This exact picture/question came up on this forum a few years ago. The resolution was that the aircraft was indeed well into its first segment climb and that the image of what appears to be a runway was either a more distant parallel runway, a taxiway or even an access road.
As has already been stated, in airline operation (which includes aircraft such as Dash 8's), the takeoff segment is terminated when the aircraft has attained a positive rate of climb, is at
V2 or better, and has attained a minumum height of 35' AGL. "Positive Rate" or "Positive Climb" is called when, during my employment at 5 different airlines, vertical speed, altimeter and radar altimeter all indicate the aircraft has left the ground and is in a climb. This usually occurs around 20-30' radar altitude. Gear retraction on a large aircraft is a complex procedure of wheel well doors opening, downlocks being broken, the actual retraction, then subsequent closing of extended gear doors. On the 767, from the time of selection "gear up", the process takes about 10-12 seconds. This is a time of high drag and one of the worst places to lose an engine. Not at V1 as most of the world's carriers and regulatory agencies mandate training to be carried out.
I have seen some hotdogs on light and large aircraft alike attempt to raise the gear while either still on the ground, leaving the squat switches to determine when the wheels have left the ground, to one or two individuals who believe that since the nose wheel is off the ground, then the mains must be too.
What a business...
Yikes!
