skoker
BUF Is A Mess Right Now!
Sun Feb 04, 2007 8:46 am
Wow!
I've lived in BUF for 17 years, and I've never seen weather like this.
Current Conditions:
Wind from the W (260 degrees) at 47 MPH, gusts 60+ (direction variable, it's shifting to the active rwy direction of 230)
Visibility 0 miles
Sky conditions obscured
Weather Heavy Snow
Freezing fog
Blowing snow
Temperature 14 F (-10 C)
Windchill -2 F (-19 C)
Dew Point 12 F (-11 C)
Relative Humidity 92%
Pressure (altimeter) 29.8 in. Hg (1009 hPa)
Right now a ground stop in in effect, and everything coming inbound is flying up, circling around, and diverting to ROC, SYR, CLE, PIT, and BWI. ATC reports RVR's around 500-600.
Ugh.
United_fan
RE: BUF Is A Mess Right Now!
Sun Feb 04, 2007 8:51 am
ROC isn't much better,I can barely see across the street. FDX 967heavy has an engine fire indicator on #1 ,too! Inbound to r/w 22.
[Edited 2007-02-04 00:54:52]
"Suspicion is a matter of opinion"
OPNLguy
Sun Feb 04, 2007 9:09 am
Quoting Skoker (Thread starter):
You betcha...
Both runways are closed at the moment...
KBUF BUFFALO NIAGARA INTL
A0174/07 (02/020) - RUNWAY CLOSED 05/23 03 FEB 22:35 UNTIL UFN
A0164/07 (02/009) - RUNWAY CLOSED 14/32 WIE UNTIL UFN
Current viz is zero, and the snow's coming down at a rate of 2 inches per hour. If it's any consolation, it's supposed to let up in a few of hours, but with 8 inches already on the airport, I'm sure they'll see over a foot...
KBUF 032359Z 24032G40KT 0SM R23/1800VP6000FT +SN FZFG BLSN SCT004 BKN015 OVC040 M09/M12 A2980 RMK AO2 PK WND 24040/2358 P0000
KBUF 032354Z 24021G35KT 1SM R23/3500VP6000FT -SN BLSN BKN004 BKN019 OVC030 M09/M11 A2980 RMK AO2 PK WND 25035/2349 SLP105 SNINCR 2/8 4/008 P0002 60004 T10941111 11072 21100 53019
KBUF 032344Z 25016G26KT 1SM R23/3500VP6000FT -SN BLSN BKN004 BKN019 OVC030 M09/M11 A2980 RMK AO2 PK WND 28028/2257 P0002
KBUF 032338Z 26015KT 1/2SM R23/1800V6000FT SN FZFG BLSN VV002 M10/M11 A2980 RMK AO2 PK WND 28028/2257 P0001
KBUF 032332Z 26013G20KT 1/4SM R23/1200V3000FT +SN FZFG BLSN VV001 M10/M11 A2980 RMK AO2 PK WND 28028/2257 P0001
KBUF 032309Z 27021G26KT 1/16SM R23/1600V4000FT +SN FZFG BLSN VV001 M10/M11 A2979 RMK AO2 PK WND 28028/2257 P0000
KBUF 032254Z 28021G25KT 1/4SM R23/3000VP6000FT +SN FZFG BLSN VV004 M09/M11 A2978 RMK AO2 PK WND 24040/2216 SLP099 SNINCR 2/6 P0002 T10941106
KBUF 032242Z 27019G27KT 1/4SM R23/2000VP6000FT +SN FZFG BLSN VV004 M09/M09 A2977 RMK AO2 PK WND 24040/2216 P0002
KBUF 032237Z 27019G27KT 1/8SM R23/1800V2800FT +SN FZFG BLSN VV002 M09/M09 A2977 RMK AO2 PK WND 24040/2216 P0001
KBUF 032210Z 24029G38KT 0SM R23/0600V2200FT +SN FZFG BLSN VV001 M08/M09 A2975 RMK AO2 PK WND 23038/2210 P0001
KBUF 032154Z 23019G38KT 1/16SM R23/1000VP6000FT +SN FZFG BLSN VV005 M08/M09 A2974 RMK AO2 PK WND 22038/2145 SNB2059 SLP086 P0000 T10831094
KBUF 032143Z 23022G27KT 1/4SM R23/1400V6000FT +SN FZFG BLSN BKN005 BKN015 OVC030 M08/M11 A2974 RMK AO2 PK WND 23033/2129 TWR VIS 1/2 SNB2059 P0000
KBUF 032132Z 23025G33KT 1/4SM R23/5500VP6000FT +SN BLSN FEW015 BKN023 OVC038 M07/M13 A2974 RMK AO2 PK WND 23033/2129 TWR VIS 2 SNB2059 P0000
KBUF 032120Z 23021G27KT 3SM R23/4000VP6000FT -SN BLSN FEW015 BKN025 OVC040 M07/M13 A2974 RMK AO2 PK WND 23028/2057 TWR VIS 8 SNB2059 P0000
skoker
Sun Feb 04, 2007 9:21 am
Here's a rundown on the list of Cancellations I've got as of 7:15 EST:
Inbound:
US918
US1722
UA7243
UA7216
USX3711
Outbound:
US1471
USX3045
US1895
UA7473
UA7157
USX3711
I'm guessing the real list is longer than that, and the diversion list even longer.
