alaskan9974
BA Or AF SFO-CDG
Mon Jul 29, 2013 4:50 am
Booking flights to Europe for the fall, either departing from SFO or LAX. I haven't flown on a A380, or 747 before and these two routes are served by both. In economy class, any appreciable difference in service and comfort? Price is close enough that its not a factor.
[Edited 2013-07-28 22:01:33]
baldwin471
RE: BA Or AF SFO-CDG
Mon Jul 29, 2013 9:33 am
AF 380. Definitely.
****Filler*****
Boston
Mon Jul 29, 2013 11:59 am
It's a no brainer. Take AF from LAX.
TurkishWings
Mon Jul 29, 2013 2:44 pm
I have flown LAX-LHR on BA 747 and SFO-CDG on AF380 and the service/comfort in both flights are very similar. If earning miles on a particular airline is not one of your concerns, I would also say try out the A380....
Coffee - Tea or Me?
alaskan9974
Mon Jul 29, 2013 4:26 pm
Ok I will take the AF, its a little cheaper anyway. I use Alaska Air for mileage and it will count towards it with either carrier.
n729pa
Mon Jul 29, 2013 4:44 pm
If I had the choice I would take Air New Zealand but that's just me (besides I don't know how their fare compares).
But back to the BA v AF saga. I love flying the A380, it's quiet and smooth, comfy etc....but if you have never flown on a 747 before, then it might be worth trying one while you still can.
There are less and less airlines are using 747s for passenger flights these days. There are more retiring than coming off the production line. In a few months BA are sending the A380 into LAX so as if to prove my point, maybe try the 747 while you can.
I had the option to fly in a UA DC8 years ago, and chose a AA 727 instead. I am happy to have flown in the 727 (a very early one at that), but I never had another chance to fly in a DC8 and I regret that now, I assumed "next time I try one". Next time never came.
LAXintl
Mon Jul 29, 2013 5:17 pm
How about Air Tahiti Nui LAX-CDG?
I think the winter schedule is 4x weekly outside of the Xmas/new year period when they have more flights.
aklrno
Mon Jul 29, 2013 6:00 pm
If you are connecting from another flight to the CDG bound flight, do not even think about connecting at SFO. If you are coming from the west coast your chance of being delayed, and thus missing your connection, is very high. Connect at LAX. Never ever connect at SFO.
Viscount724
Mon Jul 29, 2013 7:44 pm
Did you consider UA SFO-CDG? The 763 with 2-3-2 seating in Y class is much nicer than any other widebody, with only a 1-in-7 chance of a middle seat, and fewer passengers often means faster service.
Mon Jul 29, 2013 8:28 pm
If you choose AF ou can grab a seat on the upper deck in Coach. Most seats are restricted for Status frequent flyer or chargeable, but usually you find a few free of charge there as well.
goldorak
Thu Aug 01, 2013 10:55 pm
Quoting Viscount724 (Reply 8):
Oh yes, but which service ? UA in Y ? Hmmmm
I would definitely choose AF A380
alaskan9974
Sat Aug 03, 2013 12:37 am
When I look at return travel, I was looking at a LH return, CDG-FRA, FRA-LAX, when changing flights in FRA, I don't have to go through customs in FRA correct?
b777a340fan
Sat Aug 03, 2013 3:32 am
Quoting alaskan9974 (Reply 11):
Nope, not unless you leave the transit zone.
Sat Aug 03, 2013 10:53 am
If I were you, i'd get on a 747 whilst they are still around. Plenty of time to fly an A380.
Sat Aug 03, 2013 5:58 pm
Quoting B777A340Fan (Reply 12):
That is not exactly correct. Since you arrive from Paris (Schengen) and connect to LAX (nonschengen) you need to pass Schengen exit passport control. Other than in the US or Canada, you need to pass passport control not only when entering a country (or in this case the Schengen area, made out of several countries), but also when exiting. That said you do not need to pass a new security check, since FRA considers the CDG security check of same standards, nor you will need to pick up your bags. All you need is to walk to the terminal area for Nonschengen-Flights of your flight (which for USA is usually Z, but may also be B or C), pass passport immigration check, and that's it. I am unsure if they discountinued compulsory additional security screening for US flights, but I believe they did.
