LHSebi
Emergency After Takeoff? *Photo*
Fri Feb 20, 2004 12:14 am
Photo © Ralf Drews
Can anyone explain why this DC-10 is dumping fuel right after takeoff? Or is this just condensation? (Doesn't look like it though!) Ideas?
Sebastian
I guess that's what happens in the end, you start thinking about the beginning.
sushka
RE: Emergency After Takeoff? *Photo*
Fri Feb 20, 2004 12:19 am
That is dumping fuel. I wonder what happened.
Pershoyu Spravoyu Litaki!
N754PR
Fri Feb 20, 2004 12:45 am
Is that just some overflow fuel from near the cap? I saw a 727 at Kai Tak do that.
Bush, your a sad, sad man.
contrails
Fri Feb 20, 2004 2:05 am
I thought the fuel dump vents were on the far ends of the wing, and there was one for each wing. That's awfully close to the engine...if it were on fire the fuel might be close enough to ignite. Could there be there another explanation for this?
Flying Colors Forever!
HAJ_OW
Fri Feb 20, 2004 5:56 am
Hello,
I bet that's condensation. It's exactly at the outer edge of the flaps. That's the point where usually condansation takes place under high wijng loads like during take offs.
HAJ_OW
wietse
Fri Feb 20, 2004 6:07 am
No way.. it originates on the underside of the wing. Not a chance that that is condensation...
Wietse
Wietse de Graaf
LHSebi
Fri Feb 20, 2004 6:35 am
Condensation would also require different weather conditions, or? I see a blue sky in the background, so little moisture (photo taken in october in frankfurt)...
Sebastian
wietse
Fri Feb 20, 2004 6:51 am
That doesnt say anything. I have had superb condensation trails on the clearest days... Interesting pic none the less and I hope we can get the answer on what is happening here.
Wietse
Wietse de Graaf
aa61hvy
Fri Feb 20, 2004 7:06 am
Thats quite a steep angle for a DC-10
Go big or go home
HawaiianHobo
Fri Feb 20, 2004 7:09 am
It's not dumping fuel, thats for sure. It IS a bit odd that condensation would be forming there, but DCKC-10s' dump masts are at the trailing edge of the wing tips.
-Jordan Long
Chief Master A1C of the Air Force
funflyer
Fri Feb 20, 2004 7:12 am
Maybe there dumping the restroom.
Who cares about status?
Q330
Fri Feb 20, 2004 7:23 am
A vortex with condensation tends to have a well defined tube shape:
Photo © Jean
Photo © Hideaki Ohki
On the Omni DC-10, the stuff coming off the wing disperses like a spray. I think it is fuel, but I don't know why it's coming from there.
-Q
Long live the A330!
redngold
Fri Feb 20, 2004 7:33 am
I detect a helical shape to it, though... Perhaps it is a spray, but it is twisting.
redngold
Up, up and away!
B777FA
One time whilst taking off from GIG on a 767-300ER just after rotation I noticed what I thought was fuel streaming out of the Fuel dumping nozzle.I was really surprised to see this so I called the cockpit and they told me that sometimes it happens (overflow of fuel) and that it was indeed fuel coming out. About 5 minutes later it stopped . Anyway that was on the 767-300ER.
JumboBumbo
Fri Feb 20, 2004 7:34 am
The caption seems to say that the a/c is dumping. Anyone contact the photographer... he may have the scoop.
Q330
Fri Feb 20, 2004 7:35 am
Actually it is just the angle of the photo that makes it look so close. It is a good distance from the engine.
-Q
Long live the A330!
QantasA332
Fri Feb 20, 2004 7:42 am
It is indeed dumping fuel.......the place where the spray is originating is exactly where the fuel dump outlets are located on DC-10s -- right outboard of the outboard flaps.
Photo © Ralf Drews
QantasA332
HawaiianHobo
Fri Feb 20, 2004 7:43 am
The only thing that I find odd is, if you look up other pics of the same AC, you'll notice the dump masts at the edge of the wing tips.
A few explanations for the photo that I can come up with are:
1. Condensation forming on the rib and dispersing as if it were fuel.
2. Fuel leak. (but hard to buy seeing as its coming from both sides of the wing)
On a funny note, as I was driving on the flightline at Davis-Monthan AFB, an A-10 took off and as it was coming down the rwy you could see fuel just gushing out its dump mast. It continued to climb with fuel pouring out... the poor people driving down the freeway near the base must have been surprised!
what's even funnier, is that a few moments later, another A-10 took off and the pilot accidentally set off all the flares before even getting the wheels off the ground!
-Jordan
HawaiianHobo
Fri Feb 20, 2004 7:57 am
Oops...
After calling a buddy of mine at an undisclosed Air Force Base... the dump masts are located next to the outboard flaps, just as QantasA332 stated.
