There is actually not any "start order" that the 747 has to follow.
xxx
Fact is, my airline uses Boeing publications, that is AOM Aircraft Operating Manuals, and the FCTM Flight Crew Training Manual "as is - out of the box"... and we follow the Boeing "recommended" procedures and check-lists, to the letter. The start order is the one that Boeing recommends.
xxx
Many large airlines, particularly in USA, have decided to publish their own manuals, their own check lists. They adapt procedures specifically to their own operations and requirements. It is perfectly acceptable as long as not contrary to the AFM Aircraft Flight Manual, and procedures are approved by the POI - (FAA Principal Operations Inspector) in charge of that airline. If Dodo Airlines wants to start the inboard engines first,
OK, but that is not what is recommended by Boeing, the manufacturer.
xxx
My airline is just an airline, they do not claim to have designed the 747, nor is it a publishing company. Boeing publishes their AOM specific and tailored to our 747-287s, with some minor changes here and there, at our request, this because of our operations requirements. The start order we use, is known to the ramp staff, and we advise them of any changes if the start order needs to be different, for technical reasons, APU used or not used, generator problems, or push back concerns. As an example - if APU does not work (or APU generators failed), we often decide to use number 4 engine as source of power.
xxx
Happy contrails
(s) Skipper
P.S. What is that I read about cruising on 2 engines... Come on, guys...!
[Edited 2004-03-13 15:01:04]
