Sun Nov 19, 2000 8:18 pm
Don't think anyone should hold their breath for a 777F. The situation is that forwarders, the people who consolidate freight, want full height full contour capacity freighters for their long haul capacity. Boeing, responding to market conditions, is in the process of developing a larger capacity 747F with additional positions for more full-height containers/pallets. The shortcoming of a 777F is the fact that it will not be able to load full height rectangular contour pallets on main deck like 747F. It would only be able to load containers and pallets with a slightly higher contour height than DC-10/MD-11. Those aircraft can load standard M base pallets but they are contoured with a 74-84IN height limit on one side. However the advantages of a 777F are self-evident. A -200 size freighter would probably be able to load 2 more positions on main-deck, and have the same lower hold capacity as an MD-11, while offering much greater range with payload. A 777-200LR freighter with its increased MTOW would probably increase the range with payload by 55% over an MD-11! But in the final analysis it all falls back to market conditions. If there is a market, Boeing will build it. So if the Cargo airlines are on board and the climate is conducive, we will see it happen. Otherwise it is just another enthusiasts dream.
widebodyphotog