Heh, I feel stupid. This is why I only work with fighters.  Wink/being sarcastic
-Jordan
JBirdAV8r
Fri Feb 20, 2004 8:04 am
Really odd that they'd only be using one dump mast if they were dumping though. Also doesn't seem to follow a normalized flow pattern.
Condensation generally does not form on the lower side of a wing....in a nutshell, lower pressure is needed to form vapor. Comparitively high-velocity airflow is also needed (lowers the pressure obviously). This is the reason why vapor sometimes forms in front of the N1 fans, along the tops of the wings, and primarily in vortices. A large number of tornadoes are also primary examples (i.e. the visible "funnel cloud", gray and/or white in appaearance, is water vapor).
My vote is that that is fuel.
LHSebi
Fri Feb 20, 2004 8:07 am
Ok, so we have established it's probably fuel...any ideas what the hell its doing dumping straight after takeoff?
Sebastian
Markus
Fri Feb 20, 2004 9:06 am
You're all wrong...the pilot accidently hit the 'CHEMTRAIL' button prematurely.
 Big grin
QantasA332
Fri Feb 20, 2004 9:50 am
Well, there must have been a failure or problem of some sort...does anyone know if the aircraft then landed back at the airport of departure, or diverted? I have no idea besides that much...........
QantasA332
whauet
Fri Feb 20, 2004 10:29 am
It's most likely just an overflow. I've watched NW007 leave for Tokyo from Seattle for years and I have seen, several times, a visible overflow streaming from the wings. It would stream from both wings until the aircraft makes the turn to the West and then only stream from the right wing (the aircraft was turning left) because of the air pressure changes over the surface of the wing. Photo was taken in October, could have been a very warm day and the tanks were full....
theflcowboy
Fri Feb 20, 2004 10:33 am
If it is a dump, why isnt there fuel coming out of the other side?
MD
A318, A320, A332, A333, B1900, B722, B732, B733, B734, B735, B737, B738, B772, CR1, CR2, CR7, CR9, MD80, MD81, MD82, MD8
barney captain
Fri Feb 20, 2004 5:39 pm
I have to admit guys, this one had me baffled. Then it donned on me; as much as we want to think everything works perfectly 100% of the time, the reality is, sometimes thing "misbehave". With that in mind, I submit 2 possibilities; 1. Residual fuel left in the dump mast after a previous dump or, more likely, 2. A somewhat less-than-perfectly-sealed dump valve. There simply isn't enough fuel (vapor) exhausting to be a legitimate fuel dump, but it does IMO seem to be originating from the valve itself. Also, this shot appears to be taken VERY shortly after T.O., a fuel dump for a return would take much longer to initiate. My money is on the leaky valve.
Southeast Of Disorder
Georg
Fri Feb 20, 2004 5:57 pm
I am not very sure if its fuel dumping. Its actually too close to the engine, imagine if one engine is on fire, the heat coming out from it will probably fire up the fuel and you are a burning stick in the air. Usually fuel is dumped from wingtips as I know? Though I cant find any other logical explanation for that picture, they arent definately the vapour tails Big grin.
NO URLS in signature
qantasguy
Fri Feb 20, 2004 6:09 pm
I'd say its fuel too. The leaky valve is the most plausible theory considering that there is no fuel dump on the other wing. As far as the engine catching the fuel on fire, it would have to be a bloody big engine fire. I'm sure Douglass would have investigated that scenario a good many times before mass production. However, I stand to be corrected, as always.
Airplanes Flown on..B-727-100, B-727-200, DC-9, F-27, B-707, B-717, B-737, B-747SP, B-747-100, B-747-200, B-747-300, B74
tomgib
Fri Feb 20, 2004 6:15 pm
do Dc-10´s have vent or overflow tanks ?? Maybe this is what it is..
L-188
Never seen a DC-10 up close.
But I have been there when a 727, and a DC-9 both dumped fuel overboard because the crew screwed up and overfilled the tanks during some trimming transfers.
Both aircraft where on long range ferry flights so they where pretty maxed out.
Cpt Underpants
Fri Feb 20, 2004 7:46 pm
It's fuel, and it's not an emergency. There's an overflow tank which captures excess fuel (can be caused by too much pump pressure or an overfuelling). That tank vents to the dumping tube, and the excess fuel is drawn out due to the low pressure created by the air flow.
nudelhirsch
Fri Feb 20, 2004 10:59 pm
there is a valve for excessing oxygene in the tanks, maybe this plane pumped that off, with a spray of fuel in it?
in the book i read the thing above, i also found a pretty good structural drawing. comparing the dimensions on teh drawing, i'd say this "thing" is approx 10mtrs away from the engine...no too clsoe though, also, the engine is mounted a bit "forward", the "thing" begins more in the rear of the wing...
but im studying business and not engineering, so guarantee is taken...why dont we ask in the tech-forum?
