IDAWA
AA's Current MD-80 Routes
Wed Jan 08, 2014 12:05 pm
Following on this archived topic
Which Routes Now For AA's MD 80's (by CoachClass Apr 8 2012 in Civil Aviation)
I'd like to know which routes are currently being operated by American Airlines with MD-80 equipment, and, if possible, where the heavier MD-83s are operated as opposed to the MD-82
Thank you!
Flown on: 319, 320, 321, 340, 727, 737, 747, 757, 767, 777, DC9, D10, M11, M80, 146, EM2, BEH, CRJ, DH8, L4T.
YYCSpotter
RE: AA's Current MD-80 Routes
Wed Jan 08, 2014 2:10 pm
For sure, the MD-83s are operated on the DFW-YYC rotation, not sure of the others
sw733
Wed Jan 08, 2014 2:25 pm
The following routes are, I believe, exclusively MD-80
DFW-MCI
DFW-SJC
DFW-SAN
DFW-PDX (MD-83)
DFW-LAS
DFW-PHX
DFW-RNO
DFW-TUS
DFW-COS
DFW-DEN
DFW-STL
DFW-MSP
DFW-OMA
DFW-MSY
DFW-IAH
DFW-SAT
DFW-SEA (most if not all MD-83)
DFW-ATL
ORD-STL (some MD-83)
ORD-DFW
ORD-RSW
ORD-TPA
Many other routes operate some MD-80 equipment mixed in with others, including DFW-DTW, DFW-HSV, DFW-ICT, DFW-AUS, DFW-BHM, DFW-MCO, DFW-RSW, DFW-TPA
Note: These aren't all the routes, just the ones I knew of with little research.
CyberEntomology
Wed Jan 08, 2014 2:26 pm
MCI-DFW is still being run on Super 80s. When I asked AA about it, all the MD80 routes under 90 minutes were going to be getting the AAirbus treatment (started with ICT-DFW on 9/16/13), but 90-120 minute routes were keeping the 80s for now (and MCI-DFW is about 2 minutes over the cutoff).
Osubuckeyes
Wed Jan 08, 2014 2:27 pm
I know they bring the MD-80/83 on a good portion of the flights from PHX-DFW/ORD as well as PDX-DFW. I know DFW-OKC/TUL also see a bunch.
Tan Flyr
Wed Jan 08, 2014 2:42 pm
DFW-FAT has been MD80's for at least 17 or 18 years..Started with 727-023, then a mix of 023's and 223's..then about 1994 or 95 , IIRC, the switch to MD80's
Probabaly will be one of the last ones also...and it is a mix of 82's and 83's...with the 83's usually in the summer when it can be 105 degrees easily for the afternoon flight.
hope this helps.
hivue
Wed Jan 08, 2014 3:00 pm
Just dropped my son off at DFW for a trip to BWI on an 82. He'll return on an MD-80 as well.
deltaSEAalsaka
Wed Jan 08, 2014 3:11 pm
Quoting sw733 (Reply 2):
That route is currently all 738s.
The only passenger MD service that SEA gets is on DL.
There is no such thing as a stupid question, just stupid people asking questions.
crAAzy
Wed Jan 08, 2014 3:13 pm
DFW-MKE is 1 x daily MD80, 1x daily MD83, and then 2 or 3x daily Eagle (E145 or CR2) depending on the time of year.
[Edited 2014-01-08 07:28:31]
Lexy
Wed Jan 08, 2014 3:25 pm
AA at BNA is still heavy on the MD80's. There's some 738's mixed in from MIA, DFW, and LAX, but still a lot of flying on the MD80's.
Nashville, Tennessee KBNA
citationjet
Wed Jan 08, 2014 3:32 pm
Many other routes operate some MD-80 equipment mixed in with others, including ... DFW-ICT
According to ICT's airport website, DFW-ICT has gone all A319s. I haven't seen an MD-80 here in a while.
http://www.flywichita.com/news/wp-co...ploads/monthly-flight-schedule.pdf
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,73G,738,739;741,742,743,744,747SP;752,753;762,763;772,773,788.
crAAzy
Wed Jan 08, 2014 3:35 pm
Quoting CyberEntomology (Reply 3):
I'm fairly certain that AA is not determining the A319 routes by times as there are several routes over 90-120 minutes that are seeing A319 service. CLT, CLE, BOG are just a few that come to mind right now.
CyberEntomology
Wed Jan 08, 2014 3:45 pm
They started the initial deployment on the shortest routes (I expect because that's where the biggest efficiency payoff is), but as they get more aircraft, they'll be moving onto the longer routes.
