sleekjet
Please Explain The Burned Area On This Engine.
Sat Jul 24, 2004 11:27 am
I grabbed a photo of this MD-82 during push-back. Note the right engine. Is this merely a cosmetic problem? How did it happen?
https://www.airliners.net/addphotos/big/ready/N594AAoneDFW72204.jpg
II Cor. 4:17-18
LimaFoxTango
RE: Please Explain The Burned Area On This Engine.
Sat Jul 24, 2004 11:55 am
Probably just soot from the engine. Not really a pretty sight. I'm sure it can be easily wiped/washed off. I'm quite sure someone here can give you a better answer.
[Edited 2004-07-24 04:56:59]
You are said to be a good pilot when your take-off's equal your landings.
BlatantEcho
Sat Jul 24, 2004 12:30 pm
Looks like APU exhaust, you can see the outlet by the registration.
George
XFSUgimpLB41X
Sat Jul 24, 2004 12:31 pm
Thats where the APU exhaust blows on the side of the right engine... this is visible on DC-9's, too.
The APU exhaust port is the little hole on the fusalage next to the right engine pylon.
Chicks dig winglets.
JetMechMD80
Sat Jul 24, 2004 1:58 pm
It is just soot, probably from the APU, as others have stated.
But.......Its not easily wiped/washed off. And when you get it on your skin, you might as well just wear off a layer of skin. It does not want to come off, no matter what you try. My wife is always accusing me off not washing my hands. Yeah i just spent 1/2 hour taking a layer of skin off with a brilo pad, but I didn't wash my hands.  Smile
"I get along great with nobody"~ Billy Idol
Dalmd88
Sat Jul 24, 2004 7:09 pm
If the cowling is open while the apu is running the exhaust is hot enough to burn through the cowling. All DC-9 and MD-80's look like this. The soot never comes off.
miamiair
Sat Jul 24, 2004 8:09 pm
The cowling even has a placard that reads the upper cowling cannot be open while the APU is operating.
lehpron
Mon Jul 26, 2004 4:19 am
  • What are the vertical black lines in the triangluar pattern on the wings and the tailcone for?
  • Shall I assume the arrows on the wing are for where to exit?
  • The meaning of life is curiosity; we were put on this planet to explore opportunities.
    Mon Jul 26, 2004 5:05 am
    My guess is that the ones one the wing give people hints that when they evacuaty, they should move backwards.
    jetstar
    Mon Jul 26, 2004 11:03 am
    The normal escape path from the over wing emergency exits on the DC-9 family of aircraft is to head to the rear of the wings and slide down the flaps, which would be extended to the ground, that's why the arrows point to the rear.
    To prevent the exhaust soot from being embedded in your skin, there is a product on the market called ProTec, also known as "Invisible Glove". It comes in a tube like toothpaste and you should be able to get it in hardware or auto parts stores.
    It seals the pores of the skin and is water soluble. It comes off when you wash your hands. Almost all the soot will wash off with a good hand cleaner or Java hand soap, it tends to dry the skin so you will need to use a good skin cream after washing your hands. I used it when working in jet exhaust areas and it helped a lot, also is great when working on car engines.
    Dalmd88
    Mon Jul 26, 2004 4:05 pm
    The black lines on the wing are an anti skid strip. The black lines on the tail cone are not on the tail cone. They are louvered vents just forward of the removable cone. They vent the unpressurized aft section.
    Users browsing this forum: No registered users and 23 guests