Putana da Seatbeltz!
Sat Feb 21, 2004 1:25 pm
It could simply be fuel venting or maybe some condensation forming from the outboard trailing edge of the flaps. I know that it isn't fuel dumping. This is fuel dumping...
Photo © Scotty Curtis
Photo © John Higgins
That's what happens when you dump fuel and hit the after burners on an F-111. AWESOME!!!
DrJetMech
Sat Feb 21, 2004 4:00 pm
BA777FA, I'm not sure on the DC-10, but I know most planes have fuel vents that any overflow of fuel will come out of. And those are almost always at the trailing edge and outer most part of the wing.
chdmcmanus
Sat Feb 21, 2004 10:03 pm
WOW. A lot of speculation. The facts of this are the following, make your own conclusion;
1) The dump mast on the DC/KC 10 is immediately outboard of the flap but inboard of the aileron, on both sides.
2) You can see the other wings dump mast in this picture, there is nothing exiting.
3) There is only 1 dump switch in the DC-10, if you press it, BOTH valves open. Refer to 2.
4) The Fuel vents on the DC/KC10 DO NOT vent to the dump mast, there is an ambient air vent on the lower surface of the wings fwd and slightly outboard of the dump mast.
It appears to me that whatever it is, it's coming from underneath the wing, If it is fuel, it's VENTING from the right vent system, which vents the left (#1) main and center wing upper tank.
ChD
"Never trust a clean Crew Chief"
pilotpip
Sat Feb 21, 2004 10:14 pm
The fuel panel on a DC-10 is inboard of the flap farings, between those and the powerplant on the leading edge of each wing. It looks to be outboard of the refueling adapters and panel, but I think it's a fuel leak from there. Perhaps the defuel valve was stuck open?
DMI
buckfifty
Sat Feb 21, 2004 11:35 pm
I'd tend to believe Cpt Underpants explanation. In fact, it seems the most constructive of all the ones I've seen here, actually.
VC-10
Sun Feb 22, 2004 3:22 am
Believe him if you want, but having certified '10's for over 10 years I can tell you he is wrong.
Any fuel that enters the vent tank will drain back into the main tank as soon as the level drop sufficiently.
It cannot be residual fuel from a previous dump as the pipe run between the Jettison valve & the end of the pipe isn't long enough to hold that much fuel
[Edited 2004-02-21 19:27:54]
LHSebi
Sun Feb 22, 2004 5:40 am
Is it any way possible that he had an emergency after takeoff, and is dumping fuel for a go-around and landing?
Sebastian
MD11Engineer
Sun Feb 22, 2004 7:07 am
To me it looks like a overflowing vent box. I´ve seen this hqappen before, if a filling valve didn´t close. often the excess fuel will run out of the vent once the A/C attitude changes.
Jan
chdmcmanus
Sun Feb 22, 2004 7:08 am
Thanks VC-10, I was trying to figure out how to scan/post the exact same pages from my POH.
LHSebi, I don't think so, for two reasons 1) the dump mast on the opposite wing is clean (no fuel). 2) the fuel appears to be coming from under the wing (you can see the shadow).
This is Dumping in a -30/KC-10
Photo © Mike Parks
ChD
VC-10
Sun Feb 22, 2004 6:53 pm
I'd go with an overflowing vent box
Ikarus
Mon Feb 23, 2004 1:24 am
Somewhere, I've got a photo of an Atlas Air 747 freighter taking off in Heathrow a really hot sunny day, doing the same thing.... I've always been wondering what it was.
Thanks for clearing that up. Overflowing fuel.... never thought of that...
Ikarus
LHSebi
Tue Feb 24, 2004 8:09 am
Photo © Pereslavtsev Alex
I just saw this photo, and thought it looked similar to what's coming off that DC-10...possible? The photographer calls this "jet trails"...any ideas?
Sebastian
wannabe
Tue Feb 24, 2004 1:04 pm
LHSebi,
The suspect photo was taken on October 13 in Frankfurt, probably not that cold then.
Mr Spaceman
Thu Feb 26, 2004 9:07 am
Hi guys.
I know this topic has run it's course, but, I thought this photo would help.
The spray coming off the DC-10's wing looks the same as the fuel being dumped from the A340 in the photo below.
The proximity of the fuel spray to the engine on the DC-10 was brought up. Well, the fuel being dumped from this A340 is flowing out between two engines! So, unless the airliner has afterburners like the F-111 in the photos that Jetguy posted, there must not be any danger of a fire.
Photo © Javier Guerrero
Chris  Smile
Users browsing this forum: No registered users and 25 guests
