Fly2HMO
Differences Of VOR, Tacan Operation?
Sat Jun 05, 2004 8:58 am
What's different in their signals? Do they function in the exact same way to produce radials? Which one is more accurate?
Considering their construction, I imagine they operate very differently.
The TACAN is the green cylinder:
VOR (no DME):
 Smile/happy/getting dizzy
[Edited 2004-06-05 01:59:32]
SkyGuy11
RE: Differences Of VOR, Tacan Operation?
Sat Jun 05, 2004 11:42 am
TACAN is used by the military, it gives azmuth and distance information; dme only gives distance; in practice for us civil pilots they are one and the same since we use VORTACs and VOR-DMEs, both of which we get azmuth information from the VOR and distance info from the latter.
DeltaGuy
Sat Jun 05, 2004 12:43 pm
VOR operates on frequencys 108.00-117.95..anything above that is comm freqs, anything below is your FM radio stations.
TACAN operates on "channels", at least inside a military aircraft, for example, "24" would be a station designator. You can find a TACAN even on a cruiser or an aircraft carrier...it's how the Navy planes find their way back home.
VOR's with no DME suck...case in point, (former) NAS Cecil Field, Jacksonville...117.90, no DME, just bearing..but there was a TACAN right there for years, no longer in operation since the base closed.
DeltaGuy
320tech
Sat Jun 05, 2004 1:40 pm
Hi, Fly2HMO.
What's been said so far is correct. TACAN operates on UHF frequencies, around the 1 GHz range. TACAN always incorporates a DME, which is a pretty useful thing - many VORs don't have DMEs attached.
In the cockpit, the pilot selects a channel. The system automatically selects the TACAN frequency and the DME frequency (which are paired - ie, a given TACAN frequency always has the same DME frequency paired to it).
VOR and TACAN operate the same way, regardless of what the transmitter looks like. It's a phase differential system. As I am not an avionics type, I will leave further details to someone who knows better.
DeltaGuy
Sat Jun 05, 2004 2:15 pm
To sum it all up....tune the station, you still get RMI needle swinging lazily over there...TACAN or VOR, 737 or F/A-18.  Smile/happy/getting dizzy
DeltaGuy
AFHokie
Sat Jun 05, 2004 9:59 pm
"TACAN operates on "channels", at least inside a military aircraft, for example, "24" would be a station designator. You can find a TACAN even on a cruiser or an aircraft carrier...it's how the Navy planes find their way back home."
TACAN's are on frequencies too
The channels are for aircraft local to that navaid. Every navaid is broadcasting on it's own distinct frequency, Channel 24 at base X could be 216.2, while Channel 24 at base Z could be 268.7
Channels are like the preset buttons on your car radio. Instead of having to tune in the specific frequency, you just hit the button that's already been tuned to it. If you are away from your local area, you'll have to manually dial in the frequency you want.
I hope that doesn't confuse anyone
SlamClick
Sat Jun 05, 2004 10:44 pm
Simple:
TACAN was one of those words the nomex crowd used to spice up their bar conversation.
VOR is something the GNADIRS autotunes and cross-checks itself with. It is a footnote, a lesser form of magic. Some older GenAv guys like to call it "omni" for reasons similar to the explanation of TACAN above.
airplay
Sat Jun 05, 2004 11:53 pm
The so-called "older" guys call it "omni" because VOR stands for VHF Omnidirectional Range. Its not a buzz word.
DME, is Distance Measureing Equipment. The name is pretty self explanatory.
TACAN stands for Tactical Air Navigation. Again, not a buzz word.
TACAN "channels" are used so people don't have to memorize the frequencies. DME stations are also assigned channels. That's because "channel 77" is a bit easier to remember than 1164GHz.
In practice, the DME channels are paired with VOR frequencies so they can be automatically tuned with the VHF Nav receiver.
TACAN provides continuous distance and bearing just like VOR/DME but at different frequencies. As mentioned, it is primarily a military system but TACAN sensors are also utilized in civilian airplanes. To a lesser extent these days with the availability of GPS sensors.
TACAN is supposedly more accurate, because of antenna radiation pattern. The existance of more side lobes than a VOR transmission, creates a more even transmission pattern, that proponents claim is about 9 times more accurate than VOR/DME. I haven't seen evidence of this however, mainly because I've only witnessed the operation of TACAN enroute where accuracy is difficult if not impossible to determine. Required accuracy isn't quite so critical in this phase of flight either.
Perhaps someone who has used TACAN for approaches can chime in.
Fly2HMO
Sun Jun 06, 2004 5:16 am
So, they do produce their signals in the same way? I mean, do both have one rotating signal and another one that only transmits each time the rotating signal points north?
[Edited 2004-06-05 22:16:52]
Users browsing this forum: masi1157, Okcflyer and 10 guests
