Mason
Why No Concorde Over-land Supersonic Flights?
Thu Apr 06, 2000 4:21 am
I was thinking how bennifical the Concorde would be on flights like JFK-LAX, SFO-LAX, MIA-JFX, etc...Why isn't the Concorde permitted to fly supersonically over land? Military fighters do it every day. Plus, the Concorde flies so high, no other aircraft would even be close to it!
avion
RE: Why No Concorde Over-land Supersonic Flights?
Thu Apr 06, 2000 4:32 am
The sonic boom creates loud bangs every second or something. You would be able to hear it very good.
Avion
woodsboy
Thu Apr 06, 2000 4:37 am
From what I remember it was a pretty effective lobbying effort by environmentalists who argued the detremental effects of sonic booms and the very loud t/o performance of the Concorde. I think also there were concerns over the highly polluting, smokey turbojet engines.
But as I have thought about this over the years I know that military a/c fly supersonically, perhaps though not so often over land than over the ocean.
When Branniff flew the Concorde I believe they either had to fly subsonic till they got to the East Coast then increase speed or they had to stop for fuel somewhere before crossing the Atlantic- does anybody know this for sure?
exnonrev
Thu Apr 06, 2000 4:55 am
Military aircraft have been banned from flying supersonic over populated areas for many years. It is only allowed in designated training areas in the desert (primarily Nevada) and offshore.
Even back in the '60s when TWA and Continental were considering the Concorde and Boeing was developing its SST, the FAA had no intention of allowing sonic booms over populated areas.
777X
Thu Apr 06, 2000 5:10 am
The sonic boom is a shockwave that travels along with the aircraft, creating a sonic boom everywhere they plane is flying supersonic, not just when the plane transitions, or on a period basis.
This means that if a supersonic plane flew from NY to SF, EVERYONE living along the flight path would expirence the sonic boom. (The width of the affected area on the ground varies on aircraft size, but AFAIK for concorde it's ~20 miles)
Back when the US was working on the SST, test flights were flown with a milary aircraft flying supersonic over populated areas, but complaints were high and property damage resulted (broken windows mostly). Therefor there was a strong backlash against the supersonic aircraft being used over land (or at least populated areas)
Thu Apr 06, 2000 8:21 pm
Id say there isnt enough concordes around the place to want to expand there routes!
RE: Concorde And The US.
Fri Apr 07, 2000 4:28 am
Hi guys !
As previously said, the problem of supersonic fligth is the sonic boom.
The development of CONCORDE over the US is not restricted by polution nor because of noise restriction. CONCORDE is allowed by FAR 91.821 to operate over the US, even if he is not even complying with Stage 2 noise level.
Per FAR 91.817, no A/C may be operated at a true MACH of more than 1. Also the Mmo must not be above MACH 1 unless fligth crew was informed of the restriction.
As one folk said this FAR has been instated because of damage that can cause the sonic boom.
CONCORDE can fly to LAX but it will have to reduce to or below Mach 1 when reaching the ADIZ.
This will anyway not or quite not happen because CONCORDE has "short legs" and CDG-JFK is already close to the range limit of the airplane.
Bye !
JFL.
Ilyushin96M
Fri Apr 07, 2000 5:04 am
I remember when the Concorde entered service in 1976, it was the subject of much controversy here in the States. I remember the newspaper articles about the noise regulations, and how difficult it was for BA and AF to get the necessary permits even to operate in and out of JFK and Dulles. And yes, when Concorde was operated by Braniff on DFW-JFK, it was a feeder route, and did not operate at supersonic speeds.
I've experienced sonic booms several times. It's no wonder supersonic flights over populated areas are not allowed, the shock wave is quite noticeable, and jarrs one's nerves, especially in areas where earthquakes are common. But I wonder if specific routes couldn't be flown at supersonic speeds, over sparsely-populated areas, with Concorde slowing down as it approaches its destination?
As far as Concorde's range...it is my understanding the aircraft can fly as much as four hours between fueling stops, hence the flights between London and Barbados, and Paris and Rio de Janeiro. Anyone know any differently?
turbulence
Sat Apr 08, 2000 12:42 am
Just a little note:
The sonic boom is a “little” phenomenon that DOES NOT last for all the supersonic flight. It is not desirable to occur over populated areas, since it can cause (minor) material damages, but actually is nothing else than a wave conflict.
Why?
When the flight is subsonic, the air mollecules in front of the airplane start vibrating BEFORE the the airplane reaches to them, due to the sound propagation, travelling faster.
When the flight is supersonic, the nose (well, let's maybe say better “the needle” ) must cut the air mollecules that are immobile yet. Therefore there's actually a needle and not a nose, and therefore the use of special materials in order to support the high temperatures reached because of friction due to the “extra” work of cutting the air. Do not forget that, despite we do not feel it because of our low walking speed, air is something very very dense. Just try to take your hands off the window of your car when travelling at 130 Km/h (72 mph) in Europe (or 250 Km/h in Germany or in Montana daylight if you are that lucky), or even at just 55 mph (88 Km/h) in the US. Then try to imagine that speed made 1240 Km/h.
