seb146
Round opening on early DC-9s
Sat Oct 01, 2022 6:01 am
This is the best example I can find with a casual search
Directly under the engine right behind the wing is a circle. I found a pic with the circle deployed. Watching classic aviation footage, it appears open only while on the ground. I think there is an APU intake on the tail, so what is this opening for? Or is this the intake and on the tail is the exhaust?
atlamt
Re: Round opening on early DC-9s
Sat Oct 01, 2022 8:02 am
That’s the outflow valve. Used to control cabin pressurization. In auto mode will be open on the ground and closes to control cabin rate of change and desired cabin altitude in flight.
747classic
Sat Oct 01, 2022 9:41 am
See "DC-9 Redesigned Cabin Pressure Outflow Valve" : viewtopic.php?t=733991
DL_Mech
Tue Oct 04, 2022 12:23 am
This is probably the most mistaken item on the DC-9. The intake at the base of the tail is part of the air conditioning system. Specifically, the cooling air for the heat exchangers. On a Boeing, the intakes look like this:
The APU intake is just forward of the airstairs, and the exhaust is above the right engine. The 717 APU intake is above the left engine.
LH707330
Tue Oct 04, 2022 2:21 pm
This article should help with a lot of the questions: https://airlinercafe.com/aviation-artic ... de-178167/