OPNLguy
Sun Feb 04, 2007 9:29 am
Quoting Skoker (Reply 3):
Here's a couple...
http://flightaware.com/live/flight/SWA2490
http://flightaware.com/live/flight/SWA1594
DAL has one enroute from ATL, and TRS has once just off MCO...
skoker
Sun Feb 04, 2007 9:50 am
I saw both of those WN flights. I'd be mad if I was on the one that came up and then turned back to BWI, but BWI is certainly the smart choice because it's easier to re-accommodate the PAX off of the flight.
Will be interesting to see if the Delta and AirTran flights make it in or are forced an alternate.
OPNLguy
Sun Feb 04, 2007 10:10 am
Quoting Skoker (Reply 5):
Runway 14/32 isn't usuable (even if it were plowed) since it's out of crosswind limits, and runway 23 is the only one that can be used (runway 5 is out of tailwind limits.) If runway 23 is closed (presumably for plowing) and the visibility is below the minimums needed for the 23 approach due to the heavy snow, why on earth would you be "mad" about heading back to BWI? Sure, I could see being "disappointed" at being late into BUF, but mad? It ain't no sunny 70-degree day out there...
N751PR
Sun Feb 04, 2007 10:29 am
...and I was thinking of doing a birthday MR to there around this weekend too! Looks like I should be thankful that I didn't go ahead with booking it!
[Edited 2007-02-04 02:29:25]
"Ladies and Gentlemen it's happy hour. You will get two approaches for the price of one."
skoker
Sun Feb 04, 2007 10:48 am
Quoting OPNLguy (Reply 6):
I'm saying if I was Joe Q. Passenger who didn't know anything about wind limits and such... I'd be a little upset that we didn't go straight to BWI.
But then again, I'm familiar with limits and I know the intricacies of Lake Effect enough to know that there was no way BUF is/was landable.
BWI is not really close enough to BUF to be considered 'close'.
OPNLguy
Sun Feb 04, 2007 11:23 am
Quoting Skoker (Reply 8):
In a weather situation like this, there are two things that potentially keep you from landing, namely, the visibility, and the condition of the runway. If the runway is going to be closed for plowing until 8:30, and you're scheduled to arrive at 8:30, you should be able to get right in, assuming the runway opens as advertised and the visibility is above minimums. Say you get there at 8:30 and plows are late getting off the runway and it's not open until 8:45. Should you immediately divert to BWI? If the runway opens at 8:45 but the visibility then goes below minimums, do you then immediately divert to BWI or do you expect to be able to hold for a little while to see if the visibility pops back up above minimums?
Two things I'm trying to get across here are that (1) weather is not an absolute and it can easily vary minute-by-minute, and that you need to plan(fuel-wise) for that, and that (2) things happen by design and intent. I can guarantee you that if an immediate diversion had occurred, there'd be lots of folks just as unhappy that they were unable to hold even a little while to await possible improvement. Sometimes the weather does improve (and you get in), and sometimes it doesn't (and you end up diverting after all). That said, one can't really retroactively conclude you shouldn't have held and diverted immediately--the weather could have just easily improved and you'd have been able to get in.
adizzy
Sun Feb 04, 2007 11:31 am
JetBlue has 5 jets enroute to BUF lets see what happens with them!
OPNLguy
Sun Feb 04, 2007 11:59 am
Quoting ADiZzy (Reply 10):
They probably didn't launch them until there was some improvement, which there has indeed been.. Vis up to 1-3/4 miles and you only need 1/2 mile to get in...
KBUF 040254Z 27016G24KT 1 3/4SM BLSN FEW020 SCT040 BKN055 M12/M17 A2990 RMK AO2 PK WND 25030/0156 SNE53 SLP140 VIS 1 1/2V3 P0000 60000 T11221172 51033
KBUF 040136Z 040224 26024G34KT 3SM -SHSN BLSN SCT008 OVC025
TEMPO 0204 1/2SM SHSN BLSN BKN008
FM0400 26020G32KT 6SM -SHSN BLSN BKN030
FM0600 27014G25KT P6SM SCT040
AC777LR
Sun Feb 04, 2007 1:41 pm
BUF was a major mess back in October too, I know all about that, damn lake effect.
