain to me what a double hinged flap is, how it works and if it is used on any aircraft or better yet share a photo of such a device? I managed to find a patent for a double hinged flap on the internet but it is hard for me to understand. Thanks in advance for any information.
hitower3
Re: Double-hinged flap explained or shown??
Sun May 08, 2022 6:36 pm
Dear Convair,
I am not entirely sure if the author may not have meant "double slotted flaps", as the DC10's flaps were single slotted.
If it was indeed about double hinged flaps, the idea could have been an implementation of a NASA patent from 1967:
https://ntrs.nasa.gov/citations/19700032700
I hope this helps...
Hendric
kalvado
Sun May 08, 2022 8:33 pm
As far as I understand, dc-10 has Fowler flaps which pivot on a hinge below lower wing surface. While mechanics is totally unlike flap tracks used on today's A-B jets, surface movement is somewhat similar. There are no slots to be seen, but mechanics looks like that could be incorporated.
I can imagine - no proofs though - how that can be redesigned to 2 moving surfaces moving around different axis and\or different angles, possibly with slots.
This all is totally unlike patent quoted above, where 2 axis are both within the airfoil crossection.
Looks like IL-86 has something similar to what I have in mind
DL_Mech
Sun May 08, 2022 10:00 pm
A good picture showing the lower hinge point and the actuators inside the flap fairings.
https://www.flickr.com/photos/caribb/2591747496
convair880mfan
Sun May 08, 2022 11:48 pm
Thanks to you all for the responses. Do you think a double hinged flap would simply be a duplicated lower hinge or do you think perhaps there would be an upper and lower hinge? Is there an upper hinge on the flaps of the Douglas DC-8? Sorry that I am not very smart abut such things.
kalvado
Sun May 08, 2022 11:53 pm
[twoid][/twoid]
Try sketching how airfoils move in MD-11 picture @dl_mech linked, how that relates to movement of flaps in more modern design.
I bet you will answer a lot of your questions that way.
convair880mfan
Mon May 09, 2022 12:07 am
Ok. Are these things on the wing of the DC-8 upper surface wing hinges or on the aileron?
kalvado
Mon May 09, 2022 12:52 am
It's a different type of hinged design
A good animation of hinged Fowler flaps is here. On a slightly newer plane, though:
https://youtu.be/zyf-pb3qZwo
Mon May 09, 2022 1:12 am
Would this be an "offset hinge flap" like, AFAIK, the 787?
kalvado
Mon May 09, 2022 2:03 am
Yes, looks like 787 and md-11 have similar flap design principles. I actually linked 787 video above.
Users browsing this forum: SQ22 and 3 guests
