cancidas
AN-225 Design Feature
Sat Sep 06, 2003 1:39 am
as seen in this photo:
Photo © Mark Remmel
what are the "hump" on the upper surface of the wing roots for? are they simply as something left over from when the a/c was designed to carry the Buran shuttle?
"...cannot the kingdom of salvation take me home."
Ikarus
RE: AN-225 Design Feature
Sat Sep 06, 2003 2:57 am
Yup, they are attachement points for the shuttle. You've got to have a structure in place for that, can't just attach it with duct tape, and if a plane is designed to carry something on top from the outset, the hardpoints & attachment features are a part of the design that cannot simply be taken out
Sinlock
Sat Sep 06, 2003 4:00 am
A little off topic, But.
If any of you use MSFS 2004 you can download the AN-225 in both it's Cargo setup and carring Buran from AVSIM.com. That way you can get a good look at how Buran was attached to the 225. (Uses 6 contact points, unlike the NASA 747-100/200s use only 3)
One NOTE: if you do try to land her, give yourself a nice long final 15miles at the least.
aloges
Sat Sep 06, 2003 4:33 am
A short research on a website I know quite well has revealed that those two big humps were not used to attach the shuttle, but instead, those much smaller humps you can see in the picture were used. Here are the results  Big grin :
Photo © Eric Coeckelberghs
I wildly guess that the big humps either serve aerodynamic purposes, or contain equipment or structural parts that could not be placed elsewhere.
Ikarus
Sat Sep 06, 2003 5:33 am
Whooops, how embarassing....
In that case, no idea why they are there....
Ikarus
USAFHummer
Sat Sep 06, 2003 5:46 am
My guess is that they probably improve the aerodynamics and decrease drag on the aircraft when Buran was attached to it...that is nothing more than a guess though...
Greg
cancidas
Sat Sep 06, 2003 6:42 am
anyone got the number to the antonov design bureau?
covert
Sat Sep 06, 2003 9:58 am
Are you for real dude? I missed the smilie after your last post.....
none
LY744
Sat Sep 06, 2003 11:21 am
Don't forget that the An-225 was also intended to carry missile components (circular in nature) and act as a launch platform for a space vehicle, the MAKS (multipurpose Aerospace System). Either one may be a plausible explanation for the humps.
LY744.
cancidas
Sat Sep 06, 2003 11:36 am
covert, what? but i was kidding. i have the number....somewhere.
[Edited 2003-09-06 04:36:41]
L-188
Sat Sep 06, 2003 12:08 pm
Wasn't the aircraft also intended to fly the Energia (spl?) booster also?
There may be your answer.
cancidas
Sat Sep 06, 2003 12:47 pm
i never saw the AN-225 with anything but the buran on top. i did however see a pic of a TU-16 with the booster rocket pod on top of it.
LY744
Sat Sep 06, 2003 9:46 pm
L-188, yes it was, one stage at a time probably. That's what I meant by "missile components".  Smile
Don't know if it actually got to carry it.
LY744.
nfield
Thu Sep 11, 2003 12:37 am
A Google search uncovered this at http://www.aeronautics.ru/archive/vvs/an225-01.htm
Outsize loads that cannot fit into the capacious cabin (including Buran and Energiya components) are carried 'piggyback', the load supported on two main attachments above the center section. These supports and other smaller ones along the fuselage top are faired over when not in use. To avoid buffeting from the 'piggyback' load, the An-225 has twin vertical fins mounted on the end of a large tailplane.
MxCtrlr
Fri Sep 12, 2003 4:47 pm
The number is 1-877-EAT-BORSCHT!  Big thumbs up
MxCtrlr  Smile/happy/getting dizzy
Freight Dogs Anonymous - O.O.T.S.K.  Smokin cool
DAMN! This SUCKS! I just had to go to the next higher age bracket in my profile! :-(
ben
Fri Sep 12, 2003 7:42 pm
There's the phone number for you:
Photo © Dennis Yan
Photo © John Kelley
ReclaimerCaleb
Re: AN-225 Design Feature
Tue Jul 05, 2016 10:07 pm
;_; This was back in 2003 when I was 3 :(
