Quoting Aa757first (Reply 1): ICAO is more for pilots and dispatchers and the technical side of things. |
Quoting PA110 (Thread starter): I've never had any occaision to use ICAO codes. Who uses them (other then Flightsim nerds?) |
Quoting Biggles (Reply 7): In 25+ years in the industry ,I've always used ICAO codes. Only airline ground staff and aviation wannbe's use IATA codes. |
Quoting Biggles (Reply 5): As for airport codes , how many combinations can you have with 3 letters ?? |
Quoting FlyingNanook (Reply 10): 26^3 or 17,576 (in practice, less than that because some codes aren't used) Sorry, but my mathematical side had to come out. |
Quoting Biggles (Reply 14): Wouldn't it be less since you could only use AAA, BBB ,CCC etc. only once ?? If you use 26^3 wouldn't those combinations come up 3 three times |
Quoting Biggles (Reply 14): Wouldn't it be less since you could only use AAA, BBB ,CCC etc. only once ?? If you use 26^3 wouldn't those combinations come up 3 three times ?? (I'm at work , very bored ,trying to stay awake ,hence this pointless question ! ) I've always used ICAO since they are more logical to me , and there's less room for error. |
Quoting Ha763 (Reply 11): ICAO airport codes on the other hand have specific meanings for each letter, execpt for US airports. The first letter is the area of the world the airport is located The second letter is the country The third is the area in the country The fourth is the actual airport |
Quoting Biggles (Reply 17): Quoting N1120A (Reply 16): Not every airport carries an ICAO code. Smaller airstrips only carry the code of their local aviation authority, and that is always 3 digits (not always letters) |
Quote: Very true. The USA has lots of them...and those codes are not listed as IATA codes. |
Quoting Laxintl (Reply 22): The ICAO system in my opinion is preferable as its both simpler and logical. Airport codes are easy to comprehend once one understands ICAOs geographic coding system. Also airline codes can be much more logical then the restricted recent IATA method of having to assigning letter/number combinations. ie - Jetblue = JBU |
Quoting RobK (Reply 24): Talking of JetBlue I thought that their IATA code would be JB but I was pretty amazed to see that it's B6 - how ridiculous is that ?!!! |
Quoting Biggles (Reply 7): Only airline ground staff and aviation wannbe's use IATA codes. |
Quoting Aerorobnz (Reply 20): wish they would abolish the three letter IATA codes for the industry wide standard ICAO codes. |
Quoting Laxintl (Reply 22): There was talk in IATA (especially in the 90s) of switching away from the IATA system and adopting the ICAO coding system. The organization realized its own system had become too limited. Based on massive costing estimates to its members an official switch was not adopted, however airlines and airports are free to use the ICAO coding system on a voluntary basis. This can be seen by some airports and airlines for instance that use the ICAO 3 letter airline codes on flight info screens, timetables versus the IATA 2 letter coding. |
Quoting JGPH1A (Reply 26): Shouldn't that read "The entire airline universe is 100% familiar with IATA 3-letter codes except cockpit crews and flight-sim wannabes" ? |
Quoting Laxintl (Reply 22): Interestingly both organizations are based in Montreal. |
