Quoting Jtamu97 (Reply 4): unusual approach as it takes the plane over the toll road |
Quoting ISIDRINK (Reply 8): 2) If fuel has to be burned, why not use it to get the aircraft and cargo to its destination instead of wasting it? |
Quoting ISIDRINK (Reply 8): Is a blown tire a risk during flight? |
Quoting MaverickM11 (Reply 9): I would think you might as well have the emergency landing in the destination? |
Quoting Click2Houston article: According to Antonov's Web site, the AN-124 is designed for transportation of heavy and oversized cargo. |
Quoting CBPhoto (Reply 10): The worry is that one of these pieces may have punctured the fuselage, and if you continued the flight, then you might have a more serious problem, like a cabin pressure leak or additional damage to the fuselage when the aircraft pressurizes. |
Quoting StrandedInBGM (Reply 15): Anyone know the flight # or destination? |
Quoting StrandedInBGM (Reply 15): I would be interested in seeing the track it flew. Anyone know the flight # or destination? |
Quoting Tjwgrr (Reply 13): Often too, gear will not retract and stow properly after a blown tire. |
