Quoting MAH4546 (Reply 6): A handful of routes will be announced from Denver tomorrow. |
Quoting RDUDDJI (Reply 7): Fantabulous, another route for WN to get their behinds handed to them on. They are not making inroads against F9/UA...at least not yet. F9 does a great job of motivating the local DEN market. |
Quoting Atrude777 (Reply 8): Right and WN got handed it to them the first time around too??? |
Quoting M992910 (Reply 5): I surely thought with the reduction at PIT, USA would fill the gap in Texas by having nonstop to CLT, PHL, or even both. Way to fill in the network! |
Quoting Atrude777 (Reply 16): How are you guys finding this? Just going to southwest,com and checking the time tables? Alex |
Quoting Shadez (Reply 18): They will also be doing FLL-MHT Sat. Only |
Quoting M992910 (Reply 5): US Airways really screwed this one up, although it doesn't surprise me - AUS and SAT are 2 cities not served by US Airways, but should be |
Quoting RL757PVD (Reply 14): Found a couple of unannounced extras |
Quoting SkyyMaster (Reply 21): Well, technically not true. They don't fly EAST from those cities, but they are old HP destinations with service to PHX and LAS. They should've connected the cities to the eastern network by now IMO. Now that WN has apparently beaten them to it, not sure they will come in from the east, unless it's CLT, which also IMO, they should have already done. |
Quoting SANFan (Reply 23): With this new April schedule, Lindbergh should be right at about 109 flights (!) and I have a feeling they will have some additional real estate by then since 10 gates (their current number |
Quoting Bicoastal (Reply 28): certainly not to allow Southwest room to start Denver flights. |
Quoting SAN88 (Reply 30): I cant wait for the day when im working WN DEN flts out of 11-13......ahah it could be in the future who knows |
Quoting D328 (Reply 24): Who wants to fly from the East across the country to PHX or LAS only to fly half way back? Unless you're a mileage runner, I do not think anyone would. Just my opinion. |
Quoting Bicoastal (Reply 28): And where might the additional real estate come from? United likely won't budge....certainly not to allow Southwest room to start Denver flights. Maybe they can push Alaska out. |
Quoting Trvlr (Reply 34): How could they push Alaska out? |
Quoting Trvlr (Reply 34): How could they push Alaska out? Does United have any add'l rights to gates at T1 that Alaska doesn't have? I do agree that Alaska wouldn't mind being at T2 with all of its alliance partners, as well as FIS facilities, but I really can't see there being space for any of their ~14 flights. |
Quoting PITops (Reply 25): Wow. No new PIT flights. I thought we'd get at least 2 more flights. |
Quoting Bicoastal (Reply 35): By "they," I was referring to WN, not UA. But to answer your question, I have no idea what details are in the leases between the airlines and the Airport Authority. |
Quoting Bicoastal (Reply 32):
Quoting SAN88 (Reply 30): I cant wait for the day when im working WN DEN flts out of 11-13......ahah it could be in the future who knows Maybe in 2012 if United moves to the new wing of Terminal 2 and if construction ever begins! |
Quoting Trvlr (Reply 41):
At any rate, however, I did some quick calculations using this press release along with other information found on WN's website, and found that Southwest gets by with higher average flights/gate at stations other than SAN. While SAN's number will soon be something like 10.5, LAX's is well over 11, and Oakland's is a whopping 13+. |
Although Oakland probably benefits from a more effective terminal design, LAX is still pretty hard to move around. Even with these new additions, WN has the capacity (no pun intended) to make it work. |
Quoting Trvlr (Reply 41): At any rate, however, I did some quick calculations using this press release along with other information found on WN's website, and found that Southwest gets by with higher average flights/gate at stations other than SAN. While SAN's number will soon be something like 10.5, LAX's is well over 11, and Oakland's is a whopping 13+. |
Quoting Mariner (Reply 9): Between Denver and Las Vegas, for instance, its load factor averaged 68.3 percent for the 12-month period ended in June, according to data provided by The Boyd Group. That compares with 83 percent for both United and Frontier. Its load factor between Denver and Chicago averaged 70 percent for the period, vs. 74 percent for Frontier and 82 percent for United. |
Quoting Bcoz (Reply 48): UA and F9 are getting a lot of connecting traffic on that route whereas WN is more than likely all DEN O&D traffic. |