Was nice for ICT to get some new aircraft love from AA, though. Usually we get the leftovers, despite being the place where so many 73s get their start. I expect we'll be about the last place DL retires their MD fleet
avi8
Wed Jan 08, 2014 3:46 pm
AA doesn't seem to be that consistent with aircraft on routes. By consistent I mean that not all the 9am departures from Dallas to Tampa are MD-80's. It varies depending on the day so it's kind of hard to tell.
avi8
sw733
Wed Jan 08, 2014 4:11 pm
Quoting deltaSEAalsaka (Reply 7):
Quoting CitationJet (Reply 10):
Correct on both. My apologies. I'm sure other ones were wrong too
olli
Wed Jan 08, 2014 4:25 pm
DFW-MEX
DFW-MTY
DFW-GDL
DFW-SJD (MD83)
DFW-PVR
DFW-ZIH
ORD-PVR (MD83)
ORD-SJD (Sat only, daily 738)
Best Regards,
1337Delta764
Wed Jan 08, 2014 4:30 pm
DFW-PHX
Not anymore. There are now some 738s on the route as well.
sw733
Wed Jan 08, 2014 4:46 pm
OK, disregard my list...I am not too good at this
treebeard787
Wed Jan 08, 2014 4:49 pm
Quoting 1337Delta764 (Reply 16):
DFW-PHX
That's correct, today's schedule has 5 PHX-DFW flights on the MD-80 with one being the M83 and 4 on the 738. PHX-ORD is all MD-80 today, with all but one on the 83, but 738s show up on that route as well.
Allons-y!
Mainliner
Wed Jan 08, 2014 5:06 pm
PHL sees MD-80's from DFW, both -82's and -83's I believe.
Every flight counts.
ouboy79
Wed Jan 08, 2014 5:45 pm
OKC-DFW has 7 daily MD-80s and its been like that for years. They added an additional flight that is flow by a CRJ recently.
clickhappy
Wed Jan 08, 2014 6:04 pm
I don't think DL flies any MD's into KSEA. There was a one-off the other night, an MD-90 to/from MSP, but that was unusual.
AA also flys DFW-PSP on the MD-80.
KD5MDK
Wed Jan 08, 2014 6:05 pm
Quoting CyberEntomology (Reply 12):
Why is the biggest efficiency on the shorter routes? I thought that cruise fuel burn was the bigger saver compared to takeoff.
slcguy
Wed Jan 08, 2014 6:21 pm
ORD-SLC and DFW-SLC have been mainly MD-80 routes for years, before that was 727s. There was a short time when some F-100s were used. In recent years there have been some Eagle CRJs mixed in.
1337Delta764
Wed Jan 08, 2014 6:29 pm
Quoting SLCGuy (Reply 23):
Which is a bit strange, since SLC is a hot and high airport. This is the main reason why DL has historically avoided scheduling the MD-88 on SLC routes.
dfwjim1
Wed Jan 08, 2014 6:31 pm
Another route is ORD - PBI - ORD, MD-83s.
slcguy
Wed Jan 08, 2014 6:36 pm
Quoting 1337Delta764 (Reply 24):
Yeah, I'm sure AA has taken a hit on weight/loads in the summer time with MDs but they continue to use them here.
I wonder now that Doug is in charge if we start seeing Airbus instead.
[Edited 2014-01-08 10:43:03]
[Edited 2014-01-08 10:45:00]
ORDTLV2414
Wed Jan 08, 2014 7:12 pm
ORD-PHL
ORD-LGA (not sure if still but for a while)
ORD-DCA (in the process of transitioning to 737)
ORD-DEN
ORD-DFW (Although I saw a 737 do it today on flight radar))
1337Delta764
Wed Jan 08, 2014 7:21 pm
Also, ABQ-DFW is still all MD-80s (mostly MD-83s). This will probably be one of the last routes that AA will fly the MD-80 on.
Yflyer
Wed Jan 08, 2014 7:54 pm
DFW-SMF is exclusively MD-80, and from the couple of days I checked the schedule looks to be exclusively MD-83.
Sooner787
Wed Jan 08, 2014 9:31 pm
I believe DFW- EWR is still all S80's as well.
Kinda surprising, that's a long flt for a thirsty bird like that
Flaps
Wed Jan 08, 2014 9:48 pm
DFW-PIT is another all MD80 route. It is a random mix of 82's and 83's.