Back to the sonic boom, there is a moment, just when the speed of the plane is equal to that one of the sound, when both vibrations reach to the air mollecules at once. The sum of both vibrations creates a much bigger one which can be heard as an explosion, louder and deeper than the noise of the turbines, since the wave length is double.
Thus, a Concorde could take off from JFK, LGA or EWR east bounded, break the sonic barrier over the Atlantic, turn 180º, fly supersonic westwards absolutely silent (from earth distance, of course) over crowded land, slow down over the Pacific ocean, and land nicely and quietely at LAX.
Best turbulences
777X
RE: Turbulence
Sat Apr 08, 2000 2:03 am
I'm afraid this discription is not correct. The sonic boom DOES travel along with the aircraft, and is NOT a one time effect.
As an aircraft moves through the air at supersonic speed, the air is constantly producing air pressure waves, which in turn produce the sonic boom sound
Check out this link for a description
http://www.af.mil/news/factsheets/Sonic_Boom.html
Sat Apr 08, 2000 4:34 am
Hey fellas,
Actually the main cause of sonic booms is the large pressure gradients created by sound waves which names itself the so-called "compression shockwave". Whenever travelling at M larger than one, the aircraft is always ahead of the sonic waves which eventually produces a cone behind the aircraft. The faster the aircraft flies, the smaller the angle of the cone gets and hence it will create sound disturbances, much like tubular sea shells you may find at the beach.
In the case of not being able to fly over land is probably already stated above as to restrictions regarding sound disturbances over populated areas.
Leo-ERJ
Boeing 777-400
Sat Apr 08, 2000 5:14 am
"Back to the sonic boom, there is a moment, just when the speed of the plane is equal to that one of the sound, when both vibrations reach to the air mollecules at once. The sum of both vibrations creates a much bigger one which can be heard as an explosion, louder and deeper than the noise of the turbines, since the wave length is double.
Thus, a Concorde could take off from JFK, LGA or EWR east bounded, break the sonic barrier over the Atlantic, turn 180º, fly supersonic westwards absolutely silent (from earth distance, of course) over crowded land, slow down over the Pacific ocean, and land nicely and quietely at LAX. "
but it doesn't make sense to me, the sound barrier could be broken over the atlantic, and if you fly supersonic over the U.S. there wont be and sonic booms?!?
When a concorde flys over the water and comes close to other aircraft, why doesnt it damage them? If it breaks windows 10 miles to the ground then shouldn't something happen to those other airplane should they get too close?
AF777
Sat Apr 08, 2000 8:41 am
Why not have the concorde fly out over the water at JFK and LAX, go supersonic, then turn around and fly over land at 60,000 feet?
FLY777UAL
Sat Apr 08, 2000 8:54 am
Just a little tidbit...
AF flew JFK-MIA supersonically, but only over the Atlantic from The Carolinas to Georgia...
Wouldn't it be wonderful if Concorde could loop out over the Atlantic (from JFK/BOS), and then turn towards the West Coast?!
FLY777UAL
RE:AF777
Sat Apr 08, 2000 1:17 pm
Hi !
Just one precision, CONCORDE is a very complex piece of aircraft. You will almost never fly straight & level with CONCORDE. During all the flight, all alt/speed variation the FE has to X-FEED fuel from aft to FWD to modify CG. Has the Rolls Royce jet engine is not a bypass engine, the higher it is operated the best perfs you'll get (fuel efficiency). SO from CDG to JFK you will climb almost all the flight. The descent is an "open descent".
So you can't say just T/O fly away, climb, get speed and finally head to destination. You'll have lost to much time. And anyway by law (FAR) it's impossible unless no sonic boom free (no solution as for today's technologies).
It's style a dream...for now !
JFL.
777X
Sonic Boom Follows Flight Path
Sat Apr 08, 2000 11:46 pm
Maybe this wasn't stated clearly enough earlier in this thread, but let me reiterate, because many of you seem to believe that the sonic boom only occurs at the point the aircraft goes supersonic.
The Sonic Boom is a pressure wave that is present in front of the aircraft continuously while the aircraft is supersonic, thus producing a constant overpressure in front of the aircrafts flight path, and to the human ear, this is the sonic boom.
So, the sonic boom CAN be heard (& felt) along the ENTIRE flight path of the aircraft whilst it is supersonic, so an aircraft (such as concorde) could NOT simply take off, head over water, go supersonic and then proceed over land.
For a more detailed description, there is a link in my earlier post.
Hope we have cleared this up now.
777x
Users browsing this forum: 3rdGen, 817Dreamliiner, Baidu [Spider], Bealine251, chonetsao, cskok8, Desertshamrock7, diamondchap, digitalcloud, dstblj52, Google Adsense [Bot], GZM1, jasoncrh, JibberJim, journeyperson, LTEN11, MD80F, mig17, milhaus, NiallS, StinkyPinky, SueD, SXI899 and 347 guests
