Quoting eielef (Reply 5): That's a really amazing flight. It means crossing two oceans and three continents! I've checked different routes and LAX is the most efficient stop. I couldn't make it any shorter (using GCMap) |
Quoting eielef (Reply 5): That's a really amazing flight. It means crossing two oceans and three continents! |
Quoting tmiw (Reply 7): It seems like the 777-8 might be able to fly PPT-CDG without stops, at least eastbound. Thoughts? |
Quoting AF682 (Reply 6): Goldorak, Which cities are on this list? ATL by any chance? |
Quoting zoulastar (Reply 13): So, a little more to wait to see AF682 as a BEST flight! |
Quoting slcdeltarumd11 (Reply 3): It the same plane it stops in LAX between PPT and CDG. |
Quoting Web500sjc (Reply 16): If LAZ is only BEST equipped, then PPT will have to be BEST equipped. I wonder if AF will continue to send a non BEST aircraft to LAX in order to keep PPT non BEST. |
Quoting SJOtoLIR (Reply 17): I got the point. AF PPT-LAX-CDG is operated with 772. It's an independent flight from AF CDG-LAX 7x weekly with 388. |
Quoting goldorak (Reply 18): LAX is served by 2 to 3 daily flights. One of those is continuing some days to PPT. So if LAX is served with the new cabins, it doesn't mean that PPT have them. But if PPT have BEST, then LAX has it obviously. But again, no BEST to PPT in 2015. |
