mlsrar
Airbus Simulators
Sat Jun 12, 2004 2:23 am
For the families of aircraft that Airbus produces, with all of their similarities and characteristics that are shared across the entire family of frames produced, is there a single simulator that can be built for operators?
More specifically, can one simulator, with modular changes to the software that might adjust for the different handling characteristics of the particular family work for the entire spectrum?
I mean, for the right price I’ll fight a lion. - Mike Tyson
modesto2
RE: Airbus Simulators
Sat Jun 12, 2004 11:02 am
I don't know if 1 simulator can be built, but I know that Airbus' training facility in Miami has both A320 and A330 simulators. This doesn't answer your question, but maybe some inferences can be made...
MidnightMike
Sat Jun 12, 2004 2:19 pm
The A320 simulator can handle the A318,A319,A320, & A321 simulators. It is just a software change, now I am not sure if it can handle the A330 & A340 simulators, I will ask about that.
NO URLS in signature
kaddyuk
Sun Jun 13, 2004 6:33 pm
As far as I know, the narrowbodied airbus sims are different to the wide bodied ones...
bmi have 2 or 3 different sims including the A320, A330 and A340. They do some training for Virgin AFAIK as well...
Sun Jun 13, 2004 10:08 pm
The A340-600 simulator covers the A345 and A346 aircraft which is why SQ have recently purchased one. Airbus have tried to make the handling of the A340 - 5/600 very similar to the A340 - 2/300.
greasespot
Sun Jun 13, 2004 10:13 pm
No because a 32X sim only has TWO throttle and engine controls while a 34X has 4.....So with the 32X where are the extra controls?
Greasespot
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
Klaus
Sun Jun 13, 2004 11:45 pm
Don´t the long range models also have somewhat different auxiliary systems?
Control behaviour of the FBW models should be similar (and most differences would be in the simulation software anyway), but I´d guess the overhead panels and some other cockpit hardware components would still differ to a certain extent (in addition to the number of engines and related systems in the A340´s case).
Even if the differences were only minor (like exact placement of switches or displays), training pilots for blindly handling standard emergency situations wouldn´t make much sense if they would have to spend time re-orienting for differences between the simulator and the actual cockpit in the actual situation...
Airbus_A340
Mon Jun 14, 2004 12:50 am
Greasespot
"No because a 32X sim only has TWO throttle and engine controls while a 34X has 4.....So with the 32X where are the extra controls?"
I have seen an A330/A340 simulator, To meet demand they can be interchanged.
greasespot
Mon Jun 14, 2004 1:42 am
Ok then I guess they can then....
Greasespot.
What do I know. I am the fixer and not the driver. I was just guessing anyway...  Smile/happy/getting dizzy
Greasespot
fspilot747
Mon Jun 14, 2004 4:09 am
Couldn't the 757 and 767 run on the same unit, with just different software?
FSP
dl757md
Mon Jun 14, 2004 4:15 am
Delta 57-67 have similar cockpit layouts but there are differences. I think systems differences could be handled by software but I don't know how the physical layout diffs could be addressed.
schooner
Mon Jun 14, 2004 6:14 am
Apparently in 757/767 sims the cockpit can be changed between aircraft by swapping the overhead panel. Everything else is pretty much the same.
Untouched and Alive
MidnightMike
Mon Jun 14, 2004 8:15 am
I know that there are 757 & 767 simulators, I guess that you can use one simulator to handle both, but, it would depend on the airline training program. I will research this a little bit, now I am curious.
QantasA332
Mon Jun 14, 2004 9:06 am
Flight International included a civil simulator directory in a recent issue, and from the look of it, whether 330/340 simulators (for example) are common depends on the specific simulator. Most airlines that have both A330s and A340s seem to have joint "A330/A340" simulators (the same exact simulator with software and throttle-quadrant changes, I guess), but occasionally they have additional simulators specific to one type or another. Also, A330/A340 simulators are never shared with any A320 family aircraft, but there is often "sharing" within the latter. It all depends...
As for 757/767 joint simulators, there are some of those as well - Air China, for example, has one. Like Airbus, though, there are also seperate 757 and 767 simulators, so it definitely varies.
QantasA332
buckfifty
Mon Jun 14, 2004 9:21 am
We have two A330/A340 simulators, both of which are interchangeable. The overhead panels and the throttle quadrant can be changed within two hours, as long as the software changeover doesn't cause any problems.
mlsrar
Tue Jun 15, 2004 12:30 am
Thanks to all for the informative answers.
Users browsing this forum: No registered users and 32 guests