Member since April 2000
WMUPilot
Sun Feb 04, 2007 1:46 pm
I just flew into BUF from BOS on flt 1217 the 555p arrival, actually arrived at 1025p. We where the first jetblue aircraft to land in BUF. Flt 1219, also from BOS, was right behind us, and right behind them was a JFK flight. We had to wait about 20 minutes for a gate as Gate 7 and 8 where both occupied by 320s waiting to be deiced. A great majority of the customers took the delays in stride as they new the weather in BUF was bad as most where on the phone with family members in BUF. The approach was a bit hairy with the strong gusty winds, blowing snow, and very very slick runways. The Conga Line did their best to get the ramp, taxiways and runways clear but I fear they will be at it all night.
JetBlue - Bringing humanity back to air travel
jumpseatflyer
Sun Feb 04, 2007 3:20 pm
Its times like these I wish I still worked line service at Prior...
Snow storms at home, tornadoes at school.
tjwgrr
Sun Feb 04, 2007 8:35 pm
We had a mess here in GRR too due to heavy lake effect snow and high winds.
At times visibilities were reported zero-1/16 of a mile with heavy snow & blowing snow. Airport crews struggled all day Saturday to keep 26L/8R open- one of three runways. Only a couple of flights in or out from about noon until early evening- most carriers cancelled.
At home there were times I couldn't even see my mailbox on the street next to my driveway..... pretty nasty.
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
aeroc
Mon Feb 05, 2007 1:50 am
Here in KROC we got a bunch of flights from the BUF. Personally we had a MQ CR7 from ORD come in and then sit in ROC b/c the crap that was in BUF moved into ROC for awhile. Everyone seemed to have flights coming from BUF though. Oh well the price one pays for living by the lakes!
skoker
Mon Feb 05, 2007 2:07 am
This morning was relatively calm, but right now (exactly noon EST) the snow and wind are really picking up again.
There's only one cancelled pair right now, a Chautauqua E145 BUF-LGA-RDU, because the inbound cancelled at LGA after flying the PHL-LGA leg.
aogdesk
Mon Feb 05, 2007 4:58 am
Quoting Jumpseatflyer (Reply 14):
How long ago did you work for Prior?? Ever work over at UPS?
LASoctoberB6
Mon Feb 05, 2007 5:25 am
Quoting OPNLguy (Reply 2):
how can u read all that and know what it means? can u teach me to do that?
[NOT IN SERVICE] {WEStJet}
manu
Mon Feb 05, 2007 6:55 am
You can see why it is a mess when you look at this radar image of the snow...
It's like a big plow is picking up all of the snow and just dumping it over BUF.
skoker
Mon Feb 05, 2007 10:03 am
I'm happy, this just popped up on my school's website:
...and they said higher education was serious. Pffff.
lemonkitty
Mon Feb 05, 2007 12:58 pm
I was there and out in that mess!!! here are some pics..Remember this was before 5pm...LK
Big version: Width: 1024 Height: 681 File size: 540kb
Big version: Width: 1024 Height: 683 File size: 447kb
Big version: Width: 1024 Height: 683 File size: 360kb
I met my wife on Airliners.Net!!!!
aogdesk
Mon Feb 05, 2007 1:54 pm
20 miles southeast of BUF had 42" Sat/Sun.
zrb2
Wed Feb 07, 2007 3:50 am
Quoting LemonKitty (Reply 22):
Great pics, thanks. Love seeing that blowing snow up at my hometown airport. Good to hear that today it's lightening up in the northtowns and its a nice balmy 12 degrees w/ 22 mph winds!
skoker
Thu Feb 08, 2007 2:32 am
Quoting Aogdesk (Reply 23):
That's my hometown! My best friend's father was on Good Morning America yesterday talking about the snow.)
Those must have been at Gate 16? I luv the snowchains on the tug, never seen those before.
United_fan
Tue Feb 13, 2007 8:19 am
The next couple days ought to be interesting in BUF & ROC with a storm coimg our way!
WMUPilot
Tue Feb 13, 2007 8:22 am
Yup, starting tomorrow morning and continuing on through wedensday. Then it will turn into a Nor'ester as it travels up the coast.
kstateinALB
Tue Feb 13, 2007 8:47 am
Yea... ALB is expected to get from 7 to 12 inches as I heard, should be an interesting couple of days.
lemonkitty
Thu Feb 15, 2007 6:08 pm
Quoting Skoker (Reply 25):
Yes, I was at gate 16...
LK
