Francoflier
Jetstar 787 badly damaged by lightning
Thu May 19, 2022 11:32 am
https://simpleflying.com/jetstar-boeing ... ng-strike/
Jetstar has grounded one of its 787s (VH-VKL) after being severely damaged by lightning strikes on May 7th.
The video of the post flight inspection is doing the rounds and is showing quite extensive damage, including multiple scorch marks and, more worryingly, a multitude of small holes in the fuselage skin.
It will take up to 2 months to repair.
While searching if this had been posted already, I stumbled onto this old thread:
viewtopic.php?f=3&t=1436861&p=21856757&hilit=lightning#p21856757
:stirthepot:
DCA350
Re: Jetstar 787 badly damaged by lightning
Thu May 19, 2022 11:36 am
Wow.. That looks really bad.. Is this normal? I'm sure many 787s have been struck by lighting over their years in service.. Did the lighting protection fail on this particular aircraft?
Opus99
Thu May 19, 2022 11:49 am
Francoflier wrote:
https://simpleflying.com/jetstar-boeing-787-lightning-strike/
:stirthepot:
These aircraft had the protection from what I’ve read
scbriml
Thu May 19, 2022 12:02 pm
Good job it wasn't a Qatar Airways 787! :rotfl:
Thu May 19, 2022 12:09 pm
Doesn’t look that bad to me, they will assess the damage, design and execute a repair and then good to go.
pugman211
Thu May 19, 2022 12:10 pm
Those holes in the skin is just the upper layer of composite material probably melted due to the heat or ARC out from the lightning strike. You could recreate those holes with simple abrading if you continued to abrade the same spot.
The question becomes why did the lightning not follow the path to the static discharge wicks? Surely that is their function.
Is this a problem with a Boeing aircraft? NO, I don't think it is. I imagine a very similar thing would happen to the A350 and A220. Just my opinion.
Thu May 19, 2022 12:32 pm
This is perfectly normal, you see lightning entry and exit points all over even on metal aircraft
WayexTDI
Thu May 19, 2022 12:41 pm
I agree.
When I read "holes", I imagined something much worse; that video was shot up very close, those are small shots.
Isn't the outer skin sacrificial when it comes to lighting strikes?
smi0006
Thu May 19, 2022 1:38 pm
I wonder where the exit points are? Normally there is both an exit and entry.
Does remind me of the DL-772 that was struck 43 times coming into SYD one time, sat on the ground for a week then was ferried low to SIN for repairs.
Anecdotal - but at my airlines the 787s did seem to ‘attract’ more lightening strikes than the 767 and 777s!
pugman211
Thu May 19, 2022 1:50 pm
I agree that every strike has an entry/exit point regardless of material, and I do view this incident as normal too. I just thought maybe there would be a dedicated discharge location(s) on the lower half of the fuse that's all.
So, all in all, is this a non event?
dopplerd
Thu May 19, 2022 3:26 pm
Static discharge wicks are to prevent static charge from building up on the airframe from friction against the air. They are not designed to handle lightning strikes or discharge. If the lightning finds it's way to a discharge wick it will be blown off the plane.
Francoflier
Thu May 19, 2022 6:22 pm
I have never seen lightning damage this extensive on an airliner before. A few popped rivets? Sure. But not dozens of holes straight into the skin (sheetmetal or other).
Those holes are not that small (some bigger than a rivet head) and appear to have some depth to them.
I wouldn't call grounding an airliner for 2 months to repair lightning strike damage 'normal' either.
I don't know whether that CFRP structure is more prone to damage or whether the lightning storm they encountered was particularly strong, but that's certainly not a typical lightning strike event or outcome.
I'd like to know how the repair will be made. I'm guessing Boeing has developed patching techniques.
GlobalAirways
Thu May 19, 2022 6:42 pm
Yes, ET 788 ET-AOP "Queen of Sheba" suffered a much larger/worse hull fire back in 2013 and was patched and has been flying since w/out issue.
JoseSalazar
Thu May 19, 2022 6:47 pm
Nothing a little bondo and paint can’t fix!
Francoflier
Thu May 19, 2022 7:15 pm
The ET bird was not so much 'patched' as 'rebuilt-in-situ'... The repair was extensive and took a specialist team from Boeing.
I would hope that fixing a lightning strike, albeit a severe one, would not require that sort of effort.
889091
Thu May 19, 2022 7:22 pm
How would the repairs differ from a normal ramp-rash damage/repair, if any?
WayexTDI
Thu May 19, 2022 7:53 pm
Technically, the path of a lightning is ground to clouds, hence bottom to top on an aircraft.
A lightning will go originally cloud to ground, finding the path of least resistance (hence the zig-zags); once this is found, the discharge (major part of the energy) goes ground to cloud on that path.
Avatar2go
Thu May 19, 2022 8:38 pm
The effects of lightning can be very random. On this aircraft, the lightning protection system worked, as the goal is to protect the aircraft systems. There is damage to the outer skin, probably due to heating of the conductive and outermost layers. The heat is what causes the holes to develop. It can be repaired but will take some time.
WesternDC6B
Thu May 19, 2022 9:51 pm
I'm missing something here... :confused:
Avatar2go
Thu May 19, 2022 9:55 pm
The reference is to the Qatar claim that paint peeling on A350 aircraft exposed, and in some cases compromised, the lightning protection system. Which resulted in the grounding of some aircraft by their regulator, and a major spat between Airbus and Qatar. But this situation is quite different, both as to aircraft, problem, and circumstances.
Aaron747
Thu May 19, 2022 10:29 pm
The other consideration is whether the aircraft encountered positive or negative strikes. Positive strikes are far more powerful, but occur less frequently.
CrewBunk
Thu May 19, 2022 10:40 pm
Avatar2go wrote:
The effects of lightning can be very random. On this aircraft, the lightning protection system worked, as the goal is to protect the aircraft systems …
… and the passengers, the aircraft and the reputation of both the operator and Boeing. My guess is that it achieved all goals presented perfectly.
WesternDC6B
Fri May 20, 2022 12:24 am
Now, I remember.
Avatar2go
Fri May 20, 2022 7:22 am
JannEejit
Fri May 20, 2022 8:00 am
Although to be fair, the article says "It could take up to two months to repair" not "will".
vhtje
Fri May 20, 2022 9:55 am
Is JQ maintenance completely separate to QF? Will the repair be done by QF? Or is all major maintenance at the QF Group outsourced these days, so that the distinction is immaterial?
Fri May 20, 2022 11:50 am
I believe the QF was famous for saying words to the effect that new aircraft don’t need maintenance