ERJ170
Wed Jan 08, 2014 10:14 pm
RDU-DFW is 2x MD83 and 3x MD80
RDU-ORD has at least 1 flight that's an MD80
Aiming High and going far..
f18raider
Wed Jan 08, 2014 10:51 pm
DFW-LBB a mix of MD80 and Eagle service.
drerx7
Wed Jan 08, 2014 11:14 pm
MD80s will be deployed 2x on DFW-HOU
HOUSTON, TEXAS
us330
Wed Jan 08, 2014 11:21 pm
DFW-DCA sees a mix of MD80s and 738s.
kenanc
Wed Jan 08, 2014 11:47 pm
What exactly is the difference between MD82 and MD83?
ridgid727
Wed Jan 08, 2014 11:51 pm
ORD-SLC
That has been CR7's for the last 18 months, until recently when they added a Republic E75 to the other Cr7 flight. DFW has been Md80's for years. (prior to that a mixed of 727's and F100's)
1337Delta764
Wed Jan 08, 2014 11:56 pm
Quoting KenanC (Reply 36):
The MD-83 has more range than the MD-82.
drerx7
Wed Jan 08, 2014 11:58 pm
The non-tech answer...MD83 has longer range.
HOUSTON, TEXAS
deltaSEAalsaka
Thu Jan 09, 2014 12:14 am
Quoting clickhappy (Reply 21):
There is generally a 1 or 2 per month from MSP
Timaay419
Thu Jan 09, 2014 2:16 am
Only MD80 route left here out of LAX is LAX-STL.
N126DL
Thu Jan 09, 2014 2:31 am
Quoting crAAzy (Reply 8):
From which hub? Almost all of the hubs use 737/757 to SEA with an odd A320 thrown in. Are they still operating MD90 from SLC?
DH84 E135/145/175/190 CR2/7/9 A319/20/21 A332/3 D95 M80/83/88/90/95 73W/8/9 752/3 763/4 772/L
BAeRJ100
Thu Jan 09, 2014 2:34 am
I flew LAS-ORD on a AA Super 80 back in mid-November, haven't seen that route mentioned yet.
B737/738/739/744ER/752/753/763/77L/77W/788/789
A223/320/321/332/333/346/359/388
MD82/MD88/717/F100/RJ85/RJ100/146-100/200/300
E175/190/CRJ700/900
BN747DFWHNL
Thu Jan 09, 2014 2:48 am
DFW-DEN isn't MD80-exclusive for AA; 738 shares the route, too.
trnswrld
Thu Jan 09, 2014 2:59 am
I'm a controller and see MD80's between ORD and LGA all day long. Sometimes it's a 738. I have a flight booked I. April from ORD to AUS and back on an MD80.
doulasc
Thu Jan 09, 2014 3:07 am
Isn't DFW-CMH MD-80s?
PA727
Also 2X daily DFW-XNA, with the rest handled by ER4s. I imagine we'll be seeing MD80s until the bitter end, which is fine by me!
lasairlinerenth
Thu Jan 09, 2014 3:08 am
Quoting BAeRJ100 (Reply 43):
I was on an AA Super 80 from LAS to ORD today, 1/8/14. But my ORD to LAS on Monday 1/13/14 is scheduled to be a 738.
747fan
Thu Jan 09, 2014 3:16 am
DFW-SDF is currently a mix of 2X MD-82/83 (the evening turn at SDF is typically MD-83's, the RON varies day to day) and 3 Eagle ERJ's. However it will be going to 4X daily all MD-80's in April and then 3X MD-80/1X A319 in May. I'm sure it'll be a mix of -82's and -83's. Since I work them all the time, I prefer the -82's.
From what I notice the majority of the MD-80 flying at ORD is on MD-83's, perhaps due to the fact that a few of the longer MD-80 routes in the system are out of O'Hare (ORD-PHX, LAS, PVR, SJD). Along with those cities I just listed here are the other Chicago MD-80 destinations: ORD-DFW, LGA, RDU, PHL, AUS, MSP, STL, MCI, MCO, RSW, TPA. DFW and STL get lots of them but the others are typically only 1-2X MD-80 mixed with 738's or Eagle/Republic large RJ's. Notably ORD-LGA is primarily 738's now.
Out of DFW it is pretty random in terms of -82's and -83's, with the longer routes like DFW-YYC and PDX of course getting the -83. The MD-80 flying at DFW is dominated by 1-2 hour trips as well as many frequencies to regional destinations like AUS, SAT, IAH, OKC, MSY. DFW-AUS/SAT each get probably 10+ of them.
